JLG Boom Lift 400SC 460SJC Parts Catalog 31220370
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 400SC 460SJC Boom Lift
Part Number: 31220370
Publication Date: 2025
Number of Pages: 604 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. UNDERCARRIAGE ASSEMBLY - WITH RUBBER TRACKS
FIGURE 1-2. UNDERCARRIAGE ASSEMBLY - WITH RUBBER TRACKS (NON-MARKING TRACKS)
FIGURE 1-3. FRAME UNDERCARRIAGE STEEL TRACKS WITH PADS
FIGURE 1-4. UNDERCARRIAGE ASSEMBLY - WITH STEEL TRACKS
FIGURE 1-5. TRACK ASSEMBLY - STEEL
FIGURE 1-6. DRIVE HUB ASSEMBLY
FIGURE 1-7. DRIVE MOTOR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION (400SC)
FIGURE 2-2. CONTROL VALVES INSTALLATION (460SJC)
FIGURE 2-3. MAIN VALVE ASSEMBLY (400SC)
FIGURE 2-4. MAIN VALVE ASSEMBLY (460SJC)
FIGURE 2-5. AXLE VALVE ASSEMBLY
FIGURE 2-6. AUXILIARY PUMP AND BATTERY INSTALLATION (WITHOUT DISCONNECT)
FIGURE 2-7. AUXILIARY PUMP AND BATTERY INSTALLATION (WITH DISCONNECT)
FIGURE 2-8. AUXILIARY PUMP ASSEMBLY
FIGURE 2-9. SWING DRIVE INSTALLATION
FIGURE 2-10. SWING HUB/MOTOR ASSEMBLY
FIGURE 2-11. TURNTABLE BEARING INSTALLATION
FIGURE 2-12. BEARING LUBE INSTALLATION
FIGURE 2-13. TURNTABLE COVERS INSTALLATION
FIGURE 2-14. TURNTABLE LOCK INSTALLATION
FIGURE 2-15. ROTARY COUPLING INSTALLATION
FIGURE 2-16. TANKS INSTALLATION
FIGURE 2-17. ELECTRICAL INSTALLATION (400SC)
FIGURE 2-18. ELECTRICAL INSTALLATION - WITH DEUTZ (STAGE V) ENGINE (400SC)
FIGURE 2-19. ELECTRICAL INSTALLATION (460SJC)
FIGURE 2-20. ELECTRICAL INSTALLATION - WITH DEUTZ (STAGE V) ENGINE (460SJC)
FIGURE 2-21. ELECTRICAL PANEL ASSEMBLY
FIGURE 2-22. GROUND CONTROL ASSEMBLY (400SC)
FIGURE 2-23. GROUND CONTROL ASSEMBLY - WITH DEUTZ (STAGE V) ENGINE (400SC)
FIGURE 2-24. GROUND CONTROL ASSEMBLY (460SJC)
FIGURE 2-25. GROUND CONTROL ASSEMBLY - WITH DEUTZ (STAGE V) ENGINE (460SJC)
FIGURE 2-26. KEYSWITCH AND PANEL DECAL INSTALLATION (400SC)
FIGURE 2-27. KEYSWITCH AND PANEL DECAL INSTALLATION (CE & UK CA (LRC) SPEC) (400SC)
FIGURE 2-28. KEYSWITCH AND PANEL DECAL INSTALLATION - WITH DEUTZ D2.9L4 (STAGE V) ENGINES (CE & UK CA SPEC) (400SC)
FIGURE 2-29. KEYSWITCH AND PANEL DECAL INSTALLATION (460SJC)
FIGURE 2-30. KEYSWITCH AND PANEL DECAL INSTALLATION (CE & UK CA (LRC) SPEC) (460SJC)
FIGURE 2-31. KEYSWITCH AND PANEL DECAL INSTALLATION - WITH DEUTZ D2.9L4 (STAGE V) ENGINES (CE & UK CA SPEC) (460SJC)
FIGURE 2-32. LIGHT PANEL INSTALLATION
FIGURE 2-33. GROUND CONTROL PANEL MOUNTING (400SC)
FIGURE 2-34. GROUND CONTROL PANEL MOUNTING (460SJC)
FIGURE 2-35. GROUND CONTROL PANEL MOUNTING - WITH DEUTZ (STAGE V) ENGINE
FIGURE 2-36. WHITE NOISE ALARM (AMBIENT) INSTALLATION
FIGURE 2-37. WHITE NOISE ALARM (CONSTANT) INSTALLATION
FIGURE 2-38. BEACON LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON) (Prior to SN 0300297738)
FIGURE 2-39. BEACON LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON) (SN 0300297738 to Present)
FIGURE 2-40. BEACON LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON)
FIGURE 2-41. BEACON LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON)
FIGURE 2-42. HOOD INSTALLATION (ABS) (Prior to SN 0300297738)
FIGURE 2-43. HOOD INSTALLATION (ABS) (SN 0300297738 to Present)
FIGURE 2-44. HOOD INSTALLATION (STEEL) (Prior to SN 0300297738)
