JLG Boom Lift 1500SJ Service & Maintenance Manual 3122341800 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1500SJ Boom Lift
Part Number: 3122341800
Publication Date: 2025
Number of Pages: 1120 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Dimensional Data
2.1.3 Engine Data
2.1.4 Tires
2.1.5 Critical Stability Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 Hydraulic System
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Capacities
2.4.6 Lubrication Schedule
Machine Characteristics
2.5.1 Axle Extension system
2.5.2 Drive System
2.5.3 Steering Control System
2.5.4 Drive/Steering Speed Control
2.5.5 Traction Control System
2.5.6 Drive Orientation System
2.5.7 Oscillating Axle System
2.5.8 Swing Speed Proportioning
2.5.9 Chassis Tilt Indicator System
2.5.10 Auxiliary Power System
2.5.11 HRC Engine Emission Characteristics
2.5.12 Diesel Particulate Filter (If Equipped)
2.5.13 Broken Cable Indicator System
2.5.14 Platform Control Enable System
2.5.15 Transport Position Sensing System
2.5.16 Beyond Transport - Drive Speed Cutback System
2.5.17 Drive/Steer – Boom Function Interlock System (CE/UKCA ONLY)
2.5.18 Jib Stow System
2.5.19 Envelope Tracking System
2.5.20 Moment Control System
2.5.21 Boom Control System (BCS) Functional Check (Push to Test) System
2.5.22 Main Lift/Jib Velocity Control
2.5.23 Jib Lift Functionality
2.5.24 Jib Telescope Functionality
2.5.25 Jib Swing Functionality
2.5.26 Jib Swing Deploy Sequence (Jib Pin Lock)
2.5.27 Jib Lock Pin Lamp Operation
2.5.28 Swing/Axle Extend Retract Restrictions
2.5.29 Dual Capacity
2.5.30 Jib Control During Over/Under Moment
2.5.31 Electronic Platform Leveling
2.5.32 Jib Control Module
2.5.33 Control System Boom Sensors
2.5.34 CAN Gateway
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 First 300 Hours or 6 Months
3.3.5 Every 500 Hours or 6 Months
3.3.6 Every 600 Hours or 1 year
3.3.7 Every 1000 Hours or 2 Years
3.3.8 Every 1200 Hours or 2 years
3.3.9 Routine Maintenance
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Wire Rope Tensioning Adjustment
3.7.2 Wire Rope
3.7.3 Broken Boom Cable Proximity Switch
3.7.4 Powertrack Maintenance
3.7.5 Boom Cleanliness Guidelines
Hydraulic Filter Replacement
3.8.1 Hydraulic Filter Removal
3.8.2 Hydraulic Filter Installation
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Engine General Inspection
3.10.1 General Maintenance
3.10.2 Deutz TD2.9L4 (UN ECE R96) and Deutz TCD2.9L4 (China IV) Engine
3.10.3 Deutz Engine TCD2.9L4 (T4F and Stage V)
Bio Fuel In Deutz Engines
3.11.1 General
3.11.2 Bio Fuel
3.11.3 Biological Contamination In Fuels
Deutz EMR5
Generator Inspection
3.13.1 Every 250 hours
3.13.2 Every 500 hours
3.13.3 Overload Protection
3.13.4 Inspecting Brushes, Replacing Brushes, and Cleaning Slip Rings
3.13.5 Troubleshooting
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 SkyGuard
4.2.2 LSS Testing and Evaluation
4.2.3 Control System Test
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Calibration Instructions
4.3.5 Calibrating Tilt Sensor
4.3.6 Calibrating Steer
4.3.7 Calibrating Drive
4.3.8 Calibrating Platform Level
4.3.9 Calibrating Lift Crack Point
4.3.10 Calibrating Telescope Crack point
4.3.11 Jib Sensor Calibrations
4.3.12 Calibrating the Boom Sensors
Special Procedure
4.4.1 Drive Cutout Override Service Mode
4.4.2 Fuel Tank Cleaning and Drying
4.4.3 Cylinder Drift
4.4.4 Oscillating Axle Bleeding Procedure and Lockout Test
4.4.5 Axle Limit Switch Adjustment Procedure
4.4.6 Drive Orientation System — Swing Envelope Service Mode
4.4.7 Jib Leveling During Automatic/Manual Envelope Control
4.4.8 Jib Swing Stow Sequence (Jib Pin Unlock)
4.4.9 Boom Recovery Mode
4.4.10 Boom Control System Check Procedure
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Diagnostic Menu
JLG Analyzer
5.2.1 Introduction
5.2.2 To Connect the JLG Control System Analyzer
5.2.3 Hand Held Analyzer
5.2.4 Using the Analyzer
5.2.5 Changing the Access Level of the Hand Held Analyzer
5.2.6 Adjusting Parameters Using the Hand Held Analyzer
5.2.7 Machine Setup
5.2.8 Level Vehicle Description
Analyzer Software Accessibility
5.3.1 Machine Set-Up
5.3.2 Personalities
5.3.3 Calibrations
Function Test
