Hyundai
86
176,834
JLG Boom Lift 450A 450AJ Parts Catalog 3121660
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 450A 450AJ Boom Lift
Part Number: 3121660
Publication Date: 2025
Number of Pages: 946 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION​
FIGURE 1-2. STEER INSTALLATION WITHOUT TOW PACKAGE​
FIGURE 1-3. STEER INSTALLATION WITH TOW PACKAGE​
FIGURE 1-4. WHEEL DRIVE INSTALLATION (2WD)​
FIGURE 1-5. WHEEL DRIVE INSTALLATION (4WD)​
FIGURE 1-6. HUB - SPINDLE ASSEMBLY​
FIGURE 1-7. DRIVE HUB AND BRAKE ASSEMBLY - REAR​
FIGURE 1-8. DRIVE HUB ASSEMBLY - FRONT​
FIGURE 1-9. DRIVE MOTOR ASSEMBLY (2WD)​
FIGURE 1-10. DRIVE MOTOR ASSEMBLY (4WD)​
FIGURE 1-11. FRAME SHIELD INSTALLATION​
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (AVAILABLE ON ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED NON MARKING (AVAILABLE ON ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING (AVAILABLE ON AUSTRALIAN AND CE SPECS)​
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - 33 X 16LL500 PNEUMATIC TURF AND SAND (AVAILABLE ON ANSI AND ANSI EXPORT SPECS)​
FIGURE 1-16. TIRE AND WHEEL INSTALLATION - 33/1550 X 16.5 PNEUMATIC (AVAILABLE ON ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 1-17. TIRE AND WHEEL INSTALLATION - 33/1550 X 16.5 PNEUMATIC WITH TIRE SEALANT (AVAILABLE ON ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - 33/1550 X 16.5 FOAM-FILLED (AVAILABLE ON ALL SPECS)​
FIGURE 1-19. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED (AVAILABLE ON AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 1-20. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING (AVAILABLE ON AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 1-21. 2WD VALVES INSTALLATION - FRAME MOUNTED (450A)​
FIGURE 1-22. 2WD VALVES INSTALLATION - FRAME MOUNTED (450AJ)​
FIGURE 1-23. 4WD VALVES INSTALLATION - FRAME MOUNTED (450A)​
FIGURE 1-24. 4WD VALVES INSTALLATION - FRAME MOUNTED (450AJ)​
FIGURE 1-25. TRACTION VALVE ASSEMBLY - 2WD​
FIGURE 1-26. TRACTION VALVE ASSEMBLY - 4WD​
FIGURE 1-27. TOW PACKAGE INSTALLATION (OPTIONAL)​
FIGURE 1-28. TOW BAR ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. 2WD VALVES INSTALLATION - TURNTABLE MOUNTED (450A)​
FIGURE 2-2. 2WD VALVES INSTALLATION - TURNTABLE MOUNTED (450AJ)​
FIGURE 2-3. 4WD VALVES INSTALLATION - TURNTABLE MOUNTED (450A)​
FIGURE 2-4. 4WD VALVES INSTALLATION - TURNTABLE MOUNTED (450AJ)​
FIGURE 2-5. MAIN VALVE ASSEMBLY​
FIGURE 2-6. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-7. SWING DRIVE AND TURNTABLE BEARING INSTALLATION​
FIGURE 2-8. SWING MOTOR ASSEMBLY​
FIGURE 2-9. TURNTABLE BEARING ASSEMBLY​
FIGURE 2-10. TURNTABLE COVERS INSTALLATION​
FIGURE 2-11. TURNTABLE LOCK INSTALLATION​
FIGURE 2-12. TANKS INSTALLATION - DIESEL MACHINES (SN 0300201991 through 0300225480, SN E300002833 through E300004226)​
FIGURE 2-13. TANKS INSTALLATION - DIESEL MACHINES (SN 0300225481 through 0300272317, SN 1300007279 through 1300007373, SN B300003516 through B300005760, SN E300004227 through E300007990)​
FIGURE 2-14. TANKS INSTALLATION - GAS MACHINES (SN 0300201991 through 0300225480)​
FIGURE 2-15. TANKS INSTALLATION - GAS MACHINES (SN 0300225481 through 0300272317)​
FIGURE 2-16. DRIVE ORIENTATION INSTALLATION​
FIGURE 2-17. GROUND CONTROL ASSEMBLY - WITH DEUTZ/GM ENGINES (ANSI SPECS) (450A)​
