JLG Boom Lift 450AJ HC3 Parts Catalog 3122343100
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 450AJ HC3 Boom Lift
Part Number: 3122343100
Publication Date: 2025
Number of Pages: 952 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-2. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-3. STEER INSTALLATION WITHOUT TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE INSTALLATION (4WD)
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR
FIGURE 1-7. DRIVE HUB ASSEMBLY - FRONT
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (4WD)
FIGURE 1-9. FRAME SHIELD INSTALLATION
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (AVAILABLE ON ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (Prior to SN 0300330498, Prior to SN B300029976)
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED NON MARKING (AVAILABLE ON ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 14 X17.5 FOAM FILLED
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - 14 X17.5 FOAM FILLED NON-MARKING
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - 33 X 12-20 FOAM-FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CIS/EAC & UK CA SPECS)
FIGURE 1-16. TIRE AND WHEEL INSTALLATION - 33/1550 X 16.5 FOAM-FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-17. TIRE AND WHEEL INSTALLATION - 33 X 16L500 TURF AND SAND FOAM-FILLED (AVAILABLE ON ANSI, ANSI EXPORT & CSA SPECS)
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 1-19. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 1-20. VALVES INSTALLATION - FRAME MOUNTED (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-21. VALVES INSTALLATION - FRAME MOUNTED (MACHINES WITH SN STARTING WITH B3) (Prior to SN B300031130, Prior to SN C300002919)
FIGURE 1-22. VALVES INSTALLATION - FRAME MOUNTED (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031131 to Present, SN C300002920 to Present)
FIGURE 1-23. TRACTION VALVE ASSEMBLY - 4WD
FIGURE 1-24. TOW PACKAGE INSTALLATION (OPTIONAL)
FIGURE 1-25. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. VALVES INSTALLATION - TURNTABLE (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-2. VALVES INSTALLATION - TURNTABLE (MACHINES WITH SN STARTING WITH B3) (Prior to SN B300031130, Prior to SN C300002919)
FIGURE 2-3. VALVES INSTALLATION - TURNTABLE (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031131 to Present, SN C300002920 to Present)
FIGURE 2-4. MAIN VALVE ASSEMBLY
FIGURE 2-5. AUXILIARY PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-6. AUXILIARY PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-7. SWING DRIVE AND TURNTABLE BEARING INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-8. SWING DRIVE AND TURNTABLE BEARING INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-9. SWING MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-10. SWING MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-11. TURNTABLE BEARING ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-12. TURNTABLE BEARING ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-13. TURNTABLE COVERS INSTALLATION
FIGURE 2-14. TURNTABLE LOCK INSTALLATION
FIGURE 2-15. TANKS INSTALLATION - DIESEL MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-16. TANKS INSTALLATION - DIESEL MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-17. TANKS INSTALLATION - GAS MACHINES
FIGURE 2-18. HYDRAULIC TANK ASSEMBLY - WITH 4 INCH BREATHER (DIESEL MACHINES)
FIGURE 2-19. DRIVE ORIENTATION INSTALLATION
FIGURE 2-20. GROUND CONTROL ASSEMBLY (ALL SPECS EXCEPT CE, CIS/EAC & UK CA SPECS)
FIGURE 2-21. GROUND CONTROL ASSEMBLY (STAGE V ONLY) (CE & UK CA SPECS)
FIGURE 2-22. LIGHT PANEL INSTALLATION – GROUND CONTROL
FIGURE 2-23. ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-24. BEACON LIGHT INSTALLATION - ORANGE
FIGURE 2-25. BATTERY AND CABLE INSTALLATION
FIGURE 2-26. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300330497)
FIGURE 2-27. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH B3 FOR ANSI EXPORT, CHINA, RUSSIA & JAPANESE SPECS) (Prior to SN B300031129)
FIGURE 2-28. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS) (Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-29. HOODS INSTALLATION (ABS) - KUBOTA ENGINE (Prior to SN 0300330497)
