Jaguar XF RWD X260 2023 Engine L4-2.0L Turbo Wiring Diagram
Brand: Jaguar
Model: Jaguar XF RWD X260
Engine: L4-2.0L Turbo
Publication Date: 2023
Number of Pages: 294 Pages
Accessories and Optional Equipment
(Accessories and Optional Equipment) - Telematics - Telematics Circuit
Antilock Brakes _ Traction Control Systems
(Antilock Brakes _ Traction Control Systems) - Anti-Lock Control - ABS Circuit
Antitheft and Alarm Systems
(Antitheft and Alarm Systems) - Anti-Theft System - Anti Theft Alarm Circuit [Active]
(Antitheft and Alarm Systems) - Anti-Theft System - Passive Start Circuit [Passive Start]
Automatic Transmission_Transaxle
(Automatic Transmission_Transaxle) - Automatic Transmission - Transmission Auto-AJ200P Circuit [PI4]
(Automatic Transmission_Transaxle) - Automatic Transmission - Transmission Auto-Diesel AJ21D4 Circuit [DI4]
Battery
(Battery) - Battery, Mounting and Cables (MHEV) - Hybrid Control Interface-MHEV Circuit
Charging System
(Charging System) - Generator and Regulator (MHEV) - Charging Diesel AJ21D4 MHEV Circuit [DI4]
(Charging System) - Generator and Regulator - Charging Diesel AJ21D4 Non MHEV Circuit [DI4]
(Charging System) - Generator and Regulator - Charging Petrol AJ20P4 Circuit [PI4]
Collision Avoidance and Parking Assist Systems
(Collision Avoidance and Parking Assist Systems) - Parking Aid - Camera-Active Safety Circuit [Image Processing (IPMA)]
(Collision Avoidance and Parking Assist Systems) - Parking Aid - Near Field Sensing (MID Line) Circuit
(Collision Avoidance and Parking Assist Systems) - Speed Control - Front Centre Radar Circuit
(Collision Avoidance and Parking Assist Systems) - Warning Devices - ADAS Domain Controller Circuit [Driver Assistance Domain Controller]
(Cooling System) - Engine Cooling - Cooling Fans AJ20P4 Circuit [PI4]
(Cooling System) - Engine Cooling - Cooling Fans AJ21D4 Circuit [DI4]
Cruise Control
(Cruise Control) - Speed Control - Front Centre Radar Circuit
Doors, Hood and Trunk
(Doors, Hood and Trunk) - Handles, Locks, Latches and Entry Systems - Central Door Locking Circuit [Central Door Locking System]
(Doors, Hood and Trunk) - Handles, Locks, Latches and Entry Systems - Clear Exit Detection System Circuit [Clear Exit Detection System]
(Doors, Hood and Trunk) - Handles, Locks, Latches and Entry Systems - Passive Entry Circuit [Passive Entry System]
(Doors, Hood and Trunk) - Handles, Locks, Latches and Entry Systems - Power Tailgate Circuit [Tailgate - Powered]
Entertainment Systems
(Entertainment Systems) - Information and Entertainment System - Infotainment Circuit [Incontrol Touch Pro - 17-Speaker System]
(Entertainment Systems) - Information and Entertainment System - Infotainment Speakers Base Circuit [8-Speaker System]
(Entertainment Systems) - Information and Entertainment System - Infotainment Speakers HI-Line Circuit [11-Speaker System]
(Entertainment Systems) - Information and Entertainment System - Infotainment Speakers Premium Circuit [15-Speaker System]
Fuel Delivery and Air Induction
(Fuel Delivery and Air Induction) - Fuel Tank and Fuel Lines - Fuel System Diesel AJ21D4 Circuit [DI4]
(Fuel Delivery and Air Induction) - Fuel Tank and Fuel Lines - Fuel System Petrol AJ20P4 Circuit [PI4]
Heating and Air Conditioning
(Heating and Air Conditioning) - Auxiliary Climate Control - Block Heater Circuit [Engine Cooling System Heater]
(Heating and Air Conditioning) - Auxiliary Climate Control - Heated Screens Circuit [Heated Windshield]
(Heating and Air Conditioning) - Auxiliary Climate Control - Heater Fuel Burning Circuit [Fuel Fired Booster Heater]
(Heating and Air Conditioning) - Climate Control - Hevac Circuit
Horn
(Horn) - Horn - Vehicle Horn Circuit
Information Bus
(Information Bus) - Module Communications Network - Architecture Overview Flexray Circuit [Flexray]
