JCB Skid Steer Loader Robot 160 00680015-00681290 Parts Catalog 9802-4530
Brand: JCB
Type of Machine: Skid Steer Loader
Model: JCB Robot 160 Skid Steer Loader
Serial Number: 00680015-00681290
Part Number: 9802-4530
Number of Pages: 523 Pages
A Attachments
Shovel G.P. 0.37 Cu.M
Shovel G.P. 0.29 Cu.M, 1430mm
Shovel G.P. 1730mm Wide
Shovel Low Back, 1560mm
Toeplate, Bolt On
Shovel Low Back, 1397mm 0.28cu.M
Shovel G.P. 1397mm, 0.28cu.M.
Shovel G.P. 1560mm, 0.34cu.M.
Shovel Light Duty, 1430mm 0.40 Cu.M.
Shovel Light Duty, 1580mm 0.57 Cu.M.
Shovel Light Duty, 1730mm 0.48 Cu.M.
Bucket Standard Backhoe Attachment
B Bodywork, Cab, Loader End
Chassis Robot 160
Chassis Fittings
Cover Hydraulic Motor
Tank, Hydraulic
Engine Cover
Engine Cover
Soundproofing
Demolition Grille
Fender, Right Side
Bracket, Centering
Guard, Roof
Guard,Frame Rear Door
Rear Grille
Covers, Hoses
Mounting Front Lights
Brackets Rear Light Not Uk
Brackets Rear Light
Lift Frame Single Point Lift
Cab Assembly
Door
Door Tracked Option
Cab Glazing
Cab Glazing
Canopy
Door, Canopy
Floorplate
Cab Mountings
Cover Plates
Link Bar
Link Bar, Servo
Link Bar
Restraint
Restraint, Servo
Restraint,Manual Override Brake
Restraint Spring
Seat, Basic
Seat Belt
Seat Belt (3 Inch)
Control Consoles Manual
Interior Mouldings
Control Consoles Servo
Guard Screen
Rear Exit
Lifting Brackets 10mm Thick Front
Lifting Brackets 20mm Thick Front
Polyscreen, Cab
Polyscreen Canopy
Mirror, Cab Mounted Exterior
Window, Sliding
Roof Lining
Arm, Loader
Safety Strut
Guard, Hose
Travel Link Italy
C Electrics-Machine Cab & Engine
Harnesses
Light, Combination Front
Light, Working Front & Rear
Light, Head Right Hand Dip
Light, Head Left Hand Dip Clear
Light, Rear
Fuse Link Box
Horn, Single Tone
Battery Superseded See C1-8-2
Battery
Battery R.O.W.
Battery Isolator ( Optional )
Switches, Electrical
Installation Reverse Alarm Manual
Reverse Alarm Servo
Light, Beacon Hazard Warning Amber
Light, Beacon Hazard Warning Amber, Tall
Switches Brake Light
Light, Number Plate
Flasher Side Repeater 12 Volt
Harness Coverplates
Electrical Equipment
Alternator 55amp
Alternator Mountings
Motor, Starter
D Controls-Machine Engine & Steering
Control Levers Manual
Hand Controls
Hand Controls
Hand Controls Aux
Foot Controls Aux
Control Return To Neutral
Control Levers Hydr0static Pump Manual
Brackets Pump Lever Stop
Control Speed Restrictor
E Hydraulics & Air Including Steering
Hose And Pipework Hydrostatic Pump Servo
Hose And Pipework Hydrostatic Pump Manual
Hose And Pipework Drive Motor
Hose And Pipework Filter
Hose And Pipework Servo Controller Loader Std. & H.F.
Hose And Pipework Servo Controller L.H. Dual Control Std. & H.F.
Hose And Pipework Servo Controller L.H Transmission Std. & H.F.
Hose And Pipework Servo Controller R.H. Dual Control Std. & H.F.
Hose And Pipework Loader Aux.
