JLG Boom Lift 340AJ Parts Catalog 31223004
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 340AJ Boom Lift
Part Number: 31223004
Publication Date: 2025
Number of Pages: 536 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEERING INSTALLATION
FIGURE 1-2. OSCILLATING AXLE INSTALLATION
FIGURE 1-3. DRIVE VALVES INSTALLATION
FIGURE 1-4. FLOW DIVIDER VALVE ASSEMBLY
FIGURE 1-5. DRIVE INSTALLATION
FIGURE 1-6. DRIVE MOTOR ASSEMBLY
FIGURE 1-7. DRIVE HUB/BRAKE ASSEMBLY
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 7X18 SOLID CUSHION NON-MARKING
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 9X20 FOAM-FILLED NON-MARKING
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 33 X 12LL500 TURF/SAND FOAM FILLED
FIGURE 1-13. FRAME SHIELDS INSTALLATION
FIGURE 1-14. LP TANK ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. TURNTABLE FLOODLIGHT INSTALLATION (OPTIONAL)
FIGURE 2-2. CONTROL VALVE AND CHARGE FILTER INSTALLATION
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-4. SWING DRIVE INSTALLATION
FIGURE 2-5. SWING MOTOR ASSEMBLY
FIGURE 2-6. SWING BEARING ASSEMBLY
FIGURE 2-7. TANK INSTALLATION (DIESEL MACHINES)
FIGURE 2-8. TANK INSTALLATION (GAS MACHINES)
FIGURE 2-9. HYDRAULIC TANK ASSEMBLY
FIGURE 2-10. FUEL TANK ASSEMBLY (DIESEL MACHINES)
FIGURE 2-11. FUEL TANK ASSEMBLY (GAS MACHINES)
FIGURE 2-12. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA)
FIGURE 2-13. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA SPEC)
FIGURE 2-14. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 2-15. GROUND CONTROL BOX ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE & UK CA SPECS)
FIGURE 2-16. LIGHT PANEL INSTALLATION
FIGURE 2-17. KEY SWITCH INSTALLATION
FIGURE 2-18. BATTERY INSTALLATION
FIGURE 2-19. WHITE NOISE ALARM INSTALLATION (AMBIENT)
FIGURE 2-20. WHITE NOISE ALARM INSTALLATION (CONSTANT)
FIGURE 2-21. STROBE LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON)
FIGURE 2-22. STROBE LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON)
FIGURE 2-23. STROBE LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON)
FIGURE 2-24. HEAD AND TAIL LIGHT INSTALLATION (OPTIONAL)
FIGURE 2-25. HOODS INSTALLATION (Prior to SN 0300313266, Excluding 0300311516)
FIGURE 2-26. HOOD INSTALLATION (GAS ENGINE) (SN 0300313266 to Present, Including 0300311516)
FIGURE 2-27. ENGINE SIDE HOOD ASSEMBLY
FIGURE 2-28. TANK SIDE HOOD ASSEMBLY
FIGURE 2-29. HOOD COMPONENTS - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 2-30. HOOD COMPONENTS - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 2-31. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)
FIGURE 2-32. HOOD COMPONENTS - KUBOTA ENGINE WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)
FIGURE 2-33. HOOD COMPONENTS - GM ENGINE (WITHOUT ARCTIC PACKAGE) (Prior to SN 0300313266, Excluding 0300311516)
FIGURE 2-34. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE) (SN 0300313266 to Present, Including 0300311516)
FIGURE 2-35. HOOD COMPONENTS - GM ENGINE (WITH ARCTIC PACKAGE) (Prior to SN 0300313266, Excluding 0300311516)
FIGURE 2-36. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE) (SN 0300313266 to Present, Including 0300311516)
SECTION 3 - ENGINEFIGURE 3-1. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE) (Prior to SN 0300313266, Excluding 0300311516)
FIGURE 3-2. GM ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE) (SN 0300313266 to Present, Including 0300311516)
FIGURE 3-3. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE) (Prior to SN 0300313266, Excluding 0300311516)
FIGURE 3-4. GM ENGINE INSTALLATION (WITH ARCTIC PACKAGE) (SN 0300313266 to Present, Including 0300311516)
FIGURE 3-5. GM ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-6. GM ENGINE ASSEMBLY
FIGURE 3-7. KUBOTA ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-8. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITHOUT ARCTIC PACKAGE)
FIGURE 3-9. KUBOTA ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-10. KUBOTA ENGINE INSTALLATION WITH 4000W GENERATOR (WITH ARCTIC PACKAGE)
FIGURE 3-11. KUBOTA ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-12. KUBOTA ENGINE WITH 4000W GENERATOR AND PUMP SUB-ASSEMBLY
FIGURE 3-13. KUBOTA ENGINE ASSEMBLY