(Information Bus) - Module Communications Network - Architecture Overview HS Can Body (HI Spec) Circuit [CAN Bus - High Speed - Body Systems]
(Information Bus) - Module Communications Network - Architecture Overview HS Can Chassis (HI Spec) Circuit [CAN Bus - High Speed - Chassis Systems]
(Information Bus) - Module Communications Network - Architecture Overview HS Can Comfort (HI Spec) Circuit [CAN Bus - High Speed - Comfort Systems]
(Information Bus) - Module Communications Network - Architecture Overview HS Can Power Mode Zero (HI Spec) Circuit [CAN Bus - High Speed - Power Mode Zero Systems]
(Information Bus) - Module Communications Network - Architecture Overview HS Can Power Train (HI Spec) Circuit [CAN Bus - High Speed - Powertrain Systems]
(Information Bus) - Module Communications Network - Diagnostic Socket Circuit [Diagnostic Connector]
Instrument Panel, Gauges and Warning Indicators
(Instrument Panel, Gauges and Warning Indicators) - Information and Message Center - Driver Information Circuit
(Instrument Panel, Gauges and Warning Indicators) - Information and Message Center - Driver Information Head up Display Circuit [Head-up Display]
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster and Panel Illumination - IP & Switch Illumination Circuit
(Instrument Panel, Gauges and Warning Indicators) - Instrument Panel and Console - Accessory Socket Circuit [Accessory Socket(s)]
Interior Moulding _ Trim
(Interior Moulding _ Trim) - Instrument Panel and Console - Accessory Socket Circuit [Accessory Socket(s)]
Keyless Entry
(Keyless Entry) - Handles, Locks, Latches and Entry Systems - Central Door Locking Circuit [Central Door Locking System]
(Keyless Entry) - Handles, Locks, Latches and Entry Systems - Clear Exit Detection System Circuit [Clear Exit Detection System]
(Keyless Entry) - Handles, Locks, Latches and Entry Systems - Passive Entry Circuit [Passive Entry System]
(Keyless Entry) - Handles, Locks, Latches and Entry Systems - Power Tailgate Circuit [Tailgate - Powered]
Lighting and Horns
(Lighting and Horns) - Exterior Lighting - Exterior Lighting Circuit [Head, Side, Tail and License Plate Lamps]
(Lighting and Horns) - Exterior Lighting - Trailer Socket Circuit [Trailer Socket]
(Lighting and Horns) - Interior Lighting - Interior Lighting Circuit
Locks
(Locks) - Handles, Locks, Latches and Entry Systems - Central Door Locking Circuit [Central Door Locking System]
(Locks) - Handles, Locks, Latches and Entry Systems - Clear Exit Detection System Circuit [Clear Exit Detection System]
(Locks) - Handles, Locks, Latches and Entry Systems - Passive Entry Circuit [Passive Entry System]
(Locks) - Handles, Locks, Latches and Entry Systems - Power Tailgate Circuit [Tailgate - Powered]
Mirrors
(Mirrors) - Rear View Mirrors - Corner Radars Circuit [Blind Spot Monitoring System]
(Mirrors) - Rear View Mirrors - Mirrors Circuit [Mirror Movement]
(Mirrors) - Rear View Mirrors - Mirrors Electrochromic Circuit [Electrochromic]
Parking Brake System
(Parking Brake System) - Parking Brake and Actuation - Electric Park Brake Circuit
Power and Ground Distribution
(Power and Ground Distribution) - Battery, Mounting and Cables - Earth Distribution Circuit [Ground Distribution]
(Power and Ground Distribution) - Battery, Mounting and Cables - Power Distribution Battery Junction Box Circuit [Battery Junction Box]
(Power and Ground Distribution) - Battery, Mounting and Cables - Power Distribution EJB Circuit [Engine Junction Box - Front]
(Power and Ground Distribution) - Battery, Mounting and Cables - Power Distribution Engine Compartment Circuit [Engine Junction Box - Rear]
(Power and Ground Distribution) - Battery, Mounting and Cables - Power Distribution Passenger Compartment Circuit [Passenger Junction Box]
