JLG Boom Lift 1230ES Service & Maintenance Manual 31219983
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1230ES Boom Lift
Part Number: 31219983
Publication Date: 2024
Number of Pages: 238 Pages
Brand: JLG
MACHINE SPECIFICATIONS
Operating Specifications (concept)
Lubrication (task)
Cylinder Specifications (concept)
Torque Requirements (concept)
Serial Number Locations (concept)
Threadlocking Compound (concept)
Torque Charts (concept)
GENERAL SERVICE INFORMATION
Machine Preparation, Inspection, And Maintenance (concept)
Preventive Maintenance And Inspection Schedule (concept)
Servicing And Maintenance Guidelines (concept)
Lubrication Information (concept)
THEORY OF OPERATION
Overview (concept)
Modes Of Operation (concept)
Can Communications (concept)
Controls and Sensors (concept)
Traction (concept)
Pump/Lift/Mast (concept)
Steer (concept)
BASE COMPONENTS
Base Assembly Components (concept)
Base Frame Covers (concept)
Wheels And Tires - Drive And Rear (task)
Rear Wheel Hub - Installation (task)
Steering Linkage Assembly - Installation (concept)
Steer Cylinder - Servicing (task)
Drive Motor/Spindle Assembly - Installation (concept)
Wheel Drive Assembly - Servicing (task)
Hydraulic Pump/Motor/Valve Assembly - Service Procedure (tas
Pot Hole Protection System (concept)
CONTROL COMPONENTS
Control Components Overview (concept)
Control Components - Service (concept)
Traction System (task)
Power Module (concept)
Ground Control Module - Service Procedure (task)
Platform Control Station - Service Information (task)
Battery/Battery Charger (concept)
Battery Charger - Installation (task)
Battery Inverter Installation (concept)
MAST COMPONENTS
Mast Components Overview (concept)
Platform Tool Tray - Installation (concept)
Mast Cover Plate - Installation (concept)
Platform AC Receptacle Box - Installation (concept)
Mast Assembly - Components (concept)
Platform Assembly (task)
Mast Assembly (task)
Multi-Stage Hydraulic Cylinder - Servicing (task)
JLG CONTROL SYSTEM
Electronic Control System (task)
Machine Configuration Programming Information (concept)
Machine Personality - Adjustment Settings (concept)
Tilt Sensor Calibration (task)
Tilt Sensor Electrical Evaluation (concept)
Elevation Angle Sensor Electrical Evaluation (concept)
Elevation Sensor Calibration (task)
DIAGNOSTIC TROUBLE CODES
Introduction (concept)
DTC Index (concept)
DTC Check Tables (concept)
GENERAL ELECTRICAL INFORMATION & SCHEMATICS
General (concept)
Multimeter Basics (task)
Applying Silicone Dielectric Compound To Amp Connectors (con
Dielectric Grease Application (concept)
Amp Connector (task)
Working With Deutsch Connectors (task)
Electrical Switch Testing (task)
X-Connector References (concept)
Connector Loading Diagrams (concept)
X-Connector Id Index (concept)
Machine Location Of Component X-Connectors (concept)
Electrical Layout And Schematics (concept)
Electrical Schematics (concept)
Pin Input /Output Types (reference)
AC Power Receptacles And Wiring (Platform) - CE Spec Machine
Hydraulic Schematic (concept)
- SuperPac Parts Manual
- StratoLift Parts Manual
