JLG Boom Lift 450A, 450AJ Service & Maintenance Manual 3122559800 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 450A, 450AJ Boom Lift
Part Number: 3122559800
Publication Date: 2026
Number of Pages: 1048 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Tires Specifications
2.1.5 Critical Stability Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Ground Control Keyswitch System
2.5.2 Platform Control Enable System
2.5.3 Cold Start System (DIESEL)
2.5.4 Fuel Reserve / Cut-out System
2.5.5 HRC Engine Emission Characteristics
2.5.6 Diesel Particulate Filter (If Equipped)
2.5.7 Drive System
2.5.8 Drive Orientation System
2.5.9 Function Speed Control System
2.5.10 Oscillating Axle System
2.5.11 Chassis Tilt Indicator System
2.5.12 Platform Load Sensing System (LSS)
2.5.13 Tires and Counterweight
2.5.14 Side Entry Platform
2.5.15 Transport Position Sensing System
2.5.16 Beyond Transport Position - Drive Speed Cutback System
2.5.17 Drive Steer - Boom Function Interlock System (CE/UKCA Only)
2.5.18 Ground Panel Display
2.5.19 Jib Lift (if equipped) End of Stroke Dampening
2.5.20 Main Boom Lift End of Stroke Dampening
2.5.21 Emergency Decent System
2.5.22 Diagnostics/Controller Programming
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily Check
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 First 300 Hours or 6 Months
3.3.5 Every 500 Hours or 6 Months
3.3.6 Every 500 Hours or Every Year
3.3.7 Every 600 Hours or Year
3.3.8 Every 1000 Hours or 2 Year
3.3.9 Every 1200 Hours or 2 Year
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Boom Cleanliness Guidelines
3.7.2 Boom Wear Pad Inspection
Hydraulic Filter Replacement
3.8.1 Hydraulic Filter Removal
3.8.2 Hydraulic Filter Installation
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Engine General Inspection
3.10.1 General Maintenance
3.10.2 Glow Plugs
3.10.3 Checking Oil Level
3.10.4 Replacing Engine Oil
3.10.5 Replacing the Oil Filter
3.10.6 Replacing the Primary Fuel Filters
3.10.7 Replacing the Fuel Pre-Filter
3.10.8 Replacing the Auxiliary Fuel Filter For Deutz D2011L03 T4I (Only)
3.10.9 Engine Operating Temperature Specifications
3.10.10 Hydraulic Oil Operating Temperature Specifications
Bio Fuel In Deutz Engines
3.11.1 General
3.11.2 Bio Fuel
3.11.3 Biological Contamination In Fuels
Deutz EMR2
Deutz EMR5
Generator Inspection
3.14.1 Maintenance Schedule
3.14.2 Overload Protection
3.14.3 Inspecting Brushes, Replacing Brushes and Cleaning Slip Rings
3.14.4 Troubleshooting
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedure
4.2.1 Starter
4.2.2 SkyGuard
4.2.3 LSS Testing and Evaluation
4.2.4 Troubleshooting
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Tilt Sensor Calibration
4.3.5 Boom Angle Calibration
4.3.6 Calibrating Level Up CRKPT
4.3.7 Calibrating Level Down Crackpoint
4.3.8 Calibrating Platform Angle Sensor
Special Procedures
4.4.1 Fuel Tank Cleaning and Drying
4.4.2 Cylinder Drift
4.4.3 Oscillating Axle Bleeding Procedure and Lockout Test
Wheel Drive Hub
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Ground Control Console Display Gauge
5.2.3 Hand Held Analyzer
5.2.4 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Machine Set-Up
5.3.2 Personalities
5.3.3 Operator Tools
5.3.4 Calibrations
Machine Model Adjustment
5.4.1 Adjustment Notes
5.4.2 Machine Orientation When Performing Test
ClearSky (CS550) Configuration and Troubleshooting
5.5.1 ClearSky Smart FleetTM CS550 Configuration
5.5.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Deutz D2.9L4 Engine
6.2.2 Deutz D2.9L (Stage V) Engine
6.2.3 Deutz D2011L03 Engine Trouble Codes
6.2.4 Kubota Engine Trouble Codes
Machine Fault Codes
6.3.1 General
6.3.2 ClearSky Smart Fleet DTC Fault Codes
ClearSky CS550 Troubleshooting Procedures
Deutz EMR Fault Codes
6.5.1 EMR2 Fault Codes
6.5.2 EMR5 Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Drive Pump Pre-Fill Procedures
7.3.3 Pressure Setting Procedure
