JLG Boom Lift 400S HC3 460SJ HC3 Parts Catalog 3122322500
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 400S HC3, 460SJ HC3 Boom Lift
Part Number: 3122322500
Publication Date: 2025
Number of Pages: 722 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION
FIGURE 1-2. STEER INSTALLATION - WITHOUT TOW PACKAGE (400S HC3)
FIGURE 1-3. STEER INSTALLATION - WITHOUT TOW PACKAGE (460SJ HC3)
FIGURE 1-4. STEER INSTALLATION - WITH TOW PACKAGE (400S HC3)
FIGURE 1-5. STEER INSTALLATION - WITH TOW PACKAGE (460SJ HC3)
FIGURE 1-6. WHEEL DRIVE AND FRAME VALVES INSTALLATION (400S HC3)
FIGURE 1-7. WHEEL DRIVE AND FRAME VALVES INSTALLATION (460SJ HC3)
FIGURE 1-8. DRIVE HUB ASSEMBLY - FRONT (400S HC3)
FIGURE 1-9. DRIVE HUB/BRAKE ASSEMBLY - REAR (400S HC3)
FIGURE 1-10. DRIVE HUB/BRAKE ASSEMBLY - REAR (460SJ HC3)
FIGURE 1-11. DRIVE MOTOR ASSEMBLY (400S HC3)
FIGURE 1-12. DRIVE MOTOR ASSEMBLY (460SJ HC3)
FIGURE 1-13. TRACTION VALVE ASSEMBLY
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - 14 X 176.5 FOAM FILLED
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (400S HC3)
FIGURE 1-16. TIRE AND WHEEL INSTALLATION - 33 X 12D610 FOAM-FILLED (460SJ HC3)
FIGURE 1-17. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FF NON-MARKING (400S HC3)
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - 14 X 17.5 FF NON-MARKING
FIGURE 1-19. TIRE AND WHEEL INSTALLATION - TURF
FIGURE 1-20. LP TANK BRACKETS INSTALLATIONS
FIGURE 1-21. FRAME SHIELDS INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-22. FRAME SHIELDS INSTALLATION - WITH TOW PACKAGE
FIGURE 1-23. TOW PACKAGE INSTALLATION
FIGURE 1-24. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION (400S HC3)
FIGURE 2-2. CONTROL VALVES INSTALLATION (460SJ HC3)
FIGURE 2-3. CONTROL VALVE ASSEMBLY (400S HC3)
FIGURE 2-4. CONTROL VALVE ASSEMBLY (460SJ HC3)
FIGURE 2-5. AXLE CONTROL VALVE ASSEMBLY
FIGURE 2-6. SWING DRIVE INSTALLATION
FIGURE 2-7. SWING DRIVE MOTOR/HUB ASSEMBLY
FIGURE 2-8. TURNTABLE BEARING INSTALLATION
FIGURE 2-9. BEARING LUBE INSTALLATION
FIGURE 2-10. TURNTABLE LOCK INSTALLATION
FIGURE 2-11. ROTARY COUPLING INSTALLATION
FIGURE 2-12. TANK INSTALLATION - DIESEL ENGINES (17.3 GAL)
FIGURE 2-13. TANK INSTALLATION - GAS ENGINES (17.3 GAL)
FIGURE 2-14. HYDRAULIC TANK ASSEMBLYENGINES (17.3 GAL)
FIGURE 2-15. AUXILIARY POWER INSTALLATION - WITHOUT BATTERY DISCONNECT
FIGURE 2-16. AUXILIARY POWER INSTALLATION - WITH BATTERY DISCONNECT
FIGURE 2-17. AUXILIARY POWER PUMP/MOTOR ASSEMBLY
FIGURE 2-18. ELECTRICAL INSTALLATION (400S HC3)
FIGURE 2-19. ELECTRICAL INSTALLATION (460SJ HC3)
FIGURE 2-20. ELECTRICAL INSTALLATION (WITH DEUTZ D2.9L4 (STAGE V) ENGINES) (460SJ HC3)
FIGURE 2-21. ELECTRICAL PANEL ASSEMBLY
FIGURE 2-22. GROUND CONTROL BOX ASSEMBLY (400S HC3)
FIGURE 2-23. GROUND CONTROL BOX ASSEMBLY (460SJ HC3)
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY (WITH DEUTZ D2.9L4 (STAGE V) ENGINES) (CE SPECS) (460SJ HC3)
FIGURE 2-25. GROUND CONTROL BRACKET INSTALLATION (400S HC3)
FIGURE 2-26. GROUND CONTROL BRACKET INSTALLATION (460SJ HC3)
FIGURE 2-27. GROUND CONTROL BRACKET INSTALLATION (WITH DEUTZ D2.9L4 (STAGE V) ENGINES) (CE SPECS) (460SJ HC3)
FIGURE 2-28. KEYSWITCH AND PANEL DECAL INSTALLATION (400S HC3)
