118
7,392
Jacobsen Mower MP493 Safety Operation Maintenance Manual 25071G-GB-R2 2014
Brand: Jacobsen
Type of Machine: Ride On Rotary Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen MP493 Ride On Rotary Mower
Kubota: V2403-M-DI, 4WD with ROPS
Series: MQ
Product Code: JMP493
Part Number: 25071G-GB-R2
Publication Date: 2014
Number of Pages: 110 Pages
Introduction
Important
Product Identification
Guidelines For The Disposal Of Scrap Products
During Service Life
End Of Service Life
Parts Manual
Key Numbers
Safety
How To Operate Safely
Safe Operation
Preparation
Operation
Rops
Safe Handling Of Fuels
Maintenance And Storage
When You Put The Mower On A Trailer
Important Safety Notes
Safety Decals
Instruction Decals
Controls
Operator Workstation
Control Panel
Starter Key Switch
Throttle Control Lever
Parking Brakes
Hazard Warning Switch
Cutting Switch
Beacon Switch
Four Wheel Drive In Reverse Switch
Visual Display
Start Up Screen
Warning/Service Screen
Slope Warning Screen
Main Screen For Operation
Water Temperature Screen
Blocked Charge Filter Screen
Slope Warning Screens
Main Menu
Clock And Date Adjust
Service Menu
Data Logging Menu
Language Menu
Unit Lift/Lower Switch
Centre Unit Lift/Lower Switch
Left Hand Unit Lift/Lower Switch
Indicator Lamps
Weight Transfer Button
Axillary Hydraulic Services Kit Switch (Optional)
Light Switch (Optional)
Traction Pedal
Steering Tilt Control
Horn
Power Outlet
Seat Right-Side Armrest And Pod
Parking Brake Release Valve
Tow Valve
Lighting Kit (Optional)
Operation
Before You Operate, For The First Time
Operator Presence And Safety Interlock System
Procedure For Operation
To Fit The Cutter Deck To The Machine
Operation Of The Machine
How To Start The Engine
How To Drive
How To Mow
To Stop The Engine
To Remove A Blockage From Cutting Units
Transporting On A Trailer
Slinging And Jacking The Machine
Mowing On Slopes
Adjustments
General Precautions
Height Of Cut Adjustment
Height Of Cut Adjustment (Front Deck)
Height Of Cut Adjustment (Wing Cutter Decks)
General Instructions For Grammer Seats
Seat (Grammer Msg85)
Air Suspension Seat (Grammer Msg75 -521)
Weight Adjustment
Front And Back Adjustment
Backrest Extension
Lumbar Support
Left Hand Armrests
Armrest Adjustment
Backrest Adjustment
Maintenance
Maintenance And Lubrication
Maintenance And Lubrication Charts
General Precautions
Engine Lubrication
Engine Coolant
Hydraulic Filter
Fuel
Air Cleaner
Battery
Charging The Battery
Engine Exhaust
Hydraulic Hoses
Tyres
Wheel Mounting Procedure
Blade Change
Inspecting Blades
How To Sharpen The Blades
Folding Rops
Care And Cleaning
Mower Storage
Lubrication Of Cutter Decks
Problem Solving
Engine Problem Diagnostics
Quality Of Cut
Quality Of Cut Problem Solving
The Step Cut
Scalping
Stragglers
Streaks
Windrowing
Mismatched Cutter Decks
Fuses And Relays
Fuse And Relay/Component Identification
Specifications
Engine Specification
Dimensions & Weights
Machine Specification
Vibration Level
Noise
Slopes
Cutting Unit Specification
Cutting Performance
Recommended Lubricants
Air Suspension Seat Kit
Certificates Of Conformity
Guarantee
Guarantee
