[JD] John Deere PowerTech 6068 Diesel Engine Technical Manual CTM104719
Type of Document: Technical Manual
Type of Machine: PowerTech
Number of Pages: 2704 pages
Part Number: CTM104719
Model:
John Deere 6068 PowerTech OEM Diesel Engine 6090 (9.0L) above 130kW (174 hp) (Interim Tier 4/Stage III B platform)
John Deere 6068HDW78, 6068HDW85, 6068HFC94, 6068HFC95,
John Deere 6068HFG94, 6068HFG95, 6068HL495, 6068HL497,
John Deere 6068HT073, 6068HT080, 6068HT084, 6068HT088,
John Deere 6068HT089, 6068HTJ90, 6068HTJ91, 6068HZ275,
John Deere 6068HZ490, 6068HZ491, 6068RW401, 6068RW402,
John Deere 6068RW404, 6068RW414, 6068RW415
Content:
Foreword
Record of Changes
6068 PowerTech™ Engine Above 130 kW (174 hp) - Interim Tier 4/Stage III B
Related Manuals
Training Information
Definition of Terms
Safety
Engine Identification Information
Fuels, Lubricants, and Coolants
Repair and Adjustments
Engine Rebuild
Cylinder Head and Valves Repair and Adjustments
Cylinder Block, Liners, Pistons and Rods
Crankshaft, Main Bearings and Flywheel
Camshaft and Timing Gear Train Repair and Adjustment
Lubrication System Repair and Adjustment
Cooling System Repair and Adjustment
Air Intake and Exhaust System Repair and Adjustment
Air System Repair and Adjustment - Single Turbocharger Option
Electronic Fuel System Repair and Adjustment
OEM Starting and Charging Systems Repair and Adjustment
Electrical Engine Control Repair and Adjustment
Connector Repair and Adjustment
Aftertreatment Devices
Theory of Operation
Base Engine Operation
Lubrication System
Aftertreatment System
Electronic Control System
Diagnostics
Observable Diagnostics and Tests
Checks, Tests and Procedures
Diagnostic Instructions and Information
Engine Position Diagnostics
Air Intake and Exhaust System Diagnostics
Lubrication and Cooling System Diagnostics
Fuel System Diagnostics
Engine Control Unit (ECU) and Throttle Diagnostics
Air Throttle Actuator, EGR Valve, and VGT Diagnostics
VGT and Fuel Dosing Calculated Values Diagnostics
Fuel Dosing Aftertreatment System Diagnostics
Application Diagnostics
Communication Diagnostics
Tools and other materials
Repair Tools and Other Materials
Diagnostic Service Tools
Specifications
Repair and General OEM Specifications
Diagnostic Specifications
Model:
Content:
Foreword
Record of Changes
Related Manuals
Definition of Terms
Safety
Engine Rebuild
Theory of Operation
Lubrication System
Diagnostics
Specifications
- JOHN DEERE CODE DTC LIST
