118
6,911
Jacobsen Mower TR330 Safety Operation Maintenance Manual 677803-A-GB 2018
Brand: Jacobsen
Type of Machine: Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen Mower
68021-C010 - TR330, Kubota D1105-E4B, 3WD
68021-C110 - TR330, Kubota D1105-E4B, 3WD
Series: EQ, EQ1
Part Number: 677803-A-GB
Publication Date: 2018
Number of Pages: 118 Pages
INTRODUCTION
Important
Product Identification
Guidelines For The Disposal Of Scrap Products
During Service Life
End Of Service Life
Parts Manual
Key Numbers
SAFETY INSTRUCTIONS
How To Operate Safely
Safe Operation
Preparation
Operation
Rollover Protective Structure
Safe Handling Of Fuels
Maintenance And Storage
When You Put The Mower On A Trailer
Important Safety Notes
LABELS
Safety Labels EC
Instruction Labels EC
CONTROLS
Operator Workstation
Control Panel
Key Switch
Light Switch (Optional)
Parking Brake Switch
Mow Switch
Side Shift Switch
Lift Lower Joystick
Visual Display Unit
Start-up screen
Warning Service Screen
First Screen
Engine Start
The Engine Will Not Start
Main Menu
Main Navigation
Language
Clock
Display Settings
Vehicle Settings Menu
Measurement Settings Menu
Enter Pin
One Touch
Change Pin
Set Default Parameters
Reset Service Hours
Service Menu
Fault Log
Time Until Service
Vehicle Status
Input/output diagnostics (I/O Diagnostics)
Connector J1
Connector J2
Connector J3
Connector J4
Connector J5
Connector J6
Backlap
Warnings
Warning - Oil Pressure Fault
Warning - Clear Radiator Screens
Warning - Can Time Out
Warning - Battery Fault
Warning - Controller I/O Fault
Throttle Lever
Armrest Adjuster
Traction Pedal
Mow Speed Lever
Steering Tilt Control
Power Outlet
Tow Valve
Parking Brake Release Valve
Fuel Gauge
OPERATION
Daily Inspection
Operator Presence And Safety Interlock System
Procedure For Operation
To Fit The Cutting Units To The Machine
Operation Of The Machine
How To Start The Engine
How To Drive
How To Mow
To Stop The Engine
How To Remove A Blockage From Cutting Units
Backlapping
Transporting
Transporting On A Trailer Or Flatbed
Jacking Point
Mowing On Slopes
ADJUSTMENTS
General Precautions
Traction Control
Weight Transfer Adjustment
Engine: Fan Belt
Neutral Switch Adjustment
Armrest Height Adjustment
Traction Pedal Stops
Front Cutting Unit Limit Switch
Bedknife To Reel
Bedknife Adjustment
Cutting Modes
Cutting Height Adjustment
Cutting Height Floating
Height Of Cut
To Set Rear Roll
Set Height Of Cut
Reel To Bedknife Adjustment
Milsco Seat (V-2853)
Michigan Seat (V-5300)
Torque Specification
MAINTENANCE AND LUBRICATION
Maintenance And Lubrication Charts
General Precautions
Engine Lubrication
Engine Coolant
Engine: Fan Belt - Diesel
Hydraulic Filter
Hydraulic Hoses
Fuel
Replacing Fuel Filters
Fuel System
Air Cleaner
Engine Exhaust
Cutting Unit Lmac194 / 195 / 196 / 197 Lubrication
Cutting Units 67114 / 67115 / 67116 Lubrication
Backlap
Battery
Charging The Battery
Tyres
Wheel Mounting Procedure
ROPS
Care And Cleaning
Mower Storage
PROBLEM SOLVING
Engine Problem Diagnostics
QUALITY OF CUT
Quality Of Cut Problem Solving
The Step Cut
Scalping
Stragglers
Streaks
Windrowing
Mismatched Cutter Decks
FUSES AND RELAYS
Fuse And Relay/Component Identification
SPECIFICATIONS
Engine Specification
Dimensions And Weights
Machine Specification
Hydraulic Specification
Vibration
Noise
Slopes
Cutting Unit Specification
Cutting Performance
Recommended Lubricants
GUARANTEE
Warranty
Service
