Isuzu Truck FTR THAILAND EURO3 2008-2012 Parts Catalog 11125
Model: Isuzu FTR THAILAND EURO3 2008-2012 Truck
Part Number: 11125
Publication Date: 2008, 2009, 2010, 2011, 2012
Number of Pages: 1394 Pages
001_Section Index 11125 Spare Parts Catalog.pdf
002_0 01 PARTIAL ENGINE Spare Parts Catalog.pdf
051_2 07 CLUTCH BOOSTER MINIP Spare Parts Catalog.pdf
061_2 53 TRANSMISSION OIL COOL Spare Parts Catalog.pdf
062_2 81 POWER TAKE OFF TRANS Spare Parts Catalog.pdf
063_2 85 POWER TAKE OFF CONTRO Spare Parts Catalog.pdf
064_3 BRAKE BRAKES SYSTEM Spare Parts Catalog.pdf
065_3 01 FRONT WHEEL BRAKE Spare Parts Catalog.pdf
066_3 05 REAR WHEEL BRAKE Spare Parts Catalog.pdf
067_3 08 PARKING BRAKE Spare Parts Catalog.pdf
068_3 10 BRAKE PEDAL AND CONTR Spare Parts Catalog.pdf
069_3 11 PARKING BRAKE CONTROL Spare Parts Catalog.pdf
070_3 20 AIR TANK Spare Parts Catalog.pdf
071_3 22 AIR CONTROL PARTS Spare Parts Catalog.pdf
072_3 33 AIR MASTER Spare Parts Catalog.pdf
073_3 34 BRAKE VALVE AIR Spare Parts Catalog.pdf
074_3 46 AIR DRYER Spare Parts Catalog.pdf
075_3 52 BRAKE PIPING OIL FRO Spare Parts Catalog.pdf
076_3 55 BRAKE PIPING OIL REA Spare Parts Catalog.pdf
077_3 58 FIXING PARTS OIL PIP Spare Parts Catalog.pdf
078_3 70 BRAKE PIPING AIR AIR Spare Parts Catalog.pdf
079_3 75 BRAKE PIPING AIR FRO Spare Parts Catalog.pdf
080_3 77 BRAKE PIPING AIR REA Spare Parts Catalog.pdf
081_3 78 FIXING PARTS AIR PIP Spare Parts Catalog.pdf
082_4 PROPELLER SHAFT AXLES STEERIN Spare Parts Catalog.pdf
083_4 01 PROPELLER SHAFT Spare Parts Catalog.pdf
084_4 02 PROPELLER SHAFT GUARD Spare Parts Catalog.pdf
085_4 10 FRONT AXLE Spare Parts Catalog.pdf
086_4 11 FRONT HUB AND DRUM OR Spare Parts Catalog.pdf
087_4 20 REAR AXLE CASE AND SH Spare Parts Catalog.pdf
088_4 25 REAR FINAL DRIVE Spare Parts Catalog.pdf
089_4 30 STEERING WHEEL AND CO Spare Parts Catalog.pdf
090_4 31 STEERING COLUMN AND S Spare Parts Catalog.pdf
091_4 33 STEERING LINKAGE Spare Parts Catalog.pdf
092_4 35 POWER STEERING CONTRO Spare Parts Catalog.pdf
093_4 36 POWER STEERING CONTRO Spare Parts Catalog.pdf
094_4 40 STEERING UNIT Spare Parts Catalog.pdf
095_4 42 POWER STEERING OIL PU Spare Parts Catalog.pdf
096_4 50 FRONT SUSPENSION Spare Parts Catalog.pdf
097_4 55 FRONT LEAF SPRING Spare Parts Catalog.pdf
098_4 60 REAR SUSPENSION Spare Parts Catalog.pdf
099_4 65 REAR LEAF SPRING Spare Parts Catalog.pdf
100_4 80 ROAD WHEEL Spare Parts Catalog.pdf
101_5 FRAME CAB MOUNTING Spare Parts Catalog.pdf