(Power and Ground Distribution) - Battery, Mounting and Cables - Power Distribution RJB Circuit [Rear Junction Box]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview Flexray Circuit [Flexray]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview HS Can Body (HI Spec) Circuit [CAN Bus - High Speed - Body Systems]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview HS Can Chassis (HI Spec) Circuit [CAN Bus - High Speed - Chassis Systems]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview HS Can Comfort (HI Spec) Circuit [CAN Bus - High Speed - Comfort Systems]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview HS Can Power Mode Zero (HI Spec) Circuit [CAN Bus - High Speed - Power Mode Zero Systems]
(Power and Ground Distribution) - Module Communications Network - Architecture Overview HS Can Power Train (HI Spec) Circuit [CAN Bus - High Speed - Powertrain Systems]
(Power and Ground Distribution) - Module Communications Network - Diagnostic Socket Circuit [Diagnostic Connector]
Power Steering
(Power Steering) - Power Steering - EPAS Circuit
Powertrain Management
(Powertrain Management) - Electronic Engine Controls - PI4 - Engine Management Petrol AJ200 Circuit
Restraints and Safety Systems
(Restraints and Safety Systems) - Supplemental Restraint System - Occupancy Classification Sensor Circuit [Occupant Sensing]
(Restraints and Safety Systems) - Supplemental Restraint System - SRS Circuit
Seats
(Seats) - Seating - Seat Heat Circuit [Heated]
(Seats) - Seating - Seats Climatic Circuit [Climate Controlled]
(Seats) - Seating - Seats Electric Memory Circuit [Memory]
(Seats) - Seating - Seats Electric Non Memory Circuit [Non-Memory]
Starting System
(Starting System) - Starting System - PI4 - Starting System-Stop_Start AJ20P4 Circuit
Steering Column
(Steering Column) - Steering Column - Heated Steering Wheel Circuit [Steering Wheel - Heated]
(Steering Column) - Steering Column - Steering Column Adjust Circuit [Adjustable]
(Steering Column) - Steering Column - Steering Wheel Circuit [Clock Spring]
Sunroof _ Moonroof
(Sunroof _ Moonroof) - Glass, Frames and Mechanisms - Window Lift Circuit [Window Lift]
(Sunroof _ Moonroof) - Roof Opening Panel - Sunroof Circuit
Suspension Control ( Automatic - Electronic )
(Suspension Control ( Automatic - Electronic )) - Ride and Handling Optimization - Terrain Optimisation Circuit [Terrain Response]
(Suspension Control ( Automatic - Electronic )) - Vehicle Dynamic Suspension - CVD Circuit
Wheels and Tires
(Wheels and Tires) - Wheels and Tires - Tyre Pressure Monitoring Circuit [Tire Pressure Monitoring System]
Windows and Glass
(Windows and Glass) - Glass, Frames and Mechanisms - Window Lift Circuit [Window Lift]
Wiper and Washer Systems
(Wiper and Washer Systems) - Wipers and Washers - Washers & Wipers Circuit
Brand: Jaguar
Battery
Charging System
Cruise Control
Horn
Information Bus
Keyless Entry
Lighting and Horns
Locks
Mirrors
Power Steering
Seats
Starting System
Steering Column
Sunroof _ Moonroof
Wheels and Tires
Windows and Glass
- Jaguar XJ6 Parts and Service Manual
- Jaguar X-TYPE 2001 - 2009 Workshop Manual and Wiring Diagrams
- Jaguar XF 2012 Wiring Diagrams
- Jaguar XF 2010-2011 Electrical Wiring Diagrams
- Jaguar S Type 2003 - 2008 Workshop Manual & Wiring Diagrams
- Jaguar XE (X760) 2011 Workshop Manual Wiring Diagrams Diagnostic
- Jaguar XJ40 Parts Catalog and Service Manual
- Jaguar X-TYPE 2001 to 2009 Workshop Manual
- Jaguar XJ6 Service and Repair Manual
- Jaguar XK8 1996-2006 Technical Guide and Workshop Manual
- Jaguar E-Type Series I & II 1961-1970 Parts and Workshop Manuals
- Jaguar Mk X and 420G and S-Type 1960-1970 Parts and Workshop Manuals
- Jaguar X250 - XF Workshop Manual 2008 to 2009MY
- Jaguar E-Type Series III 1971-1974 Parts and Workshop Manuals