FIGURE 2-30. HOODS INSTALLATION (STEEL)
FIGURE 2-31. HOOD ASSEMBLY (STEEL) - ENGINE SIDE
FIGURE 2-32. HOOD ASSEMBLY (STEEL) - TANK SIDE
FIGURE 2-33. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-34. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH B3 FOR ANSI EXPORT, CHINA, RUSSIA & JAPANESE SPECS) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-35. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-36. HOOD ASSEMBLY (ABS) - TANK SIDE (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-37. HOOD ASSEMBLY (ABS) - TANK SIDE (MACHINES WITH SN STARTING WITH B3 FOR ANSI EXPORT, CHINA, CIS/EAC & JAPANESE SPECS) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-38. HOOD ASSEMBLY (ABS) - TANK SIDE (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300330497, Prior to SN B300031129, Prior to SN C300001330)
FIGURE 2-39. HOODS INSTALLATION (ABS) - WITH DEUTZ ENGINES (SN 0300330498 to Present, SN B300031130 to Present)
FIGURE 2-40. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH B3 OR C3 FOR AUSTRALIAN, CE & UK CA SPECS) (SN B300031130 to Present, SN C300001331 to Present)
FIGURE 2-41. HOODS INSTALLATION (ABS) - WITH KUBOTA ENGINES (MACHINES WITH SN STARTING WITH 03) (SN 0300330498 to Present)
FIGURE 2-42. HOOD ASSEMBLY (ABS) - ENGINE SIDE (SN 0300330498 to Present, SN B300031130 to Present, SN C300001331 to Present)
FIGURE 2-43. HOOD ASSEMBLY (ABS) - TANK SIDE (SN 0300330498 to Present, SN B300031130 to Present, SN C300001331 to Present)
FIGURE 2-44. WHITE NOISE ALARM AMBIENT INSTALLATION
FIGURE 2-45. WHITE NOISE ALARM INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA CIS/EAC & UK CA SPECS)
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-6. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH 17GAL HYDRAULIC TANK & ARCTIC PACKAGE) (ANSI EXPORT, CHINA & RUSSIA SPECS)
FIGURE 3-7. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-8. ENGINE ASSEMBLY - DEUTZ TD2.9L4 EMR4 ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-9. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-10. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-11. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-12. ENGINE COMPONENTS - DEUTZ D2011
FIGURE 3-13. ENGINE INSTALLATION - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 3-14. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE(WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-15. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-16. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-17. ENGINE ASSEMBLY - DEUTZ TD2.9L4 EMR4 ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-18. DEUTZ D2.9L4 - EMR4 (49HP) ENGINE COMPONENTS
FIGURE 3-19. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-20. ENGINE INSTALLATION - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-21. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-22. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (WITH PMP PUMP)
FIGURE 3-23. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE(WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS
FIGURE 3-24. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-25. ENGINE COMPONENTS - DEUTZ D2.9L4 ERM5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-26. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-27. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-28. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) (WITH PMP PUMP)
FIGURE 3-29. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 ENGINE (STAGE V)
FIGURE 3-30. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-31. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-32. MOTOR MOUNT INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) WITHOUT GENERATOR
FIGURE 3-33. MOTOR MOUNT INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) WITH GENERATOR
FIGURE 3-34. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)
FIGURE 3-35. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE) (STAGE V)
FIGURE 3-36. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE
FIGURE 3-37. PUMP COUPLING KIT – DEUTZ ENGINES
FIGURE 3-38. ENGINE INSTALLATION - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-39. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-40. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (Prior to SN 0300330497)
