Auto47
Manager
48
27,774
JCB Articulated Dump Truck 712 00612001-00612369 Parts Catalog PDF
Brand: JCB
Type of Machine: Articulated Dump Truck
Model: 712 00612001-00612369 Tw & Tx Engine Build 9802/4100
Number of Pages: 551 Pages
A1-1-1 BODYWORK & FITMENTS
A1-1-3 BODYWORK REINFORCING STANDARD BODY OPTION ONLY
A1-1-5 MOUNTINGS LADDER & SHOVEL
B1-1-1 CHASSIS & FITTINGS FRONT
B1-1-13 SOUNDPROOFING KIT
B1-1-2 CHASSIS, REAR
B1-1-3 TANK, HYDRAULIC
B1-1-4 TANK, DIESEL FUEL
B1-1-5 CHASSIS CENTRE PIVOT
B1-1-6 BODYWORK
B1-1-7 BODYWORK
B1-1-8 SOUNDPROOFING KIT
B1-1-9 SOUNDPROOFING KIT
B1-2-1 CHASSIS & FITTINGS FRONT
B1-2-5 BODYWORK
B1-2-6 BODYWORK, CENTRE
B1-2-7 TANK, HYDRAULIC
B1-2-8 BODYWORK, CENTRE
B1-2-9 CHASSIS, REAR FLATBED
B2-1-1 CAB FRAME
B2-1-10 CAB BASE (OPERATORS STAND) 2WD
B2-1-2 CAB COMPLETE INCLUDING GLASS
B2-1-3 CAB FRAME
B2-1-4 CAB COMPLETE INCLUDING GLASS
B2-10-1 FIRE EXTINGUISHER 2.5KG SERVICE OPTION
B2-2-1 CAB GLAZING CLEAR
B2-2-2 CAB GLAZING TINTED
B2-2-3 CAB GLAZING CLEAR
B2-2-4 CAB GLAZING TINTED
B2-3-1 CAB INSTALLATION
B2-4-1 SEAT
B2-4-2 SEAT
B2-5-1 PAINT
B2-7-1 LABELS
B2-8-1 HANDBOOK CASE
B2-9-1 GUARD REAR SCREEN
C1-1-1 ELECTRICS, MAIN
C1-10-1 SPEEDOMETER
C1-11-1 LIGHT, BEACON HAZARD WARNING AMBER
C1-12-1 RADIO CONSOLE
C1-2-2 ELECTRICS, CAB REAR WIPER
C1-3-1 LIGHT, COMBINATION & REVERSE ALARM
C1-4-3 AIR CONDITIONING INSTALLATION
C1-5-1 ELECTRIC GEAR SHIFT
C1-6-1 SWITCH, COLUMN
C1-7-1 INSTRUMENT PANEL
C1-7-2 INSTRUMENT CLUSTER
C1-7-4 INSTRUMENT PANEL
C1-8-1 BATTERY
C1-8-2 BATTERY ISOLATOR
C1-9-1 LIGHT, HEAD, 24.VOLT LEFT HAND DIP
C1-9-2 LIGHT, HEAD, 24.VOLT RIGHT HAND DIP
D1-2-1 TIPPING LEVER
D1-2-2 TIPPING LEVER
E1-1-1 HOSE & PIPEWORK BODY LIFT
E1-2-1 HOSE & PIPEWORK STEERING
E1-4-1 CIRCUIT EMERGENCY STEERING
E2-1-1 PUMP, MAIN HYDRAULIC ADAPTERS
E2-1-2 PUMP, MAIN HYDRAULIC
E2-2-1 VALVE, REGULATOR FLOW MAIN, BRAKE HYDRAULIC
E2-3-1 FILTER, HYDRAULIC
E2-3-2 FILTER, HYDRAULIC HIGH PRESSURE
E2-4-1 VALVE, ADAPTERS
E2-4-2 VALVE ASSEMBLY
E2-5-1 VALVE, PRIORITY
E2-5-2 VALVE, PRIORITY FITTINGS & ADAPTERS
E2-5-3 VALVE, PRIORITY FITTINGS & ADAPTERS
E2-7-1 VALVE, PUMP FAILURE ADAPTERS EMERGENCY STEERING CIRCUIT
