Hyundai
86
176,834
JLG Boom Lift 400SC 460SJC Parts Catalog 31222359
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 400SC 460SJC Boom Lift
Part Number: 31222359
Publication Date: 2025
Number of Pages: 620 Pages
SECTION 1 - FRAME
FIGURE 1-1. UNDERCARRIAGE ASSEMBLY - WITH RUBBER TRACKS​
FIGURE 1-2. UNDERCARRIAGE ASSEMBLY - WITH RUBBER TRACKS (NON-MARKING TRACKS)​
FIGURE 1-3. FRAME UNDERCARRIAGE STEEL TRACKS WITH PADS​
FIGURE 1-4. UNDERCARRIAGE ASSEMBLY - WITH STEEL TRACKS​
FIGURE 1-5. TRACK ASSEMBLY - STEEL​
FIGURE 1-6. DRIVE HUB ASSEMBLY​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATION (400SC)​
FIGURE 2-2. CONTROL VALVES INSTALLATION (460SJC)​
FIGURE 2-3. MAIN VALVE ASSEMBLY (400SC)​
FIGURE 2-4. MAIN VALVE ASSEMBLY (460SJC)​
FIGURE 2-5. AXLE VALVE ASSEMBLY​
FIGURE 2-6. AUXILIARY PUMP AND BATTERY INSTALLATION (WITHOUT DISCONNECT)​
FIGURE 2-7. AUXILIARY PUMP AND BATTERY INSTALLATION (WITH DISCONNECT)​
FIGURE 2-8. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-9. SWING DRIVE INSTALLATION​
FIGURE 2-10. SWING HUB/MOTOR ASSEMBLY​
FIGURE 2-11. TURNTABLE BEARING INSTALLATION​
FIGURE 2-12. BEARING LUBE INSTALLATION​
FIGURE 2-13. TURNTABLE COVERS INSTALLATION​
FIGURE 2-14. TURNTABLE LOCK INSTALLATION​
FIGURE 2-15. ROTARY COUPLING INSTALLATION​
FIGURE 2-16. TANKS INSTALLATION​
FIGURE 2-17. ELECTRICAL INSTALLATION (400SC)​
FIGURE 2-18. ELECTRICAL INSTALLATION - WITH DEUTZ (STAGE V) ENGINE (400SC)​
FIGURE 2-19. ELECTRICAL INSTALLATION (460SJC)​
FIGURE 2-20. ELECTRICAL INSTALLATION - WITH DEUTZ (STAGE V) ENGINE (460SJC)​
FIGURE 2-21. ELECTRICAL PANEL ASSEMBLY​
FIGURE 2-22. GROUND CONTROL ASSEMBLY (400SC)​
FIGURE 2-23. GROUND CONTROL ASSEMBLY​
FIGURE 2-24. GROUND CONTROL ASSEMBLY (460SJC)​
FIGURE 2-25. GROUND CONTROL ASSEMBLY - WITH DEUTZ (STAGE V) ENGINE (460SJC)​
FIGURE 2-26. KEYSWITCH AND PANEL DECAL INSTALLATION (400SC)​
FIGURE 2-27. KEYSWITCH AND PANEL DECAL INSTALLATION (CE & UK CA (LRC) SPEC) (400SC)​
FIGURE 2-28. KEYSWITCH AND PANEL DECAL INSTALLATION - WITH DEUTZ D2.9L4 (STAGE V) ENGINES (CE & UK CA SPEC) (400SC)​
FIGURE 2-29. KEYSWITCH AND PANEL DECAL INSTALLATION (460SJC)​
FIGURE 2-30. KEYSWITCH AND PANEL DECAL INSTALLATION (CE & UK CA (LRC) SPEC) (460SJC)​
FIGURE 2-31. KEYSWITCH AND PANEL DECAL INSTALLATION - WITH DEUTZ D2.9L4 (STAGE V) ENGINES (CE & UK CA SPEC) (460SJC)​
FIGURE 2-32. LIGHT PANEL INSTALLATION​
FIGURE 2-33. GROUND CONTROL PANEL MOUNTING (400SC)​
FIGURE 2-34. GROUND CONTROL PANEL MOUNTING (460SJC)​
FIGURE 2-35. GROUND CONTROL PANEL MOUNTING - WITH DEUTZ (STAGE V) ENGINE​
FIGURE 2-36. BEACON LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON)​
FIGURE 2-37. BEACON LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON)​
FIGURE 2-38. BEACON LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON)​
FIGURE 2-39. HOOD INSTALLATION (ABS)​
FIGURE 2-40. HOOD INSTALLATION (STEEL)​
FIGURE 2-41. HOOD ASSEMBLY - ENGINE SIDE (ABS)​
FIGURE 2-42. HOOD ASSEMBLY - ENGINE SIDE (STEEL)​
FIGURE 2-43. ABS HOOD ASSEMBLY - TANK SIDE​
FIGURE 2-44. STEEL HOOD ASSEMBLY - TANK SIDE​
FIGURE 2-45. SOUND REDUCTION INSTALLATION - WITH STEEL HOODS (OPTIONAL)​
FIGURE 2-46. WHITE NOISE ALARM (AMBIENT) INSTALLATION​
FIGURE 2-47. WHITE NOISE ALARM (CONSTANT) INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. ENGINE INSTALLATION (DEUTZ D2011) (ANSI EXPORT SPECS)​