FIGURE 3-41. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300330498 to Present)
FIGURE 3-42. ENGINE INSTALLATION - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-43. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-44. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (Prior to SN 0300330497)
FIGURE 3-45. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300330498 to Present)
FIGURE 3-46. ENGINE COMPONENTS - KUBOTA
FIGURE 3-47. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (CHINA IV) (WITH PMP PUMP)
FIGURE 3-48. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (CHINA IV)
FIGURE 3-49. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 CHINA IV ENGINE)
FIGURE 3-50. ENGINE ASSEMBLY - DEUTZ D2.9L4 (CHINA IV)
FIGURE 3-51. DEUTZ D2.9L4 ENGINE COMPONENTS (CHINA IV)
FIGURE 3-52. FUEL/WATER SEPARATOR ASSEMBLY
FIGURE 3-53. PUMP COUPLING KIT - KUBOTA ENGINE
FIGURE 3-54. PISTON PUMP ASSEMBLY
FIGURE 3-55. CLOSED PUMP LOOP ASSEMEBLY
FIGURE 3-56. SPARK ARRESTOR INSTALLATION - DEUTZ D2011 ENGINE
FIGURE 3-57. ENGINE BAFFLE INSTALLATION - WITH DEUTZ ENGINES
FIGURE 3-58. ENGINE BAFFLE INSTALLATION – WITH KUBOTA ENGINE
FIGURE 3-59. GENERATOR INSTALLATION - 2500W/50HZ (DEUTZ D2011 ENGINE)
FIGURE 3-60. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-61. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-62. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-63. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-64. GENERATOR INSTALLATION - 2500W/60HZ (KUBOTA ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-65. GENERATOR INSTALLATION - 2500W/60HZ (KUBOTA ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-66. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINE)
FIGURE 3-67. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-68. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-69. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-70. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-71. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ ENGINE) (STAGE V)
FIGURE 3-72. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 3-73. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 3-74. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-75. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE) (SN 0300332997 to Present, SN B300031130 to Present)
FIGURE 3-76. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4 ENGINE) (Prior to SN 0300332996, Prior to SN B300031129)
FIGURE 3-77. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4 ENGINE) (SN 0300332876 to Present, SN B300031048 to Present)
FIGURE 3-78. GENERATOR INSTALLATION - 7500W/60HZ (KUBOTA ENGINE) (Prior to SN 0300336481)
FIGURE 3-79. GENERATOR INSTALLATION - 7500W/60HZ (KUBOTA ENGINE) (SN 0300336482 to Present)
FIGURE 3-80. QUICKFIT OIL DRAIN INSTALLATION (DEUTZ ENGINES)
FIGURE 3-81. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA ENGINES)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION
FIGURE 4-2. MAIN BOOM ASSEMBLY
FIGURE 4-3. TOWER BOOM ASSEMBLY
FIGURE 4-4. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-5. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-6. ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-7. ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-8. PLATFORM SUPPORT INSTALLATION (Prior to SN 0300327973, Prior to SN B300029557)
FIGURE 4-9. TRADITIONAL PLATFORM SUPPORT INSTALLATION (SN 0300327974 through 0300336481, SN B300029558 through B300031129)
FIGURE 4-10. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (SN 0300336482 to Present)
FIGURE 4-11. RAPID REPLACEABLE PLATFORM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 4-12. VALVES INSTALLATION - BOOM MOUNTED (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-13. VALVES INSTALLATION - BOOM MOUNTED (MACHINES WITH SN STARTING WITH B3) (Prior to SN B300031130, Prior to SN C300002919)
FIGURE 4-14. VALVES INSTALLATION - BOOM MOUNTED (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031131 to Present, SN C300002920 to Present)
FIGURE 4-15. UPRIGHT VALVE ASSEMBLY (Prior to SN B300031130, Prior to SN C300002919)
FIGURE 4-16. UPRIGHT VALVE ASSEMBLY (SN B300031131 to Present, SN C300002920 to Present)