FIGURE 2-18. GROUND CONTROL ASSEMBLY - DEUTZ/GM ENGINES (ALL SPECS EXCEPT CE SPECS) (450AJ)​
FIGURE 2-19. GROUND CONTROL ASSEMBLY - WITH DEUTZ ENGINE (CE SPECS ONLY) (450AJ)​
FIGURE 2-20. GROUND CONTROL ASSEMBLY - WITH KUBOTA ENGINE (ANSI SPECS ONLY) (450A)​
FIGURE 2-21. GROUND CONTROL ASSEMBLY - WITH KUBOTA ENGINE (ANSI AND CSA SPECS ONLY) (450AJ)​
FIGURE 2-22. ELECTRICAL SYSTEM INSTALLATION​
FIGURE 2-23. BEACON LIGHT INSTALLATION - AMBER​
FIGURE 2-24. BEACON LIGHT INSTALLATION - BLUE (SN 0300201991 through 0300202578)​
FIGURE 2-25. BEACON LIGHT INSTALLATION - BLUE (SN 0300202579 through 0300259091, SN 1300007279 through 1300007373, SN B300003516 through B300005760, SN E300002833 through E300007540)​
FIGURE 2-26. BEACON LIGHT INSTALLATION - BLUE (SN 0300259092 through 0300272317, SN E300007541 through E300007990)​
FIGURE 2-27. BEACON LIGHT INSTALLATION - RED (SN 0300214537 through 0300272317, SN 1300007279 through 1300007373, SN B300003516 through B300005760, SN E300003246 through E300007540)​
FIGURE 2-28. BEACON LIGHT INSTALLATION - RED (SN 0300259092 through 0300272317, SN E300007541 through E300007990)​
FIGURE 2-29. BATTERY AND CABLE INSTALLATION - USA AND CHINA BUILT MACHINES​
FIGURE 2-30. BATTERY AND CABLE INSTALLATION - ROMANIAN BUILT MACHINES​
FIGURE 2-31. HOODS INSTALLATION - WITH DEUTZ/GM ENGINES (450A) (SN 0300201991 through 0300222765)​
FIGURE 2-32. HOODS INSTALLATION - WITH DEUTZ/GM ENGINES (450A) (SN 0300222766 through 0300272317)​
FIGURE 2-33. HOODS INSTALLATION - WITH DEUTZ/GM/KUBOTA ENGINES (450AJ) (SN 0300201991 through 0300272317, SN B300003516 through B300005760, SN E300002833 through E300006670)​
FIGURE 2-34. HOODS INSTALLATION - WITH DEUTZ ENGINE (450AJ) (SN E300006671 through E300007990)​
FIGURE 2-35. HOODS INSTALLATION - WITH KUBOTA ENGINE (450A)​
FIGURE 2-36. HOODS INSTALLATION - WITH KUBOTA ENGINE (450AJ)​
FIGURE 2-37. HOOD ASSEMBLY - TANK SIDE (SN 0300201991 through 0300272317, SN B300003516 through B300005760, SN E300002833 through E300006670)​
FIGURE 2-38. HOOD ASSEMBLY - TANK SIDE (SN E300006671 through E300007990)​
FIGURE 2-39. HOOD ASSEMBLY - ENGINE SIDE (SN 0300201991 through 0300272317, SN B300003516 through B300005760, SN E300002833 through E300006670)​
FIGURE 2-40. HOOD ASSEMBLY - ENGINE SIDE (SN E30000667 through E300007990)​
FIGURE 2-41. COVERS INSTALLATION - COUNTERWEIGHT (USED ON MACHINES WITH FOAM-FILLED TIRES FOR ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (450AJ)​
FIGURE 2-42. COVERS INSTALLATION - COUNTERWEIGHT (USED ON MACHINES WITH PNEUMATIC TIRES FOR ANSI EXPORT, AUSTRALIAN, CE AND JAPANESE SPECS) (450AJ)​
FIGURE 2-43. COVERS INSTALLATION - COUNTERWEIGHT (USED ON MACHINES WITH TURF AND SAND TIRES FOR ANSI AND ANSI EXPORT SPECS) (450AJ)​
SECTION 3 - ENGINE
FIGURE 3-1. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)​
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)​
FIGURE 3-6. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)​
FIGURE 3-7. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (CHINA SPEC)​
FIGURE 3-8. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (CHINA SPEC)​
FIGURE 3-9. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-10. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE​
FIGURE 3-11. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (ANSI AND CSA SPECS)​
