Hyundai
86
176,834
JLG Boom Lift 1200SJP 1350SJP Parts Catalog 31222383
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1200SJP 1350SJP Boom Lift
Part Number: 31222383
Publication Date: 2025
Number of Pages: 976 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED​
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING​
FIGURE 1-3. STEER INSTALLATION​
FIGURE 1-4. WHEEL DRIVE INSTALLATION - REGGIANA RIDUTTORI​
FIGURE 1-5. DRIVE HUB AND MOTOR ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-6. DRIVE HUB ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - FOAM FILLED​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - FOAM FILLED NON MARKING​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - SOLID​
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - SOLID NON MARKIMG​
FIGURE 1-12. FRAME VALVES INSTALLATION​
FIGURE 1-13. STEER VALVE ASSEMBLY​
FIGURE 1-14. TRACTION VALVE ASSEMBLY​
FIGURE 1-15. FRAME COVERS INSTALLATION - ABS​
FIGURE 1-16. FRAME COVERS INSTALLATION - STEEL​
SECTION 2 - TURNTABLE
FIGURE 2-1. TURNTABLE VALVES INSTALLATION​
FIGURE 2-2. BATTERY AND AUXILIARY PUMP INSTALLATION - ABS HOODS​
FIGURE 2-3. BATTERY AND AUXILIARY PUMP INSTALLATION - STEEL HOODS​
FIGURE 2-4. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-5. MAIN VALVE ASSEMBLY​
FIGURE 2-6. SWING DRIVE INSTALLATION​
FIGURE 2-7. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-8. TURNTABLE LOCK INSTALLATION​
FIGURE 2-9. PINION SHIELD INSTALLATION​
FIGURE 2-10. EXTREME HOSTILE PACKAGE INSTALLATION (OPTIONAL)​
FIGURE 2-11. SWING MOTOR/HUB ASSEMBLY​
FIGURE 2-12. ROTARY COUPLING AND COLLECTOR RING INSTALLATION (ROTARY COUPLING WITH SN PLATE)​
FIGURE 2-13. ROTARY COUPLING AND COLLECTOR RING ASSEMBLY​
FIGURE 2-14. TANK INSTALLATION - WITH ABS HOODS​
FIGURE 2-15. TANK INSTALLATION - WITH STEEL HOODS​
FIGURE 2-16. TANK INSTALLATION - WITH STEEL HOODS AND 52.8 GAL/200 L FUEL TANK​
FIGURE 2-17. HYDRAULIC OIL TANK ASSEMBLY​
FIGURE 2-18. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-19. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-20. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-21. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH REXROTH PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-22. HYDRAULIC OIL COOLER INSTALLATION – DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V & CHINA IV) ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-23. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH SAUER PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-24. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (CE & UK CA SPECS)​
FIGURE 2-25. GROUND CONTROL BOX INSTALLATION – DEUTZ TD2011 ENGINES WITH SAUER PUMPS (CE & UK CA SPECS)​
FIGURE 2-26. GROUND CONTROL BOX INSTALLATION – DEUTZ TCD2.9L4 ENGINES (ANSI, ANSI EXPORT, CSA, CHINA AND JAPANESE SPECS)​
FIGURE 2-27. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH REXROTH PUMPS (ANSI EXPORT AND AUSTRALIAN SPECS)​
FIGURE 2-28. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH SAUER PUMPS (ANSI EXPORT AND AUSTRALIAN SPECS)​
FIGURE 2-29. GROUND CONTROL BOX INSTALLATION - DEUTZ TCD2.9L4 ENGINES (STAGE V)​
FIGURE 2-30. GROUND CONTROL BOX INSTALLATION - DEUTZ TCD2.9L4 ENGINES (CHINA IV)​
FIGURE 2-31. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 ENGINES - WITH MECHANICAL HOUR METER​
FIGURE 2-32. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2011 ENGINES​
FIGURE 2-33. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 STAGE V ENGINES​
FIGURE 2-34. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 CHINA IV ENGINES​
FIGURE 2-35. GROUND CONTROL PANEL ASSEMBLY​
FIGURE 2-36. KEYSWITCH INSTALLATION​
FIGURE 2-37. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-38. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-39. ALARM INSTALLATION​
FIGURE 2-40. ALARM AMBIENT (WHITE NOISE) INSTALLATION (ALARM WITH HORIZONTAL BAR GRILLE)​
FIGURE 2-41. ALARM AMBIENT (WHITE NOISE) INSTALLATION (ALARM WITH CROSS HATCH GRILLE)​
FIGURE 2-42. STROBE LIGHT INSTALLATION (AMBER) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-43. STROBE LIGHT INSTALLATION (BLUE) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-44. STROBE LIGHT INSTALLATION (RED) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-45. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2011 ENGINES​
