JLG Boom Lift 450AJ HC3 Operation Safety Manual 3122322600
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 450AJ HC3 Boom Lift
Part Number: 3122322600
Publication Date: 2024
Number of Pages: 144 Pages
450AJ HC3 2407 Cover Page
Foreword
450AJ HC3 Revision Log
Brand: JLG
Foreword
Other Publications Available
Safety PrecautionsGeneral
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
Machine Components
Pre-Start Inspection
Walk-Around Inspection
2.5.1 General
Function Check - AJ Model
SkyGuard® Function Check
Oscillating Axle Lockout Test (If Equipped)
Machine Controls and IndicatorsGeneral
Ground Control Station
3.3.1 Ground Control Station Functions
Ground Control Indicator Panel - ICE HC3 - LF-FG
3.4.1 Ground Control Indicator Panel Functions
450A/450AJ Platform Control Station
3.5.1 Platform Control Station Functions
Platform Indicator Panel - ICE HC3 - LF-FG
3.6.1 Platform Control Indicator Panel Functions
Beacons (With SkyGuard)
3.7.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.7.2 Amber Beacon
3.7.3 Blue or Red SkyGuard® Beacon
Machine OperationGeneral AJ 355 Non-Continuous Swing
Operating Characteristics And Limitations - HC3
4.2.1 Operating Conditions
4.2.2 Platform Load Sensing System (LSS)
4.2.3 Capacity Zones (Triple Capacity)
450AJ/520AJ Stability
450AJ HC3 Reach Chart
Engine Operation
4.5.1 Starting Procedure
4.5.2 Shutdown Procedure
Fuel Reserve / Shut-Off System
Diesel Particulate Filter (If Equipped)
Traveling (Driving)
4.8.1 Traveling Forward and Reverse
450AJ/520AJ Traveling (Grade/Side Slope)
4.9.1 Traveling on a Grade
Steering
Platform - Standard Booms
4.11.1 Platform Level Adjustment
4.11.2 Platform Rotation
Boom - AJ Models
4.12.1 Swinging the Boom
4.12.2 Raising and Lowering the Tower Boom
4.12.3 Raising and Lowering the Main Boom
4.12.4 Telescoping the Main Boom
Function Speed Control - AJ Small Boom
USB Charging Port
ClearSky Smart Fleet
Access Control (Boom)
Machine Safety System Override (MSSO) (If Equipped)
SkyGuard Activation/Deactivation - AJ
Shut Down And Park
Lifting And Tie Down
4.20.1 Lifting
4.20.2 Tie Down
Lifting Chart - 450AJ HC3-520AJ HC3
450AJ HC3 Safety Decal Locations
Emergency ProceduresGeneral
Incident Notification - Boom
Emergency Operation
5.3.1 Operator Unable to Control Machine
5.3.2 Platform or Boom Caught Overhead
Manual Swing Override
Emergency Towing Procedures
ClearSky Smart Fleet - Locked Out State
Accessories450AJ HC3 Accessory Tables
Bolt-On External Fall Arrest
6.2.1 Inspection Before Use
Cable Ladder Carrier
Fabric Mesh to Mid/Top Rail
Fall Arrest Platform
6.5.1 Safety Precautions
Pipe Racks
6.6.1 Capacity Specifications (Australia Only)
6.6.2 Safety Precautions
6.6.3 Preparation and Inspection
6.6.4 Operation
Platform Mesh to Mid/Top Rail
Platform Top Rail Extension
Platform Work Lights
SkyGlazier
6.10.1 Capacity Specifications
6.10.2 Safety Precautions
6.10.3 Preparation and Inspection
6.10.4 Operation
SkyPower 7.5kW and Generator 4kW
6.11.1 Output
6.11.2 Safety Precautions
6.11.3 Preparation and Inspection
6.11.4 Operation
SkySense
6.12.1 Preparation and Inspection
6.12.2 Operation
6.12.3 SkySense Platform Panel Indicators
6.12.4 SkySense Alarm
6.12.5 SkySense Override Button
6.12.6 SkySense Coverage Areas
SkySense Platform Bumper Padding
SkyWelder
6.14.1 Operation
6.14.2 Generator Output
6.14.3 Welding Accessories
6.14.4 Safety Precautions
6.14.5 Preparation and Inspection
Soft Touch
450AJ HC3 Max Work Load Capacity with Soft Touch
General Specifications and Operator MaintenanceGeneral
Serial Number Location 450AJ/520AJ
450AJ HC3 Operating Specifications
7.3.1 Dimensional Data
7.3.2 Capacities
7.3.3 Engine Data
7.3.4 Tires
7.3.5 Major Component Weights
Hydraulic Oil Specifications - Introduction
Hydraulic Oil Operating Temperature - 400-500 Series
Engine Oil Operating Temp Spec - Introduction Note
Engine Oil Operating Temp Spec - Deutz 2011
Engine Oil Operating Temp Spec - Deutz T4F/Stage V
Engine Oil Operating Temp Spec - Kubota WG Series
Operator Maintenance and Lubrication Diagram 450AJ HC3
7.10.1 Deutz D2011 L03 Engine (T4i)
7.10.2 Deutz D2.9L Engine (T4F/Stage V)
7.10.3 Kubota Engine
Operator Maintenance 450A/450AJ
Tires and Wheels - 9 Lug Nuts
7.12.1 Tire Damage
7.12.2 Tire Replacement
7.12.3 Wheel Replacement
7.12.4 Wheel Installation
Propane Fuel System Pressure Relief
Propane Fuel Filter Replacement (Kubota Engine)
7.14.1 Removal
7.14.2 Installation
Radio Frequency (RF) Information
7.15.1 Federal Communications Commission (FCC)
7.15.2 Innovation, Science and Economic Development (ISED)
Supplemental Information Only Applicable to CE/UKCA
EC Declaration of Conformity - 450/520 AJ Series
UKCA Declaration of Conformity - 450/520 AJ Series
- SuperPac Parts Manual
- StratoLift Parts Manual
