118
6,911
Jacobsen Utility Vehicle Spraytek XP Parts Manual 672493-H 2018
Brand: Jacobsen
Model: Jacobsen Spraytek XP Diesel, Spraytek XP Gas Starting 2018 Utility Vehicle
Part Number: 672493-H
Publication Date: 2018
Number of Pages: 176 Pages
Front Panels
Dashboard
Operator Platform
Standard Seat Option
Premium Seat Option
Control Levers
Transmission Cables
Parking Brake Cables
Diesel Accelerator Pedal
Gas Accelerator Pedal
Diesel Throttle Cable Routing
Brake and Clutch Pedals
Brake Calipers and Wheels
Brake Hose Routing
Frame
ROPS
Rear Axle
Front Axle Assembly
2WD Front Axle
4WD Front Axle
Steering Column
Air Filter
Diesel Radiator Hoses
Gas Radiator Hoses
Diesel Engine and Transmission Mount
Gas Engine and Transmission Mount
Diesel Engine
Gas Engine
Diesel Exhaust
Gas Exhaust
Diesel Fuel System
Gas Fuel System
Suction and Return Hydraulics
Bed Cylinder Hydraulics
Steering Hydraulics
Hi-Lo Hydraulic Tank
Hi-Lo Hydraulics
Fuse/Relay Panel
Harness Routing
No Bed Option
Bed with Box Sides Option
Bed and Box Sides
Front Dual Piston Calipers
Rear Single Piston Caliper
Parking Brake Caliper
Hi/Lo Control Valve
Single Section Gear Pump
Two Section Gear Pump
Accessory Cylinder
Steering Cylinders
Lift Valve
Steering Valve
Front Axle Breakdown
Front and Rear Axle Cover
Axle Shafts
Input Shaft
4WD Output Shaft
Transmission Clutch Release-Shift Selector
Transmission Case
Input and Main Shaft
Gear Shift Fork Linkage
Console
Sprayer Controller Options
Sprayer Support Frame
175 Gallon Tank
300 Gallon Tank
Sprayer Pump Assembly
Strainer Assembly
Sprayer Tank Plumbing
Sprayer Manifold Options
440 Manifold
203 Manifold
440 + Sharpshooter Manifold
Envizio Pro II Manifold
Boom Mount
Boom Assembly
Three Nozzle Center Boom
Four Nozzle Center Section
Three Nozzle Left Boom
Four Nozzle Left Boom
Three Nozzle Right Boom
Four Nozzle Right Boom
Relay Box
Sprayer Harness Routing
SharpShooter Harnesses
Clean Rinse Accessory
Electric Rewind Hose Reel
Manual Rewind Hose Reel
Cleanload Accessory
Foam Marker
Water Meter Accessories
Tank Rinse and Spray Gun