FIGURE 2-46. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2.9L4/TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 2-47. HOOD INSTALLATIONS - DEUTZ TD2011 ENGINES (ABS)​
FIGURE 2-48. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (ABS)​
FIGURE 2-49. HOOD INSTALLATION - DEUTZ TD2011/TD2.9L4/TCD2.9L ENGINES (STEEL)​
FIGURE 2-50. HOOD INSTALLATION - DEUTZ TCD2.9L (CHINA IV) ENGINES (STEEL)​
FIGURE 2-51. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (STEEL)​
FIGURE 2-52. HOOD KIT DEUTZ TCD2.9L4 (CHINA IV) ENGINE​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-2. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-3. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOOD (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-4. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-5. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-6. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-7. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-8. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-9. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-10. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-11. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-12. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-13. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WTH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-14. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-15. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-16. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-17. DEUTZ TD2011 ENGINE COMPONENTS​
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-20. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-22. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-23. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-24. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-25. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-26. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-27. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-28. DEUTZ TCD2.9L4 (EMR4) ENGINE INSTALLATION - WITH PMP PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-29. DEUTZ D2.9L4 - (EMR4) ENGINE INSTALLATION WITH PMP PUMP AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-30. DEUTZ TCD2.9L4 (EMR4) ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-31. DEUTZ TCD2.9L4 (EMR4) ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-32. DEUTZ TCD2.9L4 (EMR4) ENGINE SUB-ASSEMBLY - WITH SAUER PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-33. DEUTZ TCD2.9L4 (EMR4) ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-34. DEUTZ D2.9L4 (EMR4) ENGINE SUB-ASSEMBLY WITH PMP PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-35. DEUTZ D2.9L4 (EMR4) ENGINE SUB-ASSEMBLY WITH PMP PUMP AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-36. DEUTZ TCD2.9L4 (EMR4) ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-37. DEUTZ TCD2.9L4 (EMR4) ENGINE ASSEMBLY (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-38. DEUTZ TCD2.9L4 (EMR4) ENGINE COMPONENTS​
FIGURE 3-39. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH PMP PUMP AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-40. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH PMP PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-41. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH PMP PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-42. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH REXROTH PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-43. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-44. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH REXROTH PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-45. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH SAUER PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-46. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH SAUER PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-47. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-48. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH PMP PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-49. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH PMP PUMPS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-50. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH REXROTH PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-51. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH REXROTH PUMPS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-52. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH SAUER PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-53. DEUTZ D2.9L4 - EMR5 ENGINE SUB-ASSEMBLY WITH SAUER PUMPS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-54. DEUTZ D2.9L4 - EMR5 ENGINE ASSEMBLY (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-55. DEUTZ D2.9L4 - EMR5 ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-56. ENGINE COMPONENTS - DEUTZ TCD2.9L4 EMR5 ENGINE​
