Hyundai
86
176,834
JLG Boom Lift 1850SJ Service & Maintenance Manual 3122563400 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1850SJ Boom Lift
Part Number: 3122563400
Publication Date: 2026
Number of Pages: 1162 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specification​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires​
2.1.5 Major Component Weights​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 Hydraulic System​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Axle Extension System​
2.5.2 Drive Orientation System​
2.5.3 Steering Control System​
2.5.4 Drive/Steering Speed Control​
2.5.5 Traction Control System​
2.5.6 Ground Control Keyswitch System​
2.5.7 Jib Lift End of Stroke Dampening​
2.5.8 Hydraulic System Warm Up​
2.5.9 Function Speed Control System​
2.5.10 Swing Control System​
2.5.11 Chassis Tilt Indicator System​
2.5.12 Auxiliary Power System​
2.5.13 Water in Fuel Sensing System (Optional)​
2.5.14 Deutz Turbocharger Operation​
2.5.15 Deutz Engine with Diesel Exhaust Fluid (DEF)​
2.5.16 Selective Catalytic Reduction (SCR) - Machines Using Diesel Exhaust Fluid (DEF)​
2.5.17 Wire Rope Service Indicator​
2.5.18 Transport Position Sensing System​
2.5.19 Beyond Transport - Drive Speed Cutback System​
2.5.20 Drive/Steer - Boom Function Interlock System (UKCA/CE ONLY)​
2.5.21 Jib Stow System​
2.5.22 Envelope Control System​
2.5.23 Moment Control System​
2.5.24 Boom Control System (BCS) Functional Check (Push to Test) System​
2.5.25 Controlled Arc System​
2.5.26 Controlled Boom Angle System​
2.5.27 Envelope Tracking​
2.5.28 Slow Down System​
2.5.29 Dual Capacity System​
2.5.30 Swing Speed Proportioning​
2.5.31 Platform Load Sensing System​
2.5.32 Electronic Platform Leveling​
2.5.33 Boom Control Select​
2.5.34 Platform Control Enable System​
2.5.35 Bolt-on External Fall Arrest​
2.5.36 Control System Boom Sensors​
Clearsky Smart Fleet (If Equipped)​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Maintenance Schedules​
3.3.2 Diesel Exhaust Fluid (DEF) Tank​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Wire Rope​
3.7.2 Wire Rope Tensioning Adjustment​
3.7.3 Boom Preparation for Section Repositioning​
3.7.4 Wire Rope Tensioning Procedure​
3.7.5 Confirm Proper Boom Deployment Function​
3.7.6 Re-Assembly​
3.7.7 Boom Calibration​
3.7.8 Wire Rope Proximity Switch​
3.7.9 Powertrack Maintenance​
3.7.10 Boom Cleanliness Guidelines​
Hydraulic Filter Replacement​
3.8.1 Removal​
3.8.2 Installation​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
3.9.2 Wear Tolerance​
Generator Inspection​
3.10.1 Every 250 hours​
3.10.2 Every 500 hours​
3.10.3 Overload Protection​
3.10.4 Inspecting Brushes, Replacing Brushes, and Cleaning Slip Rings​
3.10.5 Troubleshooting​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
4.2.4 System Test​
Calibration Procedures​
4.3.1 Load Sensing System Calibration​
4.3.2 Axle Calibration​
4.3.3 Calibrating Tilt Sensor​
4.3.4 Boom Sensor Calibration​
4.3.5 Jib Sensor Calibrations​
4.3.6 Setting Crackpoints​
Special Procedures​
4.4.1 Fuel Tank Cleaning and Drying​
4.4.2 Cylinder Drift​
4.4.3 Drive Cutout Override Service Mode​
4.4.4 Boom Unlock Procedure​
4.4.5 Boom Recovery Mode​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Diagnostic Menu​
JLG Analyzer​
5.2.1 Introduction​
5.2.2 To Connect the JLG Control System Analyzer​
5.2.3 Using the Analyzer​
5.2.4 Changing the Access Level of the Hand Held Analyzer​
5.2.5 Adjusting Parameters Using the Hand Held Analyzer​
5.2.6 Machine Setup​
5.2.7 Level Vehicle Description​
5.2.8 Ground Control Console Display Gauge - Machines using Diesel Exhaust Fluid (DEF)​
5.2.9 Analyzer Flow Chart​
Analyzer Software Accessibility​
5.3.1 Machine Configuration Programming Information​
5.3.2 Machine Configuration Programming Settings​
5.3.3 Machine Personality Settings and Function Speeds​
Function Test​
CANBUS Communications​
5.6.1 Platform Leveling Fault Warning​
