Hyundai
86
176,834
JLG Boom Lift 1200SJP 1350SJP Parts Catalog 3121738
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 1200SJP 1350SJP Boom Lift
Part Number: 3121738
Publication Date: 2025
Number of Pages: 1010 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED (SN 0300201016 through 0300207700)​
FIGURE 1-2. AXLE INSTALLATION - FIXED (SN 0300207701 through 0300272504, SN B30002238 through B300007118)​
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING AXLE (SN 0300201016 through 0300207700)​
FIGURE 1-4. AXLE INSTALLATION - OSCILLATING (SN 0300207701 through 0300272504, SN B300002238 through B300007118)​
FIGURE 1-5. STEER INSTALLATION​
FIGURE 1-6. WHEEL DRIVE INSTALLATION - BONFIGLIOLI​
FIGURE 1-7. WHEEL DRIVE INSTALLATION - REGGIANA RIDUTTORI​
FIGURE 1-8. DRIVE HUB AND MOTOR ASSEMBLY - BONFIGLIOLI​
FIGURE 1-9. DRIVE HUB AND MOTOR ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-10. DRIVE HUB ASSEMBLY - BONFIGLIOLI​
FIGURE 1-11. DRIVE HUB ASSEMBLY - REGGIANA RIDUTTORI​
FIGURE 1-12. DRIVE MOTOR ASSEMBLY​
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - FOAM - FILLED​
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - SOLID​
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - SOLID NON MARKIMG​
FIGURE 1-16. FRAME VALVES INSTALLATION - WITHOUT LSS AND WITH 4 CELL LSS​
FIGURE 1-17. FRAME VALVES INSTALLATION - WITH 1 CELL LSS​
FIGURE 1-18. STEER VALVE ASSEMBLY​
FIGURE 1-19. TRACTION VALVE ASSEMBLY​
FIGURE 1-20. FRAME COVERS INSTALLATION - ABS​
FIGURE 1-21. FRAME COVERS INSTALLATION - STEEL​
SECTION 2 - TURNTABLE
FIGURE 2-1. TURNTABLE VALVES INSTALLATION - WITHOUT LSS AND WITH 4 CELL LSS​
FIGURE 2-2. TURNTABLE VALVES INSTALLATION - WITH 1 CELL LSS​
FIGURE 2-3. BATTERY AND AUXILIARY PUMP INSTALLATION - ABS HOODS​
FIGURE 2-4. BATTERY AND AUXILIARY PUMP INSTALLATION - STEEL HOODS​
FIGURE 2-5. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-6. MAIN VALVE ASSEMBLY​
FIGURE 2-7. SWING DRIVE INSTALLATION (SN 0300201016 through 0300254466, SN B300002238 through B300003825)​
FIGURE 2-8. SWING DRIVE INSTALLATION (SN 0300254467 through 0300272504, SN B300003826 through B300007118)​
FIGURE 2-9. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-10. TURNTABLE LOCK INSTALLATION​
FIGURE 2-11. PINION SHIELD INSTALLATION​
FIGURE 2-12. EXTREME HOSTILE PACKAGE INSTALLATION (OPTIONAL)​
FIGURE 2-13. SWING MOTOR/HUB ASSEMBLY (SN 0300201016 through 0300254466, SN B300002238 through B300003825)​
FIGURE 2-14. SWING MOTOR/HUB ASSEMBLY (SN 0300254467 through 0300272504, SN B300003826 through B300007118)​
FIGURE 2-15. ROTARY COUPLING AND COLLECTOR RING INSTALLATION​
FIGURE 2-16. TANK INSTALLATION - WITH ABS HOODS​
FIGURE 2-17. TANK INSTALLATION - WITH STEEL HOODS​
FIGURE 2-18. TANK INSTALLATION - WITH STEEL HOODS AND 52.8 GAL/200 L FUEL TANK​
FIGURE 2-19. HYDRAULIC OIL TANK ASSEMBLY​
FIGURE 2-20. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-21. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2011 ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-22. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS (OPTIONAL)​
FIGURE 2-23. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH REXROTH PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-24. HYDRAULIC OIL COOLER INSTALLATION – DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH SAUER PUMPS (OPTIONAL)​
