Hyundai
86
176,834
JLG Boom Lift 340AJ Parts Catalog 3122317700
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 340AJ Boom Lift
Part Number: 3122317700
Publication Date: 2025
Number of Pages: 534 Pages
SECTION 1 - FRAME
FIGURE 1-1. STEERING INSTALLATION​
FIGURE 1-2. OSCILLATING AXLE INSTALLATION​
FIGURE 1-3. DRIVE VALVES INSTALLATION​
FIGURE 1-4. FLOW DIVIDER VALVE ASSEMBLY​
FIGURE 1-5. DRIVE INSTALLATION​
FIGURE 1-6. DRIVE MOTOR ASSEMBLY​
FIGURE 1-7. DRIVE HUB/BRAKE ASSEMBLY​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION NON-MARKING​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED​
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED NON-MARKING​
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 33 X 12LL500 TURF/SAND FOAM FILLED​
FIGURE 1-13. FRAME SHIELDS INSTALLATION​
FIGURE 1-14. LP TANK ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVE AND CHARGE FILTER INSTALLATION​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-3. SWING DRIVE INSTALLATION​
FIGURE 2-4. SWING MOTOR ASSEMBLY​
FIGURE 2-5. SWING BEARING ASSEMBLY​
FIGURE 2-6. TANK INSTALLATION (DIESEL MACHINES)​
FIGURE 2-7. TANK INSTALLATION (GAS MACHINES)​
FIGURE 2-8. HYDRAULIC TANK ASSEMBLY​
FIGURE 2-9. FUEL TANK ASSEMBLY (DIESEL MACHINES)​
FIGURE 2-10. FUEL TANK ASSEMBLY (GAS MACHINES)​
FIGURE 2-11. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA)​
FIGURE 2-12. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA SPEC)​
FIGURE 2-13. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 2-14. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE & UK CA SPECS)​
FIGURE 2-15. LIGHT PANEL INSTALLATION​
FIGURE 2-16. KEY SWITCH INSTALLATION​
FIGURE 2-17. BATTERY INSTALLATION​
FIGURE 2-18. WHITE NOISE ALARM INSTALLATION (AMBIENT)​
FIGURE 2-19. WHITE NOISE ALARM INSTALLATION (CONSTANT)​
FIGURE 2-20. TURNTABLE FLOODLIGHT INSTALLATION (OPTIONAL)​
FIGURE 2-21. HEAD AND TAIL LIGHT INSTALLATION (OPTIONAL)​
FIGURE 2-22. HOODS INSTALLATION​
FIGURE 2-23. HOOD INSTALLATION (GAS ENGINE)​
FIGURE 2-24. ENGINE SIDE HOOD ASSEMBLY​
FIGURE 2-25. TANK SIDE HOOD ASSEMBLY​
FIGURE 2-26. HOOD COMPONENTS - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-27. HOOD COMPONENTS - KUBOTA ENGINE (WITH ARCTIC PACKAGE)​
FIGURE 2-28. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-29. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)​
FIGURE 2-30. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 2-31. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
SECTION 3 - ENGINE
FIGURE 3-1. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-2. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-3. GM ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-4. GM ENGINE ASSEMBLY​
FIGURE 3-5. KUBOTA ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-6. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-7. KUBOTA ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-8. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)​
FIGURE 3-9. KUBOTA ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-10. KUBOTA ENGINE WITH 4000W GENERATOR AND PUMP SUB-ASSEMBLY​
FIGURE 3-11. KUBOTA ENGINE ASSEMBLY​
FIGURE 3-12. KUBOTA ENGINE ASSEMBLY WITH 4000W GENERATOR​
FIGURE 3-13. KUBOTA ENGINE COMPONENTS​
FIGURE 3-14. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA 2.5L DF)​
FIGURE 3-15. CATALYTIC MUFFLER INSTALLATION - KUBOTA ENGINE (OPTIONAL)​
FIGURE 3-16. FUEL/WATER SEPARATOR ASSEMBLY (KUBOTAT ENGNIES) (PVC2007)​
FIGURE 3-17. AXIAL PUMP ASSEMBLY​
FIGURE 3-18. GEAR PUMP ASSEMBLY​
FIGURE 3-19. 2800W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT AND CHINA SPECS)​
FIGURE 3-20. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/50HZ GENERATOR​
