Hyundai
86
176,834
JLG Boom Lift 1200SJP 1350SJP Parts Catalog 31220397
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1200SJP 1350SJP Boom Lift
Part Number: 31220397
Publication Date: 2025
Number of Pages: 964 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED​
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING​
FIGURE 1-3. STEER INSTALLATION​
FIGURE 1-4. WHEEL DRIVE INSTALLATION - REGGIANA RIDUTTORI​
FIGURE 1-5. DRIVE HUB AND MOTOR ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-6. DRIVE HUB ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - FOAM FILLED​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - FOAM FILLED NON MARKING​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - SOLID​
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - SOLID NON MARKIMG​
FIGURE 1-12. FRAME VALVES INSTALLATION (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 1-13. FRAME VALVES INSTALLATION (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 1-14. STEER VALVE ASSEMBLY​
FIGURE 1-15. TRACTION VALVE ASSEMBLY​
FIGURE 1-16. FRAME COVERS INSTALLATION - ABS​
FIGURE 1-17. FRAME COVERS INSTALLATION - STEEL​
SECTION 2 - TURNTABLE
FIGURE 2-1. TURNTABLE VALVES INSTALLATION (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-2. TURNTABLE VALVES INSTALLATION (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-3. BATTERY AND AUXILIARY PUMP INSTALLATION - ABS HOODS​
FIGURE 2-4. BATTERY AND AUXILIARY PUMP INSTALLATION - STEEL HOODS​
FIGURE 2-5. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-6. MAIN VALVE ASSEMBLY​
FIGURE 2-7. SWING DRIVE INSTALLATION​
FIGURE 2-8. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-9. TURNTABLE LOCK INSTALLATION​
FIGURE 2-10. PINION SHIELD INSTALLATION​
FIGURE 2-11. EXTREME HOSTILE PACKAGE INSTALLATION (OPTIONAL)​
FIGURE 2-12. SWING MOTOR/HUB ASSEMBLY​
FIGURE 2-13. ROTARY COUPLING AND COLLECTOR RING INSTALLATION (ROTARY COUPLING WITHOUT SN PLATE)​
FIGURE 2-14. ROTARY COUPLING AND COLLECTOR RING INSTALLATION (ROTARY COUPLING WITH SN PLATE)​
FIGURE 2-15. ROTARY COUPLING AND COLLECTOR RING ASSEMBLY​
FIGURE 2-16. TANK INSTALLATION - WITH ABS HOODS​
FIGURE 2-17. TANK INSTALLATION - WITH STEEL HOODS​
FIGURE 2-18. TANK INSTALLATION - WITH STEEL HOODS AND 52.8 GAL/200 L FUEL TANK​
FIGURE 2-19. HYDRAULIC OIL TANK ASSEMBLY​
FIGURE 2-20. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-21. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-22. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-23. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH REXROTH PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-24. HYDRAULIC OIL COOLER INSTALLATION – DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V & CHINA IV) ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-25. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH SAUER PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-26. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (CE & UK CA SPECS)​
FIGURE 2-27. GROUND CONTROL BOX INSTALLATION – DEUTZ TD2011 ENGINES WITH SAUER PUMPS (CE & UK CA SPECS)​
FIGURE 2-28. GROUND CONTROL BOX INSTALLATION – DEUTZ TCD2.9L4 ENGINES (ANSI, ANSI EXPORT, CSA, CHINA AND JAPANESE SPECS)​
FIGURE 2-29. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH REXROTH PUMPS (ANSI EXPORT AND AUSTRALIAN SPECS)​
FIGURE 2-30. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH SAUER PUMPS (ANSI EXPORT AND AUSTRALIAN SPECS)​
FIGURE 2-31. GROUND CONTROL BOX INSTALLATION - DEUTZ TCD2.9L4 ENGINES (STAGE V)​
FIGURE 2-32. GROUND CONTROL BOX INSTALLATION - DEUTZ TCD2.9L4 ENGINES (CHINA IV)​
FIGURE 2-33. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 ENGINES - WITH DIGITAL DISPLAY (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-34. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 ENGINES - WITH MECHANICAL HOUR METER (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-35. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 ENGINES - WITH MECHANICAL HOUR METER (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-36. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2011 ENGINES (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-37. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2011 ENGINES (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-38. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 STAGE V ENGINES (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-39. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 STAGE V ENGINES (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-40. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 CHINA IV ENGINES (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-41. GROUND CONTROL BOX ASSEMBLY - DEUTZ TCD2.9L4 CHINA IV ENGINES (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-42. GROUND CONTROL PANEL ASSEMBLY​
