Hyundai
86
176,834
JLG Boom Lift 340AJ Service & Maintenance Manual 3122337900 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 340AJ Boom Lift
Part Number: 3122337900
Publication Date: 2026
Number of Pages: 690 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires​
2.1.5 Critical Stability Weights​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Ground Control Keyswitch System​
2.5.2 Platform Control Enable System​
2.5.3 Cold Start System (Diesel)​
2.5.4 Fuel level Cutout System​
2.5.5 Drive System​
2.5.6 Drive Orientation System​
2.5.7 Function Speed Control System​
2.5.8 Oscillating Axle System​
2.5.9 Chassis Tilt Indicator System​
2.5.10 Platform Load Sensing System​
2.5.11 Jib Lift End Of Stroke Dampening​
2.5.12 Emergency Descent System​
2.5.13 Side Entry Platform​
2.5.14 Transport Position Sensing System​
2.5.15 Beyond Transport Position - Drive Speed Cutback System​
2.5.16 Drive/Steer - Boom Function Interlock System (UKCA/CE ONLY)​
2.5.17 MSSO​
2.5.18 Counterweight​
Clearsky Smart Fleet (If Equipped)​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Daily​
3.3.2 First 50 Hours​
3.3.3 Every 150 Hours or 3 Months​
3.3.4 First 300 Hours or 6 Months​
3.3.5 Every 500 hours or 6 months​
3.3.6 Every 600 Hours or 1 Year​
3.3.7 Every 1000 Hours or 1 Year​
3.3.8 Every 1200 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Boom Cleanliness Guidelines​
3.7.2 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
3.9.2 Wear Tolerance​
3.9.3 Swing Bearing Torque Value​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Glow Plugs (Kubota Engine)​
3.10.3 Engine Oil Pressure Switch​
3.10.4 Engine Speed Sensor​
3.10.5 Coolant Sensor​
3.10.6 Engine Speed Actuators​
3.10.7 Engine Start​
3.10.8 Alternator Excitation​
3.10.9 Fuel Pump​
3.10.10 Shutdown​
3.10.11 GM Dual Fuel Engine​
3.10.12 Replacing Engine Oil​
3.10.13 Replacing the Oil Filter​
3.10.14 Replacing the Primary Fuel Filters​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Calibrating Tilt Sensor​
Special Procedures​
4.4.1 Fuel Tank Cleaning and Drying​
4.4.2 Cylinder Drift​
4.4.3 Hydraulic Circuits​
4.4.4 Oscillating Axle Bleeding Procedure​
Wheel Drive Hub​
4.5.1 Roll, Leak and Brake Testing​
4.5.2 Tightening and Torquing Bolts​
4.5.3 Measuring Rolling Torque​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Analyzer Flow Chart​
Analyzer Software Accessibility​
5.3.1 Machine Set-Up​
5.3.2 Personalities​
Function Test​
5.4.1 Drive (Below Elevation):​
5.4.2 Drive (Above Elevation):​
5.4.3 Swing:​
5.4.4 Tower Lift:​
5.4.5 Main Lift:​
5.4.6 Telescope:​
5.4.7 Jib Lift:​
5.4.8 Platform Rotate:​
5.4.9 Test Notes​
5.5.1 ClearSky Smart FleetTM CS550 Configuration​
5.5.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
Machine Fault Codes​
6.3.1 Fault Code Troubleshooting​
6.3.2 ClearSky Smart Fleet DTC Fault Codes​
6.3.3 LSS Troubleshooting​
6.3.4 System Fault Messages​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Pressure Setting Procedure​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Ground Control Module Pin Connections​
8.5.2 Platform Control Module Pin Connections​
AMP Connector​
8.6.1 Applying Silicone Dielectric Compound to AMP Connectors​
8.6.2 Assembly​
8.6.3 Disassembly​
8.6.4 Wedge Lock​
8.6.5 Service - Voltage Reading​
Operator Controls and Switches​
8.7.1 Ground Control Switches​
8.7.2 Platform Control Switches​
Wiring Harness and Connector Label Diagrams​
8.8.1 Connector Labels​
8.8.2 Component Labels​
Telematics Gateway​
8.9.1 Telematics-Ready (TCU) Plug​
Electrical Installation​
Wheel and Tire​
9.1.1 Tire Replacement​
9.1.2 Wheel and Tire Replacement​
9.1.3 Removing Wheel and Tire Assembly from Machine​
9.1.4 Wheel Installation​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Axle Assembly​
9.2.3 Spindle Assembly​
9.2.4 Drive Hub and Motor​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Main Boom Assembly​
9.3.5 Jib and Rotator Assembly​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform Support (Traditional Design)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Coolant Overflow Tank (GM Engine)​
9.5.5 Overflow coolant tank (Kubota Engine)​
9.5.6 Pump Coupling Kit​
9.5.7 Air Filter Assembly​
9.5.8 Radiator Assembly​
9.5.9 Starter​
9.5.10 Alternator​
9.5.11 Fuel Tank​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Boom Lift Cylinder​
9.7.2 Main Boom Telescope Cylinder​
9.7.3 Tower Boom Lift Cylinder​
9.7.4 Master Cylinder​
9.7.5 Platform Level Cylinder​
9.7.6 Articulating Jib and Jib Lift Cylinder​
9.7.7 Steer Cylinder​
9.7.8 Axle Lockout Cylinder​
Hydraulic Valves​
9.8.1 Valve Installation​
Hydraulic Pumps​
9.9.1 Gear Pump Assembly​
9.9.2 Axial Pump Assembly​
Electrical Components​
9.10.1 Battery​
Turntable​
9.11.1 Swing Motor​
9.11.2 Swing Drive​
Generator and Pulley​
9.12.1 For 2800W and 3500W Generator — GM Engine​
9.12.2 For 2800W and 3500W Generator — Kubota Engine​
9.12.3 For 4000W Generator - Kubota Engine​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
Boom and Jib Assembly​
10.2.1 Main Boom Disassembly/Assembly​
10.2.2 Rotatory Actuator Disassembly/Assembly​
Platform​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Pumps​
10.5.1 Drive Pump​
10.5.2 Gear Pump​
10.6.1 Disassembly and Assembly Instructions​
10.6.2 General Information​
10.6.3 Standard of Maintenance​
10.6.4 Inspection After Assembly​
10.6.5 Disassembly Procedure​
10.6.6 Assembly​
Hydraulic Valves​
Turntable​
10.8.1 Swing Motor​
10.8.2 Swing Drive​
Generator Disassembly and Assembly​
Powertrack​
10.10.1 Remove Link​
10.10.2 Install New Link​
10.10.3 Replace Fixed End Brackets​
10.10.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