FIGURE 3-12. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (CHINA SPEC)​
FIGURE 3-13. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 3-14. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 3-15. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 3-16. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-17. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITH ARCTIC PACKAGE) (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-18. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-19. ENGINE COMPONENTS - DEUTZ D2011​
FIGURE 3-20. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (STAGE V) (WITHOUT ARCTIC PACKAGE) (CE SPECS)​
FIGURE 3-21. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (STAGE V) (WITHOUT ARCTIC PACKAGE) (CE SPECS)​
FIGURE 3-22. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (STAGE V) (WITHOUT ARCTIC PACKAGE) (CE SPECS)​
FIGURE 3-23. ENGINE COMPONENTS - DEUTZ D2011 (STAGE V)​
FIGURE 3-24. ENGINE INSTALLATION - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-25. ENGINE INSTALLATION - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-26. ENGINE AND PUMP SUB-ASSEMBLY - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-27. ENGINE AND PUMP SUB-ASSEMBLY - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-28. ENGINE ASSEMBLY - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-29. ENGINE ASSEMBLY - GM ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-30. ENGINE INSTALLATION - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-31. ENGINE INSTALLATION - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-32. ENGINE AND PUMP SUB-ASSEMBLY - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-33. ENGINE AND PUMP SUB-ASSEMBLY - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-34. ENGINE ASSEMBLY - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300222052)​
FIGURE 3-35. ENGINE ASSEMBLY - GM ENGINE (WITH ARCTIC PACKAGE) (SN 0300222053 through 0300272317)​
FIGURE 3-36. PUMP COUPLING KIT – DEUTZ/GM ENGINES​
FIGURE 3-37. ENGINE INSTALLATION - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-38. ENGINE INSTALLATION - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-39. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-40. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-41. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-42. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-43. ENGINE INSTALLATION - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-44. ENGINE INSTALLATION - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-45. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-46. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-47. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300201991 through 0300241743)​
FIGURE 3-48. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE) (SN 0300241744 through 0300272317)​
FIGURE 3-49. ENGINE COMPONENTS - KUBOTA (SN 0300201991 through 0300241743)​
FIGURE 3-50. ENGINE COMPONENTS - KUBOTA (SN 0300241744 through 0300272317)​
FIGURE 3-51. PUMP COUPLING KIT - KUBOTA ENGINE​
FIGURE 3-52. GEAR PUMP ASSEMBLY​
FIGURE 3-53. PISTON PUMP ASSEMBLY​
FIGURE 3-54. SPARK ARRESTOR INSTALLATION - DEUTZ D2.9L4 ENGINE​
FIGURE 3-55. CATALYTIC SPARK ARRESTOR INSTALLATION - DEUTZ D2011 ENGINE​
