Hyundai
86
176,834
JLG Boom Lift 1230ES Service & Maintenance Manual 3122346200
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1230ES Boom Lift
Serial Number: P130000001 to Present
Part Number: 3122346200
Publication Date: 2024
Number of Pages: 296 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
General Machine Informations and Specifications
Specifications​
2.1.1 Operating Specifications​
2.1.2 Platform Capacities​
2.1.3 Dimensional Data​
2.1.4 Tires Specifications​
2.1.5 Battery Specifications​
2.1.6 Critical Stability Weights​
2.1.7 Cylinder Specifications​
Serial Number Locations​
Lubrication​
2.3.1 Hydraulic System​
2.3.2 Lubrication Capacities​
2.3.3 Lubrication Specifications​
2.3.4 Hydraulic Oil​
2.3.5 Changing Hydraulic Oil​
2.3.6 Hydraulic Oil Specifications​
2.3.7 Oil Check Procedure​
Machine Preparation, Inspection and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Preventive Maintenance and Inspection Schedule​
Servicing and Maintenance Guidelines​
3.3.1 General​
3.3.2 Safety and Workmanship​
3.3.3 Cleanliness​
3.3.4 Components Removal and Installation​
3.3.5 Component Disassembly and Reassembly​
3.3.6 Pressure-Fit Parts​
3.3.7 Bearings​
3.3.8 Gaskets​
3.3.9 Bolt Usage and Torque Application​
3.3.10 Hydraulic Lines and Electrical Wiring​
3.3.11 Hydraulic System​
3.3.12 Lubrication and Servicing​
3.3.13 Batteries​
Wheels and Tires - Drive and Rear​
3.4.1 Tire Wear and Damage​
3.4.2 Wheel and Tire Replacement​
Battery/Battery Charger​
3.5.1 Battery Maintenance and Safety Practices​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
Wheel Drive Assembly - Servicing​
4.2.1 Drive Motor Electrical Evaluation​
4.2.2 Roll and Leak Testing​
4.2.3 Oil Type and Capacity​
4.2.4 Drive Motor Power Harness Routing​
Tilt Sensor Calibration​
Tilt Sensor Electrical Evaluation​
Elevation Angle Sensor Electrical Evaluation​
4.5.1 Tilt vs. Allowed Height Evaluation​
Elevation Sensor Calibration​
Wheel Drive Brake - Manual Disengage Procedure​
Hydraulic System Pressure Settings​
Hydraulic Cylinder Component Inspection​
Hydraulic Cylinder Assembly Testing​
System Software
Overview​
Modes Of Operation​
5.2.1 Ground Mode​
5.2.2 Platform mode​
CAN Communications​
Controls and Sensors​
5.4.1 Elevation​
5.4.2 Joystick​
5.4.3 Tilt​
Traction​
5.5.1 Personalities​
5.5.2 Interlocks​
Pump/Lift/Mast​
5.6.1 Personalities​
5.6.2 Interlocks​
Steer​
5.7.1 Personalities​
5.7.2 Interlocks​
Electronic Control System​
5.8.1 To Connect the Hand Held Analyzer​
5.8.2 Using the Analyzer​
5.8.3 Changing the Access Level of the Hand Held Analyzer​
5.8.4 Machine Setup​
5.8.5 Diagnostic Trouble Codes (DTC)​
Machine Configuration Programming Information​
Machine Personality - Adjustment Settings​
Fault Codes
Introduction​
DTC Index​
DTC Check Tables​
Troubleshooting​
6.4.1 Battery Charger Troubleshooting​
6.4.2 Battery Charger Fault Codes​
6.4.3 Trackunit Troubleshooting​
Hydraulics
Hydraulic Pump/Motor/Valve Components​
7.1.1 Common Difficulties​
7.1.2 Pump Components​
7.1.3 Hydraulic System Pressure Check Port​
Multi-Stage Hydraulic Cylinder​
7.2.1 Overview​
