Hyundai
86
176,834
JLG Boom Lift 400S 460SJ Parts Manual 31221351
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 400S 460SJ Boom Lift
Part Number: 31221351
Publication Date: 2024
Number of Pages: 786 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION​
FIGURE 1-2. STEER INSTALLATION WITHOUT TOW PACKAGE​
FIGURE 1-3. STEER INSTALLATION WITH TOW PACKAGE​
FIGURE 1-4. WHEEL DRIVE INSTALLATION (2WD)​
FIGURE 1-5. WHEEL DRIVE INSTALLATION (4WD)​
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR​
FIGURE 1-7. DRIVE HUB ASSEMBLY - FRONT​
FIGURE 1-8. HUB - SPINDLE ASSEMBLY (2WD)​
FIGURE 1-9. DRIVE MOTOR ASSEMBLY (2WD)​
FIGURE 1-10. DRIVE MOTOR ASSEMBLY (4WD)​
FIGURE 1-11. TRACTION VALVE ASSEMBLY (2WD)​
FIGURE 1-12. TRACTION VALVE ASSEMBLY (4WD)​
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (ALL SPECS)​
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM-FILLED NON-MARKING (ALL SPECS)​
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - 14 X 17.5 FOAM FILLED (ALL SPECS)​
FIGURE 1-16. TIRE AND WHEEL INSTALLATION - 14 X 17.5 FOAM FILLED NON-MARKING (ALL SPECS)​
FIGURE 1-17. TIRE AND WHEEL INSTALLATION - 33/16LL X 16.1 FOAM FILLED TURF (ANSI AND ANSI EXPORT SPECS)​
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - 33 X 12 FOAM FILLED (ALL SPECS)​
FIGURE 1-19. TOW BAR INSTALLATION​
FIGURE 1-20. TOW BAR ASSEMBLY​
FIGURE 1-21. FRAME SHIELD INSTALLATION - WITHOUT TOW BAR​
FIGURE 1-22. FRAME SHIELD INSTALLATION - WITH TOW BAR​
FIGURE 1-23. LP TANK BRACKETS INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATION (400S)​
FIGURE 2-2. CONTROL VALVES INSTALLATION (460SJ)​
FIGURE 2-3. CONTROL VALVES INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 2-4. MAIN VALVE ASSEMBLY (400S)​
FIGURE 2-5. MAIN VALVE ASSEMBLY (460SJ)​
FIGURE 2-6. MAIN VALVE ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 2-7. AXLE VALVE ASSEMBLY​
FIGURE 2-8. AUXILIARY PUMP AND BATTERY WITH DISCONNECT SWITCH INSTALLATION​
FIGURE 2-9. AUXILIARY PUMP AND BATTERY INSTALLATION​
FIGURE 2-10. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-11. ROTARY COUPLING INSTALLATION​
FIGURE 2-12. SWING DRIVE INSTALLATION​
FIGURE 2-13. SWING HUB/MOTOR ASSEMBLY​
FIGURE 2-14. TURNTABLE BEARING INSTALLATION​
FIGURE 2-15. BEARING LUBE INSTALLATION​
FIGURE 2-16. TURNTABLE LOCK INSTALLATION​
FIGURE 2-17. TURNTABLE COVERS INSTALLATION​
FIGURE 2-18. TANKS INSTALLATION - DIESEL MACHINES​
FIGURE 2-19. TANKS INSTALLATION - GAS MACHINES​
FIGURE 2-20. HYDRAULIC TANK ASSEMBLY​
FIGURE 2-21. ELECTRICAL INSTALLATION (400S)​
FIGURE 2-22. ELECTRICAL INSTALLATION (460SJ)​
FIGURE 2-23. ELECTRICAL INSTALLATION - WITH DEUTZ (STAGE V) (460SJ)​
FIGURE 2-24. ELECTRICAL INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 2-25. ELECTRICAL PANEL ASSEMBLY​
FIGURE 2-26. GROUND CONTROL MOUNTING (400S)​
FIGURE 2-27. GROUND CONTROL MOUNTING - STANDARD & 1K45FT MACHINES (460SJ)​
FIGURE 2-28. GROUND CONTROL MOUNTING - DEUTZ (STAGE V) (CE & UK CA SPECS) (460SJ)​
FIGURE 2-29. GROUND CONTROL ASSEMBLY (400S)​