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY (DEUTZ D2011) (ANSI EXPORT SPECS)​
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (ANSI EXPORT SPECS)​
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPECS)​
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPECS)​
FIGURE 3-6. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPEC)​
FIGURE 3-7. ENGINE COMPONENTS - DEUTZ D2011 (ANSI EXPORT SPECS)​
FIGURE 3-8. ENGINE INSTALLATION - DEUTZ D2.9L4 EMR4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, CSA AND ANSI EXPORT SPECS)​
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 EMR4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-10. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-11. ENGINE INSTALLATION - DEUTZ D2.9L4 EMR4 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 EMR4 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-13. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-14. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-15. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-16. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-17. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-18. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-19. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)​
FIGURE 3-20. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR4ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-21. ENGINE COMPONENTS - DEUTZ D2.9L4 ERM5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-22. ENGINE INSTALLATION - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)​
FIGURE 3-23. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)​
FIGURE 3-24. ENGINE ASSEMBLY - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)​
FIGURE 3-25. ENGINE COMPONENTS - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)​
FIGURE 3-26. MOTOR MOUNT INSTALLATION - STAGE V ENGINE (WITHOUT GENERATOR)​
FIGURE 3-27. MOTOR MOUNT INSTALLATION - STAGE V ENGINE (WITH GENERATOR)​
FIGURE 3-28. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-29. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 (STAGE V) ENGINE)​
FIGURE 3-30. GEAR PUMP ASSEMBLY​
FIGURE 3-31. PISTON PUMP ASSEMBLY (FRONT)​
FIGURE 3-32. PISTON PUMP ASSEMBLY (REAR)​
FIGURE 3-33. PUMP COUPLING KIT​
FIGURE 3-34. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE​
FIGURE 3-35. ENGINE BAFFLE INSTALLATION​
FIGURE 3-36. ENGINE BAFFLE INSTALLATION - STEEL​
FIGURE 3-37. ENGINE TRAY JACK​
FIGURE 3-38. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPEC)​
FIGURE 3-39. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)​
FIGURE 3-40. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPEC)​
FIGURE 3-41. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT, CE & UK CA (LRC) SPECS)​
FIGURE 3-42. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)​
FIGURE 3-43. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ (STAGE V) ENGINE) (CE & UK CA SPEC)​
FIGURE 3-44. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPECS)​
FIGURE 3-45. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPECS)​
FIGURE 3-46. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)​
FIGURE 3-47. OIL COOLER INSTALLATION - DEUTZ D2011 ENGINES (ANSI EXPORT, CE & UK CA (LRC) SPECS)​