5.6.2 Fault Response​
Platform LCD Display​
5.7.1 Splash Screen​
5.7.2 Open-source Software Information Screen​
Reprogramming the Platform Display​
5.8.1 Reprogramming Procedure​
5.8.2 Error Screens and Troubleshooting​
5.9.1 ClearSky Smart FleetTM CS550 Configuration​
5.9.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
6.2.1 EMR5 Fault Codes​
6.2.2 Engine Trouble Codes​
Machine Fault Codes​
6.3.1 Diagnostic Fault Code​
6.3.2 Diagnostic Trouble Code​
6.3.3 ClearSky Smart Fleet DTC Fault Codes​
6.3.4 LSS Troubleshooting​
6.3.5 System Test Messages​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Oil Sampling Procedure​
7.3.3 Pressure setting Procedure​
7.3.4 Drive and Function Pump Start Up Procedures​
Torque Values​
Standard Hydraulic Diagram - Boom And Turntable​
Hydraulic Diagram - Chassis​
Hydraulic System​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Harness Layouts​
Board Layouts​
AMP Connector​
8.5.1 Assembly​
8.5.2 Disassembly​
8.5.3 Wedge Lock​
8.5.4 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
8.6.1 Connector Labels​
8.6.2 Component Labels​
Electrical Installation​
Telematics Gateway​
8.8.1 Telematics-Ready (TCU) Plug​
Wheel and Tire​
9.1.1 Tire Replacement​
9.1.2 Wheel Replacement​
9.1.3 Wheel Installation​
Chassis/Frame Assembly​
9.2.1 Axle​
9.2.2 Drive Hub and Motor​
9.2.3 Spindle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Load Sensing Pin Removal and Installation​
9.3.3 Cylinder Length Sensor​
9.3.4 Powertrack​
9.3.5 Hose Adjustment Procedure​
9.3.6 Boom Removal and Installation​
9.3.7 Jib​
9.3.8 Jib Straight Shimming Procedure​
9.3.9 Stowed Jib Shimming Procedure​
9.3.10 Rotator​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform/Support (Traditional Design)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
9.4.4 Bolt-on External Fall Arrest​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Surge Tank​
9.5.5 Pump Coupling Kit​
9.5.6 Air Filter Assembly​
9.5.7 Radiator Assembly​
9.5.8 Relay Assembly​
9.5.9 Starter​
9.5.10 Alternator​
9.5.11 Fuel Tank​
9.5.12 Pre-Fuel Filter and Fuel Pump​
Transmission​
Hydraulic Cylinders​
9.7.1 Upper Lift Cylinder​
9.7.2 Platform Level Cylinder​
9.7.3 Jib Lift Cylinder​
9.7.4 Telescope Cylinder​
9.7.5 Axle Deploy Cylinder​
9.7.6 Steer Cylinder​
Hydraulic Valves​
9.8.1 Main Control Valve​
9.8.2 Platform Valve (Traditional Platform)​
9.8.3 Platform Valve (Rapid Replaceable Platform)​
9.8.4 Traction valve​
9.8.5 Steer Valve​
Hydraulic Pumps​
9.9.1 Charge Pump​
9.9.2 Function Pump Assembly​
9.9.3 Drive Pump​
Electrical Components​
9.10.1 Battery​
Turntable​
9.11.1 Swing Drive Hub​
9.11.2 Setting Swing Gear Backlash​
9.11.3 Swing Bearing Torque Values​
9.11.4 Swing Bearing​
9.11.5 Rotary Coupling​
Generator Pulley​
9.12.1 Removal​
9.12.2 Installation​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Motor​
10.1.2 Drive Hub​
10.1.3 Free Wheeling Option​
10.1.4 Gear Hub Oil Service​
Boom and Jib Assembly​
10.2.1 Boom Assembly​
10.2.2 Boom Shimming Procedure​
10.2.3 Boom Lubrication Application​
Platform​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Pumps​
10.5.1 Drive Pumps​
10.5.2 Function Pump​
10.5.3 Charge Pump​
10.6.1 Axle Extend Cylinder​
10.6.2 Jib Level (Slave) Cylinder​
10.6.3 Platform Level Cylinder​
10.6.4 Boom Lift Cylinder​
10.6.5 Jib Lift Cylinder​
10.6.6 Jib Lock Cylinder​
10.6.7 Steer Cylinder​
10.6.8 Jib Telescope Cylinder​
10.6.9 Boom Telescope Cylinder​
Hydraulic Valves​
10.8.1 Hydraulic Oil Tank​
Turntable​
10.9.1 Swing Drive​
10.9.2 Swing Brake​
10.9.3 Rotary Coupling​
Generator Disassembly and Assembly​
10.10.1 Generator Disassembly and Assembly​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
Generator Schematics​
12.3.1 Generator Troubleshooting Circuit Diagram​
12.3.2 Generator Electrical Circuit Diagram​
12.3.3 Power Board Electrical Circuit Diagram​
12.3.4 Lead Connection List for Generator​