5.4.1 Machine Orientation When Setting Function Speeds
CANBUS Communications
5.6.1 Platform Leveling Fault Warning
5.6.2 Fault Response
Platform LCD Display
5.7.1 Splash Screen
5.7.2 Open-source Software Information Screen
Reprogramming the Platform Display
5.8.1 Reprogramming Procedure
5.8.2 Error Screens and Troubleshooting
ClearSky (CS550) Configuration and Troubleshooting
5.9.1 ClearSky Smart FleetTM CS550 Configuration
5.9.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Deutz TCD2.9L4 Engine
Machine Fault Codes
6.3.1 General
6.3.2 LSS Troubleshooting
6.3.3 ClearSky Smart Fleet DTC Fault Codes
6.3.4 System Test Messages
Machine Diagnostics Parameters
Deutz EMR Fault Codes
6.5.1 Deutz EMR5 Fault Codes
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Lubricating O-rings In The Hydraulic System
7.3.3 Hydraulic Pump Pre-Fill Procedures
7.3.4 Oil Sampling
7.3.5 Pressure Setting Procedure
7.3.6 Drive & Function Pump Start Up Procedures
Torque Values
Standard Hydraulic Diagram- Boom and Turntable
Hydraulic Diagram - Chassis
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
8.3.1 Chassis Electrical Components
8.3.2 Turntable Electrical Components
8.3.3 Jib Electrical Components
Harness Layouts
Board Layouts
8.5.1 Control Module Location
8.5.2 Ground Control Module
8.5.3 Platform Control Module
8.5.4 Chassis Control Module
8.5.5 BLAM Control Module
8.5.6 Jib Control Module
AMP Connector
8.6.1 Assembly
8.6.2 Disassembly
8.6.3 Wedge Lock
8.6.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Ground Control Box Wiring Diagram
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Chassis Component
9.2.2 Oscillating Axle
9.2.3 Fixed Axle
9.2.4 Axle Threadlocking Compound Application
9.2.5 Steering Installation
9.2.6 Drive Motor
Boom
9.3.1 Boom Component
9.3.2 Boom Removal and Installation
9.3.3 Cylinder Length Sensor
9.3.4 Rotator
9.3.5 Jib Rotator Torquing Procedure
9.3.6 Jib
9.3.7 Jib Straight Shimming Procedure
9.3.8 Load Sensing Pin Removal and Installation
9.3.9 Hose Routing
Platform
9.4.1 Platform Support
9.4.2 Bolt-on External Fall Arrest
9.5.1 Component Terminology
9.5.2 Deutz TD2.9L4 (UN ECE R96) Engine
9.5.3 Deutz TCD2.9L4 Engine
9.5.4 Deutz TCD2.9L4 (China IV) Engine
9.5.5 Deutz TCD2.9L4 (Stage V) Engine
9.5.6 Engine Serial Number
9.5.7 Engine Replacement
9.5.8 Surge Tank
9.5.9 Pump Coupling Kit
9.5.10 Air Filter Assembly
9.5.11 Radiator Assembly
9.5.12 Thermostat
9.5.13 Coolant Temperature Sensor
9.5.14 Relay Assembly
9.5.15 Starter
9.5.16 Alternator
9.5.17 Fuel Tank
9.5.18 Pre- Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Main Boom Lift Cylinder
9.7.2 Platform Leveling Cylinder
9.7.3 Jib Telescope Cylinder
9.7.4 Jib Lift Cylinder
9.7.5 Axle Lockout Cylinder
Hydraulic Valves
9.8.1 Platform Valve
9.8.2 Main Control Valve
9.8.3 Traction Control Valve
9.8.4 Steer Valve
9.8.5 Jib Control Valve
Hydraulic Pumps
9.9.1 Charge Pump
9.9.2 Function Pump
9.9.3 Drive Pump
9.9.4 Rexroth Pump
9.10.1 Battery
9.10.2 Cold Weather Package
Turntable
9.11.1 Turntable Component
9.11.2 Swing Drive
9.11.3 Swing Drive Lubrication
9.11.4 Rotary Coupling
9.11.5 Turntable/Swing Bearing Removal
9.11.6 Turntable/Swing Bearing Installation
9.11.7 Swing Bearing Torque Values
9.11.8 Counterweight
Generator Pulley
9.12.1 Removal
9.12.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Motor Assembly
Boom and Jib Assembly
10.2.1 Disassembly
10.2.2 Assembly
10.2.3 Boom Lubrication Application
10.2.4 Jib Assembly
10.2.5 Rotary Actuator
Pumps
10.3.1 Drive Pumps (Rexroth)
10.3.2 Function Pump (Rexroth)
10.3.3 Drive Pumps (Sauer)
10.3.4 Function Pump (Sauer)
10.3.5 Charge pump (Sauer)
Hydraulic Cylinders
10.4.1 Main Lift Cylinder
10.4.2 Platform Level Cylinder
10.4.3 Jib Lift Cylinder
10.4.4 Jib Level Cylinder
10.4.5 Jib Lock Cylinder
10.4.6 Steer Cylinder
10.4.7 Jib Telescope Cylinder
10.4.8 Main Boom Telescope Cylinder
10.4.9 Axle Lockout Cylinder
10.4.10 Axle Extend Cylinder
Turntable
10.5.1 Swing Drive Hub
10.5.2 Swing Drive
10.5.3 Swing Brake
10.5.4 Swing Motor
10.5.5 Rotary Coupling
Generator Disassembly and Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR5 Schematics
Generator Schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