FIGURE 2-29. KEYSWITCH AND PANEL DECAL INSTALLATION (ALL SPECS EXCEPT CE & UK CA SPECS) (460SJ HC3)
FIGURE 2-30. KEYSWITCH AND PANEL DECAL INSTALLATION (CE-LRC & UK CA SPECS) (460SJ HC3)
FIGURE 2-31. KEYSWITCH AND PANEL DECAL INSTALLATION - (CE & UK CA SPECS WITH DEUTZ D2.9L4 (STAGE V) ENGINES (460SJ HC3)
FIGURE 2-32. LIGHT PANEL INSTALLATION
FIGURE 2-33. HOODS INSTALLATION - ABS (DEUTZ ENGINES)
FIGURE 2-34. HOODS INSTALLATION - ABS (KUBOTA ENGINES)
FIGURE 2-35. HOODS INSTALLATION - STEEL
FIGURE 2-36. ABS HOOD ASSEMBLY - ENGINE SIDE
FIGURE 2-37. HOOD ASSEMBLY - ENGINE SIDE (STEEL)
FIGURE 2-38. ABS HOOD ASSEMBLY - TANK SIDE
FIGURE 2-39. STEEL HOOD ASSEMBLY - TANK SIDE
FIGURE 2-40. SOUND REDUCTION INSTALLATION (STEEL HOODS)
FIGURE 2-41. TURNTABLE COVERS INSTALLATION
FIGURE 2-42. WHITE NOISE (AMBIENT) ALARM INSTALLATION
FIGURE 2-43. WHITE NOISE (CONSTANT) ALARM INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-3. DEUTZ D2011 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-4. DEUTZ D2011 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-8. ENGINE INSTALLATION - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT (HRC), CSA AND JAPANESE SPECS)
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-10. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS) (Prior to SN 0300321269)
FIGURE 3-11. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS) (SN 0300321270 to Present)
FIGURE 3-12. ENGINE INSTALLATION - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-13. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-14. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS) (Prior to SN 0300321269)
FIGURE 3-15. ENGINE ASSEMBLY - DEUTZ D2.9L4 ERM5 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS) (SN 0300321270 to Present)
FIGURE 3-16. ENGINE COMPONENTS - DEUTZ D2.9L4 ERM5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-17. DEUTZ D2.9L4 (STAGE V) ENGINE INSTALLATION
FIGURE 3-18. DEUTZ D2.9L4 (STAGE V) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-19. DEUTZ D2.9L4 (STAGE V) ENGINE ASSEMBLY (Prior to SN 0300321269)
FIGURE 3-20. DEUTZ D2.9L4 (STAGE V) ENGINE ASSEMBLY (SN 0300321270 to Present)
FIGURE 3-21. DEUTZ D2.9L4 (STAGE V) ENGINE COMPONENTS
FIGURE 3-22. DEUTZ D2.9L4 (STAGE V) ENGINE COMPONENTS
FIGURE 3-23. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-24. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ D2.9L4 (STAGE V) ENGINES)
FIGURE 3-25. QUICKFIT OIL DRAIN INSTALLATION (DEUTZ D2.9L4 ENGINES)
FIGURE 3-26. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA 2.5L DF)
FIGURE 3-27. BREATHER HEATER INST (DEUTZ D2.9L4 ENGINES)
FIGURE 3-28. ENGINE MOUNT (WITH GENERATOR) – DEUTZ D2.9L4 (STAGE V) ENGINE
FIGURE 3-29. ENGINE MOUNT (WITHOUT GENERATOR) – DEUTZ D2.9L4 (STAGE V) ENGINE
FIGURE 3-30. KUBOTA ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-31. KUBOTA ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-32. KUBOTA ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-33. KUBOTA ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-34. KUBOTA ENGINE AND PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-35. KUBOTA ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-36. KUBOTA ENGINE COMPONENTS
FIGURE 3-37. PUMP COUPING KIT (DEUTZ ENGINES)
