7,392
Jacobsen Rotary Mower AR-3 Parts Manual 24727G-R9 2017
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Parts Manual, Wiring Diagram, Hydraulic Diagram
Model: Jacobsen AR-3 Rotary Mower
Series EK, AR30001 (D1105-T-E3B) – 68" Width of Cut
Series FZ, AR30002 (D1105-T-E3B) – 72" Width of Cut
Series GX, AR30003 (D1105-T-E3B) – 68" Width of Cut
Series KG, AR30004 (D1105-E4B) – 68" Width of Cut
Part Number: 24727G-R9
Publication Date: 2017
Number of Pages: 190 Pages
CHASSIS
OPERATORS PLATFORM (From Serial No EK000804)
OPERATORS PLATFORM (To Serial No EK000803)
FRONT AXLE & UNIT MOUNTING
PLATFORM SUPPORT
FOOTSTEP LH
FOOTSTEP RH
FOOTGUARD LH
FOOTGUARD RH
RH FRONT STOP
LH FRONT STOP
FUEL TANK PART 1
FUEL TANK PART 2
HYDRAULIC TANK PART 1
HYDRAULIC TANK PART 2
REAR WHEEL SUPPORT
STEERING CYLINDER
STEERING TOWER
STEERING TOWER FROM SERIAL NUMBER GX100889 & KG000440
BATTERY & TRAY
FUSE BRACKET
ELECTRICAL CIRCUIT INSTRUMENT
ELECTRICAL CIRCUIT MAIN
FRONT WHEEL & MOTOR POCLAIN
FRONT WHEEL & MOTOR (SAUER DANFOSS)
REAR WHEEL & MOTOR
MOTOR-WHEEL EATON Series 2000 (4184181)
MOTOR-WHEEL DANFOSS OMSW400
PUMPS
PUMPS
PUMP (SAUER-DANFOSS M25X00805950)
PUMP (CASAPPA)
LIFT VALVE
LIFT VALVE (STERLING)
LIFT VALVE (INTEGRATED)
LIFT VALVE PROTECTION (AR30001 ONLY)
FLUSHING VALVE
FLUSHING VALVE (INTEGRATED HYDRAULICS)
CUTTER & BRAKE VALVE
CUTTER & BRAKE VALVE (STERLING)
CUTTER & BRAKE VALVE (INTEGRATED)
BRAKE RELEASE VALVE
BRAKE RELEASE VALVE FROM SERIAL NUMBER GX100889 & KG000440
HYDRAULIC FILTER
MANIFOLD & BRACKET
ROTARY DECK MOTOR FRONT
ROTARY DECK MOTOR CENTRE
ROTARY DECK MOTOR BREAKDOWN
HYDRAULIC CIRCUIT
NADI ENGINE AND MOUNTING
ENGINE & MOUNTING
EXHAUST MOUNTING
EXHAUST
RADIATOR & COWLING
AIR CLEANER MOUNTING
EXPANSION TANK
ENGINE HOOD
DECALS
SEAT & MOUNTING PLATE
SEAT & MOUNTING PLATE FROM SERIAL NUMBER GX100889 & KG000440
MICHIGAN V-5300 SERIES SEAT
GRAMMER MSG 85 SEAT (4137986) SUSPENSION
GRAMMER MSG 85 SEAT TOP
TRACTION PEDAL
TRACTION PEDAL DAMPER
DAMPER CONTROL
TRACTION PEDAL NEUTRAL SWITCH
INSTRUMENT PANEL
INSTRUMENT PANEL FROM SERIAL NUMBER GX100889 & KG000440
CONTROL PANEL
CONTROL PANEL FROM SERIAL NUMBER GX100889 & KG000440
DECK YOKE & MOUNTING
DECK HOUSING & CASTER WHEELS (Non TrimTek™)
DECK FRAME UPTO S/N GX000579
DECK FRAME (TrimTek™) UPTO S/N GX000579
DECK FRAME TrimTek™ UPTO S/N GX000579
DECK FRAME TrimTek™ FROM S/N GX000579 / KG000300
DECK ROLLER
OPS FRAME (LMAC164)
WORKING LAMP KIT (LMAC163)
NARROW WIDTH OF CUT KIT (LMAC199)
72" WIDTH OF CUT KIT (AR30002)
INCLINOMETER KIT (LMAC380)
TRANSPORT STOPS (AR LMAC174)
