Jacobsen Mower SLF530 Safety Operation Maintenance Manual 676404-C-GB 2018
Brand: Jacobsen
Type of Machine: Super Light Fairway Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen Super Light Fairway Mower
068021-F513 – SLF530, Kubota D1105-E4B, 3WD, Smooth Tires
068021-G515 – SLF530, Kubota D1105-E4B, 4WD, Smooth Tires
Part Number: 676404-C-GB
Publication Date: 2018
Number of Pages: 94 Pages
Introduction
1.1 Important
1.2 Product Identification
1.3 Key Numbers
1.4 parts manual
1.5 Guidelines For The Disposal Of Scrap Products
Safety
2.1 How to Operate Safely
Labels
3.1 Safety Labels
3.2 Instruction Labels
Controls
4.1 Operator Compartment
4.2 Control Panel
4.3 Throttle Lever
4.4 Armrest Adjuster
4.5 Traction Pedal
4.6 Mow Speed Lever
4.7 Steering Tilt Control
4.8 Parking Brake Release Valve
4.9 Tow Valve
Operation
5.1 Daily Inspection
5.2 Interlock System
5.3 Operating Procedure
5.4 Starting The Engine
5.5 To Stop The Engine
5.6 Driving
5.7 Mowing Speed
5.8 Mowing
5.9 Mowing On Slopes
5.10 Towing The Mower
5.11 To Remove A Blockage From Cutting Units
Adjustments
7.1 General Precautions
7.2 Alternator Belt
7.3 Steering Shaft Adjustment
7.4 Armrest Adjustment
7.5 Neutral Switch Adjustment
7.6 Traction Pedal Stops
7.7 Front Reel Limit Switch
7.8 Bedknife-To-Reel
7.9 Bedknife Adjustment
7.10 Cutting Height
7.11 Down Pressure
7.12 Flash Attach™
7.13 Reel Bearing
7.14 Bedknife Adjuster Spring
7.15 Bedknife Adjuster Tension
7.16 Grinding the Bedknife
7.17 Torque Specification
Maintenance and Lubrication
8.1 Maintenance And Lubrication Charts
8.2 General Precautions
8.3 Engine
8.4 Engine Lubrication
8.5 Engine Coolant
8.6 Hydraulic System
8.7 Hydraulic Filter
8.8 Hydraulic Hoses
8.9 Fuel
8.10 Air Cleaner
8.11 Battery
8.12 Charge The Battery
8.13 Engine Exhaust
8.14 Tires
8.15 Wheel Mounting Procedure
8.16 ROPS
8.17 Backlap
8.18 Care and Cleaning
8.19 Mower Storage
Problem Solving
9.1 Engine Problem Solving
Quality of Cut
10.1 Quality of Cut Problem Solving
10.2 Washboarding
10.3 Marcelling
10.4 Step Cutting
10.5 Scalping
10.6 Stragglers
10.7 Streaks
10.8 Windrowing
10.9 Rifling or Tramlining
10.10 Mismatched Cutting Units
Fuses and Relays
11.1 Fuse And Relay/Component identification
Specifications
12.1 Engine Specification
12.2 Dimensions & Weights
12.3 Machine Specification
12.4 Hydraulic Specification
12.5 Vibration
12.6 Noise
12.7 Slopes
12.8 Cutting Performance
12.9 Cutter Deck Specification
12.10 Recommended Lubricants
12.11 Accessories
Blank Page