FIGURE 3-48. OIL COOLER INSTALLATION - DEUTZ D2.9L4 ENGINES/DEUTZ D2.9L4 (STAGE V) ENGINES (ANSI, ANSI EXPORT, CE, CSA, JAPAN & UK CA SPECS)​
FIGURE 3-49. SPARK ARRESTOR INSTALLATION - ANSI EXPORT SPECS​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (400SC)​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (460SJC)​
FIGURE 4-3. MAIN BOOM ASSEMBLY (400SC)​
FIGURE 4-4. MAIN BOOM ASSEMBLY (460SJC)​
FIGURE 4-5. JIB BOOM ASSEMBLY (460SJC)​
FIGURE 4-6. JIB BOOM ASSEMBLY (460SJC) (SN 0300307137 to Present)​
FIGURE 4-7. ROTATOR ASSEMBLY (400SC)​
FIGURE 4-8. ROTATOR ASSEMBLY (460SJC)​
FIGURE 4-9. BOOM REST INSTALLATION​
FIGURE 4-10. CAPACITY SWITCH INSTALLATION​
FIGURE 4-11. PLATFORM SUPPORT INSTALLATION​
FIGURE 4-12. POWER TRACK INSTALLATION​
FIGURE 4-13. TRANSPORT SWITCHES INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.5M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-4. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.5M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPGATE​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-14. CONSOLE BOX INSTALLATION​
FIGURE 5-15. CONSOLE BOX ASSEMBLY​
FIGURE 5-16. FOOTSWITCH ASSEMBLY​
FIGURE 5-17. LIGHT PANEL INSTALLATION​
FIGURE 5-18. SOFT TOUCH INSTALLATION - 36IN X 8FT (91.5CM X 2.44M) PLATFORM (OPTIONAL)​
FIGURE 5-19. SKYGUARD SYSTEM INSTALLATION​
FIGURE 5-20. SKYGLAZIER INSTALLATION​
FIGURE 5-21. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-22. SKYWELDER INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)​
FIGURE 5-23. SKYWELDER PREP PACKAGE (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)​
FIGURE 5-24. WELDER ASSEMBLY​
FIGURE 5-25. SKYEYE INSTALLATION​
FIGURE 5-26. SKYLINE INSTALLATION​
FIGURE 5-27. SKYSENSE MID TUBE SENSOR ASSEMBLY​
FIGURE 5-28. SKYSENSE OVERHEAD SENSOR ASSEMBLY​
FIGURE 5-29. TRAY INSTALLATION​
FIGURE 5-30. USB CHARGER INSTALLATION​
SECTION 6 - CYLINDER
FIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 6-2. LIFT CYLINDER ASSEMBLY - MAIN BOOM​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (460SJC)​
FIGURE 6-4. MASTER CYLINDER ASSEMBLY​
FIGURE 6-5. TELESCOPE CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM (400SC)​
FIGURE 7-2. HYDRAULIC DIAGRAM (460SJC)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT, AND CSA SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-3. AC BOX AT PLATFORM - 110V IEC YELLOW (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-5. AC BOX AT PLATFORM - 220V IEC BLUE (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-6. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM - 220V AFSINT107 (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT AND CE & UK CA SPECS)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT & CSA SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ANSI, ANSI EXPORT & CSA SPECS)​
FIGURE 8-15. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE & UK CA SPECS)​
FIGURE 8-16. BATTERY DISCONNECT SWITCH​
FIGURE 8-17. BEACON HARNESS - AMBER BEACON​
FIGURE 8-18. BEACON HARNESS - BLUE & RED BEACONS​
FIGURE 8-19. BOOM HARNESS (400SC)​
FIGURE 8-20. BOOM HARNESS (460SJC)​
FIGURE 8-21. BOOM CAPACITY PROXIMITY SWITCH HARNESS​
FIGURE 8-22. BOOM TELE IN PROXIMITY SWITCH HARNESS​
