Jacobsen Rotary Mower HR 3300T Safety Operation Manual 24823G-R3-GB 2011
- Download this document, you need 300 Gallons
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Safety Manual, Operation Manual
Model: Jacobsen HR 3300T Rotary Mower
Product Code: JHR33001
Series: FY
Part Number: 24823G-R3-GB
Publication Date: 2011
Number of Pages: 86 Pages
Safety, Operation & Maintenance Manual
Jacobsen Hr3300t
2.1 Important
2.3 Guidelines For The Disposal Of Scrap Products
2.3.1 During Service Life
2.3.2 End Of Service Life
2.2 Product Identification
3.1 Operating Instructions
3.2 Safety Signs
3.3 Starting The Engine
3.4 Driving The Machine
3.5 Transporting
3.6 Leaving The Driving Position
3.7 Slopes
Take Extra Care When Working On Slopes
3.8 Blocked Cutting Units
3.9 Adjustments, Lubrication, Maintenance & Cleaning
Danger:
Warning:
Caution:
Important:
4.1 Engine Specification
4.2 Machine Specification
4.3 Dimensions
4.5 Vibration Level
4.6 Slopes
Do Not Use On Slopes Greater Than 14°
4.7 Cutter Deck Specification
4.8 Recommended Lubricants
4.9 Cutting Performance (Area)
4.10 Ce Certificates
5.1 Safety Decals Ec
5.2 Instruction Decals Ec
The Free Wheel Facility Is For Recovery Purposes Only.
Do Not Tow The Machine For More Than A Few Metres, Or Allow The Machine To Free Wheel Down Slopes Even When Unloading Down Ramps.
6.1.1 Instrument Panel (Before Serial No. Fr000323 & Fy000313)
6.11 Seat Right Hand Arm Rest & Pod
6.1 Instrument Panel (After Serial No. Fr000322 & Fy000312)
6.1a Starter Key Switch
6.1b Throttle Control Lever
6.1c Parking Brakes
6.1d Cutting Unit Switch
6.1e Emergency Stop Switch (Optional)
6.1f Fuel Gauge
6.1g Engine Coolant Temperature Gauge
6.1h Hourmeter
6.1j Blocked Hydraulic Filter Indicator Lamp.
6.1k Joystick Unit Lift / Lower / Slew Control
6.1l Weight Transfer Switch
6.1m Cutters Running Indicator Lamp
6.1n Fault Indicator Lamp
6.1p Rotating Beacon Switch (Optional)
6.1r Hazard Warning Switch (Optional)
6.1s Indicator Warning Lamp (Optional)
6.2 Traction Pedal
6.3 Steering Tilt Control
6.4 Horn
6.5 Diff Lock
6.6 Power Outlet
6.7 Parking Brake Release Valve
6.8 Free Wheel
6.9 Controller Error Codes
6.10 Lighting Kit (Optional)
7.1 Daily Inspection
The Daily Inspection Should Be Performed Only When The Engine Is Off And All Fluids Are Cold. Lower Implements To The Ground, Engage Parking Brake, Stop Engine And Remove Ignition Key.