FIGURE 3-56. SPARK ARRESTOR INSTALLATION - DEUTZ D2011 ENGINE​
FIGURE 3-57. SPARK ARRESTOR INSTALLATION - KUBOTA ENGINE​
FIGURE 3-58. ENGINE BAFFLE INSTALLATION - WITH DEUTZ/GM ENGINES​
FIGURE 3-59. ENGINE BAFFLE INSTALLATION – WITH KUBOTA ENGINE​
FIGURE 3-60. GENERATOR INSTALLATION - 2500W/50HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-61. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-62. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-63. GENERATOR INSTALLATION - 2500W/60HZ (GM ENGINE)​
FIGURE 3-64. GENERATOR INSTALLATION - 2500W/60HZ (KUBOTA ENGINE)​
FIGURE 3-65. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-66. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-67. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-68. GENERATOR INSTALLATION - 4000W/60HZ (GM ENGINE)​
FIGURE 3-69. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-70. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-71. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-72. GENERATOR INSTALLATION - 7500W/60HZ (GM ENGINE)​
FIGURE 3-73. GENERATOR INSTALLATION - 7500W/60HZ (KUBOTA ENGINE)​
SECTION 4 - BOOM
FIGURE 4-1. CYLINDERS INSTALLATION (450A)​
FIGURE 4-2. CYLINDERS INSTALLATION (USA AND CHINA BUILT MACHINES) (450AJ)​
FIGURE 4-3. CYLINDERS INSTALLATION (ROMANIAN BUILT MACHINES) (450AJ)​
FIGURE 4-4. BOOM INSTALLATION (450A)​
FIGURE 4-5. BOOM INSTALLATION WITH AIRLINE (450A)​
FIGURE 4-6. BOOM INSTALLATION WITH SKYPOWER AND AIRLINE (450A)​
FIGURE 4-7. BOOM INSTALLATION WITH SKYPOWER (450A)​
FIGURE 4-8. BOOM INSTALLATION KIT (450A)​
FIGURE 4-9. BOOM INSTALLATION (USA AND CHINA BUILT MACHINES) (450AJ)​
FIGURE 4-10. BOOM INSTALLATION (ROMANIAN BUILT MACHINES) (450AJ)​
FIGURE 4-11. JIB INSTALLATION (USA AND CHINA BUILT MACHINES)​
FIGURE 4-12. JIB INSTALLATION (ROMANIAN BUILT MACHINES)​
FIGURE 4-13. MAIN BOOM ASSEMBLY (450A)​
FIGURE 4-14. MAIN BOOM ASSEMBLY (450AJ)​
FIGURE 4-15. TOWER BOOM ASSEMBLY (450A)​
FIGURE 4-16. TOWER BOOM ASSEMBLY (USA AND CHINA BUILT MACHINES) (450AJ)​
FIGURE 4-17. TOWER BOOM ASSEMBLY (ROMANIAN BUILT MACHINES) (450AJ)​
FIGURE 4-18. ROTATOR ASSEMBLY (SN 0300201991 through 0300232742, SN E300002833 through E300004880)​
FIGURE 4-19. ROTATOR ASSEMBLY (SN 0300232743 through 0300272317, SN B300003516 through B300005760, SN E300004881 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 4-20. PLATFORM SUPPORT INSTALLATION - WITHOUT LSS​
FIGURE 4-21. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS​
FIGURE 4-22. PLATFORM SUPPORT INSTALLATION - WITH 4 CELL LSS (450AJ) (SN 0300201991 through 0300202578)​
FIGURE 4-23. PLATFORM SUPPORT INSTALLATION WITH 4 CELL LSS (450AJ) (SN 0300202579 through 0300272317, SN E300002833 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 4-24. 2WD VALVES INSTALLATION - BOOM MOUNTED (450A)​
FIGURE 4-25. 2WD VALVES INSTALLATION - BOOM MOUNTED (450AJ)​
FIGURE 4-26. 4WD VALVES INSTALLATION - BOOM MOUNTED (450A)​
FIGURE 4-27. 4WD VALVES INSTALLATION - BOOM MOUNTED (450AJ)​
FIGURE 4-28. UPRIGHT VALVE ASSEMBLY​
FIGURE 4-29. BOOM VALVE ASSEMBLY (450A)​
FIGURE 4-30. BOOM VALVE ASSEMBLY (450AJ)​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY (USA BUILT MACHINES)​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY (USA AND CHINA BUILT MACHINES)​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY (USA AND CHINA BUILT MACHINES)​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY (ROMANIAN BUILT MACHINES)​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY (ROMANIAN BUILT MACHINES)​
