Hyundai
86
176,834
JLG Boom Lift 313, 1504 Service Manual 3122309000 2026
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 313, 1504 Boom Lift
Part Number: 3122309000
Publication Date: 2026
Number of Pages: 364 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
General Machine Information & Specifications
Specifications​
2.1.1 Travel Speeds​
2.1.2 Transmission​
2.1.3 Boom Performance​
2.1.4 Cylinder Drift​
2.1.5 Battery​
2.1.6 Engine Specifications​
2.1.7 Tires​
2.1.8 Dimensions​
2.1.9 Machine Specifications​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedules​
Maintenance & Inspection Schedules
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 8 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 Every 200 Hours​
3.3.5 Every 400 Hours​
3.3.6 Every 600 Hours​
3.3.7 Every 1000 Hours​
3.3.8 Every 1500 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
3.6.2 Inching Valve Bleeding Procedure​
Boom Inspection and Maintenance​
3.7.1 Boom Wear Pads​
Hydraulic Filter Replacement​
Engine General Inspection​
3.9.1 General Maintenance​
3.9.2 Glow Plugs​
3.9.3 Replacing Engine Oil​
3.9.4 Replacing the Oil Filter​
3.9.5 Replacing the Fuel Filters​
3.9.6 Replace the Fuel Pump and Fuel In-Line Filter​
3.9.7 Checking Belt Tension​
Transmission Filter Replacement​
Testing, Calibrations, & Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
Calibration Procedures​
4.3.1 Load Stability Indicator (LSI) System Calibration​
4.3.2 Boom Sensor Calibration​
Special Procedures​
4.4.1 Emergency Lowering Procedure​
4.4.2 Towing a Disabled Machine​
4.4.3 Fuel Tank Cleaning and Drying​
4.4.4 Pressure Checks and Adjustments​
4.4.5 Cylinder Drift Test​
4.4.6 Hydraulic Circuits​
4.4.7 Pressure Specification​
System Software
Load Stability Indicator (LSI)​
5.1.1 LSI Sensor​
5.1.2 Boom Sensor​
5.1.3 Troubleshooting​
Fault Codes
Introduction​
Engine Fault Codes​
Machine Fault Codes​
Hydraulic Pump Fault Codes​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
Board Layouts​
8.5.1 Cab Fuses​
8.5.2 Engine Fuses​
8.5.3 Relays​
Wheels​
9.1.1 Wheel and Tire Assembly​
Drive Assembly​
9.2.1 Axle Assembly and Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shaft​
Boom​
9.3.1 Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom Systems​
9.3.4 Hydraulic Coupler​
9.3.5 Manual Coupler​
9.3.6 Forks​
9.3.7 Boom Prop​
9.3.8 Boom Wear Pad Installation and Lubrication​
9.3.9 Boom Proximity Sensor​
Cab​
9.4.1 Cab Serial Number Plate​
9.4.2 Cab​
9.4.3 Steering Wheel​
9.4.4 Steering Column and Steering Valve​
9.4.5 Brake System​
9.4.6 Throttle Pedal​
9.4.7 Joystick Assembly​
9.4.8 Front Wiper Assembly (If Equipped)​
9.4.9 Windshield Wiper Fluid Reservoir (If Equipped)​
9.4.10 Heater System (If Equipped on 313 Only)​
9.4.11 Instrument Panel​
9.4.12 Ignition Key Switch​
9.4.13 Dash Switches​
Engine​
9.5.1 Component Terminology​
9.5.2 Diesel Fuel​
9.5.3 Engine Serial Number​
9.5.4 Engine​
9.5.5 Engine Electrical System​
9.5.6 Radiator/Cooler Assembly​
9.5.7 Pump Coupling Assembly​
9.5.8 Air Cleaner Assembly​
9.5.9 Alternator​
9.5.10 Starter​
9.5.11 Fuel Tank Assembly​
9.5.12 Hydraulic Tank​
9.5.13 Fuel Filter and Pump​
9.5.14 Engine Exhaust Assembly​
Transmission​
9.6.1 Drive Motor​
9.6.2 Gearbox​
Hydraulic Valves​
9.7.1 Hydraulic Function Manifold​
9.7.2 4 Wheel / 2 Wheel Drive Selector Valve and Park Brake Valve​
9.7.3 LSI Control Valve​
9.7.4 Transmission Filter​
Hydraulic Cylinders​
9.8.1 Lift Cylinder Assembly​
9.8.2 Compensation Cylinder​
9.8.3 Tilt Cylinder​
Hydraulic Pumps​
9.9.1 Transmission and Gear Pump​
Electrical Components​
9.10.1 Battery​
Counterweight​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Disassembly​
10.2.2 Assembly​
Cab​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Transmission​
10.5.1 Drive Motor​
10.5.2 Gearbox​
10.5.3 Gear Pump​
10.5.4 Transmission Pump​
10.6.1 General Cylinder Disassembly​
10.6.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Hydraulic Function Manifold​
Hydraulic Components​
10.8.1 Hydraulic Tank​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