FIGURE 3-57. DEUTZ TCD2.9L4 (STAGE V) ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-58. DEUTZ TCD2.9L4 (STAGE V) ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-59. DEUTZ TCD2.9L4 (STAGE V) ENGINE INSTALLATION - WITH PMP PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-60. DEUTZ TCD2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY - WITH SAUER PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-61. DEUTZ TCD2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-62. DEUTZ D2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY WITH PMP PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-63. DEUTZ TCD2.9L4 (STAGE V) ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-64. DEUTZ TCD2.9L4 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-65. DEUTZ TCD2.9L4 (CHINA IV) ENGINE INSTALLATION - WITH SAUER PUMPS​
FIGURE 3-66. DEUTZ TCD2.9L4 (CHINA IV) SUB - ASSEMBLY - WITH SAUER PUMPS​
FIGURE 3-67. ENGINE ASSEMBLY - DEUTZ TCD2.9L4 (CHINA IV)​
FIGURE 3-68. DEUTZ TCD2.9L4 (CHINA IV) ENGINE COMPONENTS​
FIGURE 3-69. PUMP ASSEMBLY (REXROTH) (DEUTZ TD2011 ENGINES)​
FIGURE 3-70. PUMP ASSEMBLY (REXROTH) (DEUTZ TCD2.9L4 ENGINES)​
FIGURE 3-71. PUMP ASSEMBLY (SAUER TANDEM)​
FIGURE 3-72. PUMP ASSEMBLY (SAUER PISTON)​
FIGURE 3-73. PUMP ASSEMBLY (SAUER GEAR)​
FIGURE 3-74. PUMP ASSEMBLY - HYDRAULIC TANDEM​
FIGURE 3-75. PUMP ASSEMBLY - HYDRAULIC PISTON​
FIGURE 3-76. PUMP COUPLING KIT​
FIGURE 3-77. WATER/FUEL SEPARATOR INSTALLATION - DEUTZ TD2011 ENGINE​
FIGURE 3-78. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TCD2.9L4 ENGINE AND DEUTZ TCD2.9L4 (STAGE V) ENGINE​
FIGURE 3-79. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TD2.9L4 ENGINE (CHINA SPECS ONLY)​
FIGURE 3-80. FUEL FILTER/WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 & TCD2.9L ENGINES​
FIGURE 3-81. QUICKFIT OIL VALVE​
FIGURE 3-82. SPARK ARRESTING CATALYTIC MUFFLER - DEUTZ TD2011 ENGINES (OPTIONAL)​
FIGURE 3-83. 2500W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-84. 2500W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-85. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-86. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-87. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-88. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES) (OPTIONAL)​
FIGURE 3-89. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-90. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-91. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-92. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-2. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-3. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-4. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-5. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-6. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-7. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-8. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-9. WIRE ROPE TOOLS INSTALLATION (OPTIONAL)​
FIGURE 4-10. PLATFORM ROTATE ASSEMBLY​
FIGURE 4-11. JIB ROTATE ASSEMBLY​
FIGURE 4-12. POWER TRACK INSTALLATION (1200SJP)​
FIGURE 4-13. POWER TRACK INSTALLATION (1350SJP)​
FIGURE 4-14. BOOM SENSORS AND SWITCHES INSTALLATION​
FIGURE 4-15. PLATFORM SUPPORT INSTALLATION​
FIGURE 4-16. CONTROL VALVE INSTALLATION​
FIGURE 4-17. CONTROL VALVE ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-2. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - WITH DROP BAR​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH DROP BAR​
FIGURE 5-5. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT AND CHINA SPECS)​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ANSI SPEC)​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (AUSTRALIAN SPECS)​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (1 GATE/2 DROP BARS)​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (3 DROP BARS)​