102_5 01 FRAME AND OTHER PARTS Spare Parts Catalog.pdf
103_5 10 CAB MOUNTING FRAME S Spare Parts Catalog.pdf
104_5 15 CAB MOUNTING CAB SID Spare Parts Catalog.pdf
105_5 20 BATTERY CARRIER Spare Parts Catalog.pdf
106_5 30 SPARE TIRE CARRIER AN Spare Parts Catalog.pdf
107_6 EXTERIOR BODY GLASS MOUNTING Spare Parts Catalog.pdf
108_6 01 FRONT BUMPER Spare Parts Catalog.pdf
109_6 03 RADIATOR GRILLE Spare Parts Catalog.pdf
110_6 05 FRONT PANEL Spare Parts Catalog.pdf
111_6 07 FRONT WINDOW GLASS AN Spare Parts Catalog.pdf
112_6 20 SIDE PANEL AND STEP Spare Parts Catalog.pdf
113_6 30 FRONT DOOR AND HINGE Spare Parts Catalog.pdf
114_6 31 FRONT DOOR GLASS AND Spare Parts Catalog.pdf
115_6 32 FRONT DOOR LOCK AND H Spare Parts Catalog.pdf
116_6 35 FRONT DOOR TRIM Spare Parts Catalog.pdf
117_6 43 SIDE TRIM Spare Parts Catalog.pdf
118_6 47 MUD GUARD AND INSULAT Spare Parts Catalog.pdf
119_6 60 ROOF PANEL Spare Parts Catalog.pdf
120_6 66 HEAD LINING AND TRIM Spare Parts Catalog.pdf
121_6 70 FLOOR PANEL Spare Parts Catalog.pdf
122_6 75 MAT AND CARPET Spare Parts Catalog.pdf
123_6 76 FLOOR EQUIPMENT AND S Spare Parts Catalog.pdf
124_6 78 FLOOR HOLE PLUG Spare Parts Catalog.pdf
125_6 80 BACK PANEL Spare Parts Catalog.pdf
126_6 82 BACK GLASS AND WEATHE Spare Parts Catalog.pdf
127_6 84 BACK TRIM Spare Parts Catalog.pdf
128_6 90 REAR BUMPER Spare Parts Catalog.pdf
129_7 INTERIOR TRIM EMBLEMS LABELS Spare Parts Catalog.pdf
130_7 01 EMBLEM AND NAME PLATE Spare Parts Catalog.pdf
131_7 10 CAUTION PLATE AND LAB Spare Parts Catalog.pdf
132_7 20 MIRROR AND MIRROR STA Spare Parts Catalog.pdf
133_7 30 LOCK CYLINDER SET Spare Parts Catalog.pdf
134_7 40 INSTRUMENT PANEL AND Spare Parts Catalog.pdf
135_7 42 ASH TRAY Spare Parts Catalog.pdf
136_7 43 SUN VISOR AND ASSIST Spare Parts Catalog.pdf
137_7 45 CONSOLE BOX Spare Parts Catalog.pdf
138_7 50 FRONT SEAT Spare Parts Catalog.pdf
139_7 60 SEAT BELT Spare Parts Catalog.pdf
140_7 70 SEPARATER AND BED Spare Parts Catalog.pdf
141_8 CHASSIS ELECTRICAL HEATING AI Spare Parts Catalog.pdf
142_8 01 LAMP FRONT AND FRONT Spare Parts Catalog.pdf
143_8 03 LAMP REAR AND REAR S Spare Parts Catalog.pdf
144_8 05 INTERIOR LAMP Spare Parts Catalog.pdf
145_8 10 WIRING HARNESS AND FU Spare Parts Catalog.pdf
146_8 15 FIXING PARTS WIRING Spare Parts Catalog.pdf
147_8 21 METER ASM Spare Parts Catalog.pdf
148_8 25 SWITCH AND RELAY INS Spare Parts Catalog.pdf
149_8 26 ELECTRICAL CONTROL AN Spare Parts Catalog.pdf