FIGURE 3-14. KUBOTA ENGINE ASSEMBLY WITH 4000W GENERATOR
FIGURE 3-15. KUBOTA ENGINE COMPONENTS
FIGURE 3-16. QUICKFIT OIL DRAIN INSTALLATION (KUBOTA 2.5L DF)
FIGURE 3-17. CATALYTIC MUFFLER INSTALLATION - KUBOTA ENGINE (OPTIONAL)
FIGURE 3-18. FUEL/WATER SEPARATOR ASSEMBLY (KUBOTAT ENGNIES) (PVC2007)
FIGURE 3-19. AXIAL PUMP ASSEMBLY
FIGURE 3-20. GEAR PUMP ASSEMBLY
FIGURE 3-21. 2800W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT AND CHINA SPECS)
FIGURE 3-22. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/50HZ GENERATOR
FIGURE 3-23. 2800W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)
FIGURE 3-24. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)
FIGURE 3-25. 3500W GENERATOR INSTALLATION - GM ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 3-26. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 120V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)
FIGURE 3-27. 3500W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/60HZ GENERATOR (ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 3-28. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 220V/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA, JAPANESE, CE & UK CA SPECS)
FIGURE 3-29. 4000W GENERATOR INSTALLATION - KUBOTA ENGINE MACHINES 110V/60HZ GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDERS INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 4-3. TOWER BOOM ASSEMBLY
FIGURE 4-4. MAIN BOOM ASSEMBLY
FIGURE 4-5. JIB ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 4-6. JIB ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 4-7. PLATFORM ROTATOR ASSEMBLY
FIGURE 4-8. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS (PVC 2007)
FIGURE 4-9. POWER TRACK INSTALLATION
FIGURE 4-10. CONTROL VALVES INSTALLATION - BOOM
FIGURE 4-11. FLY BOOM VALVE ASSEMBLY
FIGURE 4-12. BOOM UPRIGHT VALVE ASSEMBLY
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - GATE ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - DROP BAR ENTRY
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - DROP BAR ENTRY
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-6. TRAY INSTALLATION
FIGURE 5-7. CONSOLE AND FOOTSWITCH INSTALLATION - DIESEL MACHINES
FIGURE 5-8. CONSOLE AND FOOTSWITCH INSTALLATION - GAS MACHINES
FIGURE 5-9. CONSOLE ASSEMBLY
FIGURE 5-10. LIGHT PANEL INSTALLATION
FIGURE 5-11. FOOTSWITCH ASSEMBLY
FIGURE 5-12. USB CHARGER INSTALLATION
FIGURE 5-13. SKYEYE INSTALLATION
FIGURE 5-14. SKYLINE INSTALLATION
FIGURE 5-15. WORKLIGHTS INSTALLATION (OPTIONAL)
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 6-3. LIFT (JIB) CYLINDER ASSEMBLY
FIGURE 6-4. LIFT (MAIN BOOM) CYLINDER ASSEMBLY
FIGURE 6-5. LIFT (TOWER BOOM) CYLINDER ASSEMBLY
FIGURE 6-6. MASTER CYLINDER ASSEMBLY
FIGURE 6-7. STEER CYLINDER ASSEMBLY
FIGURE 6-8. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 7-2. HYDRAULIC INSTALLATION - WITH ARCTIC PACKAGE
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN AND CHINA SPECS)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - LOCALLY SUPPLIED (CE & UK CA SPEC)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPEC)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW WITH 4000W GENERATOR (CE & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V (CSA SPEC)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPEC)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE WITH 4000W GENERATOR (CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITHOUT 4000W GENERATOR (CE & UK CA SPEC)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND 2 X 4 BOX WITH 4000W GENERATOR (CE & UK CA SPECS)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITHOUT 4000W GENERATOR (CE & UK CA SPEC)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 4000W GENERATOR (CE & UK CA SPECS)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER WITH 4000W GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS)
FIGURE 8-16. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)
FIGURE 8-17. AC POWER TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE) (50HZ)
FIGURE 8-18. AC POWER TO PLATFORM CABLE - MAIN BOOM (60HZ)
FIGURE 8-19. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE) (50HZ)
FIGURE 8-20. AC POWER TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE) (50HZ)
