652
1,893,758
JCB Agricultural Tractors Fastrac 8330T4FCC 2022-2025 Service Manual 9823/6850
Brand: JCB
Type of Machine: Agricultural Tractors
Model: JCB Fastrac 8000 Series 6 (T4F) - 8330T4FCC Agricultural Tractors
Publication: 2022-2025
Part Number: 9823/6850
Number of Pages: 1400 Pages
01: Machine
03: Safety​
03: Safety - Yours and Others​
06: Safety Warnings​
09: General Safety​
12: Maintenance Safety​
18: Operating Safety​
21: Worksite Safety​
24: Risk Assessment​
27: Maintenance Positions​
06: About this Manual​
03: Model and Serial Number​
06: Using the Manual​
09: Description​
12: Main Component Locations​
15: Service Point Locations​
33: Cleaning​
00: General​
03: Attachments, Couplings and Load Handling
00: Attachments​
00: General​
12: Hitch​
00: General​
01: Front Hitch​
02: Rear Hitch​
05: Ladder​
06: Pick-up​
12: Mechanical Tow​
15: Three-Point Linkage​
00: General​
18: Drawbar​
00: General​
06: Body and Framework
00: Body and Framework​
00: General​
03: Chassis​
00: General​
04: Pannier​
00: General​
06: Moveable Panel and Cover​
00: General​
03: Battery Compartment​
06: Engine Compartment​
27: Transportation Lock​
00: General​
30: Pivot Pins​
00: General​
63: Identification Label​
00: General​
03: Machine​
06: Engine​
12: Gearbox​
15: Operator Protective Structure​
66: Tools​
00: General​
03: Toolbox​
09: Operator Station
00: Operator Station​
00: General​
06: Operator Protective Structure​
09: Window​
00: General​
12: Operator Seat​
00: General​
15: Seat Belt​
00: General​
18: Door​
00: General​
03: Lock​
27: Controls​
35: Clutch Pedal​
40: Multi-Purpose Joystick​
42: Transmission Drive Lever​
30: Trim Panel​
00: General​
09: Dashboard​
39: Rear Trim​
48: Bulkhead​
33: Safety Label/Chart​
00: General​
12: Heating, Ventilating and Air-Conditioning (HVAC)
00: Heating, Ventilating and Air-Conditioning (HVAC)​
00: General​
03: HVAC Unit​
00: General​
03: Evaporator​
09: Expansion Valve​
09: Compressor​
00: General​
12: Receiver Dryer​
00: General​
15: Condenser​
00: General​
18: Filter​
00: General​
06: Fresh Air​
09: Recirculation​
96: Pipe​
00: General​
15: Engine
00: Engine​
00: General​
18: Engine Belt​
00: General​
03: Front End Accessory Drive (FEAD) Belt​
21: Tensioner​
21: Oil Filter​
00: General​
24: Air Filter​
00: General​
27: Crankcase Ventilation​
00: General​
45: Oil Sump​
00: General​
12: Gasket​
63: Mount​
00: General​
72: Alternator​
00: General​
03: Pulley​
06: Voltage Regulator​
75: Starter Motor​
00: General​
03: Solenoid​
06: Brush Gear​
84: Sensor​
00: General​
03: Crankshaft Position​
06: Camshaft Position​
15: Manifold Absolute Pressure​
19: Exhaust Temperature​
21: Engine Oil Pressure​
24: Fuel Temperature​
26: Fuel Pressure​
27: Fuel Rail Pressure​
33: Coolant Temperature​
51: Nitrogen Oxide (NOx)​
90: Air Intake​
00: General​
18: Fuel and Exhaust System
00: Fuel and Exhaust System​
00: General​
03: Tank​
00: General​
09: Filter​
00: General​
09: Pre-Filter Element​
12: Water Separator​
00: General​
24: Exhaust​
00: General​
30: Aftertreatment System​
00: General​
03: Tank​
06: Filter​
09: Tank Sensor​
12: Pump Supply Module​
15: Dosing Metering Module​
18: Catalyst​
30: Intake Throttle​
36: Mixer Reactor​
90: Hose​
96: Fuel Pipe​
00: General​
21: Cooling System
00: Cooling System​
00: General​
03: Cooling Pack​
00: General​
06: Charge Air Cooler (CAC)​
12: Hydraulic Oil Cooler​
06: Expansion Tank​
00: General​
09: Pump​
00: General​
12: Thermostat​
00: General​
93: Hose​
00: General​
24: Brake System
00: Brake System​
00: General​
03: Service Brake​
00: General​
03: Tank​
09: Brake Valve​
15: Protection Valve​
19: Pressure Modulating Valve​
24: Air Dryer​
30: Caliper​
33: Pad​
48: Actuator​