7.2.2 Hydraulic Cylinder - Disassembly​
7.2.3 Hydraulic Cylinder - Assembly​
7.2.4 Hydraulic Cylinder Assembly Testing​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
8.1.11 Scissor Platform Cable at the Platform Control​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Layout​
Amp Connector​
8.4.1 Assembly​
8.4.2 Disassembly​
8.4.3 Wedge Lock​
8.4.4 Service - Voltage Reading​
Electrical Switches​
8.5.1 Basic check​
8.5.2 Limit Switches​
8.5.3 Automatic Switches​
8.5.4 Switch Wiring - Low Side, High Side​
Control Components​
8.6.1 Control Components Overview​
8.6.2 Control Components - Service​
Traction System​
8.7.1 Common Traction System Difficulties​
Power Module​
8.8.1 ZAPI Power Module Electrical Evaluation​
X-Connector​
8.9.1 Machine Location Of Component X-Connectors​
8.9.2 X-Connector References​
8.9.3 X-Connector Id Index​
Connector Loading Diagrams​
Pin Input /Output Types​
AC Power Receptacles And Wiring (Platform)​
Mast Components​
9.1.1 Mast Components Overview​
9.1.2 Mast Removal​
9.1.3 Mast Installation​
9.1.4 Mast Cover Plate - Installation​
Platform Tool Tray - Installation​
Pot Hole Protection System​
Base Frame Covers​
9.4.1 Base Top Cover - Installation​
9.4.2 Step Plate/Battery Charger Cover - Installation​
9.4.3 Battery Tray/Side Door - Installation​
Wheel Installation​
Rear Wheel Hub - Installation​
Steering Linkage Assembly - Installation​
Drive Motor/Spindle Assembly - Installation​
Wheel Drive Motor Assembly - Removal From Machine​
Pump/Motor/Valve Assembly - Removal/Installation​
Motor Cover/Motor Installation​
Preventative Maintenance - Brush Wear - Dust Removal Procedu​
Motor Brush Installation​
Ground Control Module​
9.14.1 Ground Control Station​
9.14.2 Printed Circuit Board (PCB) Replacement​
Tilt Sensor​
Battery Installation​
Battery Charger - Installation​
Battery Inverter Installation​
Platform Assembly​
9.19.1 Platform - Extending Mast Unpowered​
9.19.2 Platform Removal​
9.19.3 Platform Installation​
Platform AC Receptacle Box - Installation​
Disassembly and Assembly
Base Assembly Components​
Mast Disassembly​
Mast Assembly - Components​
Mast - Reassembly​
Mast Installation Completion​
Steer Cylinder​
10.6.1 Steer Cylinder Disassembly​
10.6.2 Steer Cylinder - Assembly​
Drive Motor​
10.7.1 Drive Motor Disassembly​
10.7.2 Drive Motor Inspection and Servicing​
10.7.3 Drive Motor Reassembly​
10.7.4 Motor Assembly​
Main Gear Box​
10.8.1 Main Gear Box Disassembly​
10.8.2 Main Gear Box Sub-Assembly​
Input Carrier​
10.9.1 Input Carrier Disassembly​
10.9.2 Input Carrier Sub-Assembly​
Hub​
10.10.1 Hub - Disassembly​
10.10.2 Hub Sub-Assembly​
Spindle​
10.11.1 Spindle Disassembly​
10.11.2 Spindle Sub-Assembly​
Platform Control Station​
10.12.1 Platform Control Station Assembly​
10.12.2 Upper Control Box - Component Replacement​
10.12.3 Lower Control Box - Component Replacement​
Multi-Stage Hydraulic Cylinder - Cylinder Bleeding Procedure​
Hydraulic Cylinder​
10.14.1 Hydraulic Cylinder - Disassembly​
10.14.2 Hydraulic Cylinder - Assembly​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
General​
Hydraulic Schematic​
Electrical Schematic​