FIGURE 2-25. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TCD2.9L4 ENGINES WITH SAUER PUMPS (OPTIONAL) (CHINA SPEC ONLY)​
FIGURE 2-26. GROUND CONTROL BOX INSTALLATION - DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (ALL SPECS EXCEPT CE SPECS)​
FIGURE 2-27. GROUND CONTROL BOX INSTALLATION – DEUTZ TD2011 ENGINES WITH REXROTH PUMPS (CE SPECS)​
FIGURE 2-28. GROUND CONTROL BOX INSTALLATION – DEUTZ TD2011 ENGINES WITH SAUER PUMPS (ALL SPECS EXCEPT CE SPECS)​
FIGURE 2-29. GROUND CONTROL BOX INSTALLATION – DEUTZ TD2011 ENGINES WITH SAUER PUMPS (CE SPECS)​
FIGURE 2-30. GROUND CONTROL BOX INSTALLATION – DEUTZ TCD2.9L4 ENGINES (ALL SPECS EXCEPT CE SPECS)​
FIGURE 2-31. GROUND CONTROL BOX INSTALLATION – DEUTZ TCD2.9L4 ENGINES (CE SPECS)​
FIGURE 2-32. GROUND CONTROL BOX ASSEMBLY (ALL SPECS EXCEPT CE SPECS)​
FIGURE 2-33. GROUND CONTROL BOX ASSEMBLY (CE SPECS)​
FIGURE 2-34. KEYSWITCH INSTALLATION​
FIGURE 2-35. KEYSWITCH INSTALLATION (SN 0300201016 through 0300205135)​
FIGURE 2-36. LIGHT PANEL INSTALLATION - ANSI AND ANSI EXPORT SPECS​
FIGURE 2-37. LIGHT PANEL INSTALLATION - AUSTRALIAN AND CE SPECS​
FIGURE 2-38. ALARMS INSTALLATION​
FIGURE 2-39. BACKUP ALARM (WHITE NOISE) INSTALLATION​
FIGURE 2-40. BACKUP ALARM AMBIENT (WHITE NOISE) INSTALLATION​
FIGURE 2-41. STROBE LIGHT INSTALLATION (AMBER)​
FIGURE 2-42. BEACON LIGHT INSTALLATION (BLUE) (SN 0300201016 through 0300217081)​
FIGURE 2-43. STROBE LIGHT INSTALLATION (BLUE) (SN 0300217082 through 0300256988, SN B300002238 through B300003730)​
FIGURE 2-44. STROBE LIGHT INSTALLATION (BLUE) (SN 0300256989 through 0300272504, SN B300003731 through B300007118)​
FIGURE 2-45. STROBE LIGHT INSTALLATION (RED) (SN 0300216184 through 0300217081)​
FIGURE 2-46. STROBE LIGHT INSTALLATION (RED) (SN 0300217082 through 0300256988)​
FIGURE 2-47. STROBE LIGHT INSTALLATION (RED) (SN 03002589 through 0300272504)​
FIGURE 2-48. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2011 ENGINES​
FIGURE 2-49. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2.9L4/TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 2-50. HOOD INSTALLATIONS - DEUTZ TD2011 ENGINES (ABS)​
FIGURE 2-51. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (ABS)​
FIGURE 2-52. HOOD INSTALLATION - DEUTZ TD2011/TD2.9L4 ENGINES (STEEL)​
FIGURE 2-53. HOOD INSTALLATION - DEUTZ TCD2.9L4 ENGINES (STEEL)​
FIGURE 2-54. CLEARSKY TELEMATICS INSTALLATION (ANSI SPECS) (OPTIONAL)​
FIGURE 2-55. CLEARSKY TELEMATICS CONTROLLERS (ANSI EXPORT - BRAZIL AND NEW ZEALAND SPECS) (OPTIONAL)​
FIGURE 2-56. CLEARSKY TELEMATICS INSTALLATION (AUSTRALIAN SPECS) (OPTIONAL)​
FIGURE 2-57. CLEARSKY TELEMATICS INSTALLATION (CSA SPECS) (OPTIONAL)​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-2. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-3. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-4. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-5. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOOD (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-6. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS AND STEEL HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-7. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-8. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-9. DEUTZ TD2011 DIESEL ENGINE INSTALLATION – WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-10. DEUTZ TD2011 ENGINE ASSEMBLY - WITH REXROTH PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-11. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-12. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS AND ABS HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-13. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-14. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS AND ABS HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-15. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-16. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-17. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-18. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-19. DEUTZ TD2011 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-20. DEUTZ TD2011 ENGINE ASSEMBLY - WITH SAUER PUMPS AND STEEL HOODS (WITH SKYPOWER AND WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-21. DEUTZ TD2011 ENGINE COMPONENTS​
FIGURE 3-22. DEUTZ TD2.9L4 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (CHINA SPEC ONLY)​
FIGURE 3-23. DEUTZ TD2.9L4 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (CHINA SPEC ONLY)​
FIGURE 3-24. DEUTZ TD2.9L4 ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (CHINA SPEC ONLY)​
FIGURE 3-25. DEUTZ TD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (CHINA SPEC ONLY)​
FIGURE 3-26. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA SPEC ONLY)​
FIGURE 3-27. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA SPEC ONLY)​
FIGURE 3-28. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-29. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-30. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-31. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-32. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-33. DEUTZ TCD2.9L4 DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND STEEL HOODS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-34. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-35. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH REXROTH PUMP (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-36. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMP (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-37. DEUTZ TCD2.9L4 ENGINE SUB-ASSEMBLY - WITH SAUER PUMPS (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-38. DEUTZ TCD2.9L4 ENGINE ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-39. DEUTZ TCD2.9L4 ENGINE ASSEMBLY (WITH COLD WEATHER PLUS PACKAGE)​
FIGURE 3-40. DEUTZ TCD2.9L4 ENGINE COMPONENTS​
FIGURE 3-41. DEUTZ TCD2.9L4 (STAGE V) DIESEL ENGINE INSTALLATION - WITH SAUER PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-42. DEUTZ TCD2.9L4 (STAGE V) DIESEL ENGINE INSTALLATION - WITH REXROTH PUMPS AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-43. DEUTZ TCD2.9L4 (STAGE V) ENGINE SUB-ASSEMBLY - WITH SAUER PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-44. DEUTZ TCD2.9L4 (STAGE V) ENGINESUB-ASSEMBLY - WITH REXROTH PUMP AND ABS HOODS (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-45. DEUTZ TCD2.9L4 ENGINE (STAGE V) ASSEMBLY (WITHOUT COLD WEATHER PLUS PACKAGE)​
FIGURE 3-46. DEUTZ TCD2.9L4 ENGINE COMPONENTS (STAGE V)​
FIGURE 3-47. PUMP ASSEMBLY (REXROTH) (DEUTZ TD2011 ENGINES)​
FIGURE 3-48. PUMP ASSEMBLY (REXROTH) (DEUTZ TCD2.9L4 ENGINES)​
FIGURE 3-49. PUMP ASSEMBLY (SAUER TANDEM)​
FIGURE 3-50. PUMP ASSEMBLY (SAUER PISTON)​
FIGURE 3-51. PUMP ASSEMBLY (SAUER GEAR)​
FIGURE 3-52. PUMP COUPLING KIT​
