7,392
Jacobsen Rotary Mower HR700 Safety Operation Maintenance Manual 25142G-US-R1 2016
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen HR700, Kubota V2403-CR-TE4, 4WD with ROPS And Cab Rotary Mower
Series: XB YB
Product code: 070544 070545
Part Number: 25142G-US-R1
Publication Date: 2016
Number of Pages: 134 Pages
Important
Product Identification
Guidelines For The Disposal Of Scrap Products
During Service Life
End Of Service Life
Parts Manual
Key Numbers
How To Operate Safely
Safe Operation
Preparation
Operation
ROPS
Safe Handling Of Fuels
Maintenance And Storage
When You Put The Mower On A Trailer
Important Safety Notes
Safety Decals
Instruction Decals
Operator Workstation
Control Panel
Starter Key Switch
Throttle Control
Parking Brakes
Transport Lock Switch
Cutter Switch
4 Wheel Drive In Reverse Direction Switch
Cruise Control Switch
Blank On This Model
DPF Switch
Auxiliary Hydraulic Services Kit Switch (Optional) 24
Light Switch (Optional)
Hazard Warning Switch (Optional)
Rotating Beacon
Lift/lower Switch’s
Indicator Lamps
Weight Transfer Button
Visual Display
Startup Screen
Warning / Service Screen
First Screen
Engine Start
The Engine Will Not Start
Brightness Select
Brightness Adjust
Time Display Option
Main Menu Select
Clock Select
Date Select
Time Select
Date Format
Service Menu
Fault Log
Fault Log Detail
Service Menu - Time Until Service
Time Until Service
Diagnostics
I/O Diagnostics
Connector J1
Connector J2
Connector J3
Connector J4
Connector J5
Connector J6
ECU (Engine Control Unit) Monitor (J1939)
Service Manager Pin Input
ECU Monitor Information (J1939)
Information Screen One
Information Screen Two
Mode Menu
Automatic / Manual / Creep Mode Selection
Measure Units Menu
Measure Units
Pin Menu
Input Pin
Cruise Control
Cruise Select
Cross Cut
Cross Cut Active / Inactive
Vehicle Speed
Maximum Speed Settings Menu
Pin Change
New Pin
Inclinometer
Brightness Adjust
Drive Modes
Language Menu
Language Option
Warning Slope Angle - Angle Alert
Warning Slope Angle - Inhibit Lift
Warning Slope Angle - Inhibit Cut
Warning Oil-pressure Fault
Warning Clear Radiator Screens
Warning Engine Fault
Warning Foot Pedal Fault
Warning Battery Fault
Warning Charge Filter Blocked
Warning Hydraulic Oil-level Low
Warning Service Needed
Warning Solenoid Fault
Warning (TST) Tilt Sensor Technology Fault
Warning Maximum Slope Angle Exceeded
Traction Pedal
Steering Tilt Control
Horn
Power Outlet
Seat Right-side Armrest And Pod
Parking Brake Release Valve
Tow Valve
Lighting Kit (Optional)
Cab Controls
Daily Inspection
Operator Presence And Safety Interlock System 51
Procedure For Operation
To Fit The Cutter Decks To The Machine
Operation Of The Machine
How To Start The Engine
How To Drive
How To Mow
To Stop The Engine
To Remove Blockages From Cutting Units
Transporting On A Trailer
Slinging And Jacking The Machine
Mowing On Slopes
General Precautions
Engine Fan Belt
Weight Transfer Adjustment
Steering Shaft Adjustment
Axle Stop Adjustment
Height Of Cut Adjustment
Height Of Cut Adjustment (Front Deck)
Height Of Cut Adjustment (Wing Cutter Deck)
General Instructions For Grammer Seats
Seat (Grammer MSG85)
Air Suspension Seat (Grammer MSG95 -721)
Weight Adjustment
Height Adjustment
Armrests Adjustment (Option)
Armrest (Option)
Backrest Adjustment (Option)
Lumber Support (Option)
Fore / Aft Adjustment (Option)
Multifunction Armrest (Option)
Maintenance
Maintenance And Lubrication Charts
General Precautions
Engine Lubrication
Engine Coolant
Hydraulic Filter
Hydraulic Test Ports
Fuel
Fuel System
Air Cleaner
Battery
Charge The Battery
Engine Exhaust
Diesel Particulate Filter
Hydraulic Hoses
Tires
Wheel Mounting Procedure
Blade Change
Inspecting Blades
Sharpening Blades
Folding ROPS
Care And Cleaning
Mower Storage
Lubrication Of Cutting Unit
Engine Problem Solving
Quality Of Cut Problem Solving
The Step Cut
Scalping
Stragglers
Streaks
Windrowing
Mismatched Cutter Decks
Fuse And Relay/component Identification
Engine Specification
Dimensions & Weights (ROPS Machine)
Dimensions & Weights (Cabin Machine)
Machine Specification
Vibration
Noise
Slopes
Cutting Performance
Cutter Deck Specification
Recommended Lubricants
Certificates Of Conformity
Guarantee
