JLG Boom Lift 1930ES 2030ES 2630ES 2646ES 3246ES Service & Maintenance Manual 3121166 2025
Hyundai
86
176,834
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1930ES 2030ES 2630ES 2646ES 3246ES Boom Lift
Part Number: 3121166
Publication Date: 2025
Number of Pages: 222 Pages
Section A. Introduction - Maintenance Safety Precautions​
A. General​
B. Hydraulic System Safety​
C. Maintenance​
Section 1. Specifications​
1.1 Specifications​
1.2 Torque Requirements​
1.3 Lubrication​
1.4 Limit Switches​
1.5 Cylinder Specifications​
1.6 Major Component Weights​
1.7 Critical Stability Weights​
1.8 Torque ChartS​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
2.2 Service and Guidelines​
2.3 Lubrication and Information​
2.4 Cylinder Drift Test​
2.5 Pins and Composite Bearing Repair Guidelines​
2.6 Preventive Maintenance and Inspection Schedule​
Section 3. Chassis & Scissor Arms​
3.1 Diagnostic Port​
3.2 MDI (Multifunction Digital Indicator) and brake release​
3.3 Traction System​
3.4 Torque Hub​
3.5 Electric Drive Motor​
3.6 Electric Drive Motor​
3.7 Drive Motor Electrical Evaluation​
3.8 Power Module - Sevcon​
3.9 Power Module - ZAPI​
3.10 Battery Removal​
3.11 Battery Charger​
3.12 Battery Charger/Inverter (Option)​
3.13 Drive Motor Cable Routing​
3.14 Pothole Switch Replacement​
3.15 Ground Control Station​
3.16 Arms and Platform Positioning and Support​
3.17 Platform Removal​
3.18 Scissor Arms Removal​
3.19 Platform Control Station​
Section 4. Hydraulics​
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
4.3 Cylinder Checking Procedure​
4.4 Lift Pressure Setting Procedure​
4.5 Hydraulic Oil Fill​
4.6 Lift Cylinder Removal​
4.7 Pump/Motor​
4.8 Cylinder Repair​
Section 5. JLG Control System​
5.1 Hand Held Analyzer​
5.2 Tilt Sensor Calibration​
5.3 Tilt Sensor Electrical Evaluation​
5.4 Elevation Angle Sensor Electrical Evaluation​
5.5 Elevation Sensor Calibration​
5.6 Updating Software​
5.7 Troubleshooting​
5.8 Machine Model Adjustment - SEVCON - 1600346 Power Module​
5.9 Machine Model Adjustment - ZAPI - 1001092456 Power Module​
5.10 Machine Configuration Programming Information - SEVCON - 1600346​
5.11 Machine Configuration Programming Information - ZAPI - 1001092456​
Section 6. Diagnostic Trouble Codes​
6.1 Introduction​
6.2 DTC Index​
6.3 DTC Check Tables​
Section 7. General Electrical Information & Schematics​
7.1 General​
7.2 Multimeter Basics​
7.3 Applying Silicone Dielectric Compound To Amp Connectors​
7.4 Working With Deutsch Connectors​
7.5 Switches​
7.6 Circuit Boards: Inputs and Outputs​
7.7 Electrical Schematics and Layouts​
7.8 Hydraulic Schematic​