FIGURE 5-6. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY (ROMANIAN BUILT MACHINES)​
FIGURE 5-7. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (USA BUILT MACHINES)​
FIGURE 5-8. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR (USA BUILT MACHINES)​
FIGURE 5-9. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR (USA AND CHINA BUILT MACHINES)​
FIGURE 5-10. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR (USA AND CHINA BUILT MACHINES)​
FIGURE 5-11. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (ROMANIAN BUILT MACHINES)​
FIGURE 5-12. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR (ROMANIAN BUILT MACHINES)​
FIGURE 5-13. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR (ROMANIAN BUILT MACHINES)​
FIGURE 5-14. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR (ROMANIAN BUILT MACHINES)​
FIGURE 5-15. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M - FALL ARREST (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 5-16. CONSOLE BOX INSTALLATION - WITHOUT SKYGUARD (450A) (SN 0300201991 through 0300226169)​
FIGURE 5-17. CONSOLE BOX INSTALLATION - WITHOUT SKYGUARD (450AJ) (SN 0300201991 through 0300226169)​
FIGURE 5-18. CONSOLE BOX INSTALLATION - WITH SKYGUARD (450A) (SN 0300201991 through 0300259091)​
FIGURE 5-19. CONSOLE BOX INSTALLATION - WITH SKYGUARD (450A) (SN 0300259092 through 0300272317)​
FIGURE 5-20. CONSOLE BOX INSTALLATION - WITH SKYGUARD (450AJ) (SN 0300201991 through 0300259091, SN B300003516 through B300005760, SN E300002833 through E300007540, SN 1300007279 through 1300007373)​
FIGURE 5-21. CONSOLE BOX INSTALLATION - WITH SKYGUARD (450AJ) (SN 0300259092 through 0300272317, SN E300007541 through E300007990)​
FIGURE 5-22. PLATFORM CONSOLE BOX ASSEMBLY - WITHOUT SKYGUARD (450A) (SN 0300201991 through 0300226169)​
FIGURE 5-23. PLATFORM CONSOLE BOX ASSEMBLY - WITHOUT SKYGUARD (450AJ) (SN 0300201991 through 0300219950)​
FIGURE 5-24. PLATFORM CONSOLE BOX ASSEMBLY - WITHOUT SKYGUARD (450AJ) (SN 0300219951 through 0300226169)​
FIGURE 5-25. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD (450A) (SN 0300201991 through 0300259091)​
FIGURE 5-26. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD (450A) (SN 0300259092 through 0300272317)​
FIGURE 5-27. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD (450AJ) (SN 0300201991 through 0300219950, SN E300002833 through E300003608)​
FIGURE 5-28. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD (450AJ) (SN 0300219951 through 0300259091, SN B300003516 through B300005760, SN E300003609 through E300007540, SN 1300007279 through 1300007373)​
FIGURE 5-29. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD (450AJ) (SN 0300259091 through 0300272317, SN E300007541 through E300007990)​
FIGURE 5-30. CONTROLLER ASSEMBLY - DRIVE AND STEER​
FIGURE 5-31. CONTROLLER ASSEMBLY - LIFT AND SWING​
FIGURE 5-32. FOOTSWITCH ASSEMBLY​
FIGURE 5-33. TRAY ASSEMBLY​
FIGURE 5-34. SOFT TOUCH INSTALLATION - 6FT/1.8M PLATFORM (ANSI, ANSI EXPORT AND CSA SPECS) (SN 0300201991 through 0300211852)​
FIGURE 5-35. SOFT TOUCH INSTALLATION - 6FT/1.8M PLATFORM (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (SN 0300211853 through 0300272317, SN B300003516 through B300005760)​