FIGURE 2-30. GROUND CONTROL ASSEMBLY - STANDARD & 1K45FT MACHINES (460SJ)​
FIGURE 2-31. GROUND CONTROL ASSEMBLY - DEUTZ (STAGE V) (CE & UK CA SPECS) (460SJ)​
FIGURE 2-32. GROUND CONTROL DECAL AND KEYSWITCH INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (400S)​
FIGURE 2-33. GROUND CONTROL DECAL AND KEYSWITCH INSTALLATION - STANDARD & 1K45FT MACHINES (ALL SPECS EXCEPT CE & UK CA SPEC) (460SJ)​
FIGURE 2-34. GROUND CONTROL DECAL AND KEYSWITCH INSTALLATION (CE(LRC) & UK CA SPEC) (460SJ)​
FIGURE 2-35. GROUND CONTROL DECAL AND KEYSWITCH INSTALLATION (STAGE V) (CE & UK CA SPECS) (460SJ)​
FIGURE 2-36. LIGHT PANEL INSTALLATION​
FIGURE 2-37. LIGHT PANEL INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 2-38. BEACON LIGHT INSTALLATION - AMBER​
FIGURE 2-39. BEACON LIGHT INSTALLATION - BLUE​
FIGURE 2-40. BEACON LIGHT INSTALLATION - RED​
FIGURE 2-41. WHITE NOISE ALARM INSTALLATION (AMBIENT)​
FIGURE 2-42. WHITE NOISE ALARM INSTALLATION (CONSTANT)​
FIGURE 2-43. HOOD INSTALLATION - ABS (DEUTZ ENGINES)​
FIGURE 2-44. HOOD INSTALLATION - ABS (KUBOTA ENGINES)​
FIGURE 2-45. HOOD INSTALLATION - STEEL​
FIGURE 2-46. ABS HOOD ASSEMBLY - ENGINE SIDE​
FIGURE 2-47. ABS HOOD ASSEMBLY - TANK SIDE​
FIGURE 2-48. STEEL HOOD ASSEMBLY - ENGINE SIDE​
FIGURE 2-49. STEEL HOOD ASSEMBLY - TANK SIDE​
FIGURE 2-50. SOUND REDUCTION INSTALLATION - KUBOTA ENGINE MACHINES WITH STEEL HOODS​
FIGURE 2-51. HOOD PLUGS INSTALLATION (HOODS WITHOUT STROBE LIGHT)​
SECTION 3 - ENGINE
FIGURE 3-1. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT(LRC), AUSTRALIAN, CE(LRC), CHINA & UK CA SPECS)​
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITHOUT ARCTIC PACKAGE) (AUSTRALIAN AND CHINA SPECS)​
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (AUSTRALIAN AND CHINA SPECS)​
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT(LRC), AUSTRALIAN, CE(LRC), CHINA & UK CA SPECS)​
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITH ARCTIC PACKAGE) (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-6. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-7. ENGINE COMPONENTS - DEUTZ D2011​
FIGURE 3-8. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT(HRC), CSA AND JAPANESE SPECS)​
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-10. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-11. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)​
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-13. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-14. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-15. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)​
FIGURE 3-16. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)​
FIGURE 3-17. ENGINE ASSEMBLY – DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)​
FIGURE 3-18. ENGINE ASSEMBLY – DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)​
FIGURE 3-19. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)​
FIGURE 3-20. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE​