FIGURE 3-53. WATER/FUEL SEPARATOR INSTALLATION - DEUTZ TD2011 ENGINE​
FIGURE 3-54. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TCD2.9L4 ENGINE AND DEUTZ TCD2.9L4 (STAGE V) ENGINE​
FIGURE 3-55. FUEL PUMP/FILTER BRACKET ASSEMBLY - DEUTZ TD2.9L4 ENGINE (CHINA SPECS ONLY) (SN 0300238862 through 0300272504, SN B300002450 through B300007118)​
FIGURE 3-56. FUEL FILTER/WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 ENGINE​
FIGURE 3-57. SPARK ARRESTING CATALYTIC MUFFLER - DEUTZ TD2011 ENGINES (OPTIONAL)​
FIGURE 3-58. SPARK ARRESTOR INSTALLATION - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES (OPTIONAL)​
FIGURE 3-59. 2500W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-60. 2500W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-61. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-62. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-63. 4000W GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-64. 4000W GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES) (OPTIONAL)​
FIGURE 3-65. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-66. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TD2011 ENGINES) (OPTIONAL)​
FIGURE 3-67. 7500W SKYPOWER GENERATOR INSTALLATION - 60HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-68. 7500W SKYPOWER GENERATOR INSTALLATION - 50HZ SPEC (DEUTZ TCD2.9L4 ENGINES) (OPTIONAL)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-2. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-3. BOOM INSTALLATION - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-4. BOOM INSTALLATION - WITH COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-5. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-6. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1200SJP)​
FIGURE 4-7. BOOM ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-8. BOOM ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (1350SJP)​
FIGURE 4-9. WIRE ROPE TOOLS INSTALLATION (OPTIONAL)​
FIGURE 4-10. PLATFORM ROTATE ASSEMBLY (SN 0300201016 through 0300201348)​
FIGURE 4-11. PLATFORM ROTATE ASSEMBLY (SN 0300201349 through 0300272504, SN B300002238 through B300007118)​
FIGURE 4-12. JIB ROTATE ASSEMBLY (SN 0300201016 through 0300201348)​
FIGURE 4-13. JIB ROTATE ASSEMBLY (SN 0300201349 through 0300272504, SN B300002238 through B300007118)​
FIGURE 4-14. POWER TRACK INSTALLATION (1200SJP)​
FIGURE 4-15. POWER TRACK INSTALLATION (1350SJP)​
FIGURE 4-16. BOOM SENSORS AND SWITCHES INSTALLATION​
FIGURE 4-17. PLATFORM SUPPORT INSTALLATION - WITHOUT LSS​
FIGURE 4-18. PLATFORM SUPPORT INSTALLATION - WITH 4 CELL LSS​
FIGURE 4-19. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS​
FIGURE 4-20. CONTROL VALVE INSTALLATION - WITHOUT LSS AND WITH 4 CELL LSS​
FIGURE 4-21. CONTROL VALVE INSTALLATION - WITH 1 CELL LSS​
FIGURE 4-22. CONTROL VALVE ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH SWING GATE​
FIGURE 5-2. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - WITH DROP BAR​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (USA BUILT MACHINES)​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (CHINA BUILT MACHINES)​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ANSI SPEC)​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ALL SPECS EXCEPT CSA SPECS)​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-14. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR​