FIGURE 3-21. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 3-22. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 3-23. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 3-24. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 3-25. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 3-26. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, JAPANESE, CE & UK CA SPECS)​
FIGURE 3-27. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 110V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 4-3. TOWER BOOM ASSEMBLY​
FIGURE 4-4. MAIN BOOM ASSEMBLY​
FIGURE 4-5. JIB ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-6. JIB ASSEMBLY - WITHOUT ARCTIC PACKAGE (SN 0300320000 to Present)​
FIGURE 4-7. JIB ASSEMBLY - WITH ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-8. JIB ASSEMBLY - WITH ARCTIC PACKAGE (SN 0300320000 to Present)​
FIGURE 4-9. PLATFORM ROTATOR ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300319999)​
FIGURE 4-10. ROTATOR ASSEMBLY - PLATFORM (SN 0300320000 to Present)​
FIGURE 4-11. PLATFORM ROTATOR ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 4-12. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS (PVC 2007) (Prior to SN 0300325459)​
FIGURE 4-13. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS (SN 0300325460 to Present)​
FIGURE 4-14. POWER TRACK INSTALLATION​
FIGURE 4-15. CONTROL VALVES INSTALLATION - BOOM​
FIGURE 4-16. FLY BOOM VALVE ASSEMBLY​
FIGURE 4-17. BOOM UPRIGHT VALVE ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - GATE ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - GATE ENTRY​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - DROP BAR ENTRY​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - DROP BAR ENTRY​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-6. TRAY INSTALLATION​
FIGURE 5-7. CONSOLE AND FOOTSWITCH INSTALLATION - DIESEL MACHINES​
FIGURE 5-8. CONSOLE AND FOOTSWITCH INSTALLATION - GAS MACHINES​
FIGURE 5-9. CONSOLE ASSEMBLY​
FIGURE 5-10. LIGHT PANEL INSTALLATION​
FIGURE 5-11. FOOTSWITCH ASSEMBLY​
FIGURE 5-12. USB CHARGER INSTALLATION​
FIGURE 5-13. SKYEYE INSTALLATION​
FIGURE 5-14. SKYLINE INSTALLATION​
FIGURE 5-15. WORKLIGHTS INSTALLATION (OPTIONAL)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 6-3. LIFT (JIB) CYLINDER ASSEMBLY​
FIGURE 6-4. LIFT (MAIN BOOM) CYLINDER ASSEMBLY​
FIGURE 6-5. LIFT (TOWER BOOM) CYLINDER ASSEMBLY​
FIGURE 6-6. MASTER CYLINDER ASSEMBLY​
FIGURE 6-7. STEER CYLINDER ASSEMBLY​
FIGURE 6-8. TELESCOPE CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC INSTALLATION - WITHOUT ARCTIC PACKAGE (Prior to SN 0300321685)​
FIGURE 7-2. HYDRAULIC INSTALLATION - WITHOUT ARCTIC PACKAGE (SN 0300321686 to Present)​
FIGURE 7-3. HYDRAULIC INSTALLATION - WITH ARCTIC PACKAGE​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN AND CHINA SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED (CE & UK CA SPEC)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPEC)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V (CSA SPEC)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPEC)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITHOUT 4000W GENERATOR (CE & UK CA SPEC)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER WITH 4000W GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS)​
FIGURE 8-16. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)​
FIGURE 8-17. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE) (50HZ)​
FIGURE 8-18. AC POWER TO PLATFORM CABLE - MAIN BOOM (60HZ)​
FIGURE 8-19. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)​
FIGURE 8-20. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE) (50HZ)​
FIGURE 8-21. AC POWER TO PLATFORM CABLE - TOWER BOOM (60HZ)​
FIGURE 8-22. BATTERY DISCONNECT SWITCH​