FIGURE 5-36. SOFT TOUCH INSTALLATION - 5FT/1.52M PLATFORM WITH FALL ARREST (ANSI, ANSI EXPORT AND CSA SPECS) (SN 0300201991 through 0300211852)​
FIGURE 5-37. SOFT TOUCH INSTALLATION - 5FT/1.52M PLATFORM WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (SN 0300211853 through 0300272317, SN B300003516 through B300005760)​
FIGURE 5-38. SKYEYE INSTALLATION​
FIGURE 5-39. SKYGUARD SYSTEM INSTALLATION (SN 0300201991 through 0300259091, SN B300003516 through B300005760, SN E300002833 through E300007540, SN 1300007279 through 1300007373)​
FIGURE 5-40. SKYGUARD BAR INSTALLATION (SN 0300259092 through 0300272317, SN E300007541 through E300007990)​
FIGURE 5-41. SKYLINE INSTALLATION​
FIGURE 5-42. CROSS RAIL INSTALLATION​
FIGURE 5-43. SKYGLAZIER INSTALLATION​
FIGURE 5-44. SKYGLAZIER INSTALLATION​
FIGURE 5-45. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-46. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-47. SKYWELDER PREP PACKAGE INSTALLATION​
FIGURE 5-48. WELDER ASSEMBLY​
FIGURE 5-49. PIPE RACK INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN SPECS)​
FIGURE 5-50. PIPE RACK INSTALLATION (AUSTRALIAN SPEC)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450A) (SN 0300201991 through 0300235624)​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450A) (SN 0300235625 through 0300272317)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450AJ) (SN 0300201991 through 0300229340)​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450AJ) (SN 0300226835 through 0300234431)​
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450AJ) (SN E300002833 through E300004190)​
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - MAIN BOOM (450AJ) (SN 0300234432 through 0300272317, SN B300003516 through B300005760, SN E300004191 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - TOWER BOOM​
FIGURE 6-11. MASTER CYLINDER ASSEMBLY​
FIGURE 6-12. STEER CYLINDER ASSEMBLY​
FIGURE 6-13. TELESCOPE CYLINDER ASSEMBLY (450A)​
FIGURE 6-14. TELESCOPE CYLINDER ASSEMBLY (450AJ) (SN 0300201991 through 0300234431)​
FIGURE 6-15. TELESCOPE CYLINDER ASSEMBLY (450AJ) (SN 0300234432 through 0300272317, SN B300003516 through B300005760, SN E300002834 through E300007990, SN 1300007279 through 1300007373)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. 2WD HYDRAULIC SYSTEM INSTALLATION (450A)​
FIGURE 7-2. 2WD HYDRAULIC SYSTEM INSTALLATION (450AJ)​
FIGURE 7-3. 4WD HYDRAULIC SYSTEM INSTALLATION (450A)​
FIGURE 7-4. 4WD HYDRAULIC SYSTEM INSTALLATION (450AJ) (SN 0300201991 through 0300225480, SN E300002833 through E300004226)​
FIGURE 7-5. 4WD HYDRAULIC SYSTEM INSTALLATION (450AJ) (SN 0300225481 through 0300272317, SN B300003516 through B300005760, SN E300004227 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 7-6. HYDRAULIC DIAGRAM LIST​
SECTION 8 - ELECTRICAL
FIGURE 8-1. ELECTRICAL DIAGRAM LIST​
