mark2015
Well-Known Member
18
3,089
Iveco EASY 11.1 [2015] + Instruction
Year / Release Date: 2015
Language: Multilingual (Russian present)
Description: Iveco Easy is designed for diagnostics, programming and configuration of trucks buses sold under the brands Iveco, Daewoo, TATA and IRISBUS.
Eltrac Iveco Easy allows you to:
- Reading and reset error
- Dynamic parameter check onboard systems
- Reading identification data
- Fine tuning of onboard systems
- The knowledge of diagnostics
- Adaptation of new units
and much more ...
Link Bittorent & Google Drive
Iveco Easy 11.1 KG + Instruction
http://www.autorepairmanuals.ws/threads/iveco-easy-11-1-kg-instruction.33064/
Instruction
1) Install BUS DVD
DVD (X)\easy\setup\easy\setup.exe
2) Run Keygen1.exe
a) Click: Read Current and OK
b) Click: Generate New and OK
3) Install TRUCK DVD Autorun.exe
4) Copy and replace Framework.StationInformationWriter.dll to
C:\Program Files\Eltrac\EASY\Bin\EasyNET
5) Open E.a.sy on desktop and close.
6) Run Keygen2.exe
a) Set Expiration Date
b) Set ECI Number. EXAMPLE: EC-01009-04-05-04
c) Click: All
d) Click: Get
e) Create new ECIs.txt file and wrote in ur ECI Number. EXSAMPLE: EC-01009-04-05-04
f) Re-name: easy_all.txt to actCodes.txt
g) Copy actCodes.txt + ECIs.txt to
Windows XP & Windows 7: C:\Program Files\Eltrac\EASY\Db\Perms
h) Copy files and folder (pSets, pSetsNet, rSets, rSetsNet, actCodes.txt, ECIs.txt)
replace to Windows XP: C:\Documents and Settings\All Users\Application Data\Iveco\Easy\Perms
Windows 7: C:\ProgramDATA\Iveco\Easy\Perms
