118
6,911
Jacobsen Reel Mower F305 F407 Safety Operation Maintenance Manual 10033001-C-GB
Brand: Jacobsen
Type of Machine: Ride On Reel Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen F305 F407 Reel Mower
Engine: KUBOTA - V1505-CR-TE5
Fairway F305
Product code: 10011560
Series: AAA
Fairway F407
Product code: 10011568
Series: AAB
Part Number: 10033001-C-GB
Number of Pages: 108 Pages
Introduction
2.1 Important
2.2 Product Identification
2.3 Guidelines For The Disposal Of Scrap Products
2.3.1 During Service Life
2.3.2 End Of Service Life
2.4 Parts Manual
2.5 Key Numbers
Safety
3.1 How To Operate Safely
3.1.1 Safe Operation
3.1.2 Preparation
3.1.3 Operation
3.1.4 ROPS
3.1.5 Safe Handling of Fuels
3.1.6 Maintenance And Storage
3.1.7 When You Put The Mower On A Trailer
3.1.8 Important Safety Notes
Specification
4.1 Engine Specification
4.2 Dimensions and weights
4.3 Cutting Unit Specification
4.4 Machine Specification - Tires
4.5 Cutting Performance
4.6 Vibration
47 Noise
4.8 Slopes
5.1 Safety Decals EC
5.2 Instruction Decals EC
Controls
6.1 Operator Workstation
6.2 Control Panel
6.2.A Starter Key Switch
6.2.B Throttle Control Lever
6.2.C Parking Brake Switch
6.2.D Cutter Switch (P.T.O)
6.2.E Light Switch (Optional)
6.2.F Wing Lock Switch
6.3 Visual Display
6.3.1 Start up Screen
6.3.2 Service Warning Screen
6.3.3 Home Screen
6.3.4 Engine Start
6.3.5 Engine Will Not Start
6.3.6 Main Menu
6.3.7 Clock & Date adjust
6.4 Service Menu
6.5 Fault log
6.5.1 Time Until Next Service
6.5.2 Vehicle Diagnostics
6.5.3 I/O Diagnostics
6.5.4 Settings
6.5.5 Measurement Units
- General I/O Screen
- Cutting Units I/O Screen
- Cutters I/O Screen
- Traction I/O Screen
- Main Controller Misc. I/O Screen
- Misc.Continued I/O Screens
6.5.6 PIN Menu
6.5.7 Cross Cut
6.5.8 Weight Transfer
6.5.9 Reset Default Parameters
6.5.10 Change Pin
6.5.11 Brightness Screen Adjustment
6.5.12 Language Menu
6.5.13 Backlapping
6.6 Warning Screens
6.6.1 Warning Oil Pressure Fault
6.6.2 Warming Engine Overheat
6.6.3 Warning Battery Fault
6.6.4 Warning Charge Filter Blocked
6.6.5 Warning Service Required
6.6.6 Joystick Fault
6.6.7 Emission Fault Delta-P Sensor
6.6.8 Emission Fault EGR NOX Control
6.6.9 Emission Fault
6.6.10 Emission Fault
6.6.11 Clean DPF Ash
6.6.12 ECU COMMS Fault
6.6.13 MCU Display COMMS Fault
6.7 Cutting Unit Lift/Lower
6.8 Cutting Unit Position/Mode Lamp
6.9 Cutting Switch Indicator Lamp
6.10 Traction Pedal
6.11 Mow Speed Level
6.12 Steering Tilt Control
6.13 Power Outlet
6.14 Park Brake Release Valve
6.15 Free Wheel
6.16 Seat Arm Rest & Pod
Operation
7.1 Daily Inspection
7.2 Operator Presence And Safety Interlock System 52
7.3 Operating Procedure
7.4 Fitting The Cutting Unit To The Machine
7.5 Operation Of The Machine
7.6 Starting The Engine
7.7 Driving
7.8 Mowing
7.9 To Stop The Engine
7.10 Unblocking Cutting Units
7.11 Backlapping
Procedure
7.11.1 Backlap Reel Speed Adjustment
7.12 Transporting on a Trailer or Flat-bed
Jacking
7.13 Mowing On Slopes
Maintenance And Lubrication
8.1 Maintenance & Lubrication Charts
Fluid Requirements
8.1.1 Engine Service Interval Chart
8.2 Engine Service General
8.2.1 Engine Lubrication Check
8.2.2 Engine Oil Change
8.3 Engine: Alternator Belt
8.4 Engine Coolant
8.5 Hydraulic System
8.6 Hydraulic System Flushing
8.7 Hydraulic Test Ports
8.8 Hydraulic Filter
8.9 Fuel
8.10 Fuel System
8.11 Water System
8.12 Air Cleaner
8.13 Battery
8.14 Battery Charging
8.15 Engine Exhaust
8.16 Diesel Particulate Filter
8.17 Hydraulic Hoses
8.18 Tires
8.19 Wheel Mounting Procedure
8.20 Rear Hub Application & Inspection
8.21 Steering Rod & Link Check
8.22 Machine Maintenance
8.23 ROPS
8.24 Lubrication Of Cutting Unit
Adjustments
9.1 Traction Control Pedal
9.2 Weight Transfer Adjustment
9.3 Lift Lower Rate Adjustment
9.4 Cutting Unit - Setting Height of Cut
9.5 Cutting Reel to bottom blade adjustment
9.6 Cutting Reel Bearings
9.7 Front & Rear Roll Bearings
9.8 General Instructions For Grammer Seats
9.9 Seat (Grammer Msg85)
9.10 Air Suspension Seat (Grammer Msg75 -521)
10.1 Rear Roller Brush Kits
10.2 Grass Catcher Kits
10.3 Air Suspension Seat Kits
Problem Solving
11.1 Troubleshooting General
Quality Of Cut
12.1 Wash-boarding
12.2 Marcelling
12.3 Step Cutting
12.4 Scalping
12.5 Stragglers
12.6 Streaks
12.7 Windrowing
12.8 Rifling Or Tram-lining
12.9 Mismatched Cutting Units
Fuses And Relays
13.1 Fuse And Relay/component Identification
14 Torques
15 Guarantee