FIGURE 3-21. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-22. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE) (STAGE V)​
FIGURE 3-23. PUMP COUPLING KIT (DEUTZ ENGINES)​
FIGURE 3-24. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (CHINA IV)​
FIGURE 3-25. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (CHINA IV)​
FIGURE 3-26. ENGINE ASSEMBLY - DEUTZ D2.9L4 (CHINA IV)​
FIGURE 3-27. ENGINE COMPONENTS - DEUTZ D2.9L4 (CHINA IV)​
FIGURE 3-28. QUICKFIT OIL DRAIN INSTALLATION (DEUTZ D2.9L4 ENGINES)​
FIGURE 3-29. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA 2.5L DF) (SN 0300305401 to Present)​
FIGURE 3-30. ENGINE INSTALLATION - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-31. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-32. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-33. ENGINE INSTALLATION - KUBOTA ENGINE (WITH ARCTIC PACKAGE)​
FIGURE 3-34. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE)​
FIGURE 3-35. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE)​
FIGURE 3-36. ENGINE COMPONENTS - KUBOTA​
FIGURE 3-37. PUMP COUPLING KIT - KUBOTA ENGINE​
FIGURE 3-38. PISTON PUMP ASSEMBLY​
FIGURE 3-39. SPARK ARRESTOR INSTALLATION - DEUTZ D2011 ENGINE​
FIGURE 3-40. ENGINE BAFFLE INSTALLATION - ABS HOODS (DEUTZ & GM ENGINES)​
FIGURE 3-41. ENGINE BAFFLE INSTALLATION - ABS HOODS (KUBOTA ENGINES)​
FIGURE 3-42. ENGINE BAFFLE INSTALLATION - STEEL HOODS​
FIGURE 3-43. FUEL/WATER SEPARATOR INSTALLATION DUETZ D2.9L4 (CHINA IV) ENGINE​
FIGURE 3-44. FUEL PUMP AND FILTER INSTALLATION DUETZ D2.9L4 (CHINA IV) ENGINE​
FIGURE 3-45. ENGINE MOUNT (WITH GENERATOR) - DEUTZ D2.9L4 AND DEUTZ D2.9L4 (STAGE V) ENGINES​
FIGURE 3-46. ENGINE MOUNT (WITHOUT GENERATOR) - DEUTZ D2.9L4, DEUTZ D2.9L4 (STAGE V) AND DEUTZ D2.9L4 (CHINA IV) ENGINES​
FIGURE 3-47. ENGINE TRAY JACK INSTALLATION​
FIGURE 3-48. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-49. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-50. GENERATOR INSTALLATION - 2500W/60HZ (KUBOTA ENGINE)​
FIGURE 3-51. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-52. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-53. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-54. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ STAGE V ENGINE)​
FIGURE 3-55. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-56. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE)​
FIGURE 3-57. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4 ENGINE)​
FIGURE 3-58. GENERATOR INSTALLATION - 7500W/60HZ (KUBOTA ENGINE)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (400S)​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (460SJ)​
FIGURE 4-3. BOOM AND CYLINDERS INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 4-4. MAIN BOOM ASSEMBLY (400S)​
FIGURE 4-5. MAIN BOOM ASSEMBLY (460SJ)​
FIGURE 4-6. MAIN BOOM ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 4-7. JIB BOOM ASSEMBLY (460SJ)​
FIGURE 4-8. JIB BOOM ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 4-9. ROTATOR ASSEMBLY (400S)​
FIGURE 4-10. ROTATOR ASSEMBLY (460SJ)​