FIGURE 3-38. PUMP COUPING KIT (KUBOTA ENGINES)
FIGURE 3-39. PISTON PUMP ASSEMBLY
FIGURE 3-40. PISTON PUMP ASSEMBLY (REAR)
FIGURE 3-41. PISTON PUMP ASSEMBLY (FRONT)
FIGURE 3-42. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 STAGE 5 ENGINES
FIGURE 3-43. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ ENGINES WITH ABS HOODS
FIGURE 3-44. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ ENGINES WITH STEEL HOODS
FIGURE 3-45. ENGINE HOOD BAFFLE INSTALLATION - KUBOTA ENGINES
FIGURE 3-46. ENGINE TRAY JACK INSTALLATION
FIGURE 3-47. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-48. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2.9L4 ENGINES
FIGURE 3-49. 2500W/110V/60HZ GENERATOR INSTALLATION - KUBOTA ENGINES
FIGURE 3-50. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-51. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-52. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2.9L4 ENGINES
FIGURE 3-53. 4000W/50HZ GENERATOR INSTALLATION (DEUTZ D2.9L4 (STAGE V) ENGINES)
FIGURE 3-54. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-55. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-56. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2.9L4 ENGINES
FIGURE 3-57. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - KUBOTA ENGINES
FIGURE 3-58. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION (DEUTZ D2.9L4 (STAGE V) ENGINES)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (400S HC3)
FIGURE 4-2. BOOM INSTALLATION (460SJ HC3)
FIGURE 4-3. MAIN BOOM ASSEMBLY (400S HC3)
FIGURE 4-4. MAIN BOOM ASSEMBLY (460SJ HC3)
FIGURE 4-5. JIB BOOM ASSEMBLY - 1K45FT (460SJ HC3)
FIGURE 4-6. PLATFORM ROTATOR ASSEMBLY (400S HC3)
FIGURE 4-7. PLATFORM ROTATOR ASSEMBLY (460SJ HC3)
FIGURE 4-8. SUPPORT, PLATFORM INSTALLATION
FIGURE 4-9. POWER TRACK INSTALLATION (400S HC3)
FIGURE 4-10. POWER TRACK INSTALLATION (460SJ HC3)
FIGURE 4-11. CAPACITY SWITCH INSTALLATION (400S HC3)
FIGURE 4-12. CAPACITY SWITCH INSTALLATION (460SJ HC3)
FIGURE 4-13. TRANSPORT POSITION SWITCH INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 3FT (76CM X .91M)
FIGURE 5-2. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 5FT (76CM X 1.52M)
FIGURE 5-3. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-4. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-5. PLATFORM ASSEMBLY WITH GATE - 30IN X 5FT (76CM X 1.52M)
FIGURE 5-6. PLATFORM ASSEMBLY WITH GATE- 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-7. PLATFORM ASSEMBLY WITH GATE - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-8. PLATFORM ASSEMBLY WITH FALL ARREST - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-9. PLATFORM ASSEMBLY WITH TRI-ENTRY (1 GATE / 2 DROP BARS) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-10. PLATFORM ASSEMBLY WITH TRI-ENTRY (1 GATE/2 DROP BARS) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-11. PLATFORM ASSEMBLY WITH TRI-ENTRY (3 DROP BARS) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-12. PLATFORM ASSEMBLY WITH TRI-ENTRY (3 DROP BARS) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-13. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH
FIGURE 5-14. FOOTSWITCH ASSEMBLY
FIGURE 5-15. LIGHT PANEL INSTALLATION
FIGURE 5-16. SKYEYE INSTALLATION
