Jacobsen Greens Mower G-Plex III Safety Operation Maintenance Manual 24789G-GB-R4 2010
- Download this document, you need 300 Gallons
Brand: Jacobsen
Type of Machine: Ride-On Reel Greens Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual, Wiring Diagram, Hydraulic Diagram
Model: Jacobsen G-Plex III Ride-On Reel Greens Mower
USAD002 Series FH - Engine Kubota D722
USAG002 Series FJ - Engine Briggs & Stratton 350447
Part Number: 24789G-GB-R4
Publication Date: 2010
Number of Pages: 76 Pages
2 Introduction
2.1 Important
2.2 Product Identification
2.3 Guidelines For The Disposal Of Products
3 Safety Instructions
3.1 Operating Instructions
3.2 Safety Signs
3.3 Starting The Engine
3.4 Driving The Machine
3.5 Transporting
3.6 Leaving The Driving Position
3.7 Slopes
3.8 Blocked Cutting Cylinders
3.9 Adjustments, Lubrication And
Maintenance
4 Specifications
4.1 Engine Specification
4.2 Machine Specification
4.3 Cutting Unit
4.4 Dimensions
4.5 Vibration Level
4.6 Slopes
4.7 Recommended Lubricants
4.8 Fuel Recommendations - Diesel
4.9 Fuel Recommendations - Gasoline
4.10 Cutting Unit Specification
4.11 Cutting Performance
4.12 Conformity Certificates
5 Decals
5.1 Safety Decals
5.2 Instruction Decals
6 Controls
6.1 Control Panel - Diesel
6.2 Control Panel - Gasoline
6.3 Control Pedals
6.4 Parking Brake Pedal
6.4a Parking Brake Lever
6.5 Paddle/Foot Switch Mow/Lift
6.6 Joystick Mow/Lift
7 Operation
7.1 Daily Inspection
7.2.1 Operator Presence And Safety Interlock
System
7.2.2 Controller Error Codes
7.3 Operating Procedure
7.4 Mowing Procedures
7.5 Mowing On Slopes
8 Setup
8.1 Set Up
8.2 Mounting The Cutting Heads
8.3 Reel Motor Mounting
8.4 Cutting Cylinder Lift & Lower Rate &
Synchronisation
9 Lubrication & Maintenance
9.1 Lubrication And Maintenance Chart
9.2a Lubrication Diagram - Gasoline
9.2b Lubrication Diagram - Diesel
9.3 Engine Access
9.4 Engine Oil Level - Gasoline
9.5 Engine Oil Change- Gasoline
9.6 Engine Oil Filter- Gasoline
9.7 Air Filter - Gasoline
9.8 Air Cleaner - Gasoline
9.9 Engine Fuel Filter - Gasoline
9.10 Engine Oil Level - Diesel
9.11 Engine Oil Change - Diesel
9.12 Engine Oil Filter - Diesel
9.13 Engine Fuel Filter - Diesel
9.14 Air Filter - Diesel
9.15 Bleeding The Fuel System - Diesel
9.16 Air Cleaner - Diesel
9.17 Fan Belt Tension - Diesel
9.18 Tires
9.19 Brakes
9.20 Hydraulic Oil Filter
9.21 Hydraulic Oil
9.22 Hydraulic System
9.23 Hydraulic Pump Bypass Valve
9.24 Free Wheeling Or Towing Unit
9.25 Battery
9.26 Jump Starting
9.27 Oil Cooler Gasoline Machine
9.28 Radiator Diesel Machine
9.29 Oil Cooler & Radiator Diesel Machine
10 Adjustment
10.1 Cutting Head Maintenance
10.2 Bedknife Adjustment
10.3 Height Of Cut
10.4 Control Arm Adjustment
10.5 Rear Swing Out Arm
10.6 Levelling Linkage For The Front Cutting
Heads
10.7 Mow/Transport Speed Control
10.8 Speed Control Pedal
10.9 Seat Adjustment Lever
10.10 Backlapping
11 Schematics
11.1 Hydraulic Circuit
11.2 Electrical Circuit - Gasoline
11.3 Electrical Circuit - Diesel
12 Guarantee / Sales & Service
Brand: Jacobsen
2 Introduction
2.1 Important
3.2 Safety Signs
3.5 Transporting
3.7 Slopes
Maintenance
4 Specifications
4.3 Cutting Unit
4.4 Dimensions
4.5 Vibration Level
4.6 Slopes
5 Decals
5.1 Safety Decals
6 Controls
6.3 Control Pedals
7 Operation
System
8 Setup
8.1 Set Up
Synchronisation
9.3 Engine Access
9.18 Tires
9.19 Brakes
9.21 Hydraulic Oil
9.25 Battery
9.26 Jump Starting
10 Adjustment
10.3 Height Of Cut
Heads
10.10 Backlapping
11 Schematics
- JACOBSEN GT12 Parts List
- JACOBSEN GT16 hydro 53330 owner manual
- JACOBSEN 1250 1450 1650 Parts List
- Jacobsen Chief And Super Chief Garden Tractors Owner's Manual
- JACOBSEN CHIEF and SUPER CHIEF
- Jacobsen GT12H Garden Tractor UT-53275 Parts List
- Jacobsen Hydro Tractors 1250 1450 1650 Pasts Catalogue
- Jacobsen Mower ECLIPSE 322 Safety Operation Manual 4187720-GB 2015
- Jacobsen Mower HR600 HR700 Safety Operation Maintenance Manual 10005279-R0-GB 2018
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-B 2014
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4222983 2010
- Jacobsen Mower HR-6010 Maintenance Manual 24683G-GB-R3 2009
- Jacobsen Rotary Mower TurfCat Safety Operation Maintenance Manual 4312386-C 2018
- Jacobsen Mower ECLIPSE 322 Technical Repair Manual 4271491-EN-RP-P1 2012
- Jacobsen Mower HR-6010 Parts Manual 24884G-R0 2014