FIGURE 2-45. HOOD INSTALLATION (STEEL) (SN 0300297738 to Present)
FIGURE 2-46. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-47. HOOD ASSEMBLY - ENGINE SIDE (STEEL)
FIGURE 2-48. HOOD ASSEMBLY - TANK SIDE (ABS) (Prior to SN 0300297738)
FIGURE 2-49. ABS HOOD ASSEMBLY - TANK SIDE (SN 0300297738 to Present)
FIGURE 2-50. HOOD ASSEMBLY - TANK SIDE (STEEL) (Prior to SN 0300297738)
FIGURE 2-51. STEEL HOOD ASSEMBLY - TANK SIDE (SN 0300297738 to Present)
FIGURE 2-52. SOUND REDUCTION INSTALLATION - WITH STEEL HOODS (OPTIONAL)
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION (DEUTZ D2011) (ANSI EXPORT SPECS)
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY (DEUTZ D2011) (ANSI EXPORT SPECS)
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (ANSI EXPORT SPECS)
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPECS)
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPECS)
FIGURE 3-6. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT SPEC)
FIGURE 3-7. ENGINE COMPONENTS - DEUTZ D2011 (ANSI EXPORT SPECS)
FIGURE 3-8. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, CSA AND ANSI EXPORT SPECS)
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-10. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-11. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-13. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-14. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-15. ENGINE INSTALLATION - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)
FIGURE 3-16. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)
FIGURE 3-17. ENGINE ASSEMBLY - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)
FIGURE 3-18. ENGINE COMPONENTS - DEUTZ D2.9L4 (STAGE V) ENGINE (WITHOUT ARCTIC PACKAGE) (CE & UK CA SPECS)
FIGURE 3-19. MOTOR MOUNT INSTALLATION - STAGE V ENGINE (WITHOUT GENERATOR)
FIGURE 3-20. MOTOR MOUNT INSTALLATION - STAGE V ENGINE (WITH GENERATOR)
FIGURE 3-21. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)
FIGURE 3-22. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 (STAGE V) ENGINE)
FIGURE 3-23. GEAR PUMP ASSEMBLY
FIGURE 3-24. PISTON PUMP ASSEMBLY (FRONT)
FIGURE 3-25. PISTON PUMP ASSEMBLY (REAR)
FIGURE 3-26. PUMP COUPLING KIT
FIGURE 3-27. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE
FIGURE 3-28. ENGINE BAFFLE INSTALLATION
FIGURE 3-29. ENGINE BAFFLE INSTALLATION - STEEL
FIGURE 3-30. ENGINE TRAY JACK
FIGURE 3-31. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPEC)
FIGURE 3-32. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)
FIGURE 3-33. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPEC)
FIGURE 3-34. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT, CE & UK CA (LRC) SPECS)
FIGURE 3-35. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)
FIGURE 3-36. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ (STAGE V) ENGINE) (CE & UK CA SPEC)
FIGURE 3-37. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPECS)
FIGURE 3-38. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE) (ANSI EXPORT SPECS)
FIGURE 3-39. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)
FIGURE 3-40. OIL COOLER INSTALLATION - DEUTZ D2011 ENGINES (ANSI EXPORT, CE & UK CA (LRC) SPECS)
FIGURE 3-41. OIL COOLER INSTALLATION - DEUTZ D2.9L4 ENGINES/DEUTZ D2.9L4 (STAGE V) ENGINES (ANSI, ANSI EXPORT, CE, CSA, JAPAN & UK CA SPECS)