FIGURE 5-15. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPGATE​
FIGURE 5-16. TRAY ASSEMBLY​
FIGURE 5-17. PLATFORM CONTROLS INSTALLATION - WITHOUT SKYGUARD​
FIGURE 5-18. PLATFORM CONTROLS INSTALLATION - WITH SKYGUARD (SN 0300201016 through 0300235781, SN B300002238 through B300002991)​
FIGURE 5-19. PLATFORM CONTROLS INSTALLATION - WITH SKYGUARD (SN 0300235782 through 0300256988, SN B300002992 through B300003730)​
FIGURE 5-20. PLATFORM CONTROLS INSTALLATION (SN 0300256989 through 0300272504, SN B300003731 through B300007118)​
FIGURE 5-21. PLATFORM CONSOLE ASSEMBLY - WITHOUT SKYGUARD (SN 0300201016 through 0300220138)​
FIGURE 5-22. PLATFORM CONSOLE ASSEMBLY - WITHOUT SKYGUARD (SN 0300220139 through 0300272504, SN B300002238 through B300007118)​
FIGURE 5-23. PLATFORM CONSOLE ASSEMBLY - WITH SKYGUARD (SN 0300201016 through 0300220138)​
FIGURE 5-24. PLATFORM CONSOLE ASSEMBLY - WITH SKYGUARD (SN 0300220139 through 0300235781, SN B300002238 through B300002991)​
FIGURE 5-25. PLATFORM CONSOLE ASSEMBLY - WITH SKYGUARD (SN 0300235782 through 0300256988, SN B300002992 through B300003730)​
FIGURE 5-26. PLATFORM CONSOLE ASSEMBLY (SN 03002256989 through 0300272504, SN B300003731 through B300007118)​
FIGURE 5-27. DECAL AND LIGHT PANEL (ANSI SPECS)​
FIGURE 5-28. DECAL AND LIGHT PANEL (CE SPECS)​
FIGURE 5-29. CONTROLLER ASSEMBLY (LIFT AND SWING)​
FIGURE 5-30. CONTROLLER ASSEMBLY (DRIVE AND STEER)​
FIGURE 5-31. BOOM CONTROL SELECT SWITCH INSTALLATION​
FIGURE 5-32. FOOTSWITCH ASSEMBLY​
FIGURE 5-33. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.8M PLATFORMS (OPTIONAL)​
FIGURE 5-34. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.4M PLATFORMS (OPTIONAL)​
FIGURE 5-35. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (OPTIONAL)​
FIGURE 5-36. SKYGUARD SYSTEM INSTALLATION (SN 0300201016 through 0300256988, SN B300002238 through B300003794)​
FIGURE 5-37. SKYGUARD BAR INSTALLATION (SN 0300256989 through 0300272504, SN B300003795 through B300007118)​
FIGURE 5-38. CROSS RAIL INSTALLATION​
FIGURE 5-39. SKYEYE INSTALLATION​
FIGURE 5-40. SKYGLAZIER INSTALLATION (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 5-41. SKYGLAZIER INSTALLATION (AUSTRALIAN SPECS)​
FIGURE 5-42. SKYGLAZIER INSTALLATION (BRAZIL SPECS)​
FIGURE 5-43. SKYGLAZIER INSTALLATION (DANISH SPECS)​
FIGURE 5-44. SKYGLAZIER INSTALLATION (FINNISH SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-45. SKYGLAZIER INSTALLATION (FINNISH SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-46. SKYGLAZIER INSTALLATION (FRENCH SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-47. SKYGLAZIER INSTALLATION (FRENCH SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-48. SKYGLAZIER INSTALLATION (GERMAN SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-49. SKYGLAZIER INSTALLATION (GERMAN SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-50. SKYGLAZIER INSTALLATION (ITALIAN SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-51. SKYGLAZIER INSTALLATION (ITALIAN SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-52. SKYGLAZIER INSTALLATION (LATIN AMERICAN SPECS)​