FIGURE 5-14. PLATFORM CONTROLS INSTALLATION​
FIGURE 5-15. PLATFORM CONSOLE ASSEMBLEY​
FIGURE 5-16. BOOM CONTROL SELECT SWITCH INSTALLATION​
FIGURE 5-17. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 4FFT/1.22M PLATFORM)​
FIGURE 5-18. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM​
FIGURE 5-19. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM (​
FIGURE 5-20. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 8FT/2.4M PLATFORM​
FIGURE 5-21. FOOTSWITCH ASSEMBLY​
FIGURE 5-22. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-23. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-24. PLASMA CUTTER ASSEMBLY​
FIGURE 5-25. SKYCUTTER INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 5-26. SKYEYE INSTALLATION​
FIGURE 5-27. SKYGLAZIER INSTALLATION (ANSI AND CSA SPECS)​
FIGURE 5-28. SKYGLAZIER INSTALLATION (BRAZIL SPECS)​
FIGURE 5-29. SKYGLAZIER INSTALLATION (DANISH SPECS)​
FIGURE 5-30. SKYGLAZIER INSTALLATION (FINNISH SPECS)​
FIGURE 5-31. SKYGLAZIER INSTALLATION (FRENCH SPECS)​
FIGURE 5-32. SKYGLAZIER INSTALLATION (GERMAN SPECS)​
FIGURE 5-33. SKYGLAZIER INSTALLATION (ITALIAN SPECS)​
FIGURE 5-34. SKYGLAZIER INSTALLATION (LATIN AMERICAN SPECS)​
FIGURE 5-35. SKYGLAZIER INSTALLATION (PORTUGUESE SPECS)​
FIGURE 5-36. SKYGLAZIER INSTALLATION (SPANISH SPECS)​
FIGURE 5-37. SKYGLAZIER INSTALLATION (SWEDISH SPECS)​
FIGURE 5-38. SKYGLAZIER INSTALLATION (UK SPECS)​
FIGURE 5-39. SKYGUARD BAR INSTALLATION​
FIGURE 5-40. SKYLINE INSTALLATION​
FIGURE 5-41. SKYWELDER INSTALLATION (50HZ) (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS)​
FIGURE 5-42. SKYWELDER INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 5-43. SKYWELDER PREP PACKAGE (60HZ) (ANSI, ANSI EXPORT, CSA AND CHINA SPECS)​
FIGURE 5-44. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 5-45. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.8M PLATFORMS (ALL SPECS)​
FIGURE 5-46. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.4M PLATFORMS (ALL SPECS) (1350SJP)​
FIGURE 5-47. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.4M PLATFORMS (ANSI SPECS WITH SN STARTING WITH 03)) (1350SJP)​
FIGURE 5-48. TRAY ASSEMBLY​
FIGURE 5-49. USB CHARGER INSTALLATION​
FIGURE 5-50. WELDER ASSEMBLY​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE EXTENSION CYLINDER ASSEMBLY​
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-3. PLATFORM LEVEL CYLINDER ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE​
FIGURE 6-4. PLATFORM LEVEL CYLINDER ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY​
FIGURE 6-6. JIB CYLINDER ASSEMBLY - WITH OR WITHOUT COLD WEATHER PLUS PACKAGE​
FIGURE 6-7. STEER CYLINDER ASSEMBLY​
FIGURE 6-8. TELESCOPE CYLINDER ASSEMBLY (1200SJP)​
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY (1350SJP)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - BOOM (1200SJP)​
FIGURE 7-2. HYDRAULIC DIAGRAM - BOOM (1350SJP)​
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE​
FIGURE 7-4. HYDRAULIC DIAGRAM - OSCILLATING AXLE​
FIGURE 7-5. HYDRAULIC DIAGRAM - STEER​
FIGURE 7-6. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TD2011 ENGINES WITH REXROTH PUMPS)​
FIGURE 7-7. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS)​
FIGURE 7-8. HYDRAULIC DIAGRAM - TURNTABLE (WITH SAUER PUMPS)​
FIGURE 7-9. HYDRAULIC DIAGRAM - TURNTABLE (WITH PMP PUMPS) (SN B300023322 to Present, SN B300023675 to Present, Excluding B300023444)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM - 110V (ANSI SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM - 110V GFI RECEPTACLE (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM - 220V GFI RECEPTACLE (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (2X4 BOX) WITH 4000W GENERATOR (AUSTRALIAN SPECS)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN & CE & UK CA SPECS)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-17. AC 16 AMP BREAKER BOX INSTALLATION (CE & UK CA SPECS)​
FIGURE 8-18. ANALYZER CABLE HARNESS​
FIGURE 8-19. AXLE POWER TRACK HARNESS ASSEMBLY​
FIGURE 8-20. BATTERY DISCONNECT SWITCH​
FIGURE 8-21. BEACON LIGHT HARNESS (BLUE BEACON LIGHT ONLY)​
FIGURE 8-22. B.L.A.M. TO BOOM LENGTH SENSOR HARNESS​
FIGURE 8-23. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (LEFT SIDE)​
FIGURE 8-24. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (RIGHT SIDE)​
FIGURE 8-25. B.L.A.M. HARNESS​
FIGURE 8-26. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1200SJP)​