150_8 28 CHASSIS ELECTRICAL Spare Parts Catalog.pdf
151_8 40 HEATER SYSTEM Spare Parts Catalog.pdf
152_8 50 AIR CONDITIONING SYST Spare Parts Catalog.pdf
153_8 52 PIPING AIR CONDITION Spare Parts Catalog.pdf
154_8 60 HEATER UNIT FRONT Spare Parts Catalog.pdf
155_8 65 CONTROL LEVER HEATER Spare Parts Catalog.pdf
156_8 71 COMPRESSOR AIR CONDI Spare Parts Catalog.pdf
157_8 73 BLOWER UNIT Spare Parts Catalog.pdf
158_8 75 CONDENSER Spare Parts Catalog.pdf
159_8 80 WINDSHIELD WIPER AND Spare Parts Catalog.pdf
160_8 90 RADIO AND TV Spare Parts Catalog.pdf
161_9 TOOLS REAR BODY Spare Parts Catalog.pdf
162_9 01 TOOLS Spare Parts Catalog.pdf
163_0 ENGINE EMISSION ENGINE ELECTR Spare Parts Catalog.pdf
164_0 01 PARTIAL ENGINE (1) Spare Parts Catalog.pdf
165_0 05 ENGINE GASKET KIT (1) Spare Parts Catalog.pdf
166_0 10 CYLINDER HEAD COVER (1) Spare Parts Catalog.pdf
167_0 11 CYLINDER HEAD (1) Spare Parts Catalog.pdf
168_0 12 CYLINDER BLOCK (1) Spare Parts Catalog.pdf
169_0 13 OIL PAN AND LEVEL GAU (1) Spare Parts Catalog.pdf
170_0 14 CAMSHAFT AND VALVE (1) Spare Parts Catalog.pdf
171_0 15 CRANKSHAFT PISTON AND (1) Spare Parts Catalog.pdf
172_0 20 TIMING GEAR CASE AND (1) Spare Parts Catalog.pdf
173_0 22 ENGINE MOUNTING (1) Spare Parts Catalog.pdf
174_0 25 INLET MANIFOLD (1) Spare Parts Catalog.pdf
175_0 27 EXHAUST MANIFOLD (1) Spare Parts Catalog.pdf
176_0 28 VENTILATION SYSTEM (1) Spare Parts Catalog.pdf
177_0 30 WATER PUMP AND CORROS (1) Spare Parts Catalog.pdf
178_0 31 THERMOSTAT AND HOUSIN (1) Spare Parts Catalog.pdf
179_0 32 WATER PIPING ENGINE (1) Spare Parts Catalog.pdf
180_0 33 FAN AND FAN BELT (1) Spare Parts Catalog.pdf
181_0 35 ENGINE CONTROL VALVE (1) Spare Parts Catalog.pdf
182_0 36 TURBOCHARGER SYSTEM (1) Spare Parts Catalog.pdf
183_0 37 TURBOCHARGER (1) Spare Parts Catalog.pdf
184_0 38 AIR COMPRESSOR PIPING (1) Spare Parts Catalog.pdf
185_0 39 AIR COMPRESSOR BRAKE (1) Spare Parts Catalog.pdf
186_0 40 FUEL INJECTION SYSTEM (1) Spare Parts Catalog.pdf
187_0 42 FUEL PUMP AND PIPE (1) Spare Parts Catalog.pdf
188_0 50 OIL COOLER AND OIL FI (1) Spare Parts Catalog.pdf
189_0 51 OIL PUMP AND OIL STRA (1) Spare Parts Catalog.pdf
190_0 52 OIL AND VACUUM PIPING (1) Spare Parts Catalog.pdf
191_0 57 EMISSION PIPING (1) Spare Parts Catalog.pdf
192_0 60 ENGINE ELECTRICAL CON (1) Spare Parts Catalog.pdf
193_0 61 BATTERY AND ENGINE EL (1) Spare Parts Catalog.pdf
194_0 65 STARTER (1) Spare Parts Catalog.pdf