FIGURE 8-23. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 8-24. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 8-25. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITHOUT ARCTIC PACKAGE​
FIGURE 8-26. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITH ARCTIC PACKAGE​
FIGURE 8-27. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITHOUT ARCTIC PACKAGE​
FIGURE 8-28. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITH ARCTIC PACKAGE​
FIGURE 8-29. BOOM HARNESS - LIMIT SWITCHES AND UPRIGHT VALVE​
FIGURE 8-30. BOOM HARNESS - MAIN​
FIGURE 8-31. BREAKER BOX INSTALLATION​
FIGURE 8-32. BREAKER BOX KIT (CE & UK CA SPEC)​
FIGURE 8-33. CHASSIS HARNESS ASSEMBLY​
FIGURE 8-34. CHASSIS LIGHT HARNESS​
FIGURE 8-35. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-36. ENGINE HARNESS - KUBOTA ENGINE​
FIGURE 8-37. FUEL PUMP HARNESS - GM ENGINES​
FIGURE 8-38. GENERATOR HARNESS - 2500W​
FIGURE 8-39. GENERATOR HARNESS - 4000W​
FIGURE 8-40. GENERATOR CONTROL HARNESS - 4000W​
FIGURE 8-41. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 8-42. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 110/50HZ (CE & UK CA SPECS ONLY)​
FIGURE 8-43. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 8-44. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 8-45. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 110/60HZ (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 8-46. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 8-47. GROUND TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-48. GROUND TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE)​
FIGURE 8-49. GROUND TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE)​
FIGURE 8-50. GROUND TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE)​
FIGURE 8-51. GROUND CONTROL HARNESS​
FIGURE 8-52. GENERATOR TO PLATFORM HARNESS​
FIGURE 8-53. LIMIT SWITCH HARNESS​
FIGURE 8-54. LSS HARNESS​
FIGURE 8-55. MID ENGINE HARNESS​
FIGURE 8-56. PLATFORM BOX HARNESS​
FIGURE 8-57. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-58. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-59. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-60. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-61. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE & UK CA SPEC)​
FIGURE 8-62. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE & UK CA SPEC)​
FIGURE 8-63. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-64. RECEPTACLE INSTALLATION - 12V​
FIGURE 8-65. SKYEYE EMITTER HARNESS​
FIGURE 8-66. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-67. SKYEYE RECEIVER HARNESS​
FIGURE 8-68. SKYLINE HARNESS​
FIGURE 8-69. STOBE LIGHT JUMPER HARNESS​
FIGURE 8-70. STROBE LIGHT CONTROL (BLUE STROBE LIGHT)​
FIGURE 8-71. STROBE LIGHT EXTENSION HARNESS (BLUE STROBE LIGHT ONLY)​
FIGURE 8-72. VALVE HARNESS - BOOM VALVE​
FIGURE 8-73. VALVE HARNESS​
FIGURE 8-74. TILT SENSOR HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECALS INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)​
FIGURE 9-2. DECALS INSTALLATION - AUSTRALIAN SPEC (ENGLISH)​
FIGURE 9-3. DECALS INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH)​
FIGURE 9-4. DECALS INSTALLATION - CE & UK CA SPECS (ENGLISH)​
FIGURE 9-5. DECALS INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)​
FIGURE 9-6. DECALS INSTALLATION - CSA SPEC (FRENCH/ENGLISH)​
FIGURE 9-7. DECALS INSTALLATION - JAPANESE SPEC (JAPANESE)​
FIGURE 9-8. DECALS INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)​
FIGURE 9-9. DECALS INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH)​
FIGURE 9-10. OPTIONAL DECALS INSTALLATION​
FIGURE 10-1. RECOMMEDED SERVICE PARTS STOCK​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