E2-7-3 VALVE, SUPPLEMENTARY & ADAPTERS EMERGENCY STEERING CIRCUIT
E2-7-4 VALVE, SUPPLEMENTARY COMPONENTS EMERGENCY STEERING CIRCUIT
F1-1-1 AXLE ASSEMBLY FRONT & REAR
F1-1-2 PROPSHAFTS TRANSMISSION
F1-1-3 DIFFERENTIAL ASSEMBLY
F1-1-4 CROWN WHEEL & PINION
F1-1-5 AXLE BREATHER FRONT & REAR
F1-1-8 PROPSHAFTS REAR CHASSIS LONG FLATBED
F1-2-1 AXLE ASSEMBLY FRONT
F1-3-1 AXLE ASSEMBLY REAR
F1-8-1 TRANSMISSION MOUNTING
F1-9-1 WHEELS & TYRES 5 PIECE WHEEL
F1-9-2 WHEELS & TYRES 3 PIECE WHEEL
F2-1-1 TRANSMISSION STANDARD
F2-1-2 TRANSMISSION HIGH ALTITUDE BUILD
F2-1-4 TRANSMISSION ADAPTER HIGH ALTITUDE BUILD
F2-10-1 GEAR GROUP REVERSE IDLER
F2-11-1 SHAFT GROUP HIGH, 3RD
F2-12-1 SHAFT GROUP, IDLER WITH EMERGENCY STEER PUMP
F2-13-1 SHAFT, OUTPUT GROUP DISCONNECT PARKING BRAKE & SPEEDO DRIVE
F2-14-1 PUMP, CHARGING & FILTER GROUP
F2-15-1 MOUNTINGS CONTROL VALVE TRANSMISSION POWERSHIFT
F2-16-1 VALVE, CONTROL & SHUTTLE VALVE
F2-16-2 VALVE, CONTROL & SHUTTLE VALVE
F2-2-1 SHAFT, TURBINE STATOR SUPPORT & OIL BAFFLE GROUP
F2-3-1 DRIVE PLATE GROUP
F2-4-1 TORQUE CONVERTER ASSY,STEEL TURBINE HUB
F2-5-1 GEAR GROUP AUXILIARY PUMP DRIVE
F2-6-1 GEAR, DRIVE GROUP CHARGING PUMP
F2-7-1 SHAFT GROUP REVERSE, 2ND TRANSMISSION
F2-8-1 SHAFT GROUP LOW SPEED
F2-9-1 SHAFT GROUP FORWARD
G1-1-1 BRAKE, SYSTEM
G1-1-2 ACCUMULATOR & MTG.
G1-1-3 BRAKE, PARKING COMPONENTS
G1-1-4 BRAKE, PARKING LEVER OPERATED CONTROL
G1-1-5 BRAKE, PARKING COMPONENTS
G1-1-8 BRAKE, PARKING ELECTRIC OPERATED CONTROL
G1-1-9 CONTROL, HANBRAKE CONVERSION KIT LEVER OPERATION TO ELECTRIC
G1-2-2 BRAKE PEDAL INSTALLATION LEVER OPERATED HANDBRAKE CONTROL
G1-2-3 VALVE, BRAKE ADAPTERS & SWITCHES LEVER OPERATED HANDBRAKE CONTROL
G1-2-4 VALVE, BRAKE COMPONENTS LEVER OPERATED HANDBRAKE CONTROL
G1-2-5 BRAKE, COMPONENTS FOOT
G1-2-6 VALVE, BRAKE ADAPTERS & SWITCHES ELECTRIC OPERATED HANDBRAKE CONTROL
G1-2-7 VALVE, BRAKE COMPONENTS ELECTRIC OPERATED HANDBRAKE CONTROL
G1-2-8 BRAKE PEDAL INSTALLATION ELECTRIC OPERATED HANDBRAKE CONTROL
G1-2-9 BRAKE PEDAL COMPONENTS
H1-1-1 STEERING COLUMN
H1-1-3 STEERING COLUMN
H1-3-1 VALVE, ADAPTERS STEERING
H1-3-2 VALVE, STEERING
H1-3-3 VALVE, SHOCK STEERING
H1-4-1 RAM, STEERING
H1-4-2 RAM, STEERING