FIGURE 4-11. ROTATOR ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 4-12. POWER TRACK INSTALLATION​
FIGURE 4-13. POWER TRACK INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 4-14. CAPACITY SWITCH INSTALLATION​
FIGURE 4-15. CAPACITY SWITCH INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 4-16. TRANSPORT SWITCHES INSTALLATION​
FIGURE 4-17. TRANSPORT SWITCHES INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 4-18. PLATFORM SUPPORT INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.52M) WITH SWING GATE​
FIGURE 5-2. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.52M) WITH DROP BAR​
FIGURE 5-5. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE AND AUSTRALIAN SPECS)​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH GATE​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (1 GATE/2 DROP BARS)​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (3 DROP BARS)​
FIGURE 5-12. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-13. PLATFORM CONSOLE BOX INSTALLATION​
FIGURE 5-14. PLATFORM CONSOLE BOX ASSEMBLY​
FIGURE 5-15. FOOTSWITCH ASSEMBLY​
FIGURE 5-16. LIGHT PANEL INSTALLATION​
FIGURE 5-17. LIGHT PANEL INSTALLATION - 1K45FT MACHINES (460SJ)​
FIGURE 5-18. FALL ARREST (BOLT-ON) INSTALLATION - 5FTX3FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-19. FALL ARREST (BOLT-ON) INSTALLATION - 6FTX3FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-20. FALL ARREST (BOLT-ON) INSTALLATION - 6FTX3FT TRI-ENTRY PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-21. FALL ARREST (BOLT-ON) INSTALLATION - 8FTX3FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 5-22. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM​
FIGURE 5-23. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM​
FIGURE 5-24. SKYGUARD BAR INSTALLATION​
FIGURE 5-25. SKYEYE INSTALLATION​
FIGURE 5-26. SKYLINE INSTALLATION​
FIGURE 5-27. SKYGLAZIER INSTALLATION​
FIGURE 5-28. SKYSENSE MID TUBE SENSOR ASSEMBLY​
FIGURE 5-29. SKYSENSE OVERHEAD SENSOR ASSEMBLY​
FIGURE 5-30. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-31. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-32. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-33. TRAY INSTALLATION​
FIGURE 5-34. USB CHARGER INSTALLATION​
FIGURE 5-35. WELDER ASSEMBLY​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 6-3. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - MAIN BOOM​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - JIB - 1K45FT MACHINES (460SJ)​
FIGURE 6-7. MASTER CYLINDER ASSEMBLY​
FIGURE 6-8. MASTER CYLINDER ASSEMBLY - 1K45FT MACHINES (460SJ)​
FIGURE 6-9. STEER CYLINDER ASSEMBLY​
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY​
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY - 1K45FT MACHINES (460SJ)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. 2WD HYDRAULIC SYSTEM INSTALLATION (400S)​
FIGURE 7-2. 4WD HYDRAULIC SYSTEM INSTALLATION (400S)​
FIGURE 7-3. 2WD HYDRAULIC SYSTEM INSTALLATION (460SJ)​
FIGURE 7-4. 4WD HYDRAULIC SYSTEM INSTALLATION (460SJ)​
