Isuzu Truck NKR SOUTH AFRICA 2003-2006 Parts Catalog 50953
Model: Isuzu NKR SOUTH AFRICA 2003-2006 Truck
Part Number: 50953
Publication Date: 2003, 2004, 2005, 2006
Number of Pages: 734 Pages
001_Section Index 50953 Spare Parts Catalog.pdf
035_0 80 INJECTION PUMP Spare Parts Catalog.pdf
036_0 81 GOVERNOR INJECTION P Spare Parts Catalog.pdf
037_0 82 BOOST COMPENSATOR IN Spare Parts Catalog.pdf
038_0 83 ANEROID COMPENSATOR Spare Parts Catalog.pdf
039_0 84 FEED PUMP INJECTION Spare Parts Catalog.pdf
040_0 85 AUTO TIMER INJECTION Spare Parts Catalog.pdf
041_0 86 MISCELLANEOUS PARTS Spare Parts Catalog.pdf
042_1 FUEL TANK COOLING AIR INTAKE Spare Parts Catalog.pdf
043_1 01 ACCELERATOR PEDAL AND Spare Parts Catalog.pdf
044_1 10 RADIATOR Spare Parts Catalog.pdf
045_1 11 RADIATOR HOSE AND SUB Spare Parts Catalog.pdf
046_1 30 AIR CLEANER Spare Parts Catalog.pdf
047_1 31 AIR DUCT Spare Parts Catalog.pdf
048_1 40 FUEL TANK Spare Parts Catalog.pdf
049_1 41 FUEL PIPING CHASSIS Spare Parts Catalog.pdf
050_1 45 WATER SEDIMENTER FUE Spare Parts Catalog.pdf
051_1 50 EXHAUST PIPE AND SILE Spare Parts Catalog.pdf
052_1 55 EXHAUST BRAKE VALVE A Spare Parts Catalog.pdf
053_1 56 EXHAUST BRAKE SYSTEM Spare Parts Catalog.pdf
054_2 CLUTCH TRANSMISSION TRANS AXL Spare Parts Catalog.pdf
055_2 01 CLUTCH Spare Parts Catalog.pdf
056_2 03 CLUTCH PEDAL AND CONT Spare Parts Catalog.pdf
057_2 05 CLUTCH PIPING Spare Parts Catalog.pdf
058_2 06 CLUTCH SLAVE CYLINDER Spare Parts Catalog.pdf
059_2 07 CLUTCH BOOSTER MINIP Spare Parts Catalog.pdf
060_2 08 CLUTCH MASTER CYLINDE Spare Parts Catalog.pdf
061_2 10 REPAIR KIT TRANSMISS Spare Parts Catalog.pdf
062_2 20 MANUAL TRANSMISSION A Spare Parts Catalog.pdf
063_2 25 SPEEDOMETER DRIVEN GE Spare Parts Catalog.pdf
064_2 26 MANUAL TRANSMISSION G Spare Parts Catalog.pdf
065_2 30 GEAR SHIFTER AND QUAD Spare Parts Catalog.pdf
066_2 35 MANUAL TRANSMISSION S Spare Parts Catalog.pdf
067_2 36 MANUAL TRANSMISSION C Spare Parts Catalog.pdf
068_2 56 AUTO TRANS CONTROL LI Spare Parts Catalog.pdf
069_2 81 POWER TAKE OFF TRANS Spare Parts Catalog.pdf
070_2 85 POWER TAKE OFF CONTRO Spare Parts Catalog.pdf
071_3 BRAKE BRAKES SYSTEM Spare Parts Catalog.pdf
072_3 01 FRONT WHEEL BRAKE Spare Parts Catalog.pdf
073_3 05 REAR WHEEL BRAKE Spare Parts Catalog.pdf
074_3 08 PARKING BRAKE Spare Parts Catalog.pdf
075_3 10 BRAKE PEDAL AND CONTR Spare Parts Catalog.pdf
076_3 11 PARKING BRAKE CONTROL Spare Parts Catalog.pdf
077_3 21 VACUUM TANK Spare Parts Catalog.pdf
078_3 30 BRAKE MASTER CYLINDER Spare Parts Catalog.pdf
079_3 31 BRAKE MASTER VAC AND Spare Parts Catalog.pdf
080_3 45 LOAD SENSING PROPORTI Spare Parts Catalog.pdf
081_3 50 BRAKE PIPING OIL MAS Spare Parts Catalog.pdf
082_3 52 BRAKE PIPING OIL FRO Spare Parts Catalog.pdf
083_3 55 BRAKE PIPING OIL REA Spare Parts Catalog.pdf
084_3 58 FIXING PARTS OIL PIP Spare Parts Catalog.pdf