FIGURE 5-53. SKYGLAZIER INSTALLATION (PORTUGUESE SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-54. SKYGLAZIER INSTALLATION (PORTUGUESE SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-55. SKYGLAZIER INSTALLATION (SPANISH SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-56. SKYGLAZIER INSTALLATION (SPANISH SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-57. SKYGLAZIER INSTALLATION (SWEDISH SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-58. SKYGLAZIER INSTALLATION (SWEDISH SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-59. SKYGLAZIER INSTALLATION (UK SPECS) (SN 0300201016 through 0300235781)​
FIGURE 5-60. SKYGLAZIER INSTALLATION (UK SPECS) (SN 0300235782 through 0300272504)​
FIGURE 5-61. SKYLINE INSTALLATION​
FIGURE 5-62. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)​
FIGURE 5-63. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-64. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-65. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-66. WELDER ASSEMBLY​
FIGURE 5-67. SKYCUTTER INSTALLATION​
FIGURE 5-68. PLASMA CUTTER ASSEMBLY​
FIGURE 5-69. PIPE RACK INSTALLATION (ANSI SPEC)​
FIGURE 5-70. PIPE RACK INSTALLATION (AUSTRALIAN AND CE SPECS)​
FIGURE 5-71. PIPE RACK INSTALLATION (KOREAN SPEC)​
FIGURE 5-72. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM​
FIGURE 5-73. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 6FT/1.82M PLATFORM​
FIGURE 5-74. FALL ARREST INSTALLATION (BOLT - ON EXTERNAL) 8FT/2.4M PLATFORM​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE EXTENSION CYLINDER ASSEMBLY (SN 0300207701 through 0300238565, SN B300002238 through B300002404)​
FIGURE 6-2. AXLE EXTENSION CYLINDER ASSEMBLY (SN 0300238566 through 0300271480, SN B300002405 through B300005767)​
FIGURE 6-3. AXLE EXTENSION CYLINDER ASSEMBLY (SN 0300238566 through 0300271481, SN B300005768 through B300007118)​
FIGURE 6-4. AXLE LOCKOUT CYLINDER ASSEMBLY (SN 0300207701 through 0300239161, SN B300002238 through B300002449)​
FIGURE 6-5. AXLE LOCKOUT CYLINDER ASSEMBLY (SN 0300239162 through 0300272504, SN B300002450 through B300007118)​
FIGURE 6-6. PLATFORM LEVEL CYLINDER ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (SN 0300201016 through 0300239161, SN B300002238 through B300002449)​
FIGURE 6-7. PLATFORM LEVEL CYLINDER ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (SN 0300239162 through 0300272504, SN B300002450 through B300007118)​
FIGURE 6-8. PLATFORM LEVEL CYLINDER ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (SN 0300201016 through 0300239980)​
FIGURE 6-9. PLATFORM LEVEL CYLINDER ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (SN 0300239981 through 0300272504)​
FIGURE 6-10. LIFT CYLINDER ASSEMBLY (SN 0300201016 through 0300239470, SN B300002238 through B300002473)​
FIGURE 6-11. LIFT CYLINDER ASSEMBLY (SN 0300239471 through 0300272504, SN B300002474 through B300007118)​
FIGURE 6-12. JIB CYLINDER ASSEMBLY - WITHOUT COLD WEATHER PLUS PACKAGE (SN 0300201016 through 0300239161, SN B300002238 through B300002449)​
FIGURE 6-13. JIB CYLINDER ASSEMBLY - WITH COLD WEATHER PLUS PACKAGE (SN 0300201016 through 0300239161)​
FIGURE 6-14. JIB CYLINDER ASSEMBLY - WITH OR WITHOUT COLD WEATHER PLUS PACKAGE (SN 0300239162 through 0300272504, SN B300002450 through B300007118)​
FIGURE 6-15. STEER CYLINDER ASSEMBLY (SN 0300201016 through 0300238011, SN B300002238 through B300002376)​
FIGURE 6-16. STEER CYLINDER ASSEMBLY (SN 0300238012 through 0300272504, SN B300002377 through B300007118)​
FIGURE 6-17. TELESCOPE CYLINDER ASSEMBLY (1200SJP) (SN 0300201016 through 0300243437, SN B300002238 through B300002718)​
FIGURE 6-18. TELESCOPE CYLINDER ASSEMBLY (1200SJP) (SN 0300243438 through 0300272504, SN B300002719 through B300007118)​