49: Actuator (Hill hold)​
50: Light Switch​
56: ABS Sensor​
96: Pipe​
18: Park Brake​
15: Pad​
18: Caliper​
21: Disc​
48: Actuator​
36: Trailer Brake - Hydraulic​
06: Filter​
07: Filter Element​
09: Control Valve​
25: Steering System
00: Steering System​
00: General​
12: Variable Ratio System​
15: Global Positioning System (GPS)​
06: Steer Unit/Valve​
00: General​
07: Dual Steer Valve​
00: General​
08: GPS Valve​
00: General​
12: Column​
00: General​
18: Front Track Rod​
00: General​
27: Driveline
00: Driveline​
00: General​
08: CVT Gearbox​
00: General​
13: Clutch Control Valve Block​
15: Solenoid Control Valve​
21: Pressure Maintaining Valve (PMV)​
39: Filter​
40: Suction Strainer​
81: Mount​
13: Gearbox Actuator​
00: General​
16: Power Take-Off (PTO)​
00: General​
05: Filter​
51: Propshaft​
18: PTO Gearbox​
00: General​
20: Axle(s)​
00: General​
22: Drivehead​
00: General​
06: Crownwheel​
09: Pinion Gear​
24: Differential​
00: General​
10: Pinion Seal​
27: Hub​
00: General​
29: Wheel​
00: General​
33: Tyre​
00: General​
47: Propshaft​
00: General​
28: Suspension System
00: Suspension System​
00: General​
09: Upper Link Arm​
00: General​
10: Lower Link Arm​
00: General​
15: Control Rod​
00: General​
24: V-Link Arm​
00: General​
42: Anti-Roll Bar​
00: General​
90: Potentiometer​
00: General​
30: Hydraulic System
00: General​
00: General​
49: Schematic Symbols​
50: Schematic Circuit​
03: Tank​
00: General​
12: Suction Strainer​
24: Breather​
04: Filter​
00: General​
09: Return Line​
11: Gear Pump +[8330-6 [T4F]]​
00: General​
12: Variable Displacement Pump​
00: General​
15: Cylinder / Ram​
00: General​
54: Suspension​
18: Accumulator​
00: General​
03: Suspension​
04: Suspension Spring​
21: Oil Cooler​
00: General​
52: Attachment Control Valve Block​
00: General​
60: Directional Control Valve​
07: Suspension​
93: Hose​
00: General​
96: Pipe​
00: General​
97: Connectors​
00: General​
03: Quick Release Coupling​
09: Adaptor​
18: O-Ring Face Seal (ORFS)​
33: Electrical System
00: Electrical System​
00: General​
90: Earth Point​
03: Battery​
00: General​
03: Isolator Switch​
06: Battery Cable​
00: General​
09: Power Distribution​
00: General​
03: Fuse​
06: Relay​
12: Harness​
00: General​
18: Exterior View System​
06: Ground Radar​
24: Instruments​
00: General​
03: Instrument Panel​
33: Console Switch​
00: General​
45: Control Module​
00: General​
01: Instrument Panel​
03: Machine Control​
06: Engine​
09: Gearbox​
13: Anti-Lock Braking System (ABS)​
14: Suspension​
22: Rear Hitch​
27: Heating, Ventilating and Air-Conditioning (HVAC)​
54: Window Washer/Wipe​
00: General​
57: Electronic Diagnostic​
00: General​
03: Servicemaster​
90: Error Codes​
84: Sensor​
12: Ambient Air Temperature​
18: Steer Angle​
95: Rear Hitch​
72: Fasteners and Fixings
00: Fasteners and Fixings​
00: General​
03: Screws​
00: General​
06: Bolts​
00: General​
18: Bearings​
00: General​
21: Clips​
03: Worm Drive​
36: Threaded Insert​
00: General​
57: Seal​
00: General​
75: Consumable Products
00: Consumable Products​
00: General​
03: Oil​
00: General​
03: Engine​
06: Grease​
00: General​
09: Fluids​
00: General​
03: Antifreeze​
12: Diesel Exhaust Fluid (DEF)​
10: Locking Fluids​
00: General​
14: Solvents and Primers​
00: General​
15: Adhesive​
00: General​
16: Sealant​
00: General​
18: Fuel​
00: General​
78: After Sales
24: Maintenance Schedules​
00: General​
03: Maintenance Intervals​
06: Pre-start Cold Checks, Service Points and Fluid Levels​
09: Functional Tests and Final Inspection​
81: Clothing and Personal Protective Equipment (PPE)​
00: General​
93: Special Tools​
00: General​
03: Parts List​
94: Non JCB Tools​
00: General​
11: Agco Engine​
96: Units of Measurement​
00: General​
