Jacobsen Reel Mower F305 F407 Safety Operation Maintenance Manual 10033001-C-US EN ES
Language: English, Spanish
Brand: Jacobsen
Type of Machine: Ride On Reel Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen Ride On Reel Mower
Fairway F305
Product code, Código de producto: 10011560
Series, Serie: AAA
Fairway F407
Product code, Código de producto: 10011568
Series, Serie: AAB
Part Number: 10033001-C-US
Number of Pages: 215 Pages
Introduction
2.1 Important
2.2 Product Identification
2.3 Guidelines For The Disposal Of Scrap Products
2.3.1 During Service Life
2.3.2 End Of Service Life
2.4 Parts Manual
2.5 Key Numbers
Safety
3.1 How To Operate Safely
3.1.1 Safe Operation
3.1.2 Preparation
3.1.3 Operation
3.1.4 ROPS
3.1.5 Safe Handling of Fuels
3.1.6 Maintenance And Storage
3.1.7 When You Put The Mower On A Trailer
3.1.8 Important Safety Notes
Specification
4.1 Engine Specification
4.2 Dimensions and weights
4.3 Cutting Unit Specification
4.4 Machine Specification - Tires
4.5 Cutting Performance
4.6 Vibration
47 Noise
4.8 Slopes
5.1 Safety Decals EC
5.2 Instruction Decals EC
Controls
6.1 Operator Workstation
6.2 Control Panel
6.2.A Starter Key Switch
6.2.B Throttle Control Lever
6.2.C Parking Brake Switch
6.2.D Cutter Switch (P.T.O)
6.2.E Light Switch (Optional)
6.2.F Wing Lock Switch
6.3 Visual Display
6.3.1 Start up Screen
6.3.2 Service Warning Screen
6.3.3 Home Screen
6.3.4 Engine Start
6.3.5 Engine Will Not Start
6.3.6 Main Menu
6.3.7 Clock & Date adjust
6.4 Service Menu
6.5 Fault log
6.5.1 Time Until Next Service
6.5.2 Vehicle Diagnostics
6.5.3 I/O Diagnostics
6.5.4 Settings
6.5.5 Measurement Units
- General I/O Screen
- Cutting Units I/O Screen
- Cutters I/O Screen
- Traction I/O Screen
- Main Controller Misc. I/O Screen
- Misc.Continued I/O Screens
6.5.6 PIN Menu
6.5.7 Cross Cut
6.5.8 Weight Transfer
6.5.9 Reset Default Parameters
6.5.10 Change Pin
6.5.11 Brightness Screen Adjustment
6.5.12 Language Menu
6.5.13 Backlapping
6.6 Warning Screens
6.6.1 Warning Oil Pressure Fault
6.6.2 Warming Engine Overheat
6.6.3 Warning Battery Fault
6.6.4 Warning Charge Filter Blocked
6.6.5 Warning Service Required
6.6.6 Joystick Fault
6.6.7 Emission Fault Delta-P Sensor
6.6.8 Emission Fault EGR NOX Control
6.6.9 Emission Fault
6.6.10 Emission Fault
6.6.11 Clean DPF Ash
6.6.12 ECU COMMS Fault
6.6.13 MCU Display COMMS Fault
6.7 Cutting Unit Lift/Lower
6.8 Cutting Unit Position/Mode Lamp
6.9 Cutting Switch Indicator Lamp
6.10 Traction Pedal
6.11 Mow Speed Level
6.12 Steering Tilt Control
6.13 Power Outlet
6.14 Park Brake Release Valve
6.15 Free Wheel
6.16 Seat Arm Rest & Pod
Operation
7.1 Daily Inspection
7.2 Operator Presence And Safety Interlock System 52
7.3 Operating Procedure
7.4 Fitting The Cutting Unit To The Machine
7.5 Operation Of The Machine
7.6 Starting The Engine
7.7 Driving
7.8 Mowing
7.9 To Stop The Engine
7.10 Unblocking Cutting Units
7.11 Backlapping
Procedure
7.11.1 Backlap Reel Speed Adjustment
7.12 Transporting on a Trailer or Flat-bed
Jacking
7.13 Mowing On Slopes
Maintenance And Lubrication
8.1 Maintenance & Lubrication Charts
Fluid Requirements
8.1.1 Engine Service Interval Chart
