Hyundai
86
176,834
JLG Boom Lift 340AJ Parts Catalog 3122338000
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 340AJ Boom Lift
Part Number: 3122338000
Publication Date: 2025
Number of Pages: 652 Pages
SECTION 1 - FRAME
FIGURE 1-1. STEERING INSTALLATION​
FIGURE 1-2. OSCILLATING AXLE INSTALLATION​
FIGURE 1-3. DRIVE VALVES INSTALLATION (Prior to SN 0300332925, Prior to SN B300030914, Including 0300332926, 0300332927 and 0300332929)​
FIGURE 1-4. DRIVE VALVES INSTALLATION (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
FIGURE 1-5. FLOW DIVIDER VALVE ASSEMBLY​
FIGURE 1-6. DRIVE INSTALLATION​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY​
FIGURE 1-8. DRIVE HUB/BRAKE ASSEMBLY​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION NON-MARKING​
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED​
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED NON-MARKING​
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - 33 X 12LL500 TURF/SAND FOAM FILLED​
FIGURE 1-14. FRAME SHIELDS INSTALLATION​
FIGURE 1-15. LP TANK ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVE AND CHARGE FILTER INSTALLATION (Prior to SN 0300332925, Prior to SN B300030914, Including 0300332926, 0300332927 and 0300332929)​
FIGURE 2-2. CONTROL VALVE AND CHARGE FILTER INSTALLATION (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-4. MANUAL PUMP VALVE ASSEMBLY (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
FIGURE 2-5. SWING DRIVE INSTALLATION​
FIGURE 2-6. SWING MOTOR ASSEMBLY​
FIGURE 2-7. SWING BEARING ASSEMBLY​
FIGURE 2-8. TANK INSTALLATION (DIESEL MACHINES)​
FIGURE 2-9. TANK INSTALLATION (GAS MACHINES)​
FIGURE 2-10. HYDRAULIC TANK ASSEMBLY​
FIGURE 2-11. FUEL TANK ASSEMBLY (DIESEL MACHINES)​
FIGURE 2-12. FUEL TANK ASSEMBLY (GAS MACHINES)​
FIGURE 2-13. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS)​
FIGURE 2-14. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA SPEC) (Prior to SN 0300327602)​
FIGURE 2-15. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 2-16. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE & UK CA SPECS)​
FIGURE 2-17. LIGHT PANEL INSTALLATION​
FIGURE 2-18. KEY SWITCH INSTALLATION​
FIGURE 2-19. BATTERY INSTALLATION​
FIGURE 2-20. WHITE NOISE ALARM INSTALLATION (AMBIENT)​
FIGURE 2-21. WHITE NOISE ALARM INSTALLATION (CONSTANT)​
FIGURE 2-22. STROBE LIGHT INSTALLATION (AMBER)​
FIGURE 2-23. STROBE LIGHT INSTALLATION (BLUE) (OPTIONAL)​
FIGURE 2-24. STROBE LIGHT INSTALLATION (RED) (OPTIONAL)​
FIGURE 2-25. GATEWAY INSTALLATION​
FIGURE 2-26. NO BEACON INSTALLATION​
FIGURE 2-27. TELEMATICS GATEWAY HARNESS​
FIGURE 2-28. TURNTABLE FLOODLIGHT INSTALLATION (OPTIONAL)​
FIGURE 2-29. HEAD AND TAIL LIGHT INSTALLATION (OPTIONAL)​
FIGURE 2-30. HOODS INSTALLATION​
FIGURE 2-31. HOOD INSTALLATION (GAS ENGINE)​
FIGURE 2-32. ENGINE SIDE HOOD ASSEMBLY​
FIGURE 2-33. TANK SIDE HOOD ASSEMBLY​
FIGURE 2-34. HOOD COMPONENTS - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-35. HOOD COMPONENTS - KUBOTA ENGINE (WITH ARCTIC PACKAGE)​
FIGURE 2-36. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-37. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)​
FIGURE 2-38. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-39. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
SECTION 3 - ENGINE
FIGURE 3-1. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-2. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-3. GM ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-4. GM ENGINE ASSEMBLY​
FIGURE 3-5. KUBOTA ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-6. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-7. KUBOTA ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-8. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)​
FIGURE 3-9. KUBOTA ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-10. KUBOTA ENGINE WITH 4000W GENERATOR AND PUMP SUB-ASSEMBLY​
FIGURE 3-11. KUBOTA ENGINE ASSEMBLY (Prior to SN 0300335911, Except Prior to SN B300030914, Excluding 0300335912)​
FIGURE 3-12. KUBOTA ENGINE ASSEMBLY (SN 0300335911 to Present, SN B300030914 to Present, Including 0300335912)​
FIGURE 3-13. KUBOTA ENGINE ASSEMBLY WITH 4000W GENERATOR (Prior to SN 0300335911, Except Prior to SN B300030914, Excluding 0300335912)​
