JLG Boom Lift 1850SJ Service & Maintenance Manual 31223045
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1850SJ Boom Lift
Part Number: 31223045
Publication Date: 2024
Number of Pages: 1060 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
1.1.3 Do Not Operate Tags
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specification
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Tires
2.1.5 Major Component Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 Hydraulic System
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Axle Extension System
2.5.2 Drive Orientation System
2.5.3 Steering Control System
2.5.4 Drive/Steering Speed Control
2.5.5 Traction Control System
2.5.6 Ground Control Keyswitch System
2.5.7 Jib Lift End of Stroke Dampening
2.5.8 Hydraulic System Warm Up
2.5.9 Function Speed Control System
2.5.10 Swing Control System
2.5.11 Chassis Tilt Indicator System
2.5.12 Auxiliary Power System
2.5.13 Water in Fuel Sensing System (Optional)
2.5.14 Deutz Turbocharger Operation
2.5.15 Deutz Engine with Diesel Exhaust Fluid (DEF)
2.5.16 Selective Catalytic Reduction (SCR) - Machines Using Diesel Exhaust Fluid (DEF)
2.5.17 Wire Rope Service Indicator
2.5.18 Transport Position Sensing System
2.5.19 Beyond Transport - Drive Speed Cutback System
2.5.20 Drive/Steer - Boom Function Interlock System (UKCA/CE ONLY)
2.5.21 Jib Stow System
2.5.22 Envelope Control System
2.5.23 Moment Control System
2.5.24 Boom Control System (BCS) Functional Check (Push to Test) System
2.5.25 Controlled Arc System
2.5.26 Controlled Boom Angle System
2.5.27 Envelope Tracking
2.5.28 Slow Down System
2.5.29 Dual Capacity System
2.5.30 Swing Speed Proportioning
2.5.31 Platform Load Sensing System
2.5.32 Electronic Platform Leveling
2.5.33 Boom Control Select
2.5.34 Platform Control Enable System
2.5.35 Bolt-on External Fall Arrest
2.5.36 Control System Boom Sensors
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Maintenance Schedules
3.3.2 Diesel Exhaust Fluid (DEF) Tank
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Wire Rope
3.7.2 Wire Rope Tensioning Adjustment
3.7.3 Boom Preparation for Section Repositioning
3.7.4 Wire Rope Tensioning Procedure
3.7.5 Confirm Proper Boom Deployment Function
3.7.6 Re-Assembly
3.7.7 Boom Calibration
3.7.8 Wire Rope Proximity Switch
3.7.9 Powertrack Maintenance
3.7.10 Boom Cleanliness Guidelines
Hydraulic Filter Replacement
3.8.1 Removal
3.8.2 Installation
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Generator Inspection
3.10.1 Every 250 hours
3.10.2 Every 500 hours
3.10.3 Overload Protection
3.10.4 Inspecting Brushes, Replacing Brushes, and Cleaning Slip Rings
3.10.5 Troubleshooting
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 SkyGuard®
4.2.3 LSS Testing and Evaluation
4.2.4 System Test
Calibration Procedures
4.3.1 Load Sensing System Calibration
4.3.2 Axle Calibration
4.3.3 Calibrating Tilt Sensor
4.3.4 Boom Sensor Calibration
4.3.5 Jib Sensor Calibrations
4.3.6 Resetting The MSSO System
4.3.7 Setting Crackpoints
Special Procedures
4.4.1 Fuel Tank Cleaning and Drying
4.4.2 Cylinder Drift
4.4.3 Drive Cutout Override Service Mode
4.4.4 Boom Unlock Procedure
4.4.5 Boom Recovery Mode
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Diagnostic Menu
JLG Analyzer
5.2.1 Introduction
5.2.2 To Connect the JLG Control System Analyzer
5.2.3 Using the Analyzer
5.2.4 Changing the Access Level of the Hand Held Analyzer
5.2.5 Adjusting Parameters Using the Hand Held Analyzer
5.2.6 Machine Setup
5.2.7 Level Vehicle Description
5.2.8 Ground Control Console Display Gauge - Machines using Diesel Exhaust Fluid (DEF)