FIGURE 8-27. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1350SJP)​
FIGURE 8-28. BOOM CABLES INSTALLATION (AUSTRALIAN, CE & UK CA SPECS) (1200SJP)​
FIGURE 8-29. BOOM CABLES INSTALLATION (AUSTRALIAN, CE & UK CA SPECS) (1350SJP)​
FIGURE 8-30. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (1200SJP)​
FIGURE 8-31. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (1350SJP)​
FIGURE 8-32. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR (1200SJP)​
FIGURE 8-33. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR (1350SJP)​
FIGURE 8-34. BREAKER BOX KIT - 16 AMP (2500W GENERATOR)​
FIGURE 8-35. BREAKER BOX KIT - 16 AMP (4000W GENERATOR)​
FIGURE 8-36. CHASSIS HARNESS ASSEMBLY​
FIGURE 8-37. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)​
FIGURE 8-38. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE, AND UK CA SPECS)​
FIGURE 8-39. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS)​
FIGURE 8-40. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)​
FIGURE 8-41. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS)​
FIGURE 8-42. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-43. CLEARSKY INSTALLATION - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES (CHINA SPECS)​
FIGURE 8-44. CLEARSKY HARNESS - 3-WIRE TELEMATICS​
FIGURE 8-45. CLEARSKY HARNESS - CANBUS TELEMATICS​
FIGURE 8-46. CLEARSKY HARNESS - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-47. CLEARSKY TELEMATICS JUMPER HARNESS - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-48. TELEMATICS CONTROL MODULE ASSEMBLY - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-49. CLEARSKY READY HARNESS​
FIGURE 8-50. DIAGNOSTIC HARNESS​
FIGURE 8-51. DUAL CAPACITY JIB POSITION SWITCH HARNESS​
FIGURE 8-52. ENGINE HARNESS - DEUTZ TD2011 ENGINES AND DEUTZ TD2.9L4 ENGINES​
FIGURE 8-53. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TCD2.9L4 ENGINES​
FIGURE 8-54. ENGINE HARNESS - DEUTZ TCD2.9L4 (STAGE V) & DEUTZ TCD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-55. FUEL FILTER HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-56. FUEL HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-57. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-58. GENERATOR HARNESS - 7500W GENERATOR​
FIGURE 8-59. GROUND CONTROL BOX HARNESS​
FIGURE 8-60. GROUND CONTROLS TO ENGINE HARNESS​
FIGURE 8-61. JIB STOW SWITCH HARNESS​
FIGURE 8-62. LOAD SENSING PIN HARNESS​
FIGURE 8-63. LOCKOUT VALVE HARNESS​
FIGURE 8-64. MAIN BOOM CONTROL CABLE HARNESS (1200SJP)​
FIGURE 8-65. MAIN BOOM CONTROL CABLE HARNESS (1350SJP)​
FIGURE 8-66. MAIN VALVE HARNESS​
FIGURE 8-67. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-68. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-69. PLATFORM INTERFACE HARNESS​
FIGURE 8-70. PLATFORM VALVE HARNESS​
FIGURE 8-71. PUMP ADAPTER HARNESS - SAUER PUMPS​
FIGURE 8-72. RECEPTACLE BOX KIT - 110V IEC YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-73. RECEPTACLE BOX KIT - 220V IEC BLUE WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-74. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-75. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-76. RECEPTACLE BOX KIT - 220V AFSINT 107 KEYED GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-77. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-78. SKYEYE EMITTER HARNESS​
FIGURE 8-79. SKYEYE RECEIVER HARNESS​
FIGURE 8-80. SKYLINE HARNESS​
FIGURE 8-81. STROBE LIGHT HARNESS (AMBER)​
FIGURE 8-82. TILT SENSOR HARNESS (LEFT)​
FIGURE 8-83. TILT SENSOR HARNESS (RIGHT)​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI SPEC​
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPEC​
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPEC (PORTGUESE/ENGLISH)​
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC​
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)​
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (ENGLISH/FRENCH)​
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH)​
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)​
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPEC (SPANISH/ENGLISH)​
FIGURE 9-10. DECAL INSTALLATION - OPTIONS​
FIGURE 9-11. SKYCUTTER DECAL INSTALLATION (ANSI, ANSI EXPORT, CHINESE & CSA SPECS)​
FIGURE 9-12. SKYCUTTER DECAL INSTALLATION (JAPANESE SPECS)​
FIGURE 9-13. SKYWELDER DECAL INSTALLATION - 50HZ​
FIGURE 9-14. SKYWELDER DECAL INSTALLATION - 60HZ​
SECTION 11 - SPECIAL OPTIONS
PART NUMBER INDEX