FIGURE 2-43. KEYSWITCH INSTALLATION​
FIGURE 2-44. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-45. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-46. ALARM INSTALLATION​
FIGURE 2-47. ALARM AMBIENT (WHITE NOISE) INSTALLATION (ALARM WITH HORIZONTAL BAR GRILLE)​
FIGURE 2-48. ALARM AMBIENT (WHITE NOISE) INSTALLATION (ALARM WITH CROSS HATCH GRILLE)​
FIGURE 2-49. STROBE LIGHT INSTALLATION (AMBER) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-50. STROBE LIGHT INSTALLATION (AMBER) (WITHOUT CLEARSKY BEACON) (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 2-51. STROBE LIGHT INSTALLATION (BLUE) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-52. STROBE LIGHT INSTALLATION (RED) (WITHOUT CLEARSKY BEACON)​
FIGURE 2-53. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2011 ENGINES​
FIGURE 2-54. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2.9L4/TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 2-55. HOOD INSTALLATIONS - DEUTZ TD2011 ENGINES (ABS)​
FIGURE 2-56. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (ABS)​
FIGURE 2-57. HOOD INSTALLATION - DEUTZ TD2011/TD2.9L4/TCD2.9L ENGINES (STEEL)​
FIGURE 2-58. HOOD INSTALLATION - DEUTZ TCD2.9L (CHINA IV) ENGINES (STEEL)​
FIGURE 2-59. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (STEEL)​
FIGURE 2-60. HOOD KIT DEUTZ TCD2.9L4 (CHINA IV) ENGINE​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-2. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-3. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOOD (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-4. DEUTZ TD2011 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-5. DEUTZ TD2011 ENGINE INSTALLATION – WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-6. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-7. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-8. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-9. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-10. DEUTZ TD2011 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-11. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-12. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-13. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS (WTH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-14. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-15. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-16. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-17. DEUTZ TD2011 ENGINE COMPONENTS​
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-20. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA & ANSI EXPORT LRC SPECS)​
FIGURE 3-22. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-23. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-24. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-25. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-26. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-27. DEUTZ TCD2.9L4 ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-28. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-29. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-30. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-31. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-32. DEUTZ TCD2.9L4 ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-33. DEUTZ TCD2.9L4 ENGINE ASSEMBLY (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-34. DEUTZ TCD2.9L4 ENGINE COMPONENTS​
FIGURE 3-35. DEUTZ TCD2.9L4 (STAGE V) ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-36. DEUTZ TCD2.9L4 (STAGE V) ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-37. DEUTZ TCD2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY - WITH SAUER PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-38. DEUTZ TCD2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-39. DEUTZ TCD2.9L4 (STAGE V) ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-40. DEUTZ TCD2.9L4 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-41. DEUTZ TCD2.9L4 (CHINA IV) ENGINE INSTALLATION - WITH SAUER PUMPS​
FIGURE 3-42. DEUTZ TCD2.9L4 (CHINA IV) SUB - ASSEMBLY - WITH SAUER PUMPS​
FIGURE 3-43. ENGINE ASSEMBLY - DEUTZ TCD2.9L4 (CHINA IV) (Prior to SN 0300297979, Prior to SN B300017842, Except SN B300016940 through B300016942, Excluding 0300287515, B300017007 and B300017072)​
FIGURE 3-44. ENGINE ASSEMBLY - DEUTZ TCD2.9L4 (CHINA IV) (SN 0300297979 to Present, SN B300017842 to Present, SN B300016940 through B300016942, Including 0300287515, B300017007 and B300017072)​
FIGURE 3-45. DEUTZ TCD2.9L4 (CHINA IV) ENGINE COMPONENTS (Prior to SN 0300297979, Prior to SN B300017842, Except SN B300016940 through B300016942, Excluding 0300287515, B300017007 and B300017072)​