FIGURE 3-42. SPARK ARRESTOR INSTALLATION - ANSI EXPORT SPECS
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (400SC)
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (460SJC)
FIGURE 4-3. MAIN BOOM ASSEMBLY (400SC)
FIGURE 4-4. MAIN BOOM ASSEMBLY (460SJC)
FIGURE 4-5. JIB BOOM ASSEMBLY (460SJC)
FIGURE 4-6. ROTATOR ASSEMBLY (400SC)
FIGURE 4-7. ROTATOR ASSEMBLY (460SJC)
FIGURE 4-8. BOOM REST INSTALLATION
FIGURE 4-9. CAPACITY SWITCH INSTALLATION
FIGURE 4-10. PLATFORM SUPPORT INSTALLATION
FIGURE 4-11. POWER TRACK INSTALLATION
FIGURE 4-12. TRANSPORT SWITCHES INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.5M) WITH SWING GATE
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-4. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.5M) WITH DROP BAR
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPGATE
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 5-14. CONSOLE BOX INSTALLATION
FIGURE 5-15. CONSOLE BOX ASSEMBLY
FIGURE 5-16. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 5-17. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 5-18. FOOTSWITCH ASSEMBLY
FIGURE 5-19. LIGHT PANEL INSTALLATION
FIGURE 5-20. SOFT TOUCH INSTALLATION - 36IN X 8FT (91.5CM X 2.44M) PLATFORM (OPTIONAL)
FIGURE 5-21. SKYGUARD SYSTEM INSTALLATION
FIGURE 5-22. SKYGLAZIER INSTALLATION
FIGURE 5-23. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-24. SKYWELDER INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)
FIGURE 5-25. SKYWELDER PREP PACKAGE (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPAN SPECS)
FIGURE 5-26. WELDER ASSEMBLY
FIGURE 5-27. SKYEYE INSTALLATION
FIGURE 5-28. SKYLINE INSTALLATION
FIGURE 5-29. SKYSENSE MID TUBE SENSOR ASSEMBLY
FIGURE 5-30. SKYSENSE OVERHEAD SENSOR ASSEMBLY
FIGURE 5-31. TRAY INSTALLATION
FIGURE 5-32. USB CHARGER INSTALLATION
SECTION 6 - CYLINDERFIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 6-2. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (460SJC)
FIGURE 6-4. MASTER CYLINDER ASSEMBLY
FIGURE 6-5. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM (400SC)
FIGURE 7-2. HYDRAULIC DIAGRAM (460SJC)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT, AND CSA SPECS)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-3. AC BOX AT PLATFORM - 110V IEC YELLOW (CE & UK CA SPEC WITHOUT GENERATOR)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM - 220V IEC BLUE (CE & UK CA SPEC WITHOUT GENERATOR)
FIGURE 8-6. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPEC WITHOUT GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPEC WITHOUT GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM - 220V AFSINT107 (CE & UK CA SPEC WITHOUT GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT AND CE & UK CA SPECS)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT & CSA SPECS)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ANSI, ANSI EXPORT & CSA SPECS)
FIGURE 8-15. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE & UK CA SPECS)
FIGURE 8-16. BATTERY DISCONNECT SWITCH
FIGURE 8-17. BEACON HARNESS
FIGURE 8-18. BEACON HARNESS
FIGURE 8-19. BOOM HARNESS (400SC)
FIGURE 8-20. BOOM HARNESS (460SJC)
FIGURE 8-21. BOOM CAPACITY PROXIMITY SWITCH HARNESS
FIGURE 8-22. BOOM TELE IN PROXIMITY SWITCH HARNESS