5.2.9 Analyzer Software
Analyzer Software Accessibility
5.3.1 Machine Configuration Programming Information
5.3.2 Machine Configuration Programming Settings
5.3.3 Machine Personality Settings and Function Speeds
Function Test
CANBUS Communications
5.6.1 Platform Leveling Fault Warning
5.6.2 Fault Response
ClearSky (CS550) Configuration and Troubleshooting
5.7.1 ClearSky Smart FleetTM CS550 Configuration
5.7.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
Machine Fault Codes
6.3.1 Diagnostic Fault Code
6.3.2 Diagnostic Trouble Code
6.3.3 ClearSky CSV3 Smart Fleet DTC Fault Codes
6.3.4 LSS Troubleshooting
6.3.5 System Test Messages
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Oil Sampling Procedure
7.3.3 Pressure setting Procedure
7.3.4 Drive and Function Pump Start Up Procedures
Torque Values
Standard Hydraulic Diagram - Boom And Turntable
Hydraulic Diagram - Chassis
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Harness Layouts
Board Layouts
AMP Connector
8.5.1 Assembly
8.5.2 Disassembly
8.5.3 Wedge Lock
8.5.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.6.1 Connector Labels
8.6.2 Component Labels
Telematics Gateway
8.7.1 Telematics-Ready (TCU) Plug
Electrical Installation
Removal and InstallationWheel and Tire
9.1.1 Tire Replacement
9.1.2 Wheel Replacement
9.1.3 Wheel Installation
Chassis/Frame Assembly
9.2.1 Axle
9.2.2 Drive Hub and Motor
9.2.3 Spindle Assembly
Boom
9.3.1 Boom Components Terminology
9.3.2 Load Sensing Pin Removal and Installation
9.3.3 Cylinder Length Sensor
9.3.4 Powertrack
9.3.5 Hose Adjustment Procedure
9.3.6 Boom Removal and Installation
9.3.7 Jib
9.3.8 Jib Straight Shimming Procedure
9.3.9 Stowed Jib Shimming Procedure
9.3.10 Rotator
Platform
9.4.1 Platform/Support
9.4.2 Bolt-on External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Relay Assembly
9.5.9 Starter
9.5.10 Alternator
9.5.11 Fuel Tank
9.5.12 Pre-Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Upper Lift Cylinder
9.7.2 Platform Level Cylinder
9.7.3 Jib Lift Cylinder
9.7.4 Telescope Cylinder
9.7.5 Axle Deploy Cylinder
9.7.6 Steer Cylinder
Hydraulic Valves
9.8.1 Main Control Valve
9.8.2 Platform Valve
9.8.3 Traction valve
Hydraulic Pumps
9.9.1 Gear Pump
9.9.2 Piston Pump Assembly
9.9.3 Tandem Pump
Electrical Components
9.10.1 Battery
Turntable
9.11.1 Swing Drive Hub
9.11.2 Setting Swing Gear Backlash
9.11.3 Swing Bearing Torque Values
9.11.4 Swing Bearing
9.11.5 Rotary Coupling
Generator Pulley
9.12.1 Removal
9.12.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Motor
10.1.2 Drive Hub
10.1.3 Free Wheeling Option
10.1.4 Gear Hub Oil Service
Boom and Jib Assembly
10.2.1 Boom Assembly
10.2.2 Boom Shimming Procedure
10.2.3 Boom Lubrication Application
Platform
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
Pumps
10.5.1 Drive Pumps
10.5.2 Function Pump
10.5.3 Gear Pump
Hydraulic Cylinders
10.6.1 Axle Extend Cylinder
10.6.2 Jib Level (Slave) Cylinder
10.6.3 Platform Level Cylinder
10.6.4 Boom Lift Cylinder
10.6.5 Jib Lift Cylinder
10.6.6 Jib Lock Cylinder
10.6.7 Steer Cylinder
10.6.8 Jib Telescope Cylinder
10.6.9 Boom Telescope Cylinder
Hydraulic Valves
10.8.1 Hydraulic Oil Tank
Turntable
10.9.1 Swing Drive
10.9.2 Swing Brake
10.9.3 Rotary Coupling
Generator Disassembly and Assembly
10.10.1 Generator Disassembly and Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Generator Schematics
12.3.1 Generator Troubleshooting Circuit Diagram
12.3.2 Generator Electrical Circuit Diagram
12.3.3 Power Board Electrical Circuit Diagram
12.3.4 Lead Connection List for Generator
- SuperPac Parts Manual
- StratoLift Parts Manual