FIGURE 7-5. 4WD HYDRAULIC SYSTEM INSTALLATION - 1K45FT MACHINES (460SJ)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT(HRC), CSA AND JAPANESE SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-3. AC BOX AT PLATFORM - 110V IEC YELLOW (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-5. AC BOX AT PLATFORM - 220V IEC BLUE (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-6. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM - 220V AFSINT107 (CE & UK CA SPEC WITHOUT GENERATOR)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ALL SPECS EXCEPT CSA SPECS)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT(HRC), CSA AND JAPANESE SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ANSI, ANSI EXPORT(HRC), CSA AND JAPANESE SPECS)​
FIGURE 8-15. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE & UK CA SPECS)​
FIGURE 8-16. BATTERY DISCONNECT SWITCH​
FIGURE 8-17. BEACON HARNESS (AMBER LIGHT)​
FIGURE 8-18. BEACON HARNESS (BLUE/RED BEACON LIGHT)​
FIGURE 8-19. BOOM HARNESS (400S)​
FIGURE 8-20. BOOM HARNESS - STANDARD & 1K45FT MACHINES (460SJ)​
FIGURE 8-21. BOOM CAPACITY PROXIMITY SWITCH HARNESS (400S)​
FIGURE 8-22. BOOM CAPACITY PROXIMITY SWITCH HARNESS - 1K45FT MACHINES (460SJ)​
FIGURE 8-23. BOOM HI-CAPACITY HARNESS - 1K45FT MACHINES (460SJ)​
FIGURE 8-24. BOOM TELE IN PROXIMITY SWITCH HARNESS​
FIGURE 8-25. BREAKER BOX INSTALLATION - 110/220V 16AMP BREAKER (CE & UK CA SPEC)​
FIGURE 8-26. BREAKER BOX KIT - 110/220V 16AMP BREAKER (CE & UK CA SPEC)​
FIGURE 8-27. BREAKER BOX KIT - 30MA/16 AMP​
FIGURE 8-28. BREAKER BOX KIT WITH THREE BREAKERS​
FIGURE 8-29. CABLES AND CLAMPS INSTALLATION (2500W GENERATOR OR NO GENERATOR) (400S)​
FIGURE 8-30. CABLES AND CLAMPS INSTALLATION (4000W GENERATOR 60HZ) (400S)​
FIGURE 8-31. CABLES AND CLAMPS INSTALLATION (4000W GENERATOR 50HZ) (400S)​
FIGURE 8-32. CABLES AND CLAMPS INSTALLATION (7500W GENERATOR) (400S)​
FIGURE 8-33. CABLES AND CLAMPS INSTALLATION (2500W GENERATOR OR NO GENERATOR) (460SJ)​
FIGURE 8-34. CABLES AND CLAMPS INSTALLATION (4000W GENERATOR 60HZ) (460SJ)​
FIGURE 8-35. CABLES AND CLAMPS INSTALLATION (4000W GENERATOR 50HZ) (460SJ)​
FIGURE 8-36. CABLES AND CLAMPS INSTALLATION (7500W GENERATOR) (460SJ)​
FIGURE 8-37. CABLES AND CLAMPS INSTALLATION - 1K45FT MACHINES (2500W GENERATOR OR NO GENERATOR) (460SJ)​
FIGURE 8-38. CABLES AND CLAMPS INSTALLATION - 1K45FT MACHINES (4000W GENERATOR 60HZ) (460SJ)​
FIGURE 8-39. CABLES AND CLAMPS INSTALLATION - 1K45FT MACHINES(7500W GENERATOR) (460SJ)​
FIGURE 8-40. CLEARSKY (TELEMATICS) INSTALLATION - CANBUS 4G (ALL SPECS EXCEPT CHINA SPECS)​
FIGURE 8-41. CLEARSKY (TELEMATICS) INSTALLATION - CANBUS 4G (CHINA SPECS)​
FIGURE 8-42. CLEARSKY (TELEMATICS) INSTALLATION - CANBUS 3G (ANSI EXPORT, CE, JAPANESE & UK CA SPECS)​
FIGURE 8-43. CLEARSKY (TELEMATICS) INSTALLATION - CANBUS 3G (AUSTRALIAN SPECS)​
FIGURE 8-44. CLEARSKY (TELEMATICS) INSTALLATION - 3 WIRE GT1030​
FIGURE 8-45. CLEARSKY (TELEMATICS) INSTALLATION - GT1030​
FIGURE 8-46. CLEARSKY HARNESS - CANBUS​
