652
1,893,758
JLG Articulating Boom Lift 450A 450AJ Service And Maintenance Manual 3120869 2000
Brand: JLG
Type of Machine: Articulating Boom Lift
Type of Manual: Service And Maintenance Manual, Hydraulic And Electric Wiring Diagram
Model: JLG 450A ; 450AJ Articulating Boom Lift
Date: 2000
Parts Number: 3120869
Number of Pages: 116 Pages
SECTION A - INTRODUCTION - MAINTENANCE SAFETY PRECAUTIONS
A General​
B Hydraulic System Safety​
C Maintenance​
SECTION 1 - SPECIFICATIONS
1.1 Capacities​
1.2 Component Data​
1.3 Tires​
1.4 Specifications and Performance Data.​
1.5 Torque Requirements​
1.6 Lubrication.​
1.7 Pressure Settings - PSI (Bar).​
1.8 Major Component Weights​
1.9 Critical Stability Weights​
1.10 Cylinder Specifications​
1.11 Function Speeds (in Seconds)​
1.12 Serial Number Location.​
SECTION 2 - PROCEDURES
2.1 General​
2.2 Service and Guidelines​
2.3 Lubrication and Information​
2.4 Cylinders - Theory of Operation​
2.5 Valves - Theory of Operation.​
2.6 Boom Maintenance​
2.7 Drift Test​
2.8 Cylinder Checking Procedure.​
2.9 Cylinder Repair​
2.10 Mid and Lower Lift Cylinder Bleeding Procedure​
2.11 Hydraulic Pump (gear)​
2.12 Swing Bearing​
2.13 Worm gear.​
2.14 Boom Synchronizing Procedure.​
2.15 Extend-A-Reach.​
2.16 Adjustment Procedure For Lockout Valve​
2.17 Torque Hub (Prior to S/N 39594)​
2.18 Torque Hub (S/N 39594 to Present)​
2.19 Drive Brake (Ausco)​
2.20 Boom Limit Switches.​
2.21 Lift Up and Platform Level Down Disable Switch​
2.22 Throttle Checks and Adjustments - Deutz Engine​
2.23 Drive and Steer Controller.​
2.24 Lift and Swing Controller.​
2.25 Function Control​
2.26 Tilt Alarm Switch​
2.27 Pressure Setting Procedures​
2.28 Hydraulic Component Start-Up Procedures and Recommendations​
2.29 Semi-Track​
2.30 Preventive Maintenance and Inspection Schedule.​
SECTION 3 - TROUBLESHOOTING
3.1 General​
3.2 Troubleshooting​
3.3 Hydraulic Circuit Checks.​