FIGURE 3-14. KUBOTA ENGINE ASSEMBLY WITH 4000W GENERATOR (SN 0300335911 to Present, SN B300030914 to Present, Including 0300335912)​
FIGURE 3-15. KUBOTA ENGINE COMPONENTS (Prior to SN 0300335911, Except Prior to SN B300030914, Excluding 0300335912)​
FIGURE 3-16. KUBOTA ENGINE COMPONENTS (SN 0300335911 to Present, SN B300030914 to Present, Including 0300335912)​
FIGURE 3-17. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA 2.5L DF)​
FIGURE 3-18. CATALYTIC MUFFLER INSTALLATION - KUBOTA ENGINE (OPTIONAL)​
FIGURE 3-19. FUEL/WATER SEPARATOR ASSEMBLY (KUBOTAT ENGNIES) (PVC2007)​
FIGURE 3-20. AXIAL PUMP ASSEMBLY​
FIGURE 3-21. GEAR PUMP ASSEMBLY​
FIGURE 3-22. 2800W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-23. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/50HZ GENERATOR​
FIGURE 3-24. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 3-25. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 3-26. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 3-27. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 3-28. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 3-29. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, JAPANESE, CE & UK CA SPECS)​
FIGURE 3-30. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 110V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (Prior to SN 0300332919)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 4-3. TOWER BOOM ASSEMBLY​
FIGURE 4-4. MAIN BOOM ASSEMBLY​
FIGURE 4-5. JIB ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-6. JIB ASSEMBLY - WITHOUT ARCTIC PACKAGE (SN 0300320000 to Present)​
FIGURE 4-7. JIB ASSEMBLY - WITH ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-8. JIB ASSEMBLY - WITH ARCTIC PACKAGE (SN 0300320000 to Present)​
FIGURE 4-9. PLATFORM ROTATOR ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-10. ROTATOR ASSEMBLY - PLATFORM (SN 0300320000 to Present)​
FIGURE 4-11. PLATFORM ROTATOR ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 4-12. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS (PVC 2007) (Prior to SN 0300325459)​
FIGURE 4-13. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS (SN 0300325460 through 0300336409)​
FIGURE 4-14. POWER TRACK INSTALLATION​
FIGURE 4-15. CONTROL VALVES INSTALLATION - BOOM (Prior to SN 0300332925, Prior to SN B300030914, Including 0300332926, 0300332927 and 0300332929)​
FIGURE 4-16. CONTROL VALVES INSTALLATION - BOOM (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
FIGURE 4-17. FLY BOOM VALVE ASSEMBLY (Prior to SN 0300332925, Prior to SN B300030914, Including 0300332926, 0300332927 and 0300332929)​
FIGURE 4-18. FLY BOOM VALVE ASSEMBLY (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
FIGURE 4-19. BOOM UPRIGHT VALVE ASSEMBLY (Prior to SN B300030914, Including 0300332925, 0300332926, 0300332927 and 0300332929)​
FIGURE 4-20. BOOM UPRIGHT VALVE ASSEMBLY (SN 0300332925 to Present, Except SN B300030914 to Present, Excluding 0300332926, 0300332927 and 0300332929)​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - GATE ENTRY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - GATE ENTRY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - DROP BAR ENTRY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - DROP BAR ENTRY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-6. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (SN 0300336409 to Present)​
FIGURE 5-7. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3) (SN B300030914 to Present)​
FIGURE 5-8. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336409 to Present)​
FIGURE 5-9. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336409 to Present)​
FIGURE 5-10. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3) (SN B300030914 to Present)​
FIGURE 5-11. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3) (SN B300030914 to Present)​
FIGURE 5-12. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03) (SN 0300336409 to Present)​
FIGURE 5-13. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH 03) (SN 0300336409 to Present)​
FIGURE 5-14. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3) (SN B300030914 to Present)​