FIGURE 8-23. BREAKER BOX INSTALLATION - 16AMP BREAKER (CE & UK CA SPEC)​
FIGURE 8-24. BREAKER BOX KIT - 16AMP BREAKER​
FIGURE 8-25. BREAKER BOX KIT - 30MA/16 AMP​
FIGURE 8-26. BREAKER BOX KIT WITH THREE BREAKERS​
FIGURE 8-27. CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (400SC)​
FIGURE 8-28. CABLES AND CLAMPS INSTALLATION - WITH 4000W-50HZ GENERATOR (400SC)​
FIGURE 8-29. CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR (400SC)​
FIGURE 8-30. CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (400SC)​
FIGURE 8-31. CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (460SJC)​
FIGURE 8-32. CABLES AND CLAMPS INSTALLATION - WITH 4000W GENERATOR 50HZ (460SJC)​
FIGURE 8-33. CABLES AND CLAMPS INSTALLATION - WITH 4000W GENERATOR 60HZ (460SJC)​
FIGURE 8-34. CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (460SJC)​
FIGURE 8-35. CLEARSKY 3-WIRE TELEMATICS INSTALLATION​
FIGURE 8-36. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE, JAPANESE & UK CA SPECS)​
FIGURE 8-37. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION​
FIGURE 8-38. CLEARSKY CS550 BEACON INSTALLATION (WITH METAL HOOD)​
FIGURE 8-39. CLEARSKY CS550 BEACON INSTALLATION (WITH PLASTIC HOOD)​
FIGURE 8-40. CLEARSKY HARNESS - 3-WIRE TELEMATICS​
FIGURE 8-41. CLEARSKY HARNESS - CANBUS TELEMATICS​
FIGURE 8-42. ENGINE HARNESS - DEUTZ D2011​
FIGURE 8-43. ENGINE HARNESS - DEUTZ D2.9L4​
FIGURE 8-44. ENGINE HARNESS - DEUTZ D2.9L4 (STAGE V) ENGINE​
FIGURE 8-45. FUEL HARNESS - DEUTZ D2.9L4 ENGINE​
FIGURE 8-46. GROUND CONTROL BOX HARNESS​
FIGURE 8-47. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-48. GENERATOR HARNESS - 2500W GENERATOR (60HZ)​
FIGURE 8-49. INTERFACE HARNESS - WITH 1 CELL LSS​
FIGURE 8-50. LEFT DRIVE HARNESS​
FIGURE 8-51. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-52. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-53. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-54. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN (CE & UK CA SPEC)​
FIGURE 8-55. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN (CE & UK CA SPEC)​
FIGURE 8-56. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-57. TURNTABLE HARNESS​
FIGURE 8-58. VALVE HARNESS - MAIN VALVE​
FIGURE 8-59. SKYLINE HARNESS​
FIGURE 8-60. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-61. SKYEYE RECEIVER HARNESS​
FIGURE 8-62. SKYEYE EMITTER HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (400SC)​
FIGURE 9-2. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (460SJC)​
FIGURE 9-3. DECAL INSTALLATION - CE & UK CA SPEC (400SC)​
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC (460SJC)​
FIGURE 9-5. DECAL INSTALLATION - CSA SPEC (400SC)​
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (460SJC)​
FIGURE 9-7. DECAL INSTALLATION - ANSI EXPORT (JAPANESE SPECS) (400SC)​
FIGURE 9-8. DECAL INSTALLATION - ANSI EXPORT (JAPANESE SPECS) (460SJC)​
FIGURE 9-9. DECAL INSTALLATION - ANSI EXPORT SPEC (KOREAN SPECS) (400SC)​
FIGURE 9-10. DECAL INSTALLATION - ANSI EXPORT SPEC (KOREAN SPECS) (460SJC)​
FIGURE 9-11. DECAL INSTALLATION - OPTIONS​
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 50HZ (ANSI EXPORT SPECS)​
FIGURE 9-13. SKYWELDER DECAL INSTALLATION - 60HZ (ANSI EXPORT SPECS)​
SECTION 11 - SPECIAL OPTIONS
PART NUMBER INDEX
