7,392
Jacobsen Rotary Mower HR800 Parts Manual 4372607-F 2024
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Parts Manual, Wiring Diagram, Hydraulic Diagram
Model: Jacobsen HR800 Rotary Mower
HR800 - Non EU Kubota Stage V with ROPS - 070543-4613110
HR800 - Non EU Kubota Stage V with CAB - 070543-4624110
HR800 - EU Kubota Stage V with ROPS - 070543-4613210
HR800 - EU Kubota Stage V with CAB - 070543-4624210
Part Number: 4372607-F
Publication Date: 2024
Number of Pages: 210 Pages
HR800™ Rotary Mower
1.1 Hood
2.1 Operator Platform
3.1 Seat Options
4.1 Control Panel Mount
5.1 Control Panel
6.1 Control Panel
7.1 Pedals
8.1 Chassis
9.1 Chassis Subassembly
10.1 Chassis Bulkhead
11.1 2 Post ROPS
12.1 Cab Mounting
13.1 Front and Rear Axle Assembly
14.1 Rear Axle
15.1 Steering Column
16.1 Air Cleaner
17.1 Radiator
18.1 Reversing Fan
19.1 Engine Oil Cooler
20.1 Engine
21.1 Pump Mounting
22.1 Hydraulic Tank
23.1 Fuel Tank
24.1 Fuel Routing
25.1 Hydraulic Valve Mounting
26.1 Pump Suction
27.1 Front Traction Hydraulics
28.1 Rear Traction Hydraulics
29.1 Speed Select Hydraulics
30.1 Brake Valve Hydraulics
31.1 Gear Pump Hydraulics
32.1 Return Hydraulics
33.1 Center Deck Hydraulics
34.1 Left Deck Hydraulics
35.1 Right Deck Hydraulics
36.1 Lift Valve Hydraulics
37.1 Steering Hydraulics
38.1 Reversing Fan Hydraulics
39.1 Oil Cooler Hydraulics
40.1 Electrical
41.1 Battery
42.1 Front Lift Arms
43.1 Left Wing Arm
44.1 Right Wing Arm
45.1 Rear Lift Cylinder Mounting
46.1 Deck Mounting
47.1 Front Deck Baffles
48.1 Front Deck Caster Wheels
49.1 Front Deck Anti-Scalp Roller
50.1 Front Deck Motor and Blades
51.1 Left Wing Deck
52.1 Right Wing Deck
53.1 Wing Deck Casters
54.1 Standard Caster Wheel
55.1 Semi-Pneumatic Caster Wheel
56.1 Lift Valve
57.1 Transmission Valve
58.1 Brake Valve
59.1 Fan Valve
60.1 Deck Valve
61.1 Priority Valve
62.1 Speed Select Valve
63.1 Traction Pump (Rear Half)
63.1 Traction Pump (Front Half)
63.1 Traction Pump (Front Half Continued)
64.1 Gear Pump
65.1 Rear Wheel Motor
66.1 Steering Valve
67.1 Fan Pump
68.1 Fan Motor
69.1 Front Lift Cylinder
70.1 Wing Lift Cylinder
71.1 Seat Suspension
72.1 Seat Assembly
73.1 Cab Frame - MK1
74.1 Cab Frame - MK2
75.1 Sealed Glass Windows - MK1
76.1 Sealed Glass Windows - MK2
77.1 Cab Door
78.1 Upper Cab Assembly
79.1 Cab Roof Assembly
80.1 Canopy Assembly
81.1 Air Conditioner and Heater Assembly
82.1 Cab Engine Connections
83.1 Cab Miscellaneous
84.1 Wing Deck Stops - CAB
85.1 Cab Worklight Kit
86.1 Canopy Kit
87.1 Rear Wiper - CAB
88.1 Beacon - ROPS
89.1 Lighting Kit - ROPS
90.1 Lighting Kit - CAB
91.1 Electrical Schematic
92.1 Connector Terminal Identification
93.1 Hydraulic Schematic