FIGURE 8-2. AC BOX AT PLATFORM - LOCALLY SUPPLIED COMPONENTS FOR ANSI EXPORT, AUSTRALIAN AND CE SPECS (SN 0300201991 through 0300220578, SN E300002833 through E300003512)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V - ANSI, ANSI EXPORT AND CSA SPECS (SN 0300201991 through 0300220578)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V - ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS (SN 0300220579 through 0300272317, SN B300003516 through B300005760)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPEC) (SN 0300201991 through 0300220578, SN E300002833 through E300003512)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V - ANSI, ANSI EXPORT AND CSA SPECS (SN 0300201991 through 0300220578)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPEC) (SN 0300201991 through 0300220578, SN E300002833 through E300003512)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 70MM X 70MM BOX (CE SPEC) (SN 0300201991 through 0300210158, SN E300002833 through E300002763)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 70MM X 70MM BOX (CE SPEC) (SN 0300201991 through 0300210158, SN E300002833 through E300002763)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2IN X 4IN BOX (CE SPEC) (SN 0300201991 through 0300210158, SN E300002833 through E300002763)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2IN X 4IN BOX (CE SPEC) (SN 0300210159 through 0300220578, SN E300002764 through E300003512)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2IN X 4IN BOX (CE SPEC) (SN 0300201991 through 0300210158, SN E300002833 through E300002763)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2IN X 4IN BOX (CE SPEC) (SN 0300210159 through 0300220578, SN E300002764 through E300003512)​
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX (CE SPEC) (SN 0300201991 through 0300220578, SN E300002833 through E300003512)​
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, CE AND CHINA SPECS)​
FIGURE 8-21. AC CABLE INSTALLATION - WITH TWO BREAKERS (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-22. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE SPECS) (SN 0300220579 through 0300272317, SN E300003513 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-23. BATTERY DISCONNECT SWITCH​
FIGURE 8-24. BEACON LIGHT HARNESS (BLUE BEACON ONLY) (SN 0300201991 through 0300202578)​
FIGURE 8-25. BEACON LIGHT HARNESS (BLUE BEACON ONLY) (SN 0300202579 through 0300272317, SN B300003516 through B300005760, SN E300002833 through E300007990, SN 1300007279 through 1300007373)​
FIGURE 8-26. BEACON EXTENSION HARNESS (SN 0300202579 through 0300221757, SN E300002833 through E300003881)​
FIGURE 8-27. BOOM CABLES AND CLAMPS INSTALLATION (WITHOUT ARCTIC PACKAGE) (450A)​
FIGURE 8-28. BOOM CABLES AND CLAMPS INSTALLATION (WITHOUT ARCTIC PACKAGE) (450AJ)​
FIGURE 8-29. BOOM CABLES AND CLAMPS INSTALLATION (WITH ARCTIC PACKAGE) (450A)​
FIGURE 8-30. BOOM CABLES AND CLAMPS INSTALLATION (WITH ARCTIC PACKAGE) (450AJ)​
FIGURE 8-31. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE) (450A)​
FIGURE 8-32. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE) (450AJ)​
FIGURE 8-33. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE) (450A)​
FIGURE 8-34. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE) (450AJ)​
FIGURE 8-35. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT ARCTIC PACKAGE) (450A)​
FIGURE 8-36. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT ARCTIC PACKAGE) (450AJ)​
FIGURE 8-37. BOOM HARNESS (MAIN BOOM AC CABLE) (WITH ARCTIC PACKAGE) (450A)​
FIGURE 8-38. BOOM HARNESS (MAIN BOOM AC CABLE) (WITH ARCTIC PACKAGE) (450AJ)​
FIGURE 8-39. BOOM HARNESS - TOWER BOOM (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-40. BOOM HARNESS - TOWER BOOM (WITH ARCTIC PACKAGE)​