FIGURE 3-46. DEUTZ TCD2.9L4 (CHINA IV) ENGINE COMPONENTS (SN 0300297979 to Present, SN B300017842 to Present, SN B300016940 through B300016942, Including 0300287515, B300017007 and B300017072)​
FIGURE 3-47. PUMP ASSEMBLY (REXROTH) (DEUTZ TD2011 ENGINES)​
FIGURE 3-48. PUMP ASSEMBLY (REXROTH) (DEUTZ TCD2.9L4 ENGINES)​
FIGURE 3-49. PUMP ASSEMBLY (SAUER TANDEM)​
FIGURE 3-50. PUMP ASSEMBLY (SAUER PISTON)​
FIGURE 3-51. PUMP ASSEMBLY (SAUER GEAR)​
FIGURE 3-52. PUMP COUPLING KIT​
FIGURE 3-53. WATER/FUEL SEPARATOR INSTALLATION - DEUTZ TD2011 ENGINE​
FIGURE 3-54. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TCD2.9L4 ENGINE AND DEUTZ TCD2.9L4 (STAGE V) ENGINE​
FIGURE 3-55. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TD2.9L4 ENGINE (CHINA SPECS ONLY)​
FIGURE 3-56. FUEL FILTER/WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 & TCD2.9L ENGINES​
FIGURE 3-57. QUICKFIT OIL VALVE​
FIGURE 3-58. SPARK ARRESTING CATALYTIC MUFFLER - DEUTZ TD2011 ENGINES (OPTIONAL)​
FIGURE 3-59. 2500W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-60. 2500W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-61. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-62. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-63. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-64. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES) (OPTIONAL)​
FIGURE 3-65. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-66. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-67. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-68. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP) (Including B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-2. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP) (Excluding B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-3. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1200SJP) (Including B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-4. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1200SJP) (Excluding B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-5. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP) (Including B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-6. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP) (Excluding B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-7. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1350SJP) (Including B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-8. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1350SJP) (Excluding B300016796, B300016807, B300016833 and B300016836)​
FIGURE 4-9. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP) (Prior to SN 0300296108, Prior to SN B300016940, Excluding 030026105 and B300016704)​
FIGURE 4-10. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP) (SN 0300296108 to Present, SN B300016940 to Present, Including 030026105 and B300016704)​
FIGURE 4-11. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP) (Prior to SN 0300296108, Prior to SN B300016940, Excluding 030026105 and B300016704)​
FIGURE 4-12. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP) (SN 0300296108 to Present, SN B300016940 to Present, Including 030026105 and B300016704)​
FIGURE 4-13. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-14. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-15. WIRE ROPE TOOLS INSTALLATION (OPTIONAL)​
FIGURE 4-16. PLATFORM ROTATE ASSEMBLY​
FIGURE 4-17. JIB ROTATE ASSEMBLY​
FIGURE 4-18. POWER TRACK INSTALLATION (1200SJP)​
FIGURE 4-19. POWER TRACK INSTALLATION (1350SJP)​
FIGURE 4-20. BOOM SENSORS AND SWITCHES INSTALLATION​
FIGURE 4-21. PLATFORM SUPPORT INSTALLATION​
FIGURE 4-22. CONTROL VALVE INSTALLATION​
FIGURE 4-23. CONTROL VALVE INSTALLATION​
FIGURE 4-24. CONTROL VALVE ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-2. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - WITH DROP BAR​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH DROP BAR​
FIGURE 5-5. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT AND CHINA SPECS)​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ANSI SPEC)​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (AUSTRALIAN SPECS)​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (1 GATE/2 DROP BARS)​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (3 DROP BARS)​
FIGURE 5-14. PLATFORM CONTROLS INSTALLATION​
FIGURE 5-15. PLATFORM CONSOLE​
FIGURE 5-16. CONTROLLER ASSEMBLY (DRIVE AND STEER)​
FIGURE 5-17. CONTROLLER ASSEMBLY (LIFT AND SWING)​
FIGURE 5-18. BOOM CONTROL SELECT SWITCH INSTALLATION​
FIGURE 5-19. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 4FFT/1.22M PLATFORM)​
FIGURE 5-20. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM​