FIGURE 5-15. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3) (SN B300030914 to Present)​
FIGURE 5-16. TRAY INSTALLATION​
FIGURE 5-17. CONSOLE AND FOOTSWITCH INSTALLATION - DIESEL MACHINES (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-18. CONSOLE AND FOOTSWITCH INSTALLATION - DIESEL MACHINES (SN 03003336409 to Present, SN B300030914 to Present)​
FIGURE 5-19. CONSOLE AND FOOTSWITCH INSTALLATION - GAS MACHINES (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-20. CONSOLE AND FOOTSWITCH INSTALLATION - GAS MACHINES (SN 03003336409 to Present, SN B300030914 to Present)​
FIGURE 5-21. CONSOLE ASSEMBLY (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-22. CONSOLE ASSEMBLY (SN 03003336409 to Present, SN B300030914 to Present)​
FIGURE 5-23. LIGHT PANEL INSTALLATION​
FIGURE 5-24. FOOTSWITCH ASSEMBLY​
FIGURE 5-25. USB CHARGER INSTALLATION (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-26. USB CHARGER INSTALLATION (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 5-27. SKYEYE INSTALLATION​
FIGURE 5-28. SKYLINE INSTALLATION (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 5-29. SKYLINE INSTALLATION (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 5-30. WORKLIGHTS INSTALLATION (OPTIONAL)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 6-3. LIFT (JIB) CYLINDER ASSEMBLY​
FIGURE 6-4. LIFT (MAIN BOOM) CYLINDER ASSEMBLY​
FIGURE 6-5. LIFT (TOWER BOOM) CYLINDER ASSEMBLY​
FIGURE 6-6. MASTER CYLINDER ASSEMBLY​
FIGURE 6-7. STEER CYLINDER ASSEMBLY​
FIGURE 6-8. TELESCOPE CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC INSTALLATION - WITHOUT ARCTIC PACKAGE (Prior to SN 0300321685)​
FIGURE 7-2. HYDRAULIC INSTALLATION - WITHOUT ARCTIC PACKAGE (SN 0300321686 to Present)​
FIGURE 7-3. HYDRAULIC INSTALLATION - WITH ARCTIC PACKAGE​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN AND CHINA SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED (CE & UK CA SPEC)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITH 4000W GENERATOR (CE & UK CA SPECS) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITH 4000W GENERATOR (CE & UK CA SPECS) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V (CSA SPEC)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITH 4000W GENERATOR (CE & UK CA SPECS) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITH 4000W GENERATOR (CE & UK CA SPECS) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITHOUT 4000W GENERATOR (CE & UK CA SPEC) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 8-23. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 4000W GENERATOR (CE & UK CA SPECS) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-24. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 4000W GENERATOR (CE & UK CA SPECS) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-25. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER WITH 4000W GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-26. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER WITH 4000W GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS) (SN 0300336409 to Present, Including B300030914)​
FIGURE 8-27. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)​
FIGURE 8-28. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE) (50HZ)​
FIGURE 8-29. AC POWER TO PLATFORM CABLE - MAIN BOOM (60HZ)​
FIGURE 8-30. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)​
FIGURE 8-31. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE) (50HZ)​
FIGURE 8-32. AC POWER TO PLATFORM CABLE - TOWER BOOM (60HZ)​
FIGURE 8-33. BATTERY DISCONNECT SWITCH​
FIGURE 8-34. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 8-35. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 8-36. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITHOUT ARCTIC PACKAGE​
FIGURE 8-37. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITH ARCTIC PACKAGE​
FIGURE 8-38. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITHOUT ARCTIC PACKAGE (Prior to SN 0300332919)​
FIGURE 8-39. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITH ARCTIC PACKAGE (Prior to SN 0300332919)​
FIGURE 8-40. BOOM HARNESS - LIMIT SWITCHES AND UPRIGHT VALVE​
FIGURE 8-41. BOOM HARNESS - MAIN​