FIGURE 8-41. BOOM HARNESS - TOWER BOOM AC CABLE (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-42. BOOM HARNESS - TOWER BOOM AC CABLE (WITH ARCTIC PACKAGE)​
FIGURE 8-43. BOOM VALVE HARNESS​
FIGURE 8-44. BREAKER BOX KIT WITH TWO BREAKERS - CE SPEC​
FIGURE 8-45. BREAKER BOX KIT WITH THREE BREAKERS - CE SPEC​
FIGURE 8-46. BREAKER BOX KIT - 30MA/16 AMP​
FIGURE 8-47. CHASSIS SOLENOID HARNESS​
FIGURE 8-48. ENGINE HARNESS - DEUTZ D2011​
FIGURE 8-49. ENGINE HARNESS - DEUTZ D2.9L4​
FIGURE 8-50. ENGINE HARNESS - GM​
FIGURE 8-51. ENGINE HARNESS - KUBOTA​
FIGURE 8-52. FUEL HARNESS - DEUTZ D2.9L4 ENGINE​
FIGURE 8-53. GENERATOR HARNESS - 2500W GENERATOR (60HZ)​
FIGURE 8-54. GENERATOR HARNESS - 2500W GENERATOR (50HZ)​
FIGURE 8-55. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-56. GENERATOR ON/OFF SWITCH HARNESS​
FIGURE 8-57. GROUND CONTROL PANEL HARNESS​
FIGURE 8-58. KUBOTA D/F POWER HARNESS​
FIGURE 8-59. LSS HARNESS​
FIGURE 8-60. PLATFORM CONSOLE BOX HARNESS (SN 0300201991 through 0300259091, SN B300003516 through B300005760, SN E300002833 through E300007540, SN 1300007279 through 1300007373)​
FIGURE 8-61. PLATFORM CONSOLE BOX HARNESS (SN 0300259091 through 0300272317, SN E300007541 through E300007990)​
FIGURE 8-62. PLATFORM INTERFACE HARNESS​
FIGURE 8-63. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)​
FIGURE 8-64. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)​
FIGURE 8-65. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE SPEC)​
FIGURE 8-66. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE SPEC)​
FIGURE 8-67. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE SPEC)​
FIGURE 8-68. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE SPEC)​
FIGURE 8-69. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)​
FIGURE 8-70. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-71. SKYEYE RECEIVER HARNESS​
FIGURE 8-72. SKYEYE EMITTER HARNESS​
FIGURE 8-73. SKYLINE HARNESS​
FIGURE 8-74. SKYGUARD HARNESS​
FIGURE 8-75. TURNTABLE HARNESS​
FIGURE 8-76. VALVE HARNESS - MAIN VALVE​
FIGURE 8-77. VALVE HARNESS - PLATFORM VALVE​
SECTION 9 - DECAL
FIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CHINA SPECS (ENGLISH)​
FIGURE 9-2. DECAL INSTALLATION - WITH KUBOTA ENGINE (ANSI SPECS) (ENGLISH)​
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC (ENGLISH)​
FIGURE 9-4. DECAL INSTALLATION - BRAZIL SPEC (ENGLISH)​
FIGURE 9-5. DECAL INSTALLATION - CE SPEC (ENGLISH)​
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (FRENCH/ENGLISH)​
FIGURE 9-7. DECAL INSTALLATION - WITH KUBOTA ENGINE (CSA SPEC) (FRENCH/ENGLISH)​
FIGURE 9-8. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)​
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH)​
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)​
FIGURE 9-11. DECAL INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH)​
FIGURE 9-12. DECAL INSTALLATION - OPTIONS​
FIGURE 9-13. TOW BAR DECAL INSTALLATION - ENGLISH LANGUAGE (ANSI, ANSI EXPORT, CE, CHINA AND JAPANESE SPECS)​
FIGURE 9-14. TOW BAR DECAL INSTALLATION - ENGLISH/SPANISH LANGUAGE (ANSI EXPORT, CE AND CHINA SPECS)​
FIGURE 9-15. TOW BAR DECAL INSTALLATION - SPANISH LANGUAGE (ANSI EXPORT AND CE SPECS)​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS​
PART NUMBER INDEX