FIGURE 8-47. ENGINE HARNESS - DEUTZ D2011​
FIGURE 8-48. ENGINE HARNESS - DEUTZ D2.9L4​
FIGURE 8-49. ENGINE HARNESS - DEUTZ D2.9L4 (STAGE V)​
FIGURE 8-50. ENGINE HARNESS - DEUTZ D2.9L4 (CHINA IV)​
FIGURE 8-51. ENGINE HARNESS - KUBOTA​
FIGURE 8-52. FUEL HARNESS - DEUTZ D2.9L4 ENGINE​
FIGURE 8-53. FUEL HARNESS - KUBOTA ENGINE​
FIGURE 8-54. GENERATOR HARNESS - 2500W​
FIGURE 8-55. GENERATOR HARNESS - 4000W​
FIGURE 8-56. GROUND CONTROL BOX HARNESS​
FIGURE 8-57. HOUR METER JUMPER HARNESS​
FIGURE 8-58. INTERFACE HARNESS - WITH 1 CELL LSS​
FIGURE 8-59. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-60. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-61. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-62. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN (CE & UK CA SPEC)​
FIGURE 8-63. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN (CE & UK CA SPEC)​
FIGURE 8-64. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-65. TURNTABLE HARNESS​
FIGURE 8-66. VALVE HARNESS - MAIN VALVE​
FIGURE 8-67. VALVE HARNESS - MAIN VALVE - 1K45FT MACHINES (460SJ)​
FIGURE 8-68. SKYLINE HARNESS​
FIGURE 8-69. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-70. SKYEYE RECEIVER HARNESS​
FIGURE 8-71. SKYEYE EMITTER HARNESS​
SECTION 9 - DECAL
FIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CSA SPECS - ENGLISH (400S)​
FIGURE 9-2. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CSA SPECS - ENGLISH (460SJ)​
FIGURE 9-3. DECAL INSTALLATION - ANSI AND CSA SPECS - ENGLISH (1K45FT MACHINES) (460SJ)​
FIGURE 9-4. DECAL INSTALLATION - AUSTRALIAN SPEC (460SJ)​
FIGURE 9-5. DECAL INSTALLATION - CE & UK CA SPEC (460SJ)​
FIGURE 9-6. INSTALLATION - BRAZIL SPEC (DUAL LANGUAGE - PORTUGUESE/SPANISH) (400S)​
FIGURE 9-7. DECAL INSTALLATION - BRAZIL SPEC (DUAL LANGUAGE - PORTUGUESE/SPANISH) (460SJ)​
FIGURE 9-8. DECAL INSTALLATION - CHINESE SPEC (DUAL LANGUAGE - ENGLISH/CHINESE) (400S)​
FIGURE 9-9. DECAL INSTALLATION - CHINESE SPEC (DUAL LANGUAGE - ENGLISH/CHINESE) (460SJ)​
FIGURE 9-10. DECAL INSTALLATION - CSA SPEC (DUAL LANGUAGE - ENGLISH/FRENCH) (400S)​
FIGURE 9-11. DECAL INSTALLATION - CSA SPEC (DUAL LANGUAGE - ENGLISH/FRENCH) (460SJ)​
FIGURE 9-12. DECAL INSTALLATION - CSA SPEC (DUAL LANGUAGE - ENGLISH/FRENCH) (1K45FT MACHINES) (460SJ)​
FIGURE 9-13. DECAL INSTALLATION - JAPANESE SPEC (DUAL LANGUAGE - ENGLISH/JAPANESE) (400S)​
FIGURE 9-14. DECAL INSTALLATION - JAPANESE SPEC (DUAL LANGUAGE - ENGLISH/JAPANESE) (460SJ)​
FIGURE 9-15. DECAL INSTALLATION - KOREAN SPEC (DUAL LANGUAGE - ENGLISH/KOREAN) (400S)​
FIGURE 9-16. DECAL INSTALLATION - KOREAN SPEC (DUAL LANGUAGE - ENGLISH/KOREAN) (460SJ)​
FIGURE 9-17. DECAL INSTALLATION - LATIN AMERICAN SPEC (DUAL LANGUAGE - ENGLISH/SPANISH) (400S)​
FIGURE 9-18. DECAL INSTALLATION - LATIN AMERICAN SPEC (DUAL LANGUAGE - ENGLISH/SPANISH) (460SJ)​
FIGURE 9-19. DECAL INSTALLATION - OPTIONS​
FIGURE 9-20. SKYWELDER DECAL INSTALLATION - 50HZ​
FIGURE 9-21. SKYWELDER DECAL INSTALLATION - 60HZ​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