195_0 66 GENERATOR (1) Spare Parts Catalog.pdf
196_1 FUEL TANK COOLING AIR INTAKE (1) Spare Parts Catalog.pdf
197_1 01 ACCELERATOR PEDAL AND (1) Spare Parts Catalog.pdf
198_1 10 RADIATOR (1) Spare Parts Catalog.pdf
199_1 11 RADIATOR HOSE AND SUB (1) Spare Parts Catalog.pdf
200_1 30 AIR CLEANER (1) Spare Parts Catalog.pdf
201_1 31 AIR DUCT (1) Spare Parts Catalog.pdf
202_1 35 CHARGE AIR COOLER (1) Spare Parts Catalog.pdf
203_1 40 FUEL TANK (1) Spare Parts Catalog.pdf
204_1 41 FUEL PIPING CHASSIS (1) Spare Parts Catalog.pdf
205_1 45 WATER SEDIMENTER FUE (1) Spare Parts Catalog.pdf
206_1 50 EXHAUST PIPE AND SILE (1) Spare Parts Catalog.pdf
207_1 55 EXHAUST BRAKE VALVE A (1) Spare Parts Catalog.pdf
208_1 56 EXHAUST BRAKE SYSTEM (1) Spare Parts Catalog.pdf
209_2 CLUTCH TRANSMISSION TRANS AXL (1) Spare Parts Catalog.pdf
210_2 01 CLUTCH (1) Spare Parts Catalog.pdf
211_2 03 CLUTCH PEDAL AND CONT (1) Spare Parts Catalog.pdf
212_2 05 CLUTCH PIPING (1) Spare Parts Catalog.pdf
213_2 07 CLUTCH BOOSTER MINIP (1) Spare Parts Catalog.pdf
214_2 08 CLUTCH MASTER CYLINDE (1) Spare Parts Catalog.pdf
215_2 10 REPAIR KIT TRANSMISS (1) Spare Parts Catalog.pdf
216_2 20 MANUAL TRANSMISSION A (1) Spare Parts Catalog.pdf
217_2 25 SPEEDOMETER DRIVEN GE (1) Spare Parts Catalog.pdf
218_2 26 MANUAL TRANSMISSION G (1) Spare Parts Catalog.pdf
219_2 30 GEAR SHIFTER AND QUAD (1) Spare Parts Catalog.pdf
220_2 35 MANUAL TRANSMISSION S (1) Spare Parts Catalog.pdf
221_2 36 MANUAL TRANSMISSION C (1) Spare Parts Catalog.pdf
222_2 37 MANUAL TRANSMISSION C (1) Spare Parts Catalog.pdf
223_2 53 TRANSMISSION OIL COOL (1) Spare Parts Catalog.pdf
224_2 81 POWER TAKE OFF TRANS (1) Spare Parts Catalog.pdf
225_2 85 POWER TAKE OFF CONTRO (1) Spare Parts Catalog.pdf
226_3 BRAKE BRAKES SYSTEM (1) Spare Parts Catalog.pdf
227_3 01 FRONT WHEEL BRAKE (1) Spare Parts Catalog.pdf
228_3 05 REAR WHEEL BRAKE (1) Spare Parts Catalog.pdf
229_3 08 PARKING BRAKE (1) Spare Parts Catalog.pdf
230_3 10 BRAKE PEDAL AND CONTR (1) Spare Parts Catalog.pdf
231_3 11 PARKING BRAKE CONTROL (1) Spare Parts Catalog.pdf
232_3 20 AIR TANK (1) Spare Parts Catalog.pdf
233_3 22 AIR CONTROL PARTS (1) Spare Parts Catalog.pdf
234_3 33 AIR MASTER (1) Spare Parts Catalog.pdf
235_3 34 BRAKE VALVE AIR (1) Spare Parts Catalog.pdf
236_3 46 AIR DRYER (1) Spare Parts Catalog.pdf
237_3 52 BRAKE PIPING OIL FRO (1) Spare Parts Catalog.pdf
238_3 55 BRAKE PIPING OIL REA (1) Spare Parts Catalog.pdf