FIGURE 4-17. BOOM VALVE ASSEMBLY (Prior to SN B300031130, Prior to SN C300002919)
FIGURE 4-18. BOOM VALVE ASSEMBLY (SN B300031131 to Present, SN C300002920 to Present)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-6. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - FALL ARREST (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-7. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-8. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-9. RAPID REPLACEABLE PLATFORM (30IN X 4FT) (76CM X 1.22M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336482 to Present)
FIGURE 5-10. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M)(MACHINES WITH SN STARTING WITH 03) (SN 0300336482 to Present)
FIGURE 5-11. RAPID REPLACEABLE PLATFORM (30IN X 6FT (76.2CM X 1.83M)(MACHINES WITH SN STARTING WITH 03) (SN 0300336482 to Present)
FIGURE 5-12. PLATFORM - SWING GATE INSTALLATION (MACHINES WITH SN STARTING WTIH 03) (SN 0300336482 to Present)
FIGURE 5-13. PLATFORM - DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH 03) (SN 0300336482 to Present)
FIGURE 5-14. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M)(MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 5-15. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 5-16. RAPID REPLACEABLE PLATFORM (30IN X 6FT (76.2CM X 1.83M)(MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 5-17. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 5-18. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3) (SN B300031130 to Present)
FIGURE 5-19. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - FALL ARREST (MACHINES WITH SN STARTING WITH B3) (ANSI, ANSI EXPORT, AND CSA SPECS) (SN B300031130 to Present)
FIGURE 5-20. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - FALL ARREST (MACHINES WITH SN STARTING WITH 03) (ANSI, ANSI EXPORT, CSA AND JAPANEESE SPECS) (SN 0300336482 to Present)
FIGURE 5-21. PLATFORM CONSOLE BOX INSTALLATION (Prior to SN 0300336481, Prior to SN B300030759, Prior to SN C300002938)
FIGURE 5-22. CONSOLE BOX INSTALLATION (SN 0300336482 to Present, SN B300030760 to Present, SN C300002939 to Present)
FIGURE 5-23. CONSOLE BOX ASSEMBLY (SN 0300336482 to Present, SN B300030760 to Present, SN C300002939 to Present)
FIGURE 5-24. PLATFORM CONSOLE BOX ASSEMBLY (Prior to SN 0300330931, Prior to SN B300030138, Prior to SN C300001330)
FIGURE 5-25. PLATFORM CONSOLE BOX ASSEMBLY (SN 0300330932 through 0300336481, SN B300030139 through B300030759, SN C300001331 through C300002938)
FIGURE 5-26. LIGHT PANEL INSTALLATION - PLATFORM CONSOLE
FIGURE 5-27. FOOTSWITCH ASSEMBLY
FIGURE 5-28. TRAY ASSEMBLY
FIGURE 5-29. USB CHARGER INSTALLATION (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-30. USB CHARGER INSTALLATION (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 5-31. SKYGUARD BAR INSTALLATION
FIGURE 5-32. SKYLINE INSTALLATION (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 5-33. SKYLINE INSTALLATION (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 5-34. SKYGLAZIER INSTALLATION
FIGURE 5-35. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-36. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-37. SKYWELDER PREP PACKAGE INSTALLATION
FIGURE 5-38. WELDER ASSEMBLY
FIGURE 5-39. SOFT TOUCH INSTALLATION (WITHOUT FALL ARREST)
FIGURE 5-40. SOFT TOUCH INSTALLATION (WITH FALL ARREST)
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON) (5FT/1.52M PLATFORM)
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)
SECTION 6 - CYLINDERFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN LIFT
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM
FIGURE 6-7. MASTER CYLINDER ASSEMBLY
FIGURE 6-8. STEER CYLINDER ASSEMBLY
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. 4WD HYDRAULIC SYSTEM INSTALLATION (WITH 17GAL HYDRAULIC TANK) (MACHINES WITH SN STARTING WITH 03)
FIGURE 7-2. 4WD HYDRAULIC SYSTEM INSTALLATION (WITH 36GAL HYDRAULIC TANK) (MACHINES WITH SN STARTING WITH 03)
FIGURE 7-3. 4WD HYDRAULIC SYSTEM INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 7-4. 4WD HYDRAULIC SYSTEM INSTALLATION - (WITH PMP PUMP) (Prior to SN B300030138, Prior to SN C300001330)