H1-5-1 ACCUMULATOR INSTALLATION EMERGENCY STEER CIRCUIT
K1-1-1 ENGINE, COMPLETE TW & TX BUILDS
K1-2-1 ENGINE, SHORT TW & TX BUILDS
K1-3-1 BLOCK ASSEMBLY TW & TX BUILDS
K1-4-1 CRANKSHAFT, BEARINGS PISTONS & CON-RODS TW & TX BUILDS
K1-5-1 FANS, PULLEYS & FAN BELT TW & TX BUILDS
K1-6-1 TIMING CASE CAMSHAFT & GEARS TW & TX BUILDS
K1-6-2 TIMING CASE AUXILIARY DRIVE TW & TX BUILDS
K1-7-1 FLYWHEEL & HOUSING TW & TX BUILDS
K1-8-1 ENGINE MOUNTINGS TW & TX BUILDS
K2-1-1 CYLINDER HEAD TW & TX BUILDS
K2-2-1 ROCKER ASSEMBLY PUSH RODS & TAPPETS TW & TX BUILDS
K2-3-1 ROCKER COVER TW & TX BUILDS
K2-4-1 LIFTING PLATES ENGINE TW & TX BUILDS
K3-1-1 MANIFOLD, INDUCTION TW BUILD
K3-1-2 MANIFOLD, INDUCTION TX BUILD
K3-2-1 MANIFOLD, EXHAUST TW BUILD
K3-3-2 FILTER, AIR TX BUILD
K3-4-1 SILENCER TW BUILD
K3-4-2 SILENCER TX BUILD
K3-4-3 EXHAUST SYSTEM HEATED BODY
K3-5-1 SILENCER EXTENSION TW & TX BUILD
K4-1-1 PUMP, WATER TW & TX BUILDS
K4-2-1 THERMOSTAT, HOUSING INLET & OUTLET TW & TX BUILDS
K4-3-1 RADIATOR FITTINGS & MOUNTINGS TW BUILD
K4-3-2 RADIATOR FITTINGS & MOUNTINGS STANDARD, TW BUILD
K4-3-3 RADIATOR FITTINGS & MOUNTINGS WORLDWIDE, TW & TX BUILDS
K4-3-4 RADIATOR FITTINGS & MOUNTINGS TX BUILD
K4-4-1 RADIATOR HOSES & FITTINGS TW BUILD
K4-4-2 RADIATOR HOSES & FITTINGS WORLDWIDE, TW & TX BUILDS
K4-4-3 RADIATOR HOSES & PIPEWORK TX BUILD
K5-1-1 SUMP, OIL TW & TX BUILDS
K5-2-1 PUMP, OIL & RELIEF VALVE TW & TX BUILDS
K5-4-1 FILTER, OIL & OIL FEED ADAPTOR TW BUILD
K5-4-2 FILTER, OIL & OIL FEED ADAPTER TX BUILD
K5-5-1 COOLER, OIL & INSTALLATION
K5-5-2 COOLER, OIL & INSTALLATION OPTIONAL
K5-5-3 COOLER, OIL & PIPEWORK TX BUILD
K6-1-1 PUMP, FUEL INJECTION TW & TX BUILDS
K6-2-1 INJECTORS, FUEL & INJECTION PIPES TW & TX BUILDS
K6-3-1 FUEL SYSTEM TW & TX BUILDS
K6-4-1 FILTER, FUEL TW & TX BUILDS
K6-4-2 MOUNTING BRACKET FUEL FILTER TW & TX BUILDS
K6-5-1 PUMP, FUEL LIFT TW & TX BUILDS
K6-5-2 PUMP, FUEL LIFT ALTERNATIVE TW & TX BUILDS
K6-6-1 FILTER FUEL SEDIMENT TW & TX BUILDS
K6-6-2 FILTER FUEL SEDIMENT TW & TX BUILDS
K7-1-1 TURBOCHARGER TX BUILD
K7-2-1 TURBO, PIPEWORK TX BUILD
K7-3-1 TURBO, HEATSHIELD TX BUILD
K8-1-1 GASKET SETS TW & TX BUILDS
K8-2-1 KIT, ENGINE OVERHAUL TW & TX BUILD
