118
7,392
Jacobsen Rotary Mower HR-9016T Parts Manual 4319169-A 2015
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Parts Manual, Wiring Diagram, Hydraulic Diagram
Model: Jacobsen Rotary Mower
70542 – HR9016 Turbo, Kubota V3800-DICR-T-E4B
Part Number: 4319169-A
Publication Date: 2015
Number of Pages: 168 Pages
1.1 Hood
2.1 Skirts and Cowlings
3.1 Seat and Floor Pan
4.1 Control Console
6.1 Lift Valve Panel
7.1 Traction Pedal
8.1 Traction Linkage
9.1 Brake Pedals
10.1 Parking Brake and Brake Cables
11.1 Frame
12.1 ROPS/Cab Mount
13.1 Wheels and Axle Assembly
14.1 Rear Axle
15.1 Tilt Steering
16.1 Cooler Screen
17.1 Engine Oil Cooler
18.1 Air Cleaner and Heat Shield
19.1 Radiator
20.1 Engine Cooling Fan Options
21.1 Alternator Mounting
22.1 Engine Mounting
23.1 Engine and Rear Pump
24.1 Pump Installation
25.1 Fuel Tank
26.1 Fuel Routing
27.1 Hydraulic Tank
28.1 Hydraulic Valve Assembly
29.1 Tank Hydraulics
30.1 Front Traction Hydraulics
31.1 Rear Traction Hydraulics
32.1 Hydraulic Oil Cooler Hydraulics
33.1 Return Manifold Hydraulics
34.1 Charge Pressure Hydraulics
35.1 Deck Valve Hydraulics
36.1 Front Deck Hydraulics
37.1 Left Wing Deck Hydraulics
38.1 Right Wing Deck Hydraulics
39.1 Lift Valve Hydraulics
40.1 Steering Hydraulics
41.1 Battery Tray
42.1 Chassis Harness Routing
43.1 Engine Harness Routing
44.1 Front Lift Arms
45.1 Anti-Sway Latch
46.1 Rear Lift Pivot
47.1 Rear Lift Arms
48.1 Deck Attachment
49.1 Front Deck Assembly
50.1 Center Section
51.1 Winglets
52.1 Left Wing Deck
53.1 Right Wing Deck
54.1 Front Deck Caster Wheels
55.1 Wing Deck Caster Wheels
56.1 Traction Pump (Rear Half)
56.1 Traction Pump (Front Half)
56.1 Traction Pump (Front Half Continued)
57.1 Three Section Gear Pump
58.1 Two Section Gear Pump
59.1 Rear Wheel Motor
60.1 Steering Valve
61.1 Steering Cylinder
62.1 Lift Valve
63.1 Front Lift Cylinder
64.1 Wing Lift Cylinder
65.1 Deck Motor
66.1 Deck Valve
67.1 4WD Valve
68.1 Seat Breakdown
69.1 Seat Suspension Breakdown
70.1 Electrical Schematic
71.1 Connector Terminal Identification
70.1 Hydraulic Schematic
71.1 O-Ring Chart