FIGURE 7-5. HYDRAULIC SYSTEM INSTALLATION - (WITH PMP PUMP) (SN B300030139 to Present, SN C300001331 to Present)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V - ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 8-13. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPEC WITHOUT GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-14. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPEC WITHOUT GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-15. AC BOX AT PLATFORM - 220V AFSINT107 (CE & UK CA SPEC WITHOUT GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-16. AC BOX AT PLATFORM - 110V IEC YELLOW (CE & UK CA SPEC WITHOUT GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-17. AC BOX AT PLATFORM - 220V IEC BLUE (CE & UK CA SPEC WITHOUT GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-18. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPEC WITH 4000W/50HZ GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-19. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPEC WITH 4000W/50HZ GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-20. AC BOX AT PLATFORM - 220V AFSINT107 (CE & UK CA SPEC WITH 4000W/50HZ GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-21. AC BOX AT PLATFORM - 110V IEC YELLOW (CE & UK CA SPEC WITH 4000W/50HZ GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-22. AC BOX AT PLATFORM - 220V IEC BLUE (CE & UK CA SPEC WITH 4000W/50HZ GENERATOR) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-23. AC BOX AT PLATFORM - 220V CUSTOMER SUPPLIED COMPONENTS (ALL SPECS EXCEPT CSA SPECS) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 8-24. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 8-25. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 8-26. AC CABLE INSTALLATION - WITH TWO BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-27. AC CABLE INSTALLATION - WITH TWO BREAKERS (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-28. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-29. AC CABLE AND PLUG INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-30. BATTERY DISCONNECT SWITCH
FIGURE 8-31. BEACON JUMPER HARNESS (AMBER LIGHT)
FIGURE 8-32. BEACON JUMPER HARNESS (ORANGE LIGHT)
FIGURE 8-33. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR & WITHOUT AC CABLES)
FIGURE 8-34. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR & WITH AC CABLES)
FIGURE 8-35. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-36. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 50HZ 4000W GENERATOR)
FIGURE 8-37. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 60HZ 4000W GENERATOR)
FIGURE 8-38. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 7500W GENERATOR)
FIGURE 8-39. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 7500W GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-40. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE)
FIGURE 8-41. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE)
FIGURE 8-42. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT GENERATOR AND WITHOUT ARCTIC PACKAGE)
FIGURE 8-43. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-44. BOOM HARNESS - TOWER BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 8-45. BOOM HARNESS - TOWER BOOM (WITH ARCTIC PACKAGE)
FIGURE 8-46. BOOM HARNESS - TOWER BOOM AC CABLE (WITHOUT ARCTIC PACKAGE)
FIGURE 8-47. BOOM HARNESS - TOWER BOOM AC CABLE (WITH ARCTIC PACKAGE)
FIGURE 8-48. BOOM SENSORS INSTALLATION
FIGURE 8-49. BOOM SENSOR HARNESS
FIGURE 8-50. BREAKER BOX KIT WITH SINGLE DOUBLE POLE BREAKER (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-51. BREAKER BOX KIT WITH THREE BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-52. BREAKER BOX KIT - 30MA/16 AMP
FIGURE 8-53. BREAKER BOX KIT
FIGURE 8-54. CAPACITY HARNESS
FIGURE 8-55. CHASSIS SOLENOID HARNESS
FIGURE 8-56. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOOD
FIGURE 8-57. CLEARSKY CS550 BEACON INSTALLATION - WITH METAL HOOD
FIGURE 8-58. ENGINE HARNESS - DEUTZ D2011
FIGURE 8-59. ENGINE HARNESS - DEUTZ D2.9L4
FIGURE 8-60. ENGINE HARNESS
FIGURE 8-61. ENGINE HARNESS - KUBOTA
FIGURE 8-62. ENGINE HARNESS - DEUTZ D2.9L4 (CHINA IV)
FIGURE 8-63. FUEL HARNESS - DEUTZ D2.9L4 ENGINE
FIGURE 8-64. GENERATOR HARNESS - 2500W GENERATOR (60HZ)
FIGURE 8-65. GENERATOR HARNESS - 2500W GENERATOR (50HZ)
