JLG Boom Lift 1500AJP Service & Maintenance Manual 3122563100 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1500AJP Boom Lift
Part Number: 3122563100
Publication Date: 2026
Number of Pages: 1128 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Tires
2.1.4 Engine Data
2.1.5 Major Component Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 Hydraulic System
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Engine Oil Specification
2.4.6 Hydraulic Oil
2.4.7 Capacities
2.4.8 Lubrication Schedule
Machine Characteristics
2.5.1 Axle Extension System
2.5.2 Drive Orientation System
2.5.3 Steering Control System
2.5.4 Drive/Steering Speed Control
2.5.5 Drive/Steer - Boom Function Interlock System (UKCA/CE Only)
2.5.6 Traction Control System
2.5.7 Chassis Tilt Indicator System
2.5.8 Auxiliary Power System
2.5.9 Swing Speed Proportioning
2.5.10 Boom Systems
2.5.11 Fuel Level Cutout System
2.5.12 Machine Sensors and Switches
2.5.13 Boom Sensor Positions/Functions
2.5.14 Electronic Platform Leveling System
2.5.15 JLG Control System
2.5.16 Electrical Retrieval System
2.5.17 Hydraulic Retrieval System
2.5.18 Generator
2.5.19 Water in Fuel Sensing System (Optional)
2.5.20 Deutz Turbocharger Operation
2.5.21 Hydraulic System Warm Up
2.5.22 SkyWelder
2.5.23 SkyGlazier™
2.5.24 Bolt-ON External Fall Arrest
2.5.25 Deutz Engine with Diesel Exhaust Fluid (DEF)
2.5.26 Selective Catalytic Reduction (SCR) - Machines Using Diesel Exhaust Fluid (DEF)
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 Every 300 Hours or 6 Months
3.3.5 Every 500 Hours or 1 Year
3.3.6 Every 500 Hours or 2 Years
3.3.7 Every 600 Hours or 1 Year
3.3.8 Every 1200 Hours or 2 years
3.3.9 Diesel Exhaust Fluid (DEF) Tank
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Wire Rope
3.7.2 Wire Rope Tensioning/Adjustment Procedure
3.7.3 Powertrack Maintenance
3.7.4 Break-In Lubrication
3.7.5 Boom Cleanliness Guidelines
Hydraulic Filter Replacement
3.8.1 Hydraulic Filter Removal
3.8.2 Hydraulic Filter Installation
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Generator Inspection
3.10.1 Generator Rating
3.10.2 Safety Precautions
3.10.3 Preparation and Inspection
3.10.4 Operation
3.10.5 Service and Maintenance
3.10.6 Maintenance Schedule
3.10.7 Overload Protection
3.10.8 Inspecting Brushes, Replacing Brushes, and Cleaning Slip Rings
3.10.9 Generator Troubleshooting
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 SkyGuard
4.2.2 LSS Testing and Evaluation
Calibration Procedures
4.3.1 Axle Calibration
4.3.2 Calibrating Steer
4.3.3 Calibrating Drive
4.3.4 Calibrating Tilt Sensor
4.3.5 Calibrating the Boom Sensors
4.3.6 Load Sensing System Calibration
4.3.7 Setting Crackpoints
Special Procedures
4.4.1 Fuel Tank Cleaning and Drying
4.4.2 Cylinder Drift
4.4.3 Boom Unlock
4.4.4 Hose Routing
4.4.5 Shimming Procedure for the Main Boom
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Diagnostic Menu
JLG Analyzer
5.2.1 To Connect the JLG Control System Analyzer
5.2.2 Using the Analyzer
5.2.3 Changing the Access Level of the Hand Held Analyzer
5.2.4 Adjusting Parameters Using the Hand Held Analyzer
5.2.5 Machine Setup
5.2.6 Level Vehicle Description
5.2.7 Ground Control Console Display Gauge - Machines using Diesel Exhaust Fluid (DEF)
5.2.8 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Machine Configuration Programming Information
5.3.2 Machine Personality Settings and Speeds
Function Test
5.4.1 Machine Orientation When Setting Function Speeds
5.5.1 Platform Leveling Fault Warning
5.5.2 Fault Response
Platform LCD Display
5.6.1 Splash Screen
5.6.2 Open-source Software Information Screen
Reprogramming the Platform Display
5.7.1 Reprogramming Procedure
5.7.2 Error Screens and Troubleshooting
ClearSky (CS550) Configuration and Troubleshooting
5.8.1 ClearSky Smart FleetTM CS550 Configuration
5.8.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
System Fault Codes
Valves Fault Codes
Sensors Fault Codes
6.5.1 LSS Troubleshooting
6.5.2 Boom Sensor Calibration Faults
6.5.3 Boom Unlock Faults
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Lubricating O-rings in the Hydraulic System
7.3.3 Hydraulic Pump Pre-Fill Procedures
7.3.4 Pressure Setting Procedure
7.3.5 Drive and Function Pump Start-Up Procedure
Torque Values
Standard Hydraulic Diagram- Boom And Turntable
7.5.1 Turntable Hydraulic Diagram
7.5.2 Jib and Rotator Hydraulic Diagram
Hydraulic Diagram - Chassis
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
AMP Connector
8.6.1 Assembly
8.6.2 Disassembly
8.6.3 Wedge Lock
8.6.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Connector Labels
8.7.2 Component Labels
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle
9.2.2 Drive Hub and Motor
9.2.3 Drive Motor
9.2.4 Spindle Assembly
9.2.5 Hose Routing
Boom
9.3.1 Boom and Cylinders Installation
9.3.2 Tower and Main Boom
9.3.3 Boom Sensor Installation
9.3.4 Rotator
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
9.4.4 Bolt-ON External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Relay Assembly
9.5.9 Starter
9.5.10 Alternator
9.5.11 Fuel Tank
9.5.12 Pre- Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Main Lift Cylinder
9.7.2 Tower Boom Lift Cylinder
9.7.3 Axle Deploy Cylinder
9.7.4 Steer Cylinder
Hydraulic Valves
9.8.1 Platform Valve
9.8.2 Main Control Valve
9.8.3 Traction Control Valve
9.8.4 Steer Valve
Hydraulic Pumps
9.9.1 Gear Pump
9.9.2 Piston Pump
9.9.3 Tandem Pump
Electrical Components
Turntable
9.11.1 Swing Drive Hub
9.11.2 Rotary Coupling
9.11.3 Swing Bearing
9.11.4 Setting Swing Gear Backlash
Generator Pulley
9.12.1 Removal
9.12.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Gear Hub Oil Service
10.1.3 Free Wheeling Option
Boom and Jib Assembly
10.2.1 Boom Disassembly/Assembly
10.2.2 Rotary Actuator
Pumps
10.3.1 Function Pump
10.3.2 Gear Pump
10.3.3 Drive Pump
Hydraulic Cylinders
10.4.1 Axle Extend Cylinder
10.4.2 Platform Level Cylinder
10.4.3 Jib Lift Cylinder
10.4.4 Main Boom Lift Cylinder
10.4.5 Tower Boom Lift Cylinder
10.4.6 Steer Cylinder
10.4.7 Main Boom Telescope Cylinder
10.4.8 Tower Boom Telescope Cylinder
Turntable
10.5.1 Swing Drive Hub
10.5.2 Swing Drive
10.5.3 Swing Brake
Generator
10.6.1 Generator Disassembly and Assembly
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Generator Schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