239_3 58 FIXING PARTS OIL PIP (1) Spare Parts Catalog.pdf
240_3 70 BRAKE PIPING AIR AIR (1) Spare Parts Catalog.pdf
241_3 75 BRAKE PIPING AIR FRO (1) Spare Parts Catalog.pdf
242_3 77 BRAKE PIPING AIR REA (1) Spare Parts Catalog.pdf
243_3 78 FIXING PARTS AIR PIP (1) Spare Parts Catalog.pdf
244_4 PROPELLER SHAFT AXLES STEERIN (1) Spare Parts Catalog.pdf
245_4 01 PROPELLER SHAFT (1) Spare Parts Catalog.pdf
246_4 02 PROPELLER SHAFT GUARD (1) Spare Parts Catalog.pdf
247_4 10 FRONT AXLE (1) Spare Parts Catalog.pdf
248_4 11 FRONT HUB AND DRUM OR (1) Spare Parts Catalog.pdf
249_4 20 REAR AXLE CASE AND SH (1) Spare Parts Catalog.pdf
250_4 25 REAR FINAL DRIVE (1) Spare Parts Catalog.pdf
251_4 30 STEERING WHEEL AND CO (1) Spare Parts Catalog.pdf
252_4 31 STEERING COLUMN AND S (1) Spare Parts Catalog.pdf
253_4 33 STEERING LINKAGE (1) Spare Parts Catalog.pdf
254_4 35 POWER STEERING CONTRO (1) Spare Parts Catalog.pdf
255_4 36 POWER STEERING CONTRO (1) Spare Parts Catalog.pdf
256_4 40 STEERING UNIT (1) Spare Parts Catalog.pdf
257_4 42 POWER STEERING OIL PU (1) Spare Parts Catalog.pdf
258_4 50 FRONT SUSPENSION (1) Spare Parts Catalog.pdf
259_4 55 FRONT LEAF SPRING (1) Spare Parts Catalog.pdf
260_4 60 REAR SUSPENSION (1) Spare Parts Catalog.pdf
261_4 65 REAR LEAF SPRING (1) Spare Parts Catalog.pdf
262_4 80 ROAD WHEEL (1) Spare Parts Catalog.pdf
263_5 FRAME CAB MOUNTING (1) Spare Parts Catalog.pdf
264_5 01 FRAME AND OTHER PARTS (1) Spare Parts Catalog.pdf
265_5 10 CAB MOUNTING FRAME S (1) Spare Parts Catalog.pdf
266_5 15 CAB MOUNTING CAB SID (1) Spare Parts Catalog.pdf
267_5 20 BATTERY CARRIER (1) Spare Parts Catalog.pdf
268_5 30 SPARE TIRE CARRIER AN (1) Spare Parts Catalog.pdf
269_6 EXTERIOR BODY GLASS MOUNTING (1) Spare Parts Catalog.pdf
270_6 01 FRONT BUMPER (1) Spare Parts Catalog.pdf
271_6 03 RADIATOR GRILLE (1) Spare Parts Catalog.pdf
272_6 05 FRONT PANEL (1) Spare Parts Catalog.pdf
273_6 07 FRONT WINDOW GLASS AN (1) Spare Parts Catalog.pdf
274_6 20 SIDE PANEL AND STEP (1) Spare Parts Catalog.pdf
275_6 30 FRONT DOOR AND HINGE (1) Spare Parts Catalog.pdf
276_6 31 FRONT DOOR GLASS AND (1) Spare Parts Catalog.pdf
277_6 32 FRONT DOOR LOCK AND H (1) Spare Parts Catalog.pdf
278_6 35 FRONT DOOR TRIM (1) Spare Parts Catalog.pdf
279_6 43 SIDE TRIM (1) Spare Parts Catalog.pdf
280_6 47 MUD GUARD AND INSULAT (1) Spare Parts Catalog.pdf
281_6 60 ROOF PANEL (1) Spare Parts Catalog.pdf
282_6 66 HEAD LINING AND TRIM (1) Spare Parts Catalog.pdf
