JLG Boom Lift 1250AJP Service & Maintenance Manual 3122562500 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1250AJP Boom Lift
Part Number: 3122562500
Publication Date: 2026
Number of Pages: 940 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specification
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Chassis Specifications
2.1.5 Tires
2.1.6 Torque Requirements
2.1.7 Pressure Settings
2.1.8 Major Component Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Axle Extension System
2.5.2 Oscillating Axle System
2.5.3 Swing Speed Proportioning
2.5.4 HRC Engine Emission Characteristics
2.5.5 Diesel Particulate Filter (If Equipped)
2.5.6 Electronic Platform Leveling
2.5.7 Drive System
2.5.8 Steering Control System
2.5.9 Drive/Steering Speed Control
2.5.10 Traction Control System
2.5.11 Drive Orientation System
2.5.12 Chassis Tilt Indicator System
2.5.13 Auxiliary Power System
2.5.14 Platform Control Enable System
2.5.15 Transport Position Sensing System
2.5.16 Beyond Transport - Drive Speed Cutback System
2.5.17 Drive/Steer – Boom Function Interlock System (CE/UKCA ONLY)
2.5.18 Jib Stow System
2.5.19 Envelope Control System
2.5.20 Tower Path Control System
2.5.21 Automatic Main Boom Control System
2.5.22 Electrical Retrieval System
2.5.23 Hydraulic Retrieval System
2.5.24 Controlled Boom Angle System
2.5.25 Slow Down System
2.5.26 Dual Capacity System
2.5.27 Hydraulic System Warm Up
2.5.28 Reduced Platform Heights
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 First 150 Hours
3.3.4 Every 150 Hours or 3 Months
3.3.5 First 300 Hours or 6 Months
3.3.6 Every 500 Hours or 6 Months
3.3.7 Every 500 Hours or 1 Year
3.3.8 Every 600 Hours or 1 Year
3.3.9 Every 1200 Hours or 2 Years
Pins and Composite Bearing Repair Guidelines
Fuel Tank Inspection
Hydraulic Filter Replacement
Turntable Bearing Inspection
3.7.1 Turntable Bearing Mounting Bolt Condition Check
3.7.2 Wear Tolerance
Engine General Inspection
3.8.1 Deutz TCD2.9L4/TD2.9L4 Engines
3.8.2 Engine and Hydraulic Operating Temperature Specifications
Bio Fuel In Deutz Engines
3.9.1 General
3.9.2 Bio Fuel
3.9.3 Biological Contamination In Fuels
Deutz EMR5
Generator Inspection
3.11.1 Every 250 hours
3.11.2 Every 500 hours
3.11.3 Overload Protection
3.11.4 Inspecting Brushes, Replacing Brushes, and Cleaning Slip Rings
3.11.5 Troubleshooting
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 SkyGuard
4.2.3 LSS Testing and Evaluation
4.2.4 System Test
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Instructions
4.3.3 Calibration Preparation
4.3.4 Load Sensing System Calibration
4.3.5 Calibrating Platform Level
4.3.6 Calibrating Tilt Sensor
4.3.7 Boom Sensor Calibration
4.3.8 Rotary Angle Sensor Calibration
4.3.9 Boom Control System (BCS) Violation
4.3.10 Calibrating Steer
4.3.11 Calibrating Drive
4.3.12 Calibrating Boom Valves
Special Procedures
4.4.1 Fuel Tank Cleaning and Drying
4.4.2 Cylinder Drift
4.4.3 Oscillating Axle Bleeding Procedure and Lockout Test
4.4.4 Axle Limit Switch Adjustment Procedure
4.4.5 Tower Boom Drift Test
4.4.6 Drive Cutout Override Service Mode
4.4.7 Counterbalance Valve Check
4.4.8 Air Purge Procedure for Non-Calibrated Machines
4.4.9 Air Purge Procedure for Calibrated Machines
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Introduction
5.2.2 Machine Data Access
5.2.3 Hand Held Analyzer
5.2.4 Using the Analyzer
5.2.5 Changing Access Level of Hand Held Analyzer
5.2.6 Adjusting Parameters Using Hand Held Analyzer
5.2.7 Machine Setup
5.2.8 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Analyzer Diagnostics
5.3.2 Machine Set-Up
5.3.3 Machine Personality Settings and Function Speeds
Machine Orientation When Setting Speeds