FIGURE 5-17. SKYGUARD BAR INSTALLATION
FIGURE 5-18. SKYLINE INSTALLATION
FIGURE 5-19. STORAGE TRAY INSTALLATION - CENTER
FIGURE 5-20. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-21. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-22. WELDER ASSEMBLY
FIGURE 5-23. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-24. SKYGLAZIER INSTALLATION (ANSI, ANSI EXPORT, CE & CSA SPECS/460SJ HC3 ANSI, AUSTRALIAN & CSA SPECS) (400S HC3)
FIGURE 5-25. PLATFORM POWER - USB
FIGURE 5-26. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM (MACHINES WITH SN STARTING WITH 03 ONLY)
FIGURE 5-27. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM (MACHINES WITH SN STARTING WITH 03 ONLY
FIGURE 5-28. FALL ARREST (BOLT-ON) INSTALLATION - 30IN PLATFORM
FIGURE 5-29. FALL ARREST (BOLT-ON) INSTALLATION - 72IN STANDARD PLATFORM
FIGURE 5-30. FALL ARREST (BOLT-ON) INSTALLATION - 72IN TRI-ENTRY PLATFORM
FIGURE 5-31. FALL ARREST (BOLT-ON) INSTALLATION - 96IN PLATFORM
FIGURE 6-2. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (400S HC3)
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (460SJ HC3)
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (460SJ HC3)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - BOOM (400S HC3)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - BOOM (460SJ HC3)
FIGURE 6-7. MASTER CYLINDER ASSEMBLY (400S HC3)
FIGURE 6-8. MASTER CYLINDER ASSEMBLY (460SJ HC3)
FIGURE 6-9. STEER CYLINDER ASSEMBLY
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY (400S HC3)
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY (460SJ HC3)
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM (400S HC3)
FIGURE 7-2. HYDRAULIC DIAGRAM (460SJ HC3) (Prior to SN 0300322720)
FIGURE 7-3. HYDRAULIC DIAGRAM (460SJ HC3) (SN 0300322721 to Present)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (MACHINES WITH 2500W GENERATOR/NO GENERATOR OPTIONS) (ANSI AND CSA SPECS)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - CUSTOMER SUPPLIED RECEPTACLE (ANSI EXPORT, CE, CHINA & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (2500W AND 7500W SKYPOWER GENERATORS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (2500W AND 7500W SKYPOWER GENERATORS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (WITHOUT GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (WITHOUT GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS) (WITHOUT GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI, ANSI EXPORT AND CSA SPECS WITH 4000W SKYPOWER GENERATOR)
FIGURE 8-14. BATTERY DISCONNECT INSTALLATION
FIGURE 8-15. BOOM HARNESS (400S HC3)
FIGURE 8-16. BOOM HARNESS (460SJ HC3)
FIGURE 8-17. BREAKER BOX INSTALLATION - 110V/220V WITH 1 BREAKER (CE & UK CA SPECS)
FIGURE 8-18. BREAKER BOX INSTALLATION - 110V/220V WITH 3 BREAKERS (CE & UK CA SPECS)
FIGURE 8-19. BREAKER BOX KIT - 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 8-20. BREAKER BOX KIT - 1 BREAKER (CE & UK CA SPECS)
FIGURE 8-21. BREAKER BOX KIT - 3 BREAKERS (CE & UK CA SPECS)
FIGURE 8-22. CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR (400S HC3)
FIGURE 8-23. CABLES AND CLAMPS INSTALLATION -WITH 4000W/50HZ GENERATOR (400S HC3)
FIGURE 8-24. CABLES AND CLAMPS INSTALLATION -WITH 4000W/60HZ GENERATOR (400S HC3)