FIGURE 8-66. GENERATOR HARNESS - 4000W GENERATOR
FIGURE 8-67. GROUND CONTROL PANEL HARNESS
FIGURE 8-68. HOUR METER JUMPER HARNESS
FIGURE 8-69. KUBOTA D/F POWER HARNESS
FIGURE 8-70. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-71. PLATFORM INTERFACE HARNESS
FIGURE 8-72. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-73. RECEPTACLE BOX KIT - 220V IEC BLUE (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-74. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-75. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-76. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-77. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-78. SKYEYE RECEIVER HARNESS
FIGURE 8-79. SKYEYE EMITTER HARNESS
FIGURE 8-80. SKYLINE HARNESS
FIGURE 8-81. TRANSPORT HARNESS
FIGURE 8-82. TURNTABLE HARNESS
FIGURE 8-83. USB HARNESS
FIGURE 8-84. VALVE HARNESS - BOOM
FIGURE 8-85. VALVE HARNESS - MAIN VALVE
FIGURE 8-86. VALVE HARNESS - PLATFORM VALVE
FIGURE 8-87. WORKLIGHT HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CSA SPECS WITH DEUTZ ENGINES (ENGLISH LANGUAGE) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-2. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CSA SPECS WITH DEUTZ ENGINES (ENGLISH LANGUAGE) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-3. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS WITH KUBOTA ENGINES (ENGLISH LANGUAGE) (Prior to SN 0300336481)
FIGURE 9-4. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS WITH KUBOTA ENGINES (ENGLISH LANGUAGE) (SN 0300336482 to Present)
FIGURE 9-5. DECAL INSTALLATION - AUSTRALIAN SPEC (ENGLISH LANGUAGE) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-6. DECAL INSTALLATION - AUSTRALIAN SPEC (ENGLISH LANGUAGE) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-7. DECAL INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH LANGUAGES) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-8. DECAL INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH LANGUAGES) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-9. DECAL INSTALLATION - CE & UK CA SPEC (ENGLISH LANGUAGE) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-10. DECAL INSTALLATION - CE & UK CA SPEC (ENGLISH LANGUAGE) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-11. DECAL INSTALLATION - CSA SPEC WITH DEUTZ ENGINES (FRENCH/ENGLISH LANGUAGES) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-12. DECAL INSTALLATION - CSA SPEC WITH DEUTZ ENGINES (FRENCH/ENGLISH LANGUAGES) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-13. DECAL INSTALLATION - CSA SPEC WITH KUBOTA ENGINES (FRENCH/ENGLISH LANGUAGES) (Prior to SN 0300336481)
FIGURE 9-14. DECAL INSTALLATION - CSA SPEC WITH KUBOTA ENGINES (FRENCH/ENGLISH LANGUAGES) (SN 0300336482 to Present)
FIGURE 9-15. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH LANGUAGES) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-16. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH LANGUAGES) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-17. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH LANGUAGES) (Prior to SN 0300336481, Prior to SN B300031129)
FIGURE 9-18. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH LANGUAGES) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-19. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH LANGUAGES) (Prior to SN 0300336481)
FIGURE 9-20. DECAL INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH LANGUAGES) (SN 0300336482 to Present)
FIGURE 9-21. DECAL INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH LANGUAGES)
FIGURE 9-22. DECAL INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH LANGUAGES) (SN 0300336482 to Present, SN B300031130 to Present)
FIGURE 9-23. DECAL INSTALLATION - OPTIONS
FIGURE 9-24. TOW BAR DECAL INSTALLATION - ENGLISH LANGUAGE (ANSI, ANSI EXPORT, CE, CHINA, CIS/EAC, JAPANESE & UK CA SPECS)
FIGURE 9-25. TOW BAR DECAL INSTALLATION - ENGLISH/SPANISH LANGUAGE (ANSI EXPORT SPECS)
FIGURE 9-26. TOW BAR DECAL INSTALLATION - SPANISH LANGUAGE (ANSI EXPORT, CE, CIS/EAC & UK CA SPECS)
FIGURE 9-27. SKYWELDER DECAL INSTALLATION – 50HZ (ANSI EXPORT SPECS)
FIGURE 9-28. SKYWELDER DECAL INSTALLATION - 60HZ (ANSI EXPORT SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