Hose And Pipework Loader End, Standard
Hose And Pipework Parallel Lift
Hose And Pipework Lower Valve
Hose And Pipework Hydraulic Float
Hose And Pipework Self Level Valve
Circuit Industrial Grapple
Hose And Pipework Servo Cutoff Valve
Hose And Pipework Servo Cutoff Valve Backhoe Mtg. Kit
Hose And Pipework Servo Cutoff Valve Dual Controls
Motor, Drive Upper Bsp Ports
Motor, Drive Lower Bsp Ports
Pump, Main Hydraulic Manual
Pump, Hydrostatic Manual, Components
Pump, Hydrostatic Servo, Components
Pump, Gear
Valve Mounting Manual, Hand Or Foot
Valve, Manual Fittings & Adapters
Valve, Servo Control Fittings & Adapters
Valve Components, Servo 3 Spool
Valve Self Level
Valve, Control Loader Right Hand
Filter, Hydraulic Charge Circuit
Valve, Components Manual, Hand Control
Valve, Components Manual, Hand Control With Float
Valve, Components Manual, Foot Control
Valve, Components Manual, Foot Control With Float
Lubrication
Valve Solenoid Servo Cutoff
Valve, Aux Relief Anti-Cavitation Hammer Circuit Only
Spin Turn Stops Rexroth Tran J_Stick
Valve, Control Excavator 6 Spool, Backhoe Attachment
Valve, Control Excavator 7 Spool, Backhoe Attachment
F Axles, Wheels & Transmission
Hub & Components Front Right Hand
Hub & Components Front Left Hand
Scraper Oil
Kit Sprocket Shim
Hub & Components Rear Right Hand
Hub & Components Rear Left Hand
Scraper Oil
Wheels & Tyres 8 Stud 10 X 16.5, 1524 Wide Track
Wheels & Tyres 10 X 16.5 Std. 1524 Wide
Wheels & Tyres 10x16.5 1600 Wide
Wheels & Tyres 8 Stud 10 X 16.5, 1498 Wide Track
Wheels & Tyres 8 Stud 7.00 X 15std, 1372 Wide Track
Wheels & Tyres 8 Stud 7.00 X 15 Hd, 1372 Wide Track
Wheels & Tyres 8 Stud 7.00, R15 Xzm, 1372 Wide Track
Wheels & Tyres 8 Stud 31.5_1300 X 16.5, 1604 Wide Track
Wheel & Tyres Segmented 8 Stud, 7 X 15, 1443 Wide Track
Wheel & Tyres Segmented 8 Stud, 10 X 16.5, 1472 Wide Track
Wheels & Tyres Solid 8 Stud, 6.50 X 16, 1364 Wide Track
Wheels & Tyres Solid 8 Stud, 700 X 15-5.5, 1383 Wide Track
Tracks Option Over Tyres
G Brakes
Brake, Components
L Engine 100 Series, Kr Build To M681290
Engine, Complete 2600rpm Kr Build
Engine, Complete 2800rpm Kr Build
Engine, Short Kr Build
Block Assembly Kr Build
Crankshaft, Bearings Pistons & Con-Rods Kr Build
Fans, Pulleys & Fan Belt Kr Build
Timing Case Camshaft & Gears Kr Build
Timing Levers Arms & Springs Kr Build
Flywheel & Housing Kr Build
Engine Mountings Kr Build
Cylinder Head Kr Build
Rocker Assembly Push Rods & Tappets Kr Build
Rocker Cover Kr Build
Lifting Plates Engine Kr Build
Manifold, Induction Kr Build
Manifold, Exhaust Kr Build
Filter, Air Kr Build
Filter Pre-Cleaner Optional
Exhaust System Kr Build
Pump, Water Kr Build
Thermostat, Housing Inlet & Outlet Kr Build
Radiator Fittings & Mountings Kr Build
Radiator & Hoses Kr Build
Sump, Oil Kr Build
Pump, Oil Kr Build
Filter, Oil Kr Build
Pump, Fuel Injection & Shut-Off Solenoid Kr Build
Injectors, Fuel & Injection Pipes Kr Build
Fuel System Kr Build
Filter, Fuel
Pump, Fuel Lift
Pump, Fuel Lift
Brand: JCB
A Attachments
Toeplate, Bolt On
Chassis Robot 160
Chassis Fittings
Tank, Hydraulic
Engine Cover
Engine Cover
Soundproofing
Demolition Grille
Fender, Right Side
Bracket, Centering
Guard, Roof
Rear Grille
Covers, Hoses
Brackets Rear Light
Cab Assembly
Door
Door Tracked Option
Cab Glazing
Cab Glazing
Canopy
Door, Canopy
Floorplate
Cab Mountings
Cover Plates
Link Bar
Link Bar, Servo
Link Bar
Restraint
Restraint, Servo
Restraint Spring
Seat, Basic
Seat Belt
Seat Belt (3 Inch)
Interior Mouldings
Guard Screen
Rear Exit
Polyscreen, Cab
Polyscreen Canopy
Window, Sliding
Roof Lining
Arm, Loader
Safety Strut
Guard, Hose
Travel Link Italy
Harnesses
Light, Rear
Fuse Link Box
Horn, Single Tone
Battery
Battery R.O.W.
Reverse Alarm Servo
Light, Number Plate
Harness Coverplates
Alternator 55amp
Motor, Starter
Hand Controls
Hand Controls
Hand Controls Aux
Foot Controls Aux
Pump, Gear
Valve Self Level
Lubrication
Scraper Oil
Kit Sprocket Shim
Scraper Oil
G Brakes
Brake, Components
Sump, Oil Kr Build
Pump, Oil Kr Build
Filter, Fuel
Pump, Fuel Lift
Pump, Fuel Lift
- JCB 3CX,4CX Service Manual
- JCB Hydraulic Excavator JS200 Hydraulic Schematic
- JCB Excavator JS360 Tier III Electrical and Hydraulic Diagram
- JCB 3CX,4CX & Variant Service Manual
- JCB JS 130W,JS 145W,JS 160W,JS 175W Excavator Electrics
- JCB 444 Mechanical Engine Service Manual
- JCB Compact Service Manuals S2 Issue50
- JCB Service Manuals S2A Issue 50 Program
- JCB Excavator JS 130W-175W Wiring Diagrams
- JCB 3CX, 4CX, 214, 215, 217 Workshop Manual
- JCB Service Manual S3A Issue 50
- JCB Service Parts Pro 1.17.0001 [03.2013] VM
- JCB SPP v1.13 kg + Instruction
- JCB Service Manual S3 Issue 50 Program
- JCB Compact Service Manuals S1 Issue50