FIGURE 8-21. AC POWER TO PLATFORM CABLE - TOWER BOOM (60HZ)
FIGURE 8-22. BATTERY DISCONNECT SWITCH
FIGURE 8-23. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 8-24. BOOM CABLES, HARNESSES AND CLAMPS INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 8-25. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITHOUT ARCTIC PACKAGE
FIGURE 8-26. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 50HZ - WITH ARCTIC PACKAGE
FIGURE 8-27. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITHOUT ARCTIC PACKAGE
FIGURE 8-28. BOOM CABLES AND CLAMPS INSTALLATION - 4000W, 60HZ - WITH ARCTIC PACKAGE
FIGURE 8-29. BOOM HARNESS - LIMIT SWITCHES AND UPRIGHT VALVE
FIGURE 8-30. BOOM HARNESS - MAIN
FIGURE 8-31. BREAKER BOX INSTALLATION
FIGURE 8-32. BREAKER BOX KIT (CE & UK CA SPEC)
FIGURE 8-33. CHASSIS HARNESS ASSEMBLY
FIGURE 8-34. CHASSIS LIGHT HARNESS
FIGURE 8-35. CLEARSKY 3-WIRE TELEMATICS INSTALLATION
FIGURE 8-36. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION
FIGURE 8-37. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-38. CLEARSKY HARNESS - 3-WIRE TELEMATICS
FIGURE 8-39. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-40. ENGINE HARNESS - KUBOTA ENGINE
FIGURE 8-41. FUEL PUMP HARNESS - GM ENGINES
FIGURE 8-42. GENERATOR HARNESS - 2500W
FIGURE 8-43. GENERATOR HARNESS - 4000W
FIGURE 8-44. GENERATOR CONTROL HARNESS - 4000W
FIGURE 8-45. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)
FIGURE 8-46. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 110/50HZ (CE & UK CA SPECS ONLY)
FIGURE 8-47. GENERATOR TO AC PLUG HARNESS - 2800W GENERATOR 220/50HZ (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)
FIGURE 8-48. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 8-49. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 110/60HZ (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)
FIGURE 8-50. GENERATOR TO AC PLUG HARNESS - 3500W GENERATOR 220/60HZ (ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 8-51. GROUND TO PLATFORM CABLE - MAIN BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 8-52. GROUND TO PLATFORM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE)
FIGURE 8-53. GROUND TO PLATFORM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 8-54. GROUND TO PLATFORM CABLE - TOWER BOOM (WITH ARCTIC PACKAGE)
FIGURE 8-55. GROUND CONTROL HARNESS
FIGURE 8-56. GENERATOR TO PLATFORM HARNESS
FIGURE 8-57. LIMIT SWITCH HARNESS
FIGURE 8-58. LSS HARNESS
FIGURE 8-59. MID ENGINE HARNESS
FIGURE 8-60. PLATFORM BOX HARNESS
FIGURE 8-61. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-62. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-63. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-64. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-65. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-66. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-67. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-68. RECEPTACLE INSTALLATION - 12V
FIGURE 8-69. SKYEYE EMITTER HARNESS
FIGURE 8-70. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-71. SKYEYE RECEIVER HARNESS
FIGURE 8-72. SKYLINE HARNESS
FIGURE 8-73. STOBE LIGHT JUMPER HARNESS
FIGURE 8-74. STROBE LIGHT CONTROL (BLUE STROBE LIGHT)
FIGURE 8-75. STROBE LIGHT EXTENSION HARNESS (BLUE STROBE LIGHT ONLY)
FIGURE 8-76. TILT SENSOR HARNESS
FIGURE 8-77. VALVE HARNESS - BOOM VALVE
FIGURE 8-78. VALVE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECALS INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)
FIGURE 9-2. DECALS INSTALLATION - AUSTRALIAN SPEC (ENGLISH)
FIGURE 9-3. DECALS INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH)
FIGURE 9-4. DECALS INSTALLATION - CE & UK CA SPECS (ENGLISH)
FIGURE 9-5. DECALS INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)
FIGURE 9-6. DECALS INSTALLATION - CSA SPEC (FRENCH/ENGLISH)
FIGURE 9-7. DECALS INSTALLATION - JAPANESE SPEC (JAPANESE)
FIGURE 9-8. DECALS INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)
FIGURE 9-9. DECALS INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH)
FIGURE 9-10. OPTIONAL DECALS INSTALLATION
SECTION 10 - RECOMMENDED SERVICE PARTS STOCKFIGURE 10-1. RECOMMEDED SERVICE PARTS STOCK
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