283_6 70 FLOOR PANEL (1) Spare Parts Catalog.pdf
284_6 75 MAT AND CARPET (1) Spare Parts Catalog.pdf
285_6 76 FLOOR EQUIPMENT AND S (1) Spare Parts Catalog.pdf
286_6 78 FLOOR HOLE PLUG (1) Spare Parts Catalog.pdf
287_6 80 BACK PANEL (1) Spare Parts Catalog.pdf
288_6 82 BACK GLASS AND WEATHE (1) Spare Parts Catalog.pdf
289_6 84 BACK TRIM (1) Spare Parts Catalog.pdf
290_6 90 REAR BUMPER (1) Spare Parts Catalog.pdf
291_7 INTERIOR TRIM EMBLEMS LABELS (1) Spare Parts Catalog.pdf
292_7 01 EMBLEM AND NAME PLATE (1) Spare Parts Catalog.pdf
293_7 10 CAUTION PLATE AND LAB (1) Spare Parts Catalog.pdf
294_7 20 MIRROR AND MIRROR STA (1) Spare Parts Catalog.pdf
295_7 30 LOCK CYLINDER SET (1) Spare Parts Catalog.pdf
296_7 40 INSTRUMENT PANEL AND (1) Spare Parts Catalog.pdf
297_7 42 ASH TRAY (1) Spare Parts Catalog.pdf
298_7 43 SUN VISOR AND ASSIST (1) Spare Parts Catalog.pdf
299_7 45 CONSOLE BOX (1) Spare Parts Catalog.pdf
300_7 50 FRONT SEAT (1) Spare Parts Catalog.pdf
301_7 60 SEAT BELT (1) Spare Parts Catalog.pdf
302_7 70 SEPARATER AND BED (1) Spare Parts Catalog.pdf
303_8 CHASSIS ELECTRICAL HEATING AI (1) Spare Parts Catalog.pdf
304_8 01 LAMP FRONT AND FRONT (1) Spare Parts Catalog.pdf
305_8 03 LAMP REAR AND REAR S (1) Spare Parts Catalog.pdf
306_8 05 INTERIOR LAMP (1) Spare Parts Catalog.pdf
307_8 10 WIRING HARNESS AND FU (1) Spare Parts Catalog.pdf
308_8 15 FIXING PARTS WIRING (1) Spare Parts Catalog.pdf
309_8 21 METER ASM (1) Spare Parts Catalog.pdf
310_8 25 SWITCH AND RELAY INS (1) Spare Parts Catalog.pdf
311_8 26 ELECTRICAL CONTROL AN (1) Spare Parts Catalog.pdf
312_8 28 CHASSIS ELECTRICAL (1) Spare Parts Catalog.pdf
313_8 40 HEATER SYSTEM (1) Spare Parts Catalog.pdf
314_8 50 AIR CONDITIONING SYST (1) Spare Parts Catalog.pdf
315_8 52 PIPING AIR CONDITION (1) Spare Parts Catalog.pdf
316_8 60 HEATER UNIT FRONT (1) Spare Parts Catalog.pdf
317_8 65 CONTROL LEVER HEATER (1) Spare Parts Catalog.pdf
318_8 71 COMPRESSOR AIR CONDI (1) Spare Parts Catalog.pdf
319_8 73 BLOWER UNIT (1) Spare Parts Catalog.pdf
320_8 75 CONDENSER (1) Spare Parts Catalog.pdf
321_8 80 WINDSHIELD WIPER AND (1) Spare Parts Catalog.pdf
322_8 90 RADIO AND TV (1) Spare Parts Catalog.pdf
323_9 TOOLS REAR BODY (1) Spare Parts Catalog.pdf
324_9 01 TOOLS (1) Spare Parts Catalog.pdf
325_0 ENGINE EMISSION ENGINE ELECTR (1) Spare Parts Catalog.pdf
326_0 ENGINE EMISSION ENGINE ELECTR (2) Spare Parts Catalog.pdf
Part Number: 11125