FIGURE 6-19. TELESCOPE CYLINDER ASSEMBLY (1350SJP) (SN 0300201016 through 0300243473, SN B300002238 through B300002646)​
FIGURE 6-20. TELESCOPE CYLINDER ASSEMBLY (1350SJP) (SN 0300243474 through 0300272504, SN B300002647 through B300007118)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - BOOM (1200SJP)​
FIGURE 7-2. HYDRAULIC DIAGRAM - BOOM (1350SJP)​
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE​
FIGURE 7-4. HYDRAULIC DIAGRAM - OSCILLATING AXLE​
FIGURE 7-5. HYDRAULIC DIAGRAM - STEER​
FIGURE 7-6. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TD2011 ENGINES WITH REXROTH PUMPS)​
FIGURE 7-7. HYDRAULIC DIAGRAM - TURNTABLE (DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES WITH REXROTH PUMPS)​
FIGURE 7-8. HYDRAULIC DIAGRAM - TURNTABLE (WITH SAUER PUMPS)​
FIGURE 7-9. HYDRAULIC DIAGRAM LIST​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM - 110V (ANSI SPECS)​
FIGURE 8-2. AC BOX AT PLATFORM - 110V GFI RECEPTACLE (ANSI SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM - 220V GFI RECEPTACLE (ANSI SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (2X4 BOX) WITH 4000W GENERATOR (ANSI EXPORT SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (2X4 BOX) WITH 4000W GENERATOR (ANSI EXPORT SPECS) (SN 0300214025 through 0300272504, SN B300002238 through B300007118)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300214025 through 0300272504, SN B300002238 through B300007118)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300214025 through 0300272504, SN B300002238 through B300007118)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (70MM X 70MM BOX) WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300201016 through 0300205136)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (70MM X 70MM BOX) WITHOUT 2500W GENERATOR (CE SPECS) (SN 0300201016 through 0300205136)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300214025 through 0300272504)​
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300214025 through 0300272504)​
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300205136 through 0300214024)​
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 4000W GENERATOR (CE SPECS) (SN 0300214025 through 0300272504)​
FIGURE 8-23. AC 16 AMP BREAKER BOX INSTALLATION​
FIGURE 8-24. AC 16 AMP BREAKER BOX INSTALLATION (CE SPECS)​
FIGURE 8-25. ANALYZER CABLE HARNESS​
FIGURE 8-26. AXLE POWER TRACK HARNESS ASSEMBLY​
FIGURE 8-27. BATTERY DISCONNECT INSTALLATION​
FIGURE 8-28. BEACON CONTROL HARNESS (BLUE BEACON LIGHT ONLY)​
FIGURE 8-29. BEACON LIGHT HARNESS (BLUE BEACON LIGHT ONLY)​
FIGURE 8-30. B.L.A.M. TO BOOM LENGTH SENSOR HARNESS​
FIGURE 8-31. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (LEFT SIDE)​
FIGURE 8-32. B.L.A.M. TO BOOM ANGLE SENSOR HARNESS (RIGHT SIDE)​
FIGURE 8-33. B.L.A.M. HARNESS​
FIGURE 8-34. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1200SJP)​
FIGURE 8-35. BOOM CABLES INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (1350SJP)​
FIGURE 8-36. BOOM CABLES INSTALLATION (AUSTRALIAN AND CE SPECS) (1200SJP)​
FIGURE 8-37. BOOM CABLES INSTALLATION (AUSTRALIAN AND CE SPECS) (1350SJP)​
FIGURE 8-38. BOOM CABLES INSTALLATION WITH 4000W GENERATOR (1200SJP)​
FIGURE 8-39. BOOM CABLES INSTALLATION WITH 4000W GENERATOR (1350SJP)​
FIGURE 8-40. BOOM CABLES INSTALLATION WITH 7500W GENERATOR (1200SJP)​