FIGURE 8-25. CABLES AND CLAMPS INSTALLATION -WITH 7500W GENERATOR (400S HC3)
FIGURE 8-26. CABLES AND CLAMPS INSTALLATION - 460SJ HC3 WITH 2500W GENERATOR OR NO GENERATOR
FIGURE 8-27. CABLES AND CLAMPS INSTALLATION - 460SJ HC3 WITH 4000W/50HZ GENERATOR
FIGURE 8-28. CABLES AND CLAMPS INSTALLATION - 460SJ HC3 WITH 4000W/60HZ GENERATOR
FIGURE 8-29. CABLES AND CLAMPS INSTALLATION - 460SJ HC3 WITH 7500W GENERATOR
FIGURE 8-30. CAPACITY SWITCH HARNESS (400S HC3)
FIGURE 8-31. CAPACITY SWITCH HARNESS (460SJ HC3)
FIGURE 8-32. CLEARSKY CS550 BEACON INSTALLATION (WITH METAL HOOD)
FIGURE 8-33. CLEARSKY CS550 BEACON INSTALLATION (WITH PLASTIC HOOD)
FIGURE 8-34. ENGINE HARNESS ASSEMBLY (DEUTZ D2011)
FIGURE 8-35. ENGINE HARNESS - DEUTZ D2.9L4
FIGURE 8-36. ENGINE HARNESS - DEUTZ D2.9L4 (STAGE V) ENGINE
FIGURE 8-37. ENGINE HARNESS ASSEMBLY (KUBOTA)
FIGURE 8-38. FUEL HARNESS (DEUTZ D2.9L4 ENGINES)
FIGURE 8-39. FUEL HARNESS - DEUTZ D2.9L4 (STAGE V) ENGINE
FIGURE 8-40. FUEL HARNESS (KUBOTA ENGINES)
FIGURE 8-41. GENERATOR HARNESS - 2500W GENERATOR
FIGURE 8-42. GENERATOR HARNESS - 4000W GENERATOR (CONTROL BOX TO GENERATOR) (DEUTZ ENGINES)
FIGURE 8-43. GENERATOR HARNESS - 7500W GENERATOR (CONTROL BOX TO GENERATOR)
FIGURE 8-44. GROUND CONTROL BOX HARNESS
FIGURE 8-45. HIGH CAPACITY HARNESS (460SJ HC3)
FIGURE 8-46. HOUR METER JUMPER HARNESS
FIGURE 8-47. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-48. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-49. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-50. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-51. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-52. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-53. RECEPTACLE/BREAKER BOX ASSEMBLY - 240V (4000W AND 7500W SKYPOWER GENERATORS) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 8-54. SKYEYE EMITTER HARNESS
FIGURE 8-55. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-56. SKYEYE RECEIVER HARNESS
FIGURE 8-57. SKYGUARD HARNESS
FIGURE 8-58. SKYGUARD INTERFACE HARNESS
FIGURE 8-59. SKYLINE HARNESS
FIGURE 8-60. STROBE LIGHT HARNESS AMBER STROBE LIGHT)
FIGURE 8-61. STROBE LIGHT HARNESS (BLUE AND RED STROBE LIGHTS)
FIGURE 8-62. TELESCOPE IN PROXIMITY SENSORS HARNESS (400S HC3)
FIGURE 8-63. TELESCOPE IN PROXIMITY SENSORS HARNESS (460SJ HC3)
FIGURE 8-64. TELESCOPE OUT PROXIMITY SENSORS HARNESS
FIGURE 8-65. TURNTABLE HARNESS
FIGURE 8-66. VALVE HARNESS - MAIN VALVE
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS (DIESEL MACHINES)
FIGURE 9-2. DECAL INSTALLATION - ANSI SPECS (GAS MACHINES)
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPECS
FIGURE 9-4. DECAL INSTALLATION - BRAZIL SPECS
FIGURE 9-5. DECAL INSTALLATION - CE SPECS
FIGURE 9-6. DECAL INSTALLATION - CHINESE SPECS
FIGURE 9-7. DECAL INSTALLATION - CSA SPECS (DIESEL MACHINES)
FIGURE 9-8. DECAL INSTALLATION - CSA SPECS (GAS MACHINES)
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPECS
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPECS
FIGURE 9-11. DECAL INSTALLATION - LATIN AMERICAN SPECS
FIGURE 9-12. DECAL INSTALLATION - OPTIONS
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (50HZ)
FIGURE 9-14. DECAL INSTALLATION - SKYWELDER (60HZ)
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
