7,392
Jacobsen Rotary Mower HR 5111 Parts Maintenance Manual 4103524-D 2005
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Parts Manual, Maintenance Manual, Hydraulic Diagram, Wiring Diagram
Model: Jacobsen HR 5111 Rotary Mower
69116 – Kubota V2203 with ROPS Serial 6707 and Up
69158 – Kubota V2203 with ROPS, Europe Serial 1719 and Up
Part Number: 4103524-D
Publication Date: 2005
Number of Pages: 150 Pages
1.1 Operating Safety
1.2 Important Safety Notes
2.1 Product Identification
2.2 Engine
2.3 Tractor
2.4 Cutting Units
2.5 Weights and Dimensions
2.6 Accessories & Support Literature
3.1 General
3.2 Ball Joints
3.3 Engine Alternator Belt
3.4 Parking Brake
3.5 Service Brake
3.6 Cruise Control Switch
3.7 Fuel Solenoid
3.8 Ground Pressure
3.9 Hydro Neutral
3.10 Traction Pedal Stop
3.11 Steering Toe In
3.12 Turning Radius
3.13 Steering Stop Bolts
3.14 Reverse Sensing Switch
3.15 Leveling Front Mower
3.16 Cutting Height
3.17 Servicing Front Deck
3.18 Specific Torque
3.19 Torque Specification
4.1 General
4.2 Inspecting Blades
4.3 Sharpening Blades
4.4 Engine
4.5 Engine Oil
4.6 Air Filter
4.7 Fuel
4.8 Fuel System
4.9 Battery
4.10 Jump Starting
4.11 Charging Battery
4.12 Hydraulic Hoses
4.13 Hydraulic Oil
4.14 Hydraulic Oil Filters
4.15 Electrical System
4.16 Muffler And Exhaust
4.17 Tires
4.18 Wheel Mounting Procedure
4.19 Care And Cleaning
4.20 Rollover Protection Structure (ROPS)
4.21 Radiator and Oil Cooler
4.22 Storage
5.1 General
6.1 General
6.2 Lubrication Chart
6.3 Maintenance Charts
8.1 Table Of Contents
1.1 Decals
2.1 Hood
3.1 Floorboard Platform
4.1 Seat Pan
5.1 Steering Console Support
6.1 Control Panel
7.1 Lift Valve
8.1 Throttle
9.1 Steering Console
10.1 Traction Pedal Linkage
11.1 Traction Linkage
12.1 Brake Pedal
13.1 Parking Brake
14.1 Frame and Front Axle
15.1 Front Lift Arms
16.1 Wing Lift Arms
17.1 Wing Deck Latch
18.1 Steering Axle
19.1 Air Cleaner
20.1 Radiator and Oil Cooler
21.1 Engine
22.1 Engine Mounts
23.1 Engine Fuel Control
24.1 Muffler
25.1 Fuel Tank
26.1 Pumps and Control Valve
27.1 Tank Support
28.1 Hydraulic Tank
29.1 Traction Hydraulics
30.1 Gear Pump Hydraulics
31.1 Control Valve Hydraulics
32.1 Steering Hydraulics
33.1 Lift Hydraulics
34.1 Lift Return Hydraulics
35.1 Motor Return Hydraulics
36.1 Charge Hydraulics
37.1 Oil Cooler Hydraulics
38.1 Return Hydraulics
39.1 Front Deck Hydraulics
40.1 Left Wing Deck Hydraulics
41.1 Right Wing Deck Hydraulics
42.1 Hydraulic Clamping
43.1 Electrical Components
44.1 Electrical Routing
45.1 Harness
46.1 Deck Mounting
47.1 Front Deck
48.1 Wing Deck
49.1 Caster Wheels
50.1 Deck Bumper
51.1 Seat Suspension
52.1 Control Valve
53.1 4WD Valve
54.1 Lift Valve
55.1 Steering Valve
56.1 Deck Valve
57.1 Parking Brake
58.1 Traction Pump
59.1 Deck Motor
60.1 Front Axle Motor
61.1 Rear Wheel Motor
62.1 Front Axle
63.1 Differential Assembly
64.1 Drive Axle Reducer
65.1 Differential Lock Assembly
66.1 Brake Caliper
67.1 Electrical Schematic
68.1 Hydraulic Schematic
69.1 R.O.P.S
70.1 O-Ring Chart
