JLG Boom Lift 1230ES Service & Maintenance Manual 31220638
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1230ES Boom Lift
Part Number: 31220638
Publication Date: 2024
Number of Pages: 294 Pages
Brand: JLG
Safety
General
Safety Information
Safety Hazards
Safety Decals
Machine Verification
General Machine Informations and Specifications
Specifications
Serial Number Locations
Lubrication
Machine Preparation, Inspection and Maintenance
Preventive Maintenance and Inspection Schedule
Servicing and Maintenance Guidelines
Wheels and Tires - Drive and Rear
Battery/Battery Charger
Testing, Calibrations and Special Procedures
Special Tools
Wheel Drive Assembly - Servicing
Tilt Sensor Calibration
Tilt Sensor Electrical Evaluation
Elevation Angle Sensor Electrical Evaluation
Elevation Sensor Calibration
Wheel Drive Brake - Manual Disengage Procedure
Hydraulic System Pressure Settings
Hydraulic Cylinder Component Inspection
Hydraulic Cylinder Assembly Testing
System Software
Overview
Modes Of Operation
CAN Communications
Controls and Sensors
Traction
Pump/Lift/Mast
Steer
Electronic Control System
Machine Configuration Programming Information
Machine Personality - Adjustment Settings
Fault Codes
Introduction
DTC Index
DTC Check Tables
Troubleshooting
Hydraulics
Hydraulic Pump/Motor/Valve Components
Multi-Stage Hydraulic Cylinder
Electricals
Electrical Connectors
Electrical Layout
Amp Connector
Electrical Switches
Control Components
Traction System
Power Module
X-Connector
Connector Loading Diagrams
Pin Input /Output Types
AC Power Receptacles And Wiring (Platform)
Removal and Installation
Mast Components
Platform Tool Tray - Installation
Pot Hole Protection System
Base Frame Covers
Wheel Installation
Rear Wheel Hub - Installation
Steering Linkage Assembly - Installation
Drive Motor/Spindle Assembly - Installation
Wheel Drive Motor Assembly - Removal From Machine
Pump/Motor/Valve Assembly - Removal/Installation
Motor Cover/Motor Installation
Preventative Maintenance - Brush Wear - Dust Removal Procedu
Motor Brush Installation
Ground Control Module
Tilt Sensor
Battery Charger - Installation
Battery Inverter Installation
Platform Assembly
Platform AC Receptacle Box - Installation
Disassembly and Assembly
Base Assembly Components
Mast Disassembly
Mast Assembly - Components
Mast - Reassembly
Mast Installation Completion
Steer Cylinder
Drive Motor
Main Gear Box
Input Carrier
Hub
Spindle
Platform Control Station
Multi-Stage Hydraulic Cylinder - Cylinder Bleeding Procedure
Hydraulic Cylinder
Torque/Connection Information
Hydraulic Fittings
Torque Charts
Schematics
General
Hydraulic Schematic
Electrical Schematic
- SuperPac Parts Manual
- StratoLift Parts Manual