FIGURE 8-23. BREAKER BOX INSTALLATION - 16AMP BREAKER (CE & UK CA SPEC)
FIGURE 8-24. BREAKER BOX KIT - 16AMP BREAKER
FIGURE 8-25. BREAKER BOX KIT - 30MA/16 AMP
FIGURE 8-26. BREAKER BOX KIT WITH THREE BREAKERS
FIGURE 8-27. CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (400SC)
FIGURE 8-28. CABLES AND CLAMPS INSTALLATION - WITH 4000W-50HZ GENERATOR (400SC)
FIGURE 8-29. CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR (400SC)
FIGURE 8-30. CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (400SC)
FIGURE 8-31. CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (460SJC)
FIGURE 8-32. CABLES AND CLAMPS INSTALLATION - WITH 4000W GENERATOR 50HZ (460SJC)
FIGURE 8-33. CABLES AND CLAMPS INSTALLATION - WITH 4000W GENERATOR 60HZ (460SJC)
FIGURE 8-34. CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (460SJC)
FIGURE 8-35. CLEARSKY 3-WIRE TELEMATICS INSTALLATION
FIGURE 8-36. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE, JAPANESE & UK CA SPECS)
FIGURE 8-37. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION
FIGURE 8-38. CLEARSKY CS550 BEACON INSTALLATION (WITH METAL HOOD)
FIGURE 8-39. CLEARSKY CS550 BEACON INSTALLATION (WITH PLASTIC HOOD)
FIGURE 8-40. CLEARSKY HARNESS - 3-WIRE TELEMATICS
FIGURE 8-41. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-42. ENGINE HARNESS - DEUTZ D2011
FIGURE 8-43. ENGINE HARNESS - DEUTZ D2.9L4
FIGURE 8-44. ENGINE HARNESS - DEUTZ D2.9L4 (STAGE V) ENGINE
FIGURE 8-45. FUEL HARNESS - DEUTZ D2.9L4 ENGINE
FIGURE 8-46. GROUND CONTROL BOX HARNESS
FIGURE 8-47. GENERATOR HARNESS - 4000W GENERATOR
FIGURE 8-48. GENERATOR HARNESS - 2500W GENERATOR (60HZ)
FIGURE 8-49. INTERFACE HARNESS - WITH 1 CELL LSS
FIGURE 8-50. LEFT DRIVE HARNESS
FIGURE 8-51. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-52. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-53. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-54. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN (CE & UK CA SPEC)
FIGURE 8-55. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN (CE & UK CA SPEC)
FIGURE 8-56. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-57. TURNTABLE HARNESS
FIGURE 8-58. VALVE HARNESS - MAIN VALVE
FIGURE 8-59. SKYLINE HARNESS
FIGURE 8-60. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-61. SKYEYE RECEIVER HARNESS
FIGURE 8-62. SKYEYE EMITTER HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (400SC)
FIGURE 9-2. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (460SJC)
FIGURE 9-3. DECAL INSTALLATION - CE & UK CA SPEC (400SC)
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC (460SJC)
FIGURE 9-5. DECAL INSTALLATION - CSA SPEC (400SC)
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (460SJC)
FIGURE 9-7. DECAL INSTALLATION - ANSI EXPORT (JAPANESE SPECS) (400SC)
FIGURE 9-8. DECAL INSTALLATION - ANSI EXPORT (JAPANESE SPECS) (460SJC)
FIGURE 9-9. DECAL INSTALLATION - ANSI EXPORT SPEC (KOREAN SPECS) (400SC)
FIGURE 9-10. DECAL INSTALLATION - ANSI EXPORT SPEC (KOREAN SPECS) (460SJC)
FIGURE 9-11. DECAL INSTALLATION - OPTIONS
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 50HZ (ANSI EXPORT SPECS)
FIGURE 9-13. SKYWELDER DECAL INSTALLATION - 60HZ (ANSI EXPORT SPECS)
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