085_3 60 BRAKE PIPING VACUUM Spare Parts Catalog.pdf
086_4 PROPELLER SHAFT AXLES STEERIN Spare Parts Catalog.pdf
087_4 01 PROPELLER SHAFT Spare Parts Catalog.pdf
088_4 10 FRONT AXLE Spare Parts Catalog.pdf
089_4 11 FRONT HUB AND DRUM OR Spare Parts Catalog.pdf
100_4 55 FRONT LEAF SPRING Spare Parts Catalog.pdf
103_4 65 REAR LEAF SPRING Spare Parts Catalog.pdf
108_5 15 CAB MOUNTING CAB SID Spare Parts Catalog.pdf
109_5 20 BATTERY CARRIER Spare Parts Catalog.pdf
110_5 30 SPARE TIRE CARRIER AN Spare Parts Catalog.pdf
111_6 EXTERIOR BODY GLASS MOUNTING Spare Parts Catalog.pdf
112_6 01 FRONT BUMPER Spare Parts Catalog.pdf
113_6 03 RADIATOR GRILLE Spare Parts Catalog.pdf
114_6 05 FRONT PANEL Spare Parts Catalog.pdf
115_6 07 FRONT WINDOW GLASS AN Spare Parts Catalog.pdf
123_6 60 ROOF PANEL Spare Parts Catalog.pdf
124_6 66 HEAD LINING AND TRIM Spare Parts Catalog.pdf
125_6 68 ROOF VENTILATOR Spare Parts Catalog.pdf
126_6 70 FLOOR PANEL Spare Parts Catalog.pdf
127_6 75 MAT AND CARPET Spare Parts Catalog.pdf
128_6 76 FLOOR EQUIPMENT AND S Spare Parts Catalog.pdf
129_6 78 FLOOR HOLE PLUG Spare Parts Catalog.pdf
130_6 80 BACK PANEL Spare Parts Catalog.pdf
131_6 82 BACK GLASS AND WEATHE Spare Parts Catalog.pdf
132_6 84 BACK TRIM Spare Parts Catalog.pdf
133_6 90 REAR BUMPER Spare Parts Catalog.pdf
134_7 INTERIOR TRIM EMBLEMS LABELS Spare Parts Catalog.pdf
135_7 01 EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
136_7 10 CAUTION PLATE AND LAB Spare Parts Catalog.pdf
137_7 20 MIRROR AND MIRROR STA Spare Parts Catalog.pdf
138_7 30 LOCK CYLINDER SET Spare Parts Catalog.pdf
139_7 40 INSTRUMENT PANEL AND Spare Parts Catalog.pdf
140_7 41 UNDER COVER INSTRUME Spare Parts Catalog.pdf
141_7 42 ASH TRAY Spare Parts Catalog.pdf
142_7 43 SUN VISOR AND ASSIST Spare Parts Catalog.pdf
143_7 50 FRONT SEAT Spare Parts Catalog.pdf
144_7 60 SEAT BELT Spare Parts Catalog.pdf
145_8 CHASSIS ELECTRICAL HEATING AI Spare Parts Catalog.pdf
146_8 01 LAMP FRONT AND FRONT Spare Parts Catalog.pdf
147_8 03 LAMP REAR AND REAR S Spare Parts Catalog.pdf
148_8 10 WIRING HARNESS AND FU Spare Parts Catalog.pdf
149_8 15 FIXING PARTS WIRING Spare Parts Catalog.pdf
150_8 21 METER ASM Spare Parts Catalog.pdf
151_8 25 SWITCH AND RELAY INS Spare Parts Catalog.pdf
152_8 26 ELECTRICAL CONTROL AN Spare Parts Catalog.pdf
153_8 28 CHASSIS ELECTRICAL Spare Parts Catalog.pdf
154_8 40 HEATER SYSTEM Spare Parts Catalog.pdf
155_8 45 HEATER PIPING Spare Parts Catalog.pdf
156_8 50 AIR CONDITIONING SYST Spare Parts Catalog.pdf
157_8 60 HEATER UNIT FRONT Spare Parts Catalog.pdf
158_8 65 CONTROL LEVER HEATER Spare Parts Catalog.pdf
159_8 73 BLOWER UNIT Spare Parts Catalog.pdf
160_8 80 WINDSHIELD WIPER AND Spare Parts Catalog.pdf
161_8 90 RADIO AND TV Spare Parts Catalog.pdf
162_9 TOOLS REAR BODY Spare Parts Catalog.pdf
163_9 01 TOOLS Spare Parts Catalog.pdf
Part Number: 50953