FIGURE 8-41. BOOM CABLES INSTALLATION WITH 7500W GENERATOR (1350SJP)​
FIGURE 8-42. BREAKER BOX KIT - 16 AMP (2500W GENERATOR)​
FIGURE 8-43. BREAKER BOX KIT - 16 AMP (4000W GENERATOR)​
FIGURE 8-44. CHASSIS HARNESS ASSEMBLY​
FIGURE 8-45. CLEARSKY READY HARNESS​
FIGURE 8-46. DUAL CAPACITY JIB POSITION SWITCH HARNESS​
FIGURE 8-47. EIM LOAD CELL HARNESS​
FIGURE 8-48. ENGINE HARNESS - DEUTZ TD2011 ENGINES​
FIGURE 8-49. ENGINE HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-50. FUEL FILTER HARNESS - DEUTZ TCD2.9L4 ENGINES AND UTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-51. FUEL HARNESS - DEUTZ TCD2.9L4 ENGINES AND DEUTZ TCD2.9L4 (STAGE V) ENGINES​
FIGURE 8-52. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-53. GENERATOR HARNESS - 7500W GENERATOR​
FIGURE 8-54. GENERATOR HARNESS - 7500W GENERATOR​
FIGURE 8-55. GROUND CONTROL BOX HARNESS​
FIGURE 8-56. GROUND CONTROL BOX HARNESS - DEUTZ TCD2.9L4 ENGINES (CE SPECS)​
FIGURE 8-57. GROUND CONTROLS TO ENGINE HARNESS​
FIGURE 8-58. JIB STOW SWITCH HARNESS​
FIGURE 8-59. LOAD SENSING PIN HARNESS​
FIGURE 8-60. LOCKOUT VALVE HARNESS​
FIGURE 8-61. MAIN BOOM CONTROL CABLE HARNESS (1200SJP)​
FIGURE 8-62. MAIN BOOM CONTROL CABLE HARNESS (1350SJP)​
FIGURE 8-63. MAIN VALVE HARNESS​
FIGURE 8-64. PLATFORM CONSOLE BOX HARNESS - WITHOUT SKYGUARD​
FIGURE 8-65. PLATFORM CONSOLE BOX HARNESS - WITH SKYGUARD (SN 0300201016 through 0300234290, SN B300002238 through B300002991)​
FIGURE 8-66. PLATFORM CONSOLE BOX HARNESS - WITH SKYGUARD (SN 0300234291 through 0300272504, SN B300002992 through B300007118)​
FIGURE 8-67. PLATFORM INTERFACE HARNESS​
FIGURE 8-68. PLATFORM VALVE HARNESS​
FIGURE 8-69. PUMP ADAPTER HARNESS - SAUER PUMPS​
FIGURE 8-70. RECEPTACLE BOX KIT - 110V IEC YELLOW WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-71. RECEPTACLE BOX KIT - 220V IEC BLUE WITHOUT 2500W GENERATOR (CE SPECS)​
FIGURE 8-72. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND WITHOUT 2500W GENERATOR (70MM X 70MM BOX) (CE SPECS)​
FIGURE 8-73. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND WITHOUT 2500W GENERATOR (70MM X 70MM BOX) (CE SPECS)​
FIGURE 8-74. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE SPECS)​
FIGURE 8-75. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE SPECS)​
FIGURE 8-76. RECEPTACLE BOX KIT - 220V AFSINT 107 KEYED GROUND WITHOUT 2500W GENERATOR (2X4 BOX) (CE SPECS)​
FIGURE 8-77. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-78. SKYEYE EMITTER HARNESS​
FIGURE 8-79. SKYEYE RECEIVER HARNESS​
FIGURE 8-80. SKYLINE HARNESS​
FIGURE 8-81. STROBE LIGHT HARNESS (AMBER)​
FIGURE 8-82. TILT SENSOR HARNESS (LEFT)​
FIGURE 8-83. TILT SENSOR HARNESS (RIGHT)​
FIGURE 8-84. ELECTRICAL DIAGRAM LIST​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI SPEC​
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPEC​
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPEC (PORTGUESE/ENGLISH)​
FIGURE 9-4. DECAL INSTALLATION - CE SPEC​
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH)​
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC (ENGLISH/FRENCH)​
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH)​
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH)​
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPEC (SPANISH/ENGLISH)​
FIGURE 9-10. DECAL INSTALLATION - OPTIONS​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS​
PART NUMBER INDEX