FIGURE 5-21. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM (​
FIGURE 5-22. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 8FT/2.4M PLATFORM​
FIGURE 5-23. FOOTSWITCH ASSEMBLY​
FIGURE 5-24. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-25. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-26. PLASMA CUTTER ASSEMBLY​
FIGURE 5-27. SKYCUTTER INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 5-28. SKYEYE INSTALLATION​
FIGURE 5-29. SKYGLAZIER INSTALLATION (ANSI AND CSA SPECS)​
FIGURE 5-30. SKYGLAZIER INSTALLATION (BRAZIL SPECS)​
FIGURE 5-31. SKYGLAZIER INSTALLATION (DANISH SPECS)​
FIGURE 5-32. SKYGLAZIER INSTALLATION (FINNISH SPECS)​
FIGURE 5-33. SKYGLAZIER INSTALLATION (FRENCH SPECS)​
FIGURE 5-34. SKYGLAZIER INSTALLATION (GERMAN SPECS)​
FIGURE 5-35. SKYGLAZIER INSTALLATION (ITALIAN SPECS)​
FIGURE 5-36. SKYGLAZIER INSTALLATION (LATIN AMERICAN SPECS)​
FIGURE 5-37. SKYGLAZIER INSTALLATION (PORTUGUESE SPECS)​
FIGURE 5-38. SKYGLAZIER INSTALLATION (SPANISH SPECS)​
FIGURE 5-39. SKYGLAZIER INSTALLATION (SWEDISH SPECS)​
FIGURE 5-40. SKYGLAZIER INSTALLATION (UK SPECS)​
FIGURE 5-41. SKYGUARD BAR INSTALLATION​
FIGURE 5-42. SKYLINE INSTALLATION​
FIGURE 5-43. SKYWELDER INSTALLATION (50HZ) (ANSI EXPORT, AUSTRALIAN, CHINA AND JAPANESE SPECS)​
FIGURE 5-44. SKYWELDER INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 5-45. SKYWELDER PREP PACKAGE (60HZ) (ANSI, ANSI EXPORT, CSA AND CHINA SPECS)​
FIGURE 5-46. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 5-47. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ) (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 5-48. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.4M PLATFORMS (ALL SPECS) (1350SJP)​
FIGURE 5-49. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.4M PLATFORMS (ANSI SPECS WITH SN STARTING WITH 03)) (1350SJP)​
FIGURE 5-50. TRAY ASSEMBLY​
FIGURE 5-51. USB CHARGER INSTALLATION​
FIGURE 5-52. WELDER ASSEMBLY​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE EXTENSION CYLINDER ASSEMBLY​
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-3. PLATFORM LEVEL CYLINDER ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE​
FIGURE 6-4. PLATFORM LEVEL CYLINDER ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY (Including B300016796, B300016807, B300016833 and B300016836)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY (Excluding B300016796, B300016807, B300016833 and B300016836)​
FIGURE 6-7. JIB CYLINDER ASSEMBLY - WITH OR WITHOUT COLD WEATHER PLUS PACKAGE​
FIGURE 6-8. STEER CYLINDER ASSEMBLY​
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY (1200SJP) (Prior to SN 0300296108, Prior to SN B300016940, Excluding 030026105 and B300016704)​
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY (1200SJP) (SN 0300296108 to Present, SN B300016940 to Present, Including 030026105 and B300016704)​
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY (1350SJP)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - BOOM (1200SJP)​
FIGURE 7-2. HYDRAULIC DIAGRAM - BOOM (1350SJP)​
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE​
FIGURE 7-4. HYDRAULIC DIAGRAM - OSCILLATING AXLE​
FIGURE 7-5. HYDRAULIC DIAGRAM - STEER​
FIGURE 7-6. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TD2011 ENGINES WITH REXROTH PUMPS)​
FIGURE 7-7. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS)​
FIGURE 7-8. HYDRAULIC DIAGRAM - TURNTABLE (WITH SAUER PUMPS)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM - 110V (ANSI SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM - 110V GFI RECEPTACLE (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM - 220V GFI RECEPTACLE (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (2X4 BOX) WITH 4000W GENERATOR (AUSTRALIAN SPECS)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN & CE & UK CA SPECS)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-17. AC 16 AMP BREAKER BOX INSTALLATION (CE & UK CA SPECS)​
FIGURE 8-18. ANALYZER CABLE HARNESS​
FIGURE 8-19. AXLE POWER TRACK HARNESS ASSEMBLY​
FIGURE 8-20. BATTERY DISCONNECT SWITCH​
FIGURE 8-21. BEACON LIGHT HARNESS (BLUE BEACON LIGHT ONLY)​
FIGURE 8-22. B.L.A.M. TO BOOM LENGTH SENSOR HARNESS​
FIGURE 8-23. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (LEFT SIDE)​
FIGURE 8-24. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (RIGHT SIDE)​
FIGURE 8-25. B.L.A.M. HARNESS​
FIGURE 8-26. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1200SJP)​
FIGURE 8-27. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1350SJP)​
FIGURE 8-28. BOOM CABLES INSTALLATION (AUSTRALIAN, CE & UK CA SPECS) (1200SJP)​
FIGURE 8-29. BOOM CABLES INSTALLATION (AUSTRALIAN, CE & UK CA SPECS) (1350SJP)​
FIGURE 8-30. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (1200SJP)​