CANBUS Communications
5.5.1 CANBUS Connections
5.5.2 CANBUS Communication Failure
Service Mode
5.6.1 Load Sensing System
5.6.2 Drive Cutout Override
5.6.3 Axle
5.7.1 Description
5.7.2 Normal Operation
5.7.3 Platform Leveling Fault Warning
5.7.4 Fault Response
5.7.5 CAN Errors
5.7.6 Additional Platform and Jib Valves
ClearSky (CS550) Configuration and Troubleshooting
5.8.1 ClearSky Smart FleetTM CS550 Configuration
5.8.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Engine Fault Codes (Deutz)
6.2.2 Engine Trouble Codes
Machine Fault Codes
6.3.1 General
6.3.2 ClearSky Smart Fleet DTC Fault Codes
6.3.3 LSS Troubleshooting
6.3.4 System Test Messages
Deutz EMR Fault Codes
6.4.1 Deutz EMR5 Fault Codes
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Tank
7.3.2 Pressure Setting Procedure
7.3.3 Drive and Function Pump Start Up
7.3.4 Rotary Coupling Ports
Torque Values
7.4.1 Main Valve Torque Specifications
Standard Hydraulic Diagram- Boom And Turntable
7.5.1 Boom
7.5.2 Turntable (with Rexroth Pump)
7.5.3 Turntable (with Sauer Pump)
Hydraulic Diagram - Chassis
7.6.1 4WD Chassis (with Rexroth Pump)
7.6.2 4WD Chassis (with Sauer Pump)
7.6.3 Oscillating Axle
7.6.4 Axle Extend and Steer
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Chassis Control Module
8.5.2 BLAM Control Module
8.5.3 Ground Control Module
8.5.4 Platform Control Module
AMP Connector
8.6.1 Applying Silicone Dielectric Compound to AMP Connectors
8.6.2 Assembly
8.6.3 Disassembly
8.6.4 Wedge Lock
8.6.5 Service - Voltage Reading
Wiring Harness
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Wheel Drive Assembly
9.2.2 Spindle
9.2.3 Axle
Boom
9.3.1 Boom Switches
9.3.2 Main Boom Powertrack
9.3.3 Tower Boom Powertrack
9.3.4 Tower Boom Installation and Assembly
9.3.5 Pin Clamp Installation Procedure
9.3.6 Boom Sensors
9.3.7 Rotary Angle Sensor
9.3.8 Jib Assembly
9.3.9 Rotator
9.3.10 Hose Routing Procedure
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
9.4.4 Bolt-on External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Thermostat
9.5.9 Coolant Temperature Sensor
9.5.10 Relay Assembly
9.5.11 Starter
9.5.12 Alternator
9.5.13 Fuel Tank
9.5.14 Pre-Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Tower Telescopic Cylinder
9.7.2 Tower Lift Cylinder
9.7.3 Main Lift Cylinder
9.7.4 Main Boom Telescope Cylinder
9.7.5 Platform Level Cylinder
9.7.6 Jib Lift Cylinder
9.7.7 Steer Cylinder
9.7.8 Axle Extend Cylinder
9.7.9 Axle Lockout Cylinder
Hydraulic Valves
9.8.1 Platform Valve (Traditional Design)
9.8.2 Platform Valve (Rapid Replaceable)
9.8.3 Main Control Valve
9.8.4 Traction Valve
9.8.5 Axle Extend and Steer Valve
9.8.6 Enable Valves
Hydraulic Pumps
9.9.1 Charge Pump
9.9.2 Function Pump
9.9.3 Drive Pump
9.9.4 Rexroth Pump
Electrical Components
9.10.1 Battery
9.10.2 Cold Weather Package
Turntable
9.11.1 Swing Drive Hub
9.11.2 Swing Brake
9.11.3 Procedure For Setting Gear Backlash
9.11.4 Swing Drive Lubrication
9.11.5 Rotary Coupling
9.11.6 Swing Bearing
9.11.7 Counterweight
Generator Pulley
9.12.1 Removal
9.12.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
Boom and Jib Assembly
10.2.1 Main Boom
10.2.2 Tower Boom
10.2.3 Rotary Actuator
Pumps
10.3.1 Drive Pumps
10.3.2 Function Pump
Hydraulic Cylinders
10.4.1 Disassembly
10.4.2 Cleaning and Inspection
10.4.3 Assembly
Turntable
10.5.1 Swing Drive Hub
10.5.2 Swing Drive
10.5.3 Swing Brake
10.5.4 Rotary Coupling Seal
Generator Disassembly and Assembly
Powertrack
10.7.1 One Piece Bracket Maintenance
10.7.2 Two Piece Bracket Maintenance
10.7.3 Snap Rings and Screws
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR5 Schematics
Generator Schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