7.2 Operator Presence And Safety Interlock System
7.3 Operating Procedure
7.4 Fitting The Cutting Unit To The Machine
7.5 Operation Of The Machine
Before Operating For The First Time
7.6 Starting The Engine
7.7 Driving
7.8 Mowing
7.9 To Stop The Engine
7.10 Unblocking Cutter Decks
7.11 Transporting On A Trailer
7.12 Slinging The Machine
Slope Calculation Chart
8.12 Machine Maintenance
8.1 Maintenance & Lubrication Chart
8.2 Engine Lubrication
8.3 Engine: Fan Belt
8.4 Engine Coolant
8.5 Hydraulic System
8.7 Hydraulic Test Ports
8.8 Fuel System
8.9 Air Cleaner
8.10 Battery
Maintenance And Lubrication Chart
Fluid Requirements
8.11 Rear Hub Nut Lock- Application And Inspection.
8.13 Machine Maintenance With Cab Fitted
9.1 Traction Control Pedal
9.2 Weight Transfer Adjustment
9.3 Height Of Cut
9.4 Blade Change
9.5 Blade Sharpening
9.6 Lift Arm Proximity Switch
9.7 General Instructions For Grammer Seats
9.8 Seat (Grammer Msg85)
9.9 Air Suspension Seat (Grammer Msg75 -521)
9.9.1 Weight Adjustment
9.9.2 Fore/Aft Adjustment
9.9.3 Backrest Extension
9.9.4 Seat Heater
9.9.5 Lumbar Support
9.9.6 Armrests
9.9.7 Armrest Adjustment
9.9.8 Backrest Adjustment
9.9.9 Maintenance
10.18 E Stop Kit
10.19 Slave Battery Lead Kit
10.17 Weight Kit
10.15 Rotary Brush
10.16 Snow Blade
10.1 152 Cm Rear Discharge Deck
10.2 183 Cm Rear Discharge Deck
10.3 152 Cm Mulching Deck
10.4 152 Cm Mulching Deck Conversion Kit
10.5 160cm Side Discharge Deck
10.6 Flail Mower
10.7 Rops Cab Kit
10.8 Rops Frame
10.9 Rotary Beacon Kit
10.11 Mirror Kit
10.12 Storage Racks
10.13 Storage Pod
10.14 Auxiliary Hydraulic Services Kit
11.1 Troubleshooting General
12.2 Step Cutting
12 Quality Of Cut Troubleshooting
12.1 Washboarding
12.3 Scalping
12.4 Stragglers
12.5 Streaks
12.6 Windrowing
12.7 Mismatched Cutting Units
13.1 Electrical Fuses & Relays
14.1 Torques
Brand: Jacobsen
Series: FY
Jacobsen Hr3300t
2.1 Important
3.2 Safety Signs
3.5 Transporting
3.7 Slopes
Danger:
Warning:
Caution:
Important:
4.3 Dimensions
4.5 Vibration Level
4.6 Slopes
6.1c Parking Brakes
6.1f Fuel Gauge
6.1h Hourmeter
6.2 Traction Pedal
6.4 Horn
6.5 Diff Lock
6.6 Power Outlet
6.8 Free Wheel
7.7 Driving
7.8 Mowing
8.4 Engine Coolant
8.8 Fuel System
8.9 Air Cleaner
8.10 Battery
Fluid Requirements
9.3 Height Of Cut
9.4 Blade Change
9.9.4 Seat Heater
9.9.6 Armrests
9.9.9 Maintenance
10.18 E Stop Kit
10.17 Weight Kit
10.15 Rotary Brush
10.16 Snow Blade
10.6 Flail Mower
10.7 Rops Cab Kit
10.8 Rops Frame
10.11 Mirror Kit
10.12 Storage Racks
10.13 Storage Pod
12.2 Step Cutting
12.1 Washboarding
12.3 Scalping
12.4 Stragglers
12.5 Streaks
12.6 Windrowing
14.1 Torques
- JACOBSEN GT12 Parts List
- JACOBSEN GT16 hydro 53330 owner manual
- JACOBSEN 1250 1450 1650 Parts List
- Jacobsen Chief And Super Chief Garden Tractors Owner's Manual
- JACOBSEN CHIEF and SUPER CHIEF
- Jacobsen GT12H Garden Tractor UT-53275 Parts List
- Jacobsen Hydro Tractors 1250 1450 1650 Pasts Catalogue
- Jacobsen Mower ECLIPSE 322 Safety Operation Manual 4187720-GB 2015
- Jacobsen Mower HR600 HR700 Safety Operation Maintenance Manual 10005279-R0-GB 2018
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-B 2014
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4222983 2010
- Jacobsen Mower HR-6010 Maintenance Manual 24683G-GB-R3 2009
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-C 2018
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4271491-EN-RP-P1 2012
- Jacobsen Mower HR-6010 Parts Manual 24884G-R0 2014
