118
6,911
Jacobsen Reel Mower F305 F407 Parts Manual 10041484 2025
Brand: Jacobsen
Type of Machine: Reel Mower
Type of Manual: Parts Manual, Hydraulic Diagram
Model: Jacobsen Reel Mower
F305 Series: AAA
Product Code: 10011560
F407 Series: AAB
Product Code: 10011568
Part Number: 10041484
Publication Date: 2025
Number of Pages: 168 Pages
PRODUCT IDENTIFICATION
SPARES STOCKING GUIDE
HOW TO USE THE PARTS MANUAL
GUIDELINES FOR THE DISPOSAL OF SCRAP PRODUCTS
• Position the machine in a suitable location for any necessary lifting equipment to be used.
• Use appropriate tools and Personal Protective Equipment (PPE) and take guidance from the technical manuals applicable to the machine.
• Remove and store appropriately:
1. Batteries
2. Fuel residue
3. Engine coolant
4. Oils
• Disassemble the structure of the machine referring to the technical manuals where appropriate. Special attention should be made for dealing with ‘stored energy’ within pressurized elements of the machine or tensioned springs.
• Any items that still have a useful service life as second hand components or can be re-serviced should be separated and returned to the relevant centre.
• Other worn out items should be separated into material groups for recycling and disposal consistent with available facilities. More common separation types are as follows:
• Steel
• Non ferrous metals
• Aluminium
• Brass
• Copper
•Plastics
•Identifiable
• Recyclable
• Non recyclable
• Not identified
• Rubber
• Electrical & Electronic Components
• Items that cannot be separated economically into different material groups should be added to the ‘General waste’ area.
• Do not incinerate waste.
1.1 DECALS
2.1 CONTROL PANEL - F305
3.1 CONTROL PANEL - F407
4.1 CONTROL PANEL AND MOUNTING
5.1 MAIN CONTROLLER
6.1 TRANSMISSION PEDAL
7.1 CHASSIS
7.1 CHASSIS
7.1 CHASSIS
8.1 ROPS
9.1 FRONT WHEEL MOTORS
10.1 REAR AXLE
10.1 REAR AXLE
11.1 OPERATORS PLATFORM
12.1 ENGINE MOUNTING
13.1 COOLER AND MOUNTING
14.1 ENGINE BULKHEAD
15.1 TRANSMISSION PUMP
16.1 AUXILIARY PUMP - F305
17.1 AUXILIARY PUMP - F407
18.1 FUEL TANK
19.1 FUEL PUMP AND FILTER
20.1 HYDRAULIC TANK
21.1 TRANSMISSION VALVE
22.1 TRANSMISSION VALVE BREAKDOWN
23.1 CUTTER VALVE - F305
24.1 CUTTER VALVE - F407
25.1 CUTTER MOTORS - F305 - F407
26.1 LIFT VALVE - F305
27.1 LIFT VALVE - F407
28.1 BRAKE VALVE
29.1 HYDRAULIC FILTER AND MOUNTING
30.1 HYDRAULIC COVER
31.1 RETURN MANIFOLD
32.1 FRONT UNIT MOUNTING
33.1 CENTER UNIT MOUNTING
34.1 CUTTING UNITS LH - 26" - 7 & 11 KNIFE
35.1 CUTTING UNITS RH - 26" - 7 & 11 KNIFE
36.1 HOOD MOUNTING
37.1 HOOD SIDE PANEL - LH - RH
38.1 HOOD TOP & HOOD STAY KIT
39.1 SEATING AND MOUNTING
40.1 GRAMMER MSG85 SEAT
41.1 GRAMMER MSG85 SUSPENSION
42.1 ARMREST POD MOUNTING - F305
43.1 ARMREST POD ASSEMBLY - F305
44.1 ARMREST POD MOUNTING - F407
45.1 ARMREST POD ASSEMBLY - F407
46.1 BUMPER AND NAMEPLATE
47.1 BATTERY MOUNTING
48.1 ENGINE CONTROLLER
49.1 WING UNIT MOUNTING - F407
50.1 WHEEL KIT
51.1 STOP BRACKET - F407
52.1 ELECTRICAL KIT
53.1 HYDRAULIC FITTINGS - F305
54.1 HYDRAULIC FITTINGS - F407
55.1 HYDRAULIC HOSES - F305
56.1 HYDRAULIC HOSES - F407