Torque Values
7.4.1 Valve Torque Specifications
Hydraulics Installation
7.5.1 Frame Hoses
7.5.2 Turntable Hoses (US Built)
7.5.3 Turntable Hoses (China Built)
7.5.4 Boom Hoses
Standard Hydraulic Diagram- Boom And Turntable
7.6.1 4WD 450AJ TJN
7.6.2 2WD 450AJ TJN
7.6.3 2WD 450AJ US
7.6.4 4WD 450AJ US
7.6.5 4WD 450A US
7.6.6 2WD 450A US
Hydraulic Diagram - Chassis
7.7.1 4WD 450AJ TJN
7.7.2 2WD 450AJ TJN
7.7.3 2WD 450AJ US
7.7.4 4WD 450AJ US
7.7.5 4WD 450A US
7.7.6 2WD 450A US
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Ground Control Module Pin Connections
8.5.2 Platform Control Module Pin Connections
AMP Connector
8.6.1 Assembly
8.6.2 Disassembly
8.6.3 Wedge Lock
8.6.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Connector Labels
8.7.2 Component Labels
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Electrical Installation
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle and Drive Assemblies Troubleshooting
9.2.2 Front and Rear Axle Assembly
9.2.3 Drive Hub and Motor
9.2.4 Spindle Assembly
Boom
9.3.1 Boom Components Terminology
9.3.2 Main Boom Powertrack
9.3.3 Boom Assembly
9.3.4 Rotator Assembly (450AJ)
9.3.5 Jib Assembly (450AJ)
9.3.6 Fixed Jib and Rotator Assembly (450A)
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
9.4.4 Bolt-On External Fall Arrest
9.4.5 Foot Switch Adjustment
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank (Deutz D2.9L4 T4F/Stage V/China IV)
9.5.5 Surge Tank (Kubota Engine)
9.5.6 Pump Coupling Kit
9.5.7 Air Filter Assembly (Deutz Engines)
9.5.8 Air Filter Assembly (Kubota Engine)
9.5.9 Radiator Assembly
9.5.10 Thermostat
9.5.11 Coolant Temperature Sensor
9.5.12 Relay Assembly
9.5.13 Starter
9.5.14 Alternator
9.5.15 Fuel Tank
9.5.16 Pre-Fuel Filter and Fuel Pump — Deutz Engine
9.5.17 Pre-Fuel Filter and Fuel Pump — Kubota Engine
Hydraulic Cylinders
9.7.1 Main Boom Lift Cylinder
9.7.2 Platform Level Cylinder
9.7.3 Steer Cylinder
9.7.4 Jib Lift Cylinder
9.7.5 Axle Lockout Cylinder
Hydraulic Valves
9.8.1 Boom Mounted Valve
9.8.2 Main Control Valve
9.8.3 Traction Control Valve
Hydraulic Pumps
9.9.1 Function Pump
9.9.2 Drive Pump
Electrical Components
9.10.1 Battery
Turntable
9.11.1 Swing Bearing
9.11.2 Swing Motor
9.11.3 Counterweight
Generator and Pulley
9.12.1 For 7500W Generator - Deutz D2011L03
9.12.2 For 4000W Generator - Deutz D2011L03
9.12.3 For 2500W Generator - Deutz D2011L03
9.12.4 For 2500W Generator - Kubota WG2503 and Deutz T4F
9.12.5 For 7500W and 4000W Generator - Kubota, Deutz T4F and D2.9L4 Stage V
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Motor
10.1.3 Drive Brake
Boom and Jib Assembly
10.2.1 Upper Boom
10.2.2 Jib
10.2.3 Rotary Actuator
Platform
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
Pumps
10.5.1 Function Pump
10.5.2 Drive Pump
Hydraulic Cylinders
10.6.1 Axle Lockout Cylinder
10.6.2 Platform Level Cylinder (450A, 450AJ US Built)
10.6.3 Platform Level Cylinder (450AJ China Built)
10.6.4 Jib Lift Cylinder (450AJ US Built)
10.6.5 Jib Lift Cylinder (450AJ China Built)
10.6.6 Main Lift Cylinder (450A)
10.6.7 Main Lift Cylinder (450AJ)
10.6.8 Tower Boom Lift Cylinder
10.6.9 Master Cylinder (450A, 450AJ US Built)
10.6.10 Master Cylinder (450AJ China Built)
10.6.11 Steer Cylinder
10.6.12 Telescope Cylinder (450A)
10.6.13 Telescope Cylinder (450AJ)
Hydraulic Valves
10.8.1 Hydraulic Oil Tank
Turntable
10.9.1 Swing Motor
Generator Disassembly and Assembly
Powertrack
10.11.1 Remove Link
10.11.2 Install New Link
10.11.3 Replace Fixed End Brackets
10.11.4 Replace Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR2 Schematics
12.3.1 Vehicle Side Connection Diagram
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2
12.3.4 Engine Plug Pin
12.3.5 Vehicle Plug Pin Identification
Deutz EMR5 Schematics
12.4.1 Engine Plug Pin Identification
12.4.2 Vehicle Plug Pin Identification
Generator Schematics
12.5.1 Lead Connection List
- SuperPac Parts Manual
- StratoLift Parts Manual