FIGURE 8-31. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (1350SJP)​
FIGURE 8-32. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR (1200SJP)​
FIGURE 8-33. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR (1350SJP)​
FIGURE 8-34. BREAKER BOX KIT - 16 AMP (2500W GENERATOR)​
FIGURE 8-35. BREAKER BOX KIT - 16 AMP (4000W GENERATOR)​
FIGURE 8-36. CHASSIS HARNESS ASSEMBLY​
FIGURE 8-37. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)​
FIGURE 8-38. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE, AND UK CA SPECS)​
FIGURE 8-39. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS)​
FIGURE 8-40. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)​
FIGURE 8-41. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS)​
FIGURE 8-42. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-43. CLEARSKY INSTALLATION - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES (CHINA SPECS)​
FIGURE 8-44. CLEARSKY HARNESS - 3-WIRE TELEMATICS​
FIGURE 8-45. CLEARSKY HARNESS - CANBUS TELEMATICS​
FIGURE 8-46. CLEARSKY HARNESS - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-47. CLEARSKY TELEMATICS JUMPER HARNESS - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-48. TELEMATICS CONTROL MODULE ASSEMBLY - WITH DEUTZ TD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-49. CLEARSKY READY HARNESS (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-50. CLEARSKY READY HARNESS (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-51. DIAGNOSTIC HARNESS​
FIGURE 8-52. DUAL CAPACITY JIB POSITION SWITCH HARNESS​
FIGURE 8-53. ENGINE HARNESS - DEUTZ TD2011 ENGINES AND DEUTZ TD2.9L4 ENGINES​
FIGURE 8-54. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TCD2.9L4 ENGINES​
FIGURE 8-55. ENGINE HARNESS - DEUTZ TCD2.9L4 (STAGE V) & DEUTZ TCD2.9L4 (CHINA IV) ENGINES​
FIGURE 8-56. FUEL FILTER HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-57. FUEL HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-58. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-59. GENERATOR HARNESS - 7500W GENERATOR​
FIGURE 8-60. GROUND CONTROL BOX HARNESS (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-61. GROUND CONTROL BOX HARNESS (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-62. GROUND CONTROLS TO ENGINE HARNESS​
FIGURE 8-63. JIB STOW SWITCH HARNESS​
FIGURE 8-64. LOAD SENSING PIN HARNESS​
FIGURE 8-65. LOCKOUT VALVE HARNESS​
FIGURE 8-66. MAIN BOOM CONTROL CABLE HARNESS (1200SJP)​
FIGURE 8-67. MAIN BOOM CONTROL CABLE HARNESS (1350SJP)​
FIGURE 8-68. MAIN VALVE HARNESS (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-69. MAIN VALVE HARNESS (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-70. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-71. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-72. PLATFORM INTERFACE HARNESS​
FIGURE 8-73. PLATFORM VALVE HARNESS​
FIGURE 8-74. PUMP ADAPTER HARNESS - SAUER PUMPS​
FIGURE 8-75. RECEPTACLE BOX KIT - 110V IEC YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-76. RECEPTACLE BOX KIT - 220V IEC BLUE WITHOUT 2500W GENERATOR (CE & UK CA SPECS)​
FIGURE 8-77. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-78. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-79. RECEPTACLE BOX KIT - 220V AFSINT 107 KEYED GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE & UK CA SPECS)​
FIGURE 8-80. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-81. SKYEYE EMITTER HARNESS​
FIGURE 8-82. SKYEYE RECEIVER HARNESS​
FIGURE 8-83. SKYLINE HARNESS​
FIGURE 8-84. STROBE LIGHT HARNESS (AMBER) (Prior to SN 0300298064, Prior to SN B300017880, Excluding 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-85. STROBE LIGHT HARNESS (AMBER) (SN 0300298064 to Present, SN B300017880 to Present, Including 0300287515, B300016940, B300017007 and B300017072)​
FIGURE 8-86. TILT SENSOR HARNESS (LEFT)​
FIGURE 8-87. TILT SENSOR HARNESS (RIGHT)​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI SPEC​
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPEC​
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPEC (PORTGUESE/ENGLISH)​
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC​
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)​
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (ENGLISH/FRENCH)​
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH)​
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)​
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPEC (SPANISH/ENGLISH)​
FIGURE 9-10. DECAL INSTALLATION - OPTIONS​
FIGURE 9-11. SKYCUTTER DECAL INSTALLATION (ANSI, ANSI EXPORT, CHINESE & CSA SPECS)​
FIGURE 9-12. SKYCUTTER DECAL INSTALLATION (JAPANESE SPECS)​
FIGURE 9-13. SKYWELDER DECAL INSTALLATION - 50HZ​
FIGURE 9-14. SKYWELDER DECAL INSTALLATION - 60HZ​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
