Hyundai
86
176,834
JLG Boom Lift 40HT Parts Manual 3120244
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 40HT Boom Lift
Part Number: 3120244
Number of Pages: 240 Pages
SECTION 1 - ILLUSTRATED PARTS LIST
FIGURE 1-1. BOOM, TURNTABLE AND HORIZONTAL CUTOUT SWITCH INSTALLATIONS​
FIGURE 1-2. BOOM ASSEMBLY (2 SECTION)​
FIGURE 1-3. TELESCOPE CYLINDER ASSEMBLY (2 SECTION BOOM)​
FIGURE 1-4. BOOM ASSEMBLY (3 SECTION)​
FIGURE 1-5. TELESCOPE CYLINDER ASSEMBLY (3 SECTION BOOM)​
FIGURE 1-6. SLAVE CYLINDER ASSEMBLY​
FIGURE 1-7. LIFT CYLINDER ASSEMBLY​
FIGURE 1-8. MASTER CYLINDER ASSEMBLY​
FIGURE 1-9. BOOM WIPERS INSTALLATION (2 SECTION)​
FIGURE 1-10. BOOM WIPERS INSTALLATION (3 SECTION)​
FIGURE 1-11. PLATFORM AND CONTROL STANDS ASSEMBLIES AND INSTALLATIONS​
FIGURE 1-12. ROTATOR MOTOR ASSEMBLY​
FIGURE 1-13. PLATFORM CONTROL BOX ASSEMBLIES - PQ CONTROLLERS (CIRCA 1983-1984)​
FIGURE 1-14. PLATFORM CONTROL BOX ASSEMBLIES - PQ CONTROLLERS (CIRCA 1984 AND NEWER)​
FIGURE 1-15. PLATFORM CONTROL BOX ASSEMBLIES - OEM CONTROLLERS​
FIGURE 1-16. GROUND CONTROL BOX ASSEMBLIES (RACINE VALVES)​
FIGURE 1-17. GROUND CONTROL BOX ASSEMBLIES (VICKERS VALVES)​
FIGURE 1-18. CONTROL VALVES INSTALLATION (RACINE VALVES)​
FIGURE 1-19. PROPORTIONAL CONTROL VALVE ASSEMBLY - OUTLET SECTION​
FIGURE 1-20. PROPORTIONAL CONTROL VALVE ASSEMBLY - WORKING SECTIONS​
FIGURE 1-21. PROPORTIONAL CONTROL VALVE ASSEMBLY - INLET (DUMP) SECTION​
FIGURE 1-22. PROPORTIONAL CONTROL VALVE ASSEMBLY - SERVO ASSEMBLY​
FIGURE 1-23. CONTROL VALVE ASSEMBLY - RACINE BANG-BANG​
FIGURE 1-24. CONTROL VALVES INSTALLATION (VICKERS VALVES)​
FIGURE 1-25. CONTROL VALVE ASSEMBLY - VICKERS​
FIGURE 1-26. ENGINE COMPONENTS, ASSEMBLIES AND INSTALLATIONS - WISCONSIN VH4D GAS​
FIGURE 1-27. DUAL FUEL AND LPG COMPONENTS INSTALLATION - WISCONSIN​
FIGURE 1-28. 110 VOLT GENERATOR INSTALLATION - WICONSIN​
FIGURE 1-29. ENGINE COMPONENTS, ASSEMBLIES AND INSTALLATION - DEUTZ F2L511​
FIGURE 1-30. 110 VOLT GENERATOR INSTALLATION - DEUTZ​
FIGURE 1-31. MOTOR COMPONENTS, ASSEMBLIES AND INSTALLATIONS - ELECTRIC​
FIGURE 1-32. GEAR PUMP ASSEMBLY​
FIGURE 1-33. TANDEM PUMP ASSEMBLY (PISTON PUMP SECTION)​
FIGURE 1-34. TANDEMPUMPASSEMBLY(GEARPUMPSECTION)​