8.2 Engine Service General
8.2.1 Engine Lubrication Check
8.2.2 Engine Oil Change
8.3 Engine: Alternator Belt
8.4 Engine Coolant
8.5 Hydraulic System
8.6 Hydraulic System Flushing
8.7 Hydraulic Test Ports
8.8 Hydraulic Filter
8.9 Fuel
8.10 Fuel System
8.11 Water System
8.12 Air Cleaner
8.13 Battery
8.14 Battery Charging
8.15 Engine Exhaust
8.16 Diesel Particulate Filter
8.17 Hydraulic Hoses
8.18 Tires
8.19 Wheel Mounting Procedure
8.20 Rear Hub Application & Inspection
8.21 Steering Rod & Link Check
8.22 Machine Maintenance
8.23 ROPS
8.24 Lubrication Of Cutting Unit
Adjustments
9.1 Traction Control Pedal
9.2 Weight Transfer Adjustment
9.3 Lift Lower Rate Adjustment
9.4 Cutting Unit - Setting Height of Cut
9.5 Cutting Reel to bottom blade adjustment
9.6 Cutting Reel Bearings
9.7 Front & Rear Roll Bearings
9.8 General Instructions For Grammer Seats
9.9 Seat (Grammer Msg85)
9.10 Air Suspension Seat (Grammer Msg75 -521)
10.1 Rear Roller Brush Kits
10.2 Grass Catcher Kits
10.3 Air Suspension Seat Kits
Problem Solving
11.1 Troubleshooting General
Quality Of Cut
12.1 Wash-boarding
12.2 Marcelling
12.3 Step Cutting
12.4 Scalping
12.5 Stragglers
12.6 Streaks
12.7 Windrowing
12.8 Rifling Or Tram-lining
12.9 Mismatched Cutting Units
Fuses And Relays
13.1 Fuse And Relay/component Identification
14 Torques
15 Guarantee
Brand: Jacobsen
Fairway F305
Series, Serie: AAA
Fairway F407
Series, Serie: AAB
Introduction
2.1 Important
2.4 Parts Manual
2.5 Key Numbers
Safety
3.1.2 Preparation
3.1.3 Operation
3.1.4 ROPS
Specification
4.6 Vibration
47 Noise
4.8 Slopes
Controls
6.2 Control Panel
6.3 Visual Display
6.3.3 Home Screen
6.3.4 Engine Start
6.3.6 Main Menu
6.4 Service Menu
6.5 Fault log
6.5.4 Settings
6.5.6 PIN Menu
6.5.7 Cross Cut
6.5.10 Change Pin
6.5.13 Backlapping
6.6 Warning Screens
6.10 Traction Pedal
6.13 Power Outlet
6.15 Free Wheel
Operation
7.7 Driving
7.8 Mowing
7.11 Backlapping
Procedure
Jacking
Fluid Requirements
8.4 Engine Coolant
8.9 Fuel
8.10 Fuel System
8.11 Water System
8.12 Air Cleaner
8.13 Battery
8.15 Engine Exhaust
8.18 Tires
8.23 ROPS
Adjustments
Problem Solving
Quality Of Cut
12.1 Wash-boarding
12.2 Marcelling
12.3 Step Cutting
12.4 Scalping
12.5 Stragglers
12.6 Streaks
12.7 Windrowing
Fuses And Relays
14 Torques
15 Guarantee
- JACOBSEN GT12 Parts List
- JACOBSEN GT16 hydro 53330 owner manual
- JACOBSEN 1250 1450 1650 Parts List
- Jacobsen Chief And Super Chief Garden Tractors Owner's Manual
- JACOBSEN CHIEF and SUPER CHIEF
- Jacobsen GT12H Garden Tractor UT-53275 Parts List
- Jacobsen Hydro Tractors 1250 1450 1650 Pasts Catalogue
- Jacobsen Mower ECLIPSE 322 Safety Operation Manual 4187720-GB 2015
- Jacobsen Mower HR600 HR700 Safety Operation Maintenance Manual 10005279-R0-GB 2018
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-B 2014
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4222983 2010
- Jacobsen Mower HR-6010 Maintenance Manual 24683G-GB-R3 2009
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-C 2018
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4271491-EN-RP-P1 2012
- Jacobsen Mower HR-6010 Parts Manual 24884G-R0 2014