FIGURE 8-42. BREAKER BOX INSTALLATION​
FIGURE 8-43. BREAKER BOX KIT (CE & UK CA SPEC)​
FIGURE 8-44. CHASSIS HARNESS ASSEMBLY​
FIGURE 8-45. CHASSIS LIGHT HARNESS​
FIGURE 8-46. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-47. ENGINE HARNESS - KUBOTA ENGINE​
FIGURE 8-48. FUEL PUMP HARNESS - GM ENGINES​
FIGURE 8-49. GENERATOR HARNESS - 2500W​
FIGURE 8-50. GENERATOR HARNESS - 4000W​
FIGURE 8-51. GENERATOR CONTROL HARNESS - 4000W​
FIGURE 8-52. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 8-53. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 110/50HZ (CE & UK CA SPECS ONLY)​
FIGURE 8-54. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 8-55. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 8-56. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 110/60HZ (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 8-57. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 8-58. GROUND TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-59. GROUND TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE)​
FIGURE 8-60. GROUND TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-61. GROUND TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE)​
FIGURE 8-62. GROUND CONTROL HARNESS​
FIGURE 8-63. GENERATOR TO PLATFORM HARNESS​
FIGURE 8-64. LIMIT SWITCH HARNESS​
FIGURE 8-65. LSS HARNESS​
FIGURE 8-66. MID ENGINE HARNESS​
FIGURE 8-67. PLATFORM BOX HARNESS​
FIGURE 8-68. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-69. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-70. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-71. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-72. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE & UK CA SPEC)​
FIGURE 8-73. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE & UK CA SPEC)​
FIGURE 8-74. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-75. RECEPTACLE INSTALLATION - 12V​
FIGURE 8-76. SKYEYE EMITTER HARNESS​
FIGURE 8-77. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-78. SKYEYE RECEIVER HARNESS​
FIGURE 8-79. SKYLINE HARNESS​
FIGURE 8-80. STOBE LIGHT JUMPER HARNESS​
FIGURE 8-81. STROBE LIGHT CONTROL (BLUE STROBE LIGHT)​
FIGURE 8-82. STROBE LIGHT EXTENSION HARNESS (BLUE STROBE LIGHT ONLY)​
FIGURE 8-83. USB HARNESS​
FIGURE 8-84. VALVE HARNESS - BOOM VALVE (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 8-85. VALVE HARNESS​
FIGURE 8-86. TILT SENSOR HARNESS​
FIGURE 8-87. WORKLIGHT HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECALS INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-2. DECALS INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-3. DECALS INSTALLATION - AUSTRALIAN SPEC (ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-4. DECALS INSTALLATION - AUSTRALIAN SPEC (ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-5. DECALS INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-6. DECALS INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-7. DECALS INSTALLATION - CE & UK CA SPECS (ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-8. DECALS INSTALLATION - CE & UK CA SPECS (ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-9. DECALS INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-10. DECALS INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-11. DECALS INSTALLATION - CSA SPEC (FRENCH/ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-12. DECALS INSTALLATION - CSA SPEC (FRENCH/ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-13. DECALS INSTALLATION - JAPANESE SPEC (JAPANESE) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-14. DECALS INSTALLATION - JAPANESE SPEC (JAPANESE) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-15. DECALS INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-16. DECALS INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-17. DECALS INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH) (Prior to SN 0300336409, Prior to SN B300030914)​
FIGURE 9-18. DECALS INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH) (SN 0300336409 to Present, SN B300030914 to Present)​
FIGURE 9-19. OPTIONAL DECALS INSTALLATION​
FIGURE 10-1. RECOMMEDED SERVICE PARTS STOCK​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
