JLG Boom Lift 20AM 25AM 30AM 36AM 41AM Service & Maintenance Manual 3120752 2025
Brand: JLG
Type of Machine: Boom Lift
SN 0900000001-0900038985
Model: JLG 20AM 25AM 30AM 36AM 41AM Boom Lift
Part Number: 3120752
Publication Date: 2025
Number of Pages: 84 Pages
INTRODUCTION - operation/safety precautions
INTRODUCTION - Maintenance safety precautions
TABLE OF CONTENTS
Section 1. specifications
Brand: JLG
General
Hydraulic System Safety
Maintenance Safety
Effectivity ChangesTABLE OF CONTENTS
1.1 Capacities
Hydraulic Oil Reservoir
1.2 Component Data
Hydraulic Pump/Electric Motor Assembly
Batteries (1) – DC Models
Battery Charger – DC Models
1.3 Performance Data
Platform Capacity
Platform Cycle Performance
Machine Weight (with Standard Platform)
Machine Height (Platform Stowed)
Maximum Platform Height (Mast Extended)
Maximum Working Height (Average Person)
Machine Overall Width and Length (Base)
Outrigger Footprint
Outrigger Machine Leveling Capability
1.4 Torque Requirements
1.5 Lubrication
Hydraulic Oil (HO)
1.6 Hydraulic Pressure Adjustment
1.7 Cylinder Specifications
1.8 Serial Number Locations
Section 2. SERVICE PROCEDURES2.1 MACHINE PREPARATION, INSPECTION, AND MAINTENANCE
General
Preparation, Inspection, and Maintenance
Pre-Start Inspection
Pre-Delivery Inspection and Frequent Inspection
Annual Machine Inspection
Preventative Maintenance
2.2 Preventive Maintenance and Inspection Schedule
2.3 Servicing and Maintenance Guidelines
General
Safety and Workmanship
Cleanliness
Components Removal and Installation
Component Disassembly and Reassembly
Pressure-Fit Parts
Bearings
Gaskets
Bolt Usage and Torque Application
Hydraulic Lines and Electrical Wiring
Lubrication and Servicing
Batteries
Mast Chain Inspection Procedure
Mast Cable Inspection Procedure
2.4 Lubrication Information
Hydraulic Oil
Changing Hydraulic Oil
Lubrication Specifications
2.5 Battery Charger - Assembly and Disassembly
Battery Charger Removal
Cover Removal
Transformer Replacement
Printed Circuit Board Replacement
DC Circuit Breaker Replacement
AC Circuit Breaker and Voltage Selection Switch Replacement
Shunt Assembly, Varistor, and SCR Rectifier Replacement (See Illustration)
2.6 hydraulic LIFT pump - servicing
FENNER BRAND PUMP - Brush Replacement
Motor Cap/Motor Installation
Motor Brush Installation
Brush Housing Final Assembly Tips
MONARCH BRAND PUMP - Brush Replacement
Motor Assembly - Remove/Install - Reference Marks
Motor/Brush Cover - Remove/Install
Brush Carrier Assembly - Remove/Install
Brush Assembly - Remove/Install
TANK AND PUMP REMOVAL - (All Pumps)
Tank Installation
Filter Screen Installation
Pump Installation
Pressure Adjust Valve Installation
Pressure Check Valve Installation
2.7 Hydraulic Lift Cylinder - Removal, Inspection and rebuild
Cylinder Removal
Cylinder Disassembly
Lift Cylinder Component Inspection
Cylinder Assembly
Installation
2.8 Mast Assembly And Disassembly Procedures
Mast Disassembly Procedure
Platform Section Removal (All Masts)
Mast Section 6 Removal (7 Section Mast)
Mast Section 5 Removal (6 & 7 Section Mast)
Mast Section 4 Removal (All Masts)
Mast Section 3 Removal (All Masts)
Mast Section 2 Removal (All Masts)
Mast Section 1 Disassembly (All Masts)
2.9 Mast Assembly
Mast Section 1 - Assembly (All Masts)
Mast Section 2 - Assembly (All Masts)
Mast Section 3 - Assembly (All Masts)
Mast Section 4 - Assembly (All Masts)
Mast Section 5 - Assembly (25/30/36/41 ft. Masts)
Mast Section 6 - Assembly (30/41 ft. Masts)
Platform Mounting Section - Assy. (All Masts)
2.10 Mast To Base Frame Installation
2.11 MAST CHAINS/CABLES AND SEQUENCING CABLES ADJUSTMENT
Mast Chain/Cable Adjustment
Sequencing Cable Adjustment
2.12 Sequence Cable replacement kit
Remove Old Cable
Replacement Cable Installation
Clamp Installation (Drum/Socket Type)
Section 3. troubleshooting3.1 General
3.2 Troubleshooting Information
3.3 Hydraulic Circuit Checks
3.4 ELECTRICAL SYSTEM - MULTIMETER BASICS
Grounding
Backprobing
Min/Max
Polarity
Scale
Continuity Measurement Over Long Distances
Requirements:
Procedure
3.5 ELECTRICAL SWITCH TESTING
Basic Check
Limit Switches
Automatic Switches
Switch Wiring - Low Side, High Side
3.6 Outrigger Interlock Contacts
Outrigger Socket and Outrigger Beam - Interlock Contacts
Outrigger Socket - Contactor Screw Mounting Instructions
Outrigger Beam - Interlock Contactor Plate Mounting Instructions
Detent Screws
- SuperPac Parts Manual
- StratoLift Parts Manual