FIGURE 1-35. TANKS INSTALLATION​
FIGURE 1-36. HOODS INSTALLATION​
FIGURE 1-37. REMOTE LUBRICATION AND TURNTABLE LOKING PIN INSTALLATION​
FIGURE 1-38. ROTARY OIL COUPLING INSTALLATION​
FIGURE 1-39. ROTARY OIL COUPLING INSTALLATION​
FIGURE 1-40. SWING DRIVE AND SWING BEARING INSTALLATIONS​
FIGURE 1-41. SWING BRAKE ASSEMBLY​
FIGURE 1-42. SWING BRAKE ASSEMBLY​
FIGURE 1-43. SWING HUB ASSEMBLY​
FIGURE 1-44. FRAME, STEERING AND DRIVE COMPONENTS INSTALLATION (DOUBLE ACTING STEER CYLINDER)​
FIGURE 1-45. STEER CYLINDER ASSEMBLY (DOUBLE ACTING)​
FIGURE 1-46. FRAME, STEERING AND DRIVE COMPONENTS INSTALLATION (SINGLE ACTING STEER CYLINDER)​
FIGURE 1-47. STEER CYLINDER ASSEMBLY (SINGLE ACTING)​
FIGURE 1-48. DRIVE MOTOR ASSEMBLY​
FIGURE 1-49. DRIVE BRAKE ASSEMBLY (HOUSING LENGTH - 3 3/4IN)​
FIGURE 1-50. DRIVE BRAKE ASSEMBLY - AUSCO (HOUSING LENGTH - 4IN)​
FIGURE 1-51. DRIVE BRAKE ASSEMBLY - MICO (HOUSING LENGTH - 4IN)​
FIGURE 1-52. DRIVE HUB ASSEMBLY​
FIGURE 1-53. TOW PACKAGE (SINGLE ACTING STEER CYLINDER MACHINES)​
FIGURE 1-54. PLACARDS AND DECALS INSTALLATION - MODEL 40HT​
FIGURE 1-55. HYDRAULIC DIAGRAM - DRIVE​
FIGURE 1-56. HYDRAULIC DIAGRAM - LEVEL​
FIGURE 1-57. HYDRAULIC DIAGRAM - LIFT​
FIGURE 1-58. HYDRAULIC DIAGRAM - MANUAL DESCENT​
FIGURE 1-59. HYDRAULIC DIAGRAM - PUMP (RACINE VALVES WITHOUT STEERING WHEEL)​
FIGURE 1-60. HYDRAULIC DIAGRAM - PUMP (RACINE VALVES WITH STEERING WHEEL)​
FIGURE 1-61. HYDRAULIC DIAGRAM - PUMP (VICKERS VALVES WITHOUT STEERING WHEEL)​
FIGURE 1-62. HYDRAULIC DIAGRAM - PUMP (VICKERS VALVES WITH STEERING WHEEL)​
FIGURE 1-63. HYDRAULIC DIAGRAM - ROTATE (WITHOUT STEERING WHEEL)​
FIGURE 1-64. HYDRAULIC DIAGRAM - ROTATE (WITH STEERING WHEEL)​
FIGURE 1-65. HYDRAULIC DIAGRAM - STEER (WITHOUT STEERING WHEEL)​
FIGURE 1-66. HYDRAULIC DIAGRAM - STEER (WITH STEERING WHEEL)​
FIGURE 1-67. HYDRAULIC DIAGRAM - SWING​
FIGURE 1-68. HYDRAULIC DIAGRAM - TELESCOPE​
FIGURE 1-69. HYDRAULIC DIAGRAM - TOW​
FIGURE 1-70. ELECTRICAL WIRING DIAGRAMS - RACINE VALVES​
FIGURE 1-71. ELECTRICAL WIRING DIAGRAMS - VICKERS VALVES​
SECTION 2 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 2-1. 40HT LIFT STANDARD PARTS​
FIGURE 2-2. 40HT LIFT OPTIONAL/VARIABLE PARTS​
PART NUMBER INDEX
